hi,ti
I want to know how large the EEPROM size for chip configuration needs? Is AT24C64 OK?
Best,
jack
您好,E2E上有个帖子不知是不是您咨询的,和您的问题相同,我看E2E也已经给出了答复,您可以参考下:
Looking over the AT24C64, it seems to use 2 word addresses as part of its addressing. AT24C01C/02C/04C/08C/16C EEPROMs, which this device is known to be compatible with, seem to use 1 word address during addressing. I would recommending using one of these if possible in order to ensure compatibility.
