We use the TMDS1204 chip, but the input port of TMDS1204 does not have a DDC channel. Therefore, we set the datasheet to DDC disable snoop mode, and TMDS 1204 cannot detect the input signal
I used the example source code of datasheet
/ (address, data)
// Initial power-on configuration.
(0x0A, 0x05), // Rate snoop disabled and TXFFE controlled by 35h, 41h, and 42h
(0x0B, 0x23), // 3G and 6G tx slew rate control
(0x0C, 0x70), // HDMI clock and 8G10G12G TX slew rate control
(0x0E, 0x97), // HDMI 1.4, 2.0 and 2.1 CTLE selection
(0x11, 0x00), // Disable all four lanes.
(0x09, 0x00), // Take out of PD state. Should be done after initialization is complete.
// Selection between HDMI modes (1.4, 2.0, and 2.1)
switch (HDMI_MODE) {
case 'HDMI14_165' : // HDMI 1.4 configuration for less than 1.65 Gbps
(0x0D, 0x20), // Limited mode, DC-coupled TX, 0dB DCG, Term open, disable CTLE bypass
(0x12, 0x03), // Clock lane VOD and TXFFE
(0x13, 0x00), // Clock lane EQ.
(0x14, 0x03), // D0 lane VOD and TXFFE.
(0x15, 0x0Y), // D0 lane EQ. Set "Y" to desired value.
(0x16, 0x03), // D1 lane VOD and TXFFE.
(0x17, 0x0Y), // D1 lane EQ. Set "Y" to desired value.
(0x18, 0x03), // D2 lane VOD and TXFFE.
(0x19, 0x0Y), // D2 lane EQ. Set "Y" to desired value.
(0x20, 0x00), // Clear TMDS_CLK_RATIO
(0x31, 0x00), // Disable FRL
(0x11, 0x0F), // Enable all four lanes.
break;
case 'HDMI14_340' : // HDMI 1.4 configuration for greater than 1.65 Gbps
(0x0D, 0x21), // Limited mode, DC-coupled TX, 0dB DCG, Term 300, disable CTLE bypass
break;
case 'HDMI20' : // HDMI 2.0 configuration
(0x0D, 0x23), // Limited mode, DC-coupled TX, 0dB DCG, Term 100, disable CTLE bypass
(0x20, 0x02), // Set TMDS_CLK_RATIO
break;
case 'HDMI21_3G' : // HDMI 2.1 3 Gbps FRL
(0x0D, 0x23), // Limited mode, DC-coupled TX, 0 dB DCG, Term 100, disable CTLE bypass
(0x31, 0x01), // Set to 3G FRL. Only TXFFE0 supported.
break;
case 'HDMI21_6G_3lane' : // HDMI 2.1 6 Gbps FRL 3 lanes
(0x31, 0x02), // Set to 6G FRL and 3 lanes. Only TXFFE0 supported.
break;
case 'HDMI21_6G_4lane' : // HDMI 2.1 6 Gbps FRL 4 lanes
(0x13, 0x0Y), // Clock lane EQ. Set to "Y" to desired value.
(0x31, 0x03), // Set to 6G FRL and 4 lanes. Only TXFFE0 supported.
break;
case 'HDMI21_8G' : //HDMI 2.1 8 Gbps FRL
(0x13, 0x0Y), // Clock lane EQ. Set "Y" to desired value.
(0x31, 0x04), // Set to 8G FRL and 4 lanes. Only TXFFE0 supported.
break;
case 'HDMI21_10G' : //HDMI 2.1 10 Gbps FRL
(0x31, 0x05), // Set to 10G FRL and 4 lanes. Only TXFFE0 supported.
break;
case 'HDMI21_12G' : //HDMI 2.1 12 Gbps FRL
(0x31, 0x06), // Set to 12G FRL and 4 lanes. Only TXFFE0 supported.
break;
Hello, about your questions, I need some times to confirm.
And I would reply you as soon as possiable.
Our application method is as follows:
There is no DDC channel between FPGA and TMDS1204
Source(HDMI2.1)-> ITE hdmi2.1 IC->FPGA->TMDS1204->ITE hdmi2.1 IC
Is this a source or a sink side design? Can you share the TMDS1204 portion of the schematic?
I haven‘t receive your Email yet.
Or you could send it with private message. I have sent the friend request over forum, please approve and you could sent the schematic to me.
I have sent you with private message, and I will reply you as soon as possible.
Hello,
SIGDET_OUT requires a 10k or greater pull-up resistor.
Please remove the pull up on EN, and have a 0.1uF or 0.22uF capacitor on the EN pin for the proper reset.
LV_DDC_SCL and LV_DDC_SDA should left floating if not used.
If you write a value of 0x06 to register 0x09, are you able to see the TMDS1204 output?
1. We are testing 1920*1080*60Hz TMDS without any issues, and SIGDET_ OUT pin can detect input signals normally, and the monitor can output images normally
2.We are testing 3840*2160*60Hz TMDS without any issues, and SIGDET_ OUT pin can detect input signals normally and the monitor can output images normally
3. When we using FRL 8G (7680*3840*30Hz),SIGDET_ OUT pin can detect input signals normally,but the TMDS1204 has not output. Why?
Hello,
Is HPD_SNK being driven high for FRL 8G resolution?
Can you dump out all TMDS1204 registers when doing FRL 8G resolution?
1. HPD is High when FRL 8G resolution
2. Can you provide some feasible suggestions or do you have TI professional technical support
I have escalated your question to our senior engineer who is specified for this IC yesterday ,he suggested you could dump all TMDS1204 registers to check.
