CDCE62005通过SPI端口配置的verilog代码
Other Parts Discussed in Thread: CDCE62005
请问谁有FPGA通过SPI配置CDCE62005的代码工程,我门的芯片的时钟一直配置不出来,向大家求助了
  • 手头没有现成的verilog code。建议先申请一块EVM板,在EVM板上把时钟调通之后,再把寄存器的值导出,写到你自己的62005里。
  • 是个标准的SPI接口吧。去度娘上看看。下面是一个度娘的结果,不保证正确
    module spi_mosi(rst,clk,rd,wr,datain, spics,spiclk,spido,spidi,dataout);
    input rst;              //置位信号,低有效
    input clk;              //时钟信号
    input rd;               //接收数据命令
    input wr;               //发送数据命令
    input spidi;          //SPI数据输入信号
    input [7:0] datain;     //发送数据输入
    output spics;           //SPI片选信号
    output spiclk;          //SPI时钟信号
    output spido;           //SPI数据输出信号
    output [7:0] dataout;   //接收数据输出
    reg spics;
    reg spiclk;
    reg spido;
    reg [7:0]  dstate, dsend,dataout,dreceive ;//,cnt;
    reg [1:0] spistate;
    parameter idle = 2'b00;
    parameter send_data = 2'b01;
    parameter receive_data = 2'b10;
    initial
    begin
    spics  <= 1'b1;
    spiclk <= 1'b1;
    spido  <= 1'b1;
    end
    always @(posedge clk)
    begin
    if(!rst)
    begin
     spistate <= idle;
    //  cnt <= 8'd0;
     spics  <= 1'b1;
     spiclk <= 1'b1;
     spido  <= 1'b1;
     dstate <= 8'd0;
    end
    else
    begin
     case (spistate)
     2'b00:
     begin
       // spics <= 1'b1;
       // spiclk <= 1'b1;
       // spido <= 1'b1;
       //   if(cnt == 8'd0)
       // begin
       //  cnt <= 8'd0;
       if((wr == 1'b0) && (rd == 1'b1))        //发送资料转换
       begin
        spistate <= send_data;
        dstate <= 8'd0;
        dsend <= datain;
       end
       else if((wr == 1'b1) && (rd == 1'b0))   //接收数据转换
       begin
        spistate <= receive_data;
        dstate <= 8'd0;
       end
       else
       begin
        spistate <= idle;
        dstate <= 8'd0;
       end
     // end
     // else
     // begin
     //  cnt <= cnt + 8'd1;
     // end
     end
     2'b01:             //发送数据状态
     begin
      case (dstate)
      8'd0:          //产生片选信号有效
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= 1'b1;
       dstate <= 8'd1;
      end
      8'd1:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= 1'b1;
       dstate <= 8'd2;
      end
      8'd2:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= 1'b1;
       dstate <= 8'd3;
      end
      8'd3:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[7];  //发送数据最高位
       dstate <= 8'd4;
      end
      8'd4:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[7];
       dstate <= 8'd5;
      end
      8'd5:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[6];
       dstate <= 8'd6;
      end
      8'd6:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[6];
       dstate <= 8'd7;
      end
      8'd7:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[5];
       dstate <= 8'd8;
      end
      8'd8:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[5];
       dstate <= 8'd9;
      end
      8'd9:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[4];
       dstate <= 8'd10;
      end
      8'd10:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[4];
       dstate <= 8'd11;
      end
      8'd11:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[3];
       dstate <= 8'd12;
      end
      8'd12:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[3];
       dstate <= 8'd13;
      end
      8'd13:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[2];
       dstate <= 8'd14;
      end
      8'd14:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[2];
       dstate <= 8'd15;
      end
      8'd15:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       spido <= dsend[1];
       dstate <= 8'd16;
      end
      8'd16:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[1];
       dstate <= 8'd17;
      end
      8'd17:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;      //发送最低位数据
       spido <= dsend[0];
       dstate <= 8'd18;
      end
      8'd18:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       spido <= dsend[0];   //spiclk的下降沿让最低位数据被读取
       dstate <= 8'd19;
      end
      8'd19:       //置片选信号无效
      begin
       spics <= 1'b1;
       spiclk <= 1'b1;
       spido <= 1'b1;
       dstate <= 8'd20;
      end
      8'd20:
      begin
       spics <= 1'b1;
       spiclk <= 1'b1;
       spido <= 1'b1;
       dstate <= 8'd0;
       spistate <= idle;
      end
      default
      begin
       spics <= 1'b1;
       spiclk <= 1'b1;
       spido <= 1'b1;
       spistate <= idle;
      end
      endcase
     end
     2'b10:      //接收数据状态
     begin
      case (dstate)     //片选信号有效
      8'd0:
      begin
       spics  <= 1'b0;
       spiclk <= 1'b1;
       spido  <= 1'b1;
       dstate <= 8'd1;
      end
      8'd1:
      begin
       spics  <= 1'b0;
       spiclk <= 1'b1;
       spido  <= 1'b1;
       dstate <= 8'd2;
      end
      8'd2:
      begin
       spics  <= 1'b0;
       spiclk <= 1'b0;
       spido  <= 1'b1;
       dstate <= 8'd3;
      end
      8'd3:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd4;
      end
      8'd4:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;      //紧接着上升沿的下降沿数据被读取
       dreceive[7] <= spidi;   //接收数据最高位
       dstate <= 8'd5;
      end
      8'd5:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd6;
      end
      8'd6:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[6] <= spidi;
       dstate <= 8'd7;
      end
      8'd7:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd8;
      end
      8'd8:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[5] <= spidi;
       dstate <= 8'd9;
      end
      8'd9:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd10;
      end
      8'd10:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[4] <= spidi;
       dstate <= 8'd11;
      end
      8'd11:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd12;
      end
      8'd12:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[3] <= spidi;
       dstate <= 8'd13;
      end
      8'd13:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd14;
      end
      8'd14:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[2] <= spidi;
       dstate <= 8'd15;
      end
      8'd15:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd16;
      end
      8'd16:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[1] <= spidi;
       dstate <= 8'd17;
      end
      8'd17:
      begin
       spics <= 1'b0;
       spiclk <= 1'b1;
       dstate <= 8'd18;
      end
      8'd18:
      begin
       spics <= 1'b0;
       spiclk <= 1'b0;
       dreceive[0] <= spidi;   //接收数据最低位
       dstate <= 8'd19;
      end
      8'd19:
      begin
       spics  <= 1'b0;
       spiclk <= 1'b1;
       spido  <= 1'b1;
       dstate <= 8'd20;
       dataout<= dreceive;
      end
      8'd20:
      begin
       spics <= 1'b1;       //片选信号无效
       spiclk <= 1'b1;
       spido <= 1'b1;
       dstate <= 8'd0;
       spistate <= idle;
      end
      endcase
     end
     default:
     begin
      spics <= 1'b1;
      spiclk <= 1'b1;
      spido <= 1'b1;
      spistate <= idle;
        end
    endcase //对应上面的发送数据情形
    end     //对应上面的RST没有按下的情形
    end        //对应最上面的always@(posedge clk)
    endmodule
  • 你好!
    请见附件,仅供参考!
    clk_cfg.v
  • 有CDCE62005配置的软核代码吗?在XILINX平台实现的。谢谢
  • 已经验证,程序完全可以使用,太棒了,省了不少事,非常感谢!
x 出现错误。请重试或与管理员联系。
