DS90UB981-Q1: MIPI输入,但是total为0
Part Number: DS90UB981-Q1
Other Parts Discussed in Thread: ALP
1.981和988均在本地初始化。脚本见附件
2.981的pattern--VP0--可以正常点亮988侧的TFT
3.开阳输出MIPI信号,981切换为MIPI--VP0。当前排查981侧VP_total为0,异常
page4:
0x2A = 0x3E
0x30 = 0x7E
0x31 = 0x59
page12:
0x30= 0x00
981配置源码:
Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
ALL RIGHTS RESERVED
Global Setups - Do Not Change
FPD4 = [0,0]
FPD4Rate = [0,0]
FPD3Stream = [0,0]
THW = [0,0,0,0]
TVW = [0,0,0,0]
AHW = [0,0,0,0]
AVW = [0,0,0,0]
HBP = [0,0,0,0]
VBP = [0,0,0,0]
HSW = [0,0,0,0]
VSW = [0,0,0,0]
HFP = [0,0,0,0]
VFP = [0,0,0,0]
HSP = [0,0,0,0]
VSP = [0,0,0,0]
PCLK = [0,0,0,0]
Bits_per_pixel = [0,0,0,0]
PATGEN = [0,0,0,0]
CropEnable = [0,0,0,0]
FilterEnable = [0,0,0,0]
CropXStart = [0,0,0,0]
CropXStop = [0,0,0,0]
CropYStart = [0,0,0,0]
CropYStop = [0,0,0,0]
FilterA = [0,0,0,0]
FilterN = [0,0,0,0]
DSI_PORT0 = 0
DSI_PORT1 = 0
MAPSEL = [0,0]
OLDIBpp = [0,0]
HDCP = [0,0]
Des0_DaisyVPs = [0,0,0,0]
FPD4RateDaisy0 = [0,0,0]
FPD4RateDaisy1 = [0,0,0]
FPD4Daisy0 = [1,1]
DP0_ON = [0,0,0,0]
DP1_ON = [0,0,0,0]
DP_Output_0_Source = [0,0,0,0]
DP_Output_1_Source = [0,0,0,0]
Des_Device = [0,0,0,0]
DP_Rate = [0,0,0,0]
DP_Lane_Num = [0,0,0,0]
RGBMode = [0,0,0,0]
OLDIEnabled = [0,0,0,0]
MAPSEL0 = [0,0,0,0]
MAPSEL1 = [0,0,0,0]
RGBBpp = [0,0,0,0]
OLDIBpp0 = [0,0,0,0]
OLDIBpp1 = [0,0,0,0]
OLDI_RGB_Port0_Source = [0,0,0,0]
OLDI_Port1_Source = [0,0,0,0]
DaisyConf = [0,0,0]
FPD4LinkEN0 = [0,0,0,0]
FPD4LinkEN1 = [0,0,0,0]
DES_Display_SSCG = [0,0,0,0]
DES_Display_SSCG_FDEV = [0,0,0,0]
DES_Display_SSCG_FMOD = [0,0,0,0]
serFPDSSCG = [0,0]
serFPDSSCG_fdev = [0,0]
serFPDSSCG_fmod = [0,0]
eFuseOV = 0
FPD3DaisyVP_P0 = [0,0,0]
FPD3DaisyVP_P1 = [0,0,0]
DES_BC_SSCG = [0,0,0,0]
DES_BC_SSCG_FDEV = [0,0,0,0]
DES_BC_SSCG_FMOD = [0,0,0,0]
General Configurations - Set by the user
# Serializer Address
# Ignore if using DES only configurations
SER_Address = 0x18
# First deserializer Address Port 0
# For dual FPD-Link configurations use this address for the first deserializer. P1 addresses are ignored
# For single port 0 or independent FPD configurations this is the address of the first DES attached to port 0
DES0_Address = 0x58
DES0_Alias = 0x58
# First deserializer Address Port 1
# Only used for single port 1 or independent FPD link configurations
P1DES0_Address = 0x58
P1DES0_Alias = 0x60
# Deserializer Daisy Chain Addresses
DES1_Address = 0x58
DES1_Alias = 0x62
DES2_Address = 0x58
DES2_Alias = 0x64
DES3_Address = 0x58
DES3_Alias = 0x66
# Serializer Device
# For FPD IV serializer, options are 983 or 981
# For FPD III serializer, options are 925, 926, 921, 929, 949, 941AS, 947
Device = "981"
