Part Number: TLIN1431-Q1
hi!
When I want to open the TLIN1431 window watchdog, it cannot be opened successfully according to the register configuration. That is, the nRST pin has not been reset. How do I allocate the required amount correctly?
The following registers are used when configuring the window watchdog
Is there anything that has not been considered?
