Part Number: TMDS181RGZEVM
To follow up on this question:
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1362708/tmds181-does-tmds181-support-ac-coupled-input?tisearch=e2e-sitesearch&keymatch=TMDS181#
David said that after AC coupling, the internal 50 ohm pull-up resistor of TMS181 causes the signal to swing around the common mode point of 3.3v. According to common understanding, when a pull-up resistor is connected to the signal, the swing should also be below 3.3v. Could you please explain why it exceeds 3.3v? Thank you for helping to clarify