# DES eFuse Override Enable
# Enabling eFuse override will generate a script to
# manually override the eFuse settings for the DES
# to the final production version when using either 984 or 988
eFuseOV = 0
# If Des_Only = 1, 98x Serialzier configuration will be ignored but
# 94x/92x SER configuration will be included if Fes_FPD3_Only = 1
# Only applicable for configurations with 988/984 DES
# Use this setting when the SER is 94x or 92x FPD III or to generate a 98x to 98x script
# which only includes the DES side configurations
Des_Only = 0
# Select deserializer PatGen enable
# Only applicable for FPD IV DES configurations - ignore for FPD III DES configurations
# 0 = disable
# 1 = enable
DES_Patgen_on = 0
# If Des_FPD3_Only = 1, Serialzier configuration will be ignored and Deserializer will be configured to FPD3 mode.
# Only applicable for 988/984 configurations - ignore if using FPD III DES device
Des_FPD3_Only = 0
# Set the deserializer FPD port configuration
# Ignored if serializer is 98x
# Options:
# FPD3 Dual = 5
# FPD3 Single Port 0 = 6
DES_FPDIII_Conf = 5
# Set the serializer FPD port configuration
# Options:
# FPD4 Dual = 1
# FPD4 Single Port 0 = 2
# FPD4 Single Port 1 = 3
# FPD4 Independent = 4
# FPD3 Dual = 5
# FPD3 Single Port 1 = 7
# FPD3 Independent = 8
# FPD4 Port 0/FPD3 Port 1 = 9
# FPD3 Port 0/FPD4 Port 1 = 10
FPDConf = 2
# Enable HDCP1.4 per FPD Channel (Only applicable for UH to UH connections)
# Options: 0 = No HDCP, 1 = HDCP Enabled
# HDCP[0] controls FPD port 0
# HDCP[1] controls FPD port 1
# Unused FPD ports are ignored and only the HDCP[0] setting is used for dual FPD modes
HDCP[0] = 0
HDCP[1] = 0
# Enter number of VPs used
# Options:
# 1 Display = 1 (VP0)
# 2 Displays = 2 (VP0/VP1)
# 3 Displays = 3(VP0/VP1/VP2)
# 4 Displays = 4 (VP0/VP1/VP2/VP3)
numVPs = 1
# Enter Video Processor 0 Properties
# THW = Horizontal Total Pixels = AHW + HBP + HFP + HSW
# TVW = Vertical Total Lines = AVW + VBP + VFP + VSW
# AHW = Hoizontal Active Pixels
# AVW = Vertical Active Lines
# HBP = Horizontal Back Porch Pixels
# VBP = Vertical Back Porch Pixels
# HSW = Horizontal Sync Width Pixels
# VSW = Vertical Sync Width Lines
# HSP = Horizontal Sync Polarity: 0 = Positive, 1 = Negative
# VSP = Vertical Sync Polarity: 0 = Positive, 1 = Negative
# PCLK = Pixel Clock Rate in MHz
# Bits_per_pixel = 18, 24, or 30 (30bpp only available for FPD IV)
# PATGEN = 1 - Generate PATGEN from the VP
# PATGEN = 0 - Configure the VP but don't enable PATGEN (use for end to end video)
# If Des is set to FPD3 mode only, VP0 timing is used to configure Des.
AHW[0] = 1280
AVW[0] = 720
HBP[0] = 48
HFP[0] = 16
HSW[0] = 32
VBP[0] = 8
VFP[0] = 36
VSW[0] = 4
THW[0] = HFP[0] + AHW[0] + HBP[0] + HSW[0]
TVW[0] = VFP[0] + AVW[0] + VBP[0] + VSW[0]
HSP[0] = 0
VSP[0] = 0
PCLK[0] = 62
Bits_per_pixel[0] = 24
PATGEN[0] = 0
# Crop and filter parameters (Optional - Ignored if CropEnable[x] is 0)
CropEnable[0] = 0
CropXStart[0] = 0
CropXStop[0] = 1279
CropYStart[0] = 0
CropYStop[0] = 719
# Filter parameters (Optional - Ignored if FilterEnable[x] is 0)
FilterEnable[0] = 0
FilterA[0] = 1
FilterN[0] = 2
# Enter Video Processor 1 Properties (Optional)
AHW[1] = 1920
AVW[1] = 720
HBP[1] = 48
HFP[1] = 48
HSW[1] = 12
VBP[1] = 40
VFP[1] = 4
VSW[1] = 4
THW[1] = HFP[1] + AHW[1] + HBP[1] + HSW[1]
TVW[1] = VFP[1] + AVW[1] + VBP[1] + VSW[1]
HSP[1] = 0
VSP[1] = 0
PCLK[1] = 93
Bits_per_pixel[1] = 24
PATGEN[1] = 1
CropEnable[1] = 0
CropXStart[1] = 0
CropXStop[1] = 1399
CropYStart[1] = 0
CropYStop[1] = 1199
FilterEnable[1] = 0
FilterA[1] = 1
FilterN[1] = 2
# Enter Video Processor 2 Properties (Optional)
AHW[2] = 1400
AVW[2] = 1200
HBP[2] = 16
HFP[2] = 16
HSW[2] = 12
VBP[2]= 92
VFP[2] = 12
VSW[2] = 2
THW[2] = HFP[2] + AHW[2] + HBP[2]+ HSW[2]
TVW[2] = VFP[2] + AVW[2] + VBP[2]+ VSW[2]
HSP[2] = 0
VSP[2] = 0
PCLK[2] = 113
Bits_per_pixel[2] = 24
PATGEN[2] = 1
CropEnable[2] = 1
CropXStart[2] = 1400
CropXStop[2] = 2799
CropYStart[2] = 0
CropYStop[2] = 1199
FilterEnable[2] = 0
FilterA[2] = 1
FilterN[2] = 2
# Enter Video Processor 3 Properties (Optional)
THW[3] = 2200
TVW[3] = 1125
AHW[3] = 1920
AVW[3] = 1080
HBP[3] = 148
VBP[3] = 36
HSW[3] = 44
VSW[3] = 5
HFP[3] = THW[3] - AHW[3] - HBP[3] - HSW[3]
VFP[3] = TVW[3] - AVW[3] - VBP[3] - VSW[3]
HSP[3] = 0
VSP[3] = 0
PCLK[3] = 148.5
Bits_per_pixel[3] = 24
PATGEN[3] = 0
CropEnable[3] = 1
CropXStart[3] = 1920
CropXStop[3] = 3839
CropYStart[3] = 0
CropYStop[3] = 1079
FilterEnable[3] = 1
FilterA[3] = 1
FilterN[3] = 2
# Enter stream mapping for FPD3 Mode (ignored if using FPD4)
# Ignore map setting for unused port in single FPD3 mode
# If using dual mode, set FPD3Stream[0] and FPD3Stream[1] to the same VP
# Options: 0 = VP0, 1 = VP1, 2 = VP2, 3 = VP3: Maps the corresponding VP to the FPD3 port
FPD3Stream[0] = 0
FPD3Stream[1] = 0
# FPD4 Rate Selection (Gbps)
# Ignored if the port is set to FPD3 mode
# FPD4Rate[0] sets FPD TX Port 0
# FPD4Rate[1] sets FPD TX Port 1
# Options: 3.375, 6.75, 10.8, 13.5, 12.528
FPD4Rate[0] = 6.75
FPD4Rate[1] = 6.75
# FPD4 Port SSCG Configuration
# serFPDSSCG[0] controls FPD Port 0
# serFPDSSCG[1] controls FPD Port 1
# Options:
# 0 = Disabled
# 1 = Enable SSCG Center Spread
# 2 = Enable SSCG Down Spread
serFPDSSCG[0] = 0
serFPDSSCG[1] = 0
# Serializer SSCG FDEV %
# serFPDSSCG_fdev[0] controls FPD Port 0
# serFPDSSCG_fdev[1] controls FPD Port 1
# Ignored is serFPDSSCG = 0
# Sets the SSCG frequency deviation percentage for FPD4 port 0
# Options: 0-0.5 (%)
serFPDSSCG_fdev[0] = 0.25
serFPDSSCG_fdev[1] = 0.25
# Display SSCG FMOD kHz
# serFPDSSCG_fmod[0] controls FPD Port 0
# serFPDSSCG_fmod[1] controls FPD Port 1
# Ignored is DES_Display_SSCG = 0
# Set the SSCG modulation frequency for display interface SSCG
# Options: 30-33 (kHz)
serFPDSSCG_fmod[0] = 33
serFPDSSCG_fmod[1] = 33
# FPD4 Link Layer Selection for independent FPD IV Mode or mixed FPD III/IV modes
# Ignored for dual FPD IV or single FPD IV modes
# Select which VPs are forwarded to FPD Port 0 and Port 1 Link layers
# FPD4LinkEN0 controls SER FPD Port 0
# FPD4LinkEN1 controls SER FPD Port 1
# For example, to send VP 0 to port 0 and VP1 to port 1, use the following
# Note that in order to send any stream to both FPD ports, the FPD IV links rate must be the same
# FPD4LinkEN0 = [1,0,0,0]
# FPD4LinkEN1 = [0,1,0,0]
983 Configs - Ignored if using 981
# Set max DP lane count
# Options: 1, 2, 4
DPlanes = 4
# Set max advertised DP lane rate in Gbps
# Options: 1.62, 2.7, 5.4, 8.1
maxRate = 5.4
# Set MST or SST mode
# Options: 0 = SST mode, 1 = MST mode
# MST mode always uses VP0 for MST0 and VP1 for MST1
MST = 0
# Set DP receiver to expect SSC or no SSC from the DPTX
# Options: 0 = No SSC, 1 = SSC
SSC = 0
#Set DP receiver to DP or eDP mode
# Options: 0 = DP Mode, 1 = eDP Mode
eDP = 0
981 Configs - Ignored if using 983
#DSI ports active
# 0 = DSI 0 only
# 1 = DSI 1 only
# 2 = DSI 0 and DSI 1
DSI_PORTS_ACTIVE = 2
# Set max DSI lane count
# Options: 1, 2, 3, 4
Port0_DSI_Lanes = 4
Port1_DSI_Lanes = 4
# Set DSI in Continuous or Non-Continuous Clock
# 1 = Continuous ; 0 = Non-Continuous Clock
Port0_Contin = 1
Port1_Contin = 1
# Set the DSI rate
# example: 500 Mbps= 500, 1.2 Gbps = 1200Mbps
Port0_DSI_Rate = 372
Port1_DSI_Rate = 372
#DSI Source for Video Processors
#0 = DPHY 0 virtual Channel 0
#1 = DPHY 0 virtual Channel 1
#2 = DPHY 0 virtual Channel 2
