Other Parts Discussed in Thread: DP83640
Hi
When DP83640 connected with MPU by RMII interface, which mode is DP83640 work in, master mode or slave mode?
Hi
It can work in both master mode and slave mode. Several days ago another post pointed out this issue. Try this link and read the app note, then you can get some useful information.
Select master mode or slave mode,it only depends on reference clock solution in your system。 using master mode can decrease system clock requirement.
