Hello:)
How could TPS65988 connect and used with TPS55288 together ?
There are two version of TPS55288 ; I2C verison and non-I2C version.
Through I2C or use GPIO to select the VOUT.
Does it allow customer to develop the firmware to read - write the internal registers of TPS65988 for I2C control ? .
Which one is the correct version to use ?
Thanks