#3 = DPHY 0 virtual Channel 3
#4 = DPHY 1 virtual Channel 0
#5 = DPHY 1 virtual Channel 1
#6 = DPHY 1 virtual Channel 2
#7 = DPHY 1 virtual Channel 3
VP_0_Source = 0
VP_1_Source = 4
VP_2_Source = 0
VP_3_Source = 0
DES0 (First Deserialzier) Configurations - Ignored for FPD III Modes
This section is referenced for FPD IV Dual mode or Single FPD IV Port 0 mode (NOT FPD IV Single Port 1 Mode)
# Des_Device
# Only used for FPD IV deserializer configurations - ignore if using FPD III deserializer
# Options 984, 988
Des_Device[0] = "988"
# Set the deserializer Daisy Chain TX FPD port configuration
# Options:
# Daisy Chaining Disabled = 0
# FPD4 Dual = 1
# FPD4 Single Port 1 = 3 # Net yet functional
# FPD4 Independent = 4 # Net yet functional
# FPD3 Dual = 5
# FPD4 Port 0/FPD3 Port 1 = 9 # Net yet functional
# FPD3 Port 0/FPD4 Port 1 = 10 # Net yet functional
DaisyConf[0] = 2
# Enable daisy chain TX forwarding for deserializer 0 (first DES in the chain)
# Set VPs 0-4 = 1 to enable forwarding of that VP to the next DES
# If all VP forwarding is set to 0, then daisy chaining is disabled
# Example: Forward only VP0 to the next DES:    Des0_DaisyVPs = [1,0,0,0]
# Example Forward VP1 and VP2 to the next DES:  Des0_DaisyVPs = [0,1,1,0]
Des0_DaisyVPs = [0,1,0,0]
# Set which VP is forwarded to chain chain output in FPD III mode
# FPD3DaisyVP_P0 controls daisy chain FPD port 0
# FPD3DaisyVP_P1 controls daisy chain FPD port 1
# FPD3DaisyVP_P0 and FPD3DaisyVP_P1 must be set to the same VP for dual FPD III mode
# Setting the daisy chain output to FPD III mode terminates the daisy chain at the connected deserializer
# This is ignored if the daisy chain is set up for FPD IV output mode
# Example: Forward VP1 to Daisy Chain Output in FPD III mode: FPD3DaisyVP[0] = 1
# Example: Forward VP3 to Daisy Chain Output in FPD III mode: FPD3DaisyVP[0] = 3
FPD3DaisyVP_P0[0] = 1
FPD3DaisyVP_P1[0] = 1
# FPD4 Rate Selection for DES0 Daisy Chain TX (Gbps)
# FPD4RateDaisy0[0] sets DES0 Daisy Chain TX Port 0
# FPD4RateDaisy1[0] sets DES0 Daisy Chain TX Port 1
FPD4RateDaisy0[0] = 6.75
FPD4RateDaisy1[0] = 6.75
# FPD BC SSCG Configuration
# SSCG options for the deserializer back channel output
# Options:
# 0 = Disable SSCG on FPD back channel interface
# 1 = Enable SSCG with Center Spread
# 2 = Enable SSCG with Down Spread
DES_BC_SSCG[0] = 1
# FPD BC SSCG FDEV %
# Ignored is DES_BC_SSCG = 0
# Sets the SSCG frequency deviation percentage for FPD back channel interface SSCG
# Note: Combined FPD FC and BC FDEV should not exceed 0.5% for center spread or 0.25% for down spread
# Options: 0-0.5 (%) in Center Spread Mode
# Options: 0-0.25 (%) in Down Spread Mode
DES_BC_SSCG_FDEV[0] = 0.25
# FPD SSCG FMOD kHz
# Set the SSCG modulation frequency for FPD back channel interface SSCG
DES_BC_SSCG_FMOD[0] = 33
# Display SSCG Configuration
# SSCG options for the deserializer display output (OLDI or DP/eDP Interface)
# This is independent of the FPD-Link SSCG
# Options:
# 0 = Disable SSCG on display interface
# 1 = Enable SSCG with Center Spread (988 only)
DES_Display_SSCG[0] = 0
# Display SSCG FDEV %
# Sets the SSCG frequency deviation percentage for display interface SSCG
# Options: 0-6 (%) for 988 in Center Spread Mode (+/-3%)
# Options: 0-3 (%) for 988 in Down Spread Mode
# Options: 0-0.5 (%) for 984 (Down Spread Only)
DES_Display_SSCG_FDEV[0] = 1
# Options: 10-100 (kHz) for 988
# Options: 30-33 (kHz) for 984
DES_Display_SSCG_FMOD[0] = 10
DES0 984 Configs - Ignored if using 988
#Select DP ports to be enabled
# Enabled = 1, Disabled = 0
DP0_ON[0] = 1
DP1_ON[0] = 0
#Select video source for DP output
#Ser VP0 is mapped to Stream 0, Ser VP1 is mapped to Stream 1, and etc.
