GND不需要分层,要实现单点接地防止地回路的产生,datasheet中也有提到:A solid ground plane is recommended for both DVDD, PVDD or AVDD. Using a split plane may have potential problem of ground loops, or difference in ground potential at various ground pins of the device.
另外,这款查了下没有评估板呢,在哪儿看到的提到了评估板?
恩看到了,但是如果还有评估板的话,在官网的产品主页上应该能查到,因为这款是之前国半的产品,现在查不到应该是已经停产之类的了。
我看了下,和DS92LV16同功能的,类似的18bit的DS92LV18有demo board,user's guide 请参考:
