DS90UB929-Q1EVM: pattern generator
Part Number: DS90UB929-Q1EVM
Other Parts Discussed in Thread: ALP
hello everyone:
    I would like to know if the 929 press plate has the function of pre-storing custom pictures, and by what means? And the specific use of the pattern generator function in the ALP software, is the custom in pattern 14 customizable?
thanks
  • 您好,
    为更加有效地解决您的问题,我已将您的问题发布在E2E英文技术论坛上,请更了解这款芯片的TI资深工程师为您解答。帖子链接如下,您也可以关注帖子,以方便查看或追问后续疑问。
    英文论坛对应子论坛链接:https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1243034/ds90ub929-q1evm-pattern-generator
  • The 929 does not support uploading and storing custom pictures to the device, the customer would need to have a source that is inputting video data to the device in order to have an output.
    The pattern generator is very customizable, but only to the extent that you are seeing on the pattern generation tab. Past that, we do not support additional customization of the pattern generator.
    Please let me know if you have any more questions.