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
DP_Output_0_Source[0] = 0
DP_Output_1_Source[0] = 0
# Select DP output lane rate and number of lanes
# Options (in Gbps):
# 1.62
# 2.7
# 5.4
# 8.1
DP_Rate[0] = 2.7
DP_Lane_Num[0] = 4
DES0 988 Configs - Ignored if using 984
# Select OLDI or RGB mode
# Options:
# 1 = RGB Mode Enabled
# 0 = OLDI Mode
RGBMode[0] = 0
# Select OLDI port configuration (Ignored for RGB mode)
# Options:
# 0 = Single OLDI port 0
# 1 = Single OLDI port 1
# 2 = Dual OLDI
# 3 = Dual OLDI Swap
OLDIEnabled[0] = 0
# Select MAPSEL Setting for port 0 and port 1 (Ignored for RGB mode)
# 0 = MAPSEL = L (LSB on D3/D4)
# 1 = MAPSEL = H (MSB on D3/D4)
MAPSEL0[0] = 1
MAPSEL1[0] = 1
# Set OLDI Bits Per Pixel for port 0 and 1 (Ignored in RGB mode)
# Options: 18, 24, 30
OLDIBpp0[0] = 24
OLDIBpp1[0] = 24
# Set RGB mode Bits Per Pixel (Ignored in OLDI mode)
RGBBpp[0] = 24
# Select video source for OLDI/RGB output
# Ser VP0 is mapped to Stream 0, Ser VP1 is mapped to Stream 1, and etc.
# For Dual OLDI, use same stream for both ports
# OLDI_Port1_Source is ignored for single OLDI port 0 or RGB mode
# OLDI_RGB_Port0_Source is ignored for single OLDI port 1 mode
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
OLDI_RGB_Port0_Source[0] = 0
OLDI_Port1_Source[0] = 0
DES1 (Second Deserialzier) Configurations - Ignored for FPD III Modes
For Y-split (Independent FPD IV) configurations, DES1 is the device attached to SER TX port 1
For single port 1 FPD IV configurations, this is the device attached to SER TX port 1
# Des_Device
# Options 984, 988
Des_Device[1] = "988"
# Options:
# FPD4 Dual = 1
# FPD3 Dual = 5
DaisyConf[1] = 0
# Enable daisy chain TX forwarding for deserializer 1 (second DES in the chain)
# Example: Forward only VP0 to the next DES:    Des1_DaisyVPs = [1,0,0,0]
# Example Forward VP1 and VP2 to the next DES:  Des1_DaisyVPs = [0,1,1,0]
Des1_DaisyVPs = [0,0,0,0]
FPD3DaisyVP_P0[1] = 2
FPD3DaisyVP_P1[1] = 2
# FPD4 Rate Selection for DES1 Daisy Chain TX (Gbps)
# FPD4RateDaisy0[1] sets DES1 Daisy Chain TX Port 0
# FPD4RateDaisy1[1] sets DES1 Daisy Chain TX Port 1
FPD4RateDaisy0[1] = 6.75
FPD4RateDaisy1[1] = 6.75
# Options:
DES_BC_SSCG[1] = 0
DES_BC_SSCG_FDEV[1] = 0.25
# FPD SSCG FMOD kHz
DES_BC_SSCG_FMOD[1] = 33
# Options:
DES_Display_SSCG[1] = 0
DES_Display_SSCG_FDEV[1] = 1
DES_Display_SSCG_FMOD[1] = 10
DES1 984 Configs - Ignored if using 988
DP0_ON[1] = 1
DP1_ON[1] = 0
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
DP_Output_0_Source[1] = 1
DP_Output_1_Source[1] = 1
# 1.62
# 2.7
# 5.4
# 8.1
DP_Rate[1] = 1.62
DP_Lane_Num[1] = 4
DES1 988 Configs - Ignored if using 984
# Options:
# 0 = OLDI Mode
RGBMode[1] = 0
# Options:
# 2 = Dual OLDI
OLDIEnabled[1] = 2
MAPSEL0[1] = 1
MAPSEL1[1] = 1
OLDIBpp0[1] = 24
OLDIBpp1[1] = 24
RGBBpp[1] = 24
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
OLDI_RGB_Port0_Source[1] = 0
OLDI_Port1_Source[1] = 0
DES2 (Third Deserialzier) Configurations
# Des_Device
# Options 984, 988
Des_Device[2] = "988"
# Options:
# FPD4 Dual = 1
# FPD3 Dual = 5
DaisyConf[2] = 0
# Enable daisy chain TX forwarding for deserializer 2 (third DES in the chain)
# Example: Forward only VP0 to the next DES:    Des2_DaisyVPs = [1,0,0,0]
# Example Forward VP1 and VP2 to the next DES:  Des2_DaisyVPs = [0,1,1,0]
Des2_DaisyVPs = [0,0,0,1]
FPD3DaisyVP_P0[2] = 1
FPD3DaisyVP_P1[2] = 1
# FPD4 Rate Selection for DES2 Daisy Chain TX (Gbps)
# FPD4RateDaisy0[2] sets DES2 Daisy Chain TX Port 0
# FPD4RateDaisy1[2] sets DES2 Daisy Chain TX Port 1
FPD4RateDaisy0[2] = 10.8
FPD4RateDaisy1[2] = 10.8
# Options:
DES_BC_SSCG[2] = 0
DES_BC_SSCG_FDEV[2] = 0.25
# FPD SSCG FMOD kHz
DES_BC_SSCG_FMOD[2] = 33
# Options:
DES_Display_SSCG[2] = 0
DES_Display_SSCG_FDEV[2] = 1
DES_Display_SSCG_FMOD[2] = 50
DES2 984 Configs - Ignored if using 988
DP0_ON[2] = 1
DP1_ON[2] = 0
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
DP_Output_0_Source[2] = 2
DP_Output_1_Source[2] = 1
# 1.62
# 2.7
# 5.4
# 8.1
DP_Rate[2] = 2.7
DP_Lane_Num[2] = 4
DES2 988 Configs - Ignored if using 984
# Options:
# 0 = OLDI Mode
RGBMode[2] = 0
# Options:
# 2 = Dual OLDI
OLDIEnabled[2] = 0
MAPSEL0[2] = 1
MAPSEL1[2] = 1
OLDIBpp0[2] = 24
OLDIBpp1[2] = 24
RGBBpp[2] = 24
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
OLDI_RGB_Port0_Source[2] = 2
OLDI_Port1_Source[2] = 2
DES3 (Fourth Deserialzier) Configurations
# Des_Device
# Options 984, 988
Des_Device[3] = "984"
# Options:
DES_BC_SSCG[3] = 1
DES_BC_SSCG_FDEV[3] = 0.25
# FPD SSCG FMOD kHz
DES_BC_SSCG_FMOD[3] = 33
# Options:
DES_Display_SSCG[3] = 0
DES_Display_SSCG_FDEV[3] = 1
DES_Display_SSCG_FMOD[3] = 50
DES3 984 Configs - Ignored if using 988
DP0_ON[3] = 1
DP1_ON[3] = 0
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
DP_Output_0_Source[3] = 3
DP_Output_1_Source[3] = 1
# 1.62
# 2.7
# 5.4
# 8.1
DP_Rate[3] = 2.7
DP_Lane_Num[3] = 4
DES3 988 Configs - Ignored if using 984
# Options:
# 0 = OLDI Mode
RGBMode[3] = 0
# Options:
# 2 = Dual OLDI
OLDIEnabled[3] = 2
MAPSEL0[3] = 1
MAPSEL1[3] = 1
OLDIBpp0[3] = 24
OLDIBpp1[3] = 24
RGBBpp[3] = 24
# 0 = Stream 0
# 1 = Stream 1
# 2 = Stream 2
# 3 = Stream 3
OLDI_RGB_Port0_Source[3] = 1
OLDI_Port1_Source[3] = 1
981配置ALP生成代码:
## TI Confidential - NDA Restrictions
## Copyright 2018 Texas Instruments Incorporated. All rights reserved.
## IMPORTANT: Your use of this Software is limited to those specific rights
## granted under the terms of a software license agreement between the user who
## downloaded the software, his/her employer (which must be your employer) and
## Texas Instruments Incorporated (the License). You may not use this Software
## unless you agree to abide by the terms of the License. The License limits your
## use, and you acknowledge, that the Software may not be modified, copied or
## distributed unless embedded on a Texas Instruments microcontroller which is
## integrated into your product. Other than for the foregoing purpose, you may
## not use, reproduce, copy, prepare derivative works of, modify, distribute,
## perform, display or sell this Software and/or its documentation for any
## purpose.
## YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
## PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
## INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
## NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL TEXAS
## INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
## NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER LEGAL
## EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES INCLUDING BUT NOT
## LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE OR CONSEQUENTIAL
## DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT OF SUBSTITUTE GOODS,
## TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT
## LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
## Should you have any questions regarding your right to use this Software,
## contact Texas Instruments Incorporated at www.TI.com.
## DS90Ux98x-Q1 Auto Script Generation Output
## Tool Version 3.3
import time
## Serializer: DS90Ux981-Q1
## User Inputs:
## Serializer I2C Address= 0x18
## Port 0 DSI Lanes = 4
## Port 0 DSI Rate = 372 Mbps/lane
## Port 1 DSI Lanes = 4
## Port 1 DSI Rate = 372 Mbps/lane
## FPD-Link Configuration: FPD-Link IV Single Port 0 - 6.75Gbps
## Number of Displays = 1
## Video Processor 0 Properties:
## Total Horizontal Pixels = 1376
## Total Vertical Lines = 768
## Active Horizontal Pixels = 1280
## Active Vertical Lines = 720
## Horizontal Back Porch = 48
## Vertical Back Porch = 8
## Horizontal Sync = 32
## Vertical Sync = 4
## Horizontal Front Porch = 16
## Vertical Front Porch = 36
## Horizontal Sync Polarity = Positive
## Vertical Sync Polarity = Positive
## Bits per pixel = 24
## Pixel Clock = 62MHz
## PATGEN Disabled
## Deserializer 0: DS90Ux988-Q1
## Note: The 988 should be strapped to 6.75Gbps FPD IV mode using MODE_SEL0
## User Inputs:
## Deserializer I2C Address = 0x58
## Deserializer I2C Alias = 0x58
## FPD BC SSCG Enabled:
## Spread Type: Center
## fMOD = 33kHz
## fDEV = 0.25%
## Daisy Chain Output Enabled
## Daisy Chain Output Mode: FPD IV Single Port 0 - 6.75Gbps
## 988 OLDI Output Mode
## Single OLDI Port 0
## OLDI Port 0 Bpp = 24
## OLDI Port 0 MAPSEL = H (MSB on D3/D4)
## OLDI Port 0 Video Source = Serializer Stream 0
## OLDI PATGEN Disabled
## Deserializer 1: DS90Ux988-Q1
## User Inputs:
## Deserializer I2C Alias = 0x62
## Dual OLDI Mode
## OLDI Port 1 Bpp = 24
## OLDI Port 1 MAPSEL = H (MSB on D3/D4)
## Dual OLDI Video Source = Serializer Stream 0
## Set up Variables
serAddr = 0x18
desAddr0 = 0x58
desAlias0 = 0x58
des_daisy1_Addr = 0x58
des_daisy1_Alias = 0x62
board.WriteI2C(serAddr,0x70,desAddr0)
board.WriteI2C(serAddr,0x78,desAlias0)
board.WriteI2C(serAddr,0x88,0x0)
board.WriteI2C(serAddr,0x72,des_daisy1_Addr)
board.WriteI2C(serAddr,0x7A,des_daisy1_Alias)
board.WriteI2C(serAddr,0x8a,0x1)
## Program DSI Configs
Reg_value = board.ReadI2C(serAddr,0x2,1)
Reg_value = Reg_value | 0x8
board.WriteI2C(serAddr,0x2,Reg_value) #Disable DSI
board.WriteI2C(serAddr,0x2d,0x1) #Select port 0
board.WriteI2C(serAddr,0x40,0x10) #Change indirect page to page 4
board.WriteI2C(serAddr,0x41,0x5)
board.WriteI2C(serAddr,0x42,0x6) #Port 0 TSKIP value:3
Reg_value = board.ReadI2C(serAddr,0x4f,1)
Reg_value = Reg_value & 0x73
Reg_value = Reg_value | 0x8c
board.WriteI2C(serAddr,0x4f,Reg_value) #Set number of lanes and continuous or non-continuous
board.WriteI2C(serAddr,0x2d,0x12) #Select port 1
board.WriteI2C(serAddr,0x40,0x18) #Change indirect page to page 6
board.WriteI2C(serAddr,0x42,0x6) #Port 1 TSKIP value:3
board.WriteI2C(serAddr,0x2d,0x3) #Select write port 0 and 1
board.WriteI2C(serAddr,0xbd,0x20) #Set DSI source for the Video processors 0 and 1
board.WriteI2C(serAddr,0xbe,0x0) #Set DSI source for the Video processors 2 and 3
## Program SER to FPD-Link IV mode
board.WriteI2C(serAddr,0x5b,0x23) #Disable FPD3 FIFO pass through
board.WriteI2C(serAddr,0x5,0x2c) #Force FPD4_TX single port 0 mode
## Set up FPD IV PLL Settings - This section can be commented out to improve bringup time if 983/981 MODE_SEL0 and MODE_SEL2 are strapped to the correct FPD IV speed
board.WriteI2C(serAddr,0x40,0x8) #Select PLL reg page
board.WriteI2C(serAddr,0x41,0x1b)
board.WriteI2C(serAddr,0x42,0x8) #Disable PLL0
board.WriteI2C(serAddr,0x41,0x5b)
board.WriteI2C(serAddr,0x42,0x8) #Disable PLL1
board.WriteI2C(serAddr,0x2,0xd1) #Enable mode overwrite
board.WriteI2C(serAddr,0x40,0x24)
board.WriteI2C(serAddr,0x41,0x84)
board.WriteI2C(serAddr,0x42,0x2) #Switch encoder from ADAS to IVI on port 0
board.WriteI2C(serAddr,0x40,0x8) #Select PLL page
board.WriteI2C(serAddr,0x41,0x5) #Select Ncount Reg
board.WriteI2C(serAddr,0x42,0x7d) #Set Ncount
board.WriteI2C(serAddr,0x41,0x13) #Select post div reg
board.WriteI2C(serAddr,0x42,0x90) #Set post div for 6.75 Gbps
board.WriteI2C(serAddr,0x2d,0x1) #Select write reg to port 0
board.WriteI2C(serAddr,0x6a,0xa) #set BC sampling rate
board.WriteI2C(serAddr,0x6e,0x80) #set BC fractional sampling
board.WriteI2C(serAddr,0x40,0x4) #Select FPD page and set BC settings for FPD IV port 0
board.WriteI2C(serAddr,0x41,0x6)
board.WriteI2C(serAddr,0x42,0x0)
board.WriteI2C(serAddr,0x41,0xd)
board.WriteI2C(serAddr,0x42,0x34)
board.WriteI2C(serAddr,0x41,0xe)
board.WriteI2C(serAddr,0x42,0x53)
board.WriteI2C(serAddr,0x2,0x51) #Set HALFRATE_MODE
## Zero out PLL fractional - This section can be commented out to improve bringup time if 983/981 MODE_SEL0 and MODE_SEL2 are strapped to the correct FPD IV speed
board.WriteI2C(serAddr,0x41,0x4)
board.WriteI2C(serAddr,0x42,0x1)
board.WriteI2C(serAddr,0x41,0x1e)
board.WriteI2C(serAddr,0x41,0x1f)
board.WriteI2C(serAddr,0x41,0x20)
## Configure and Enable PLLs - This section can be commented out to improve bringup time if 983/981 MODE_SEL0 and MODE_SEL2 are strapped to the correct FPD IV speed
board.WriteI2C(serAddr,0x41,0xe) #Select VCO reg
board.WriteI2C(serAddr,0x42,0xc7) #Set VCO
board.WriteI2C(serAddr,0x1,0x30) #soft reset PLL
board.WriteI2C(serAddr,0x42,0x0) #Enable PLL0
board.WriteI2C(serAddr,0x1,0x1) #soft reset Ser
time.sleep(0.04)
## Enable I2C Passthrough
I2C_PASS_THROUGH = board.ReadI2C(serAddr,0x7,1)
I2C_PASS_THROUGH_MASK = 0x08
I2C_PASS_THROUGH_REG = I2C_PASS_THROUGH | I2C_PASS_THROUGH_MASK
board.WriteI2C(serAddr,0x07,I2C_PASS_THROUGH_REG) #Enable I2C Passthrough
board.WriteI2C(desAlias0,0x1,0x1) #Soft reset Des
time.sleep(0.04)
board.WriteI2C(serAddr,0x2d,0x1) #Select write to port0 reg
## Program VP Configs
# Configure VP 0
board.WriteI2C(serAddr,0x40,0x32)
board.WriteI2C(serAddr,0x41,0x2)
board.WriteI2C(serAddr,0x42,0x0) #VID H Active
board.WriteI2C(serAddr,0x42,0x5) #VID H Active
board.WriteI2C(serAddr,0x41,0x10)
board.WriteI2C(serAddr,0x42,0x0) #Horizontal Active
board.WriteI2C(serAddr,0x42,0x5) #Horizontal Active
board.WriteI2C(serAddr,0x42,0x30) #Horizontal Back Porch
board.WriteI2C(serAddr,0x42,0x0) #Horizontal Back Porch
board.WriteI2C(serAddr,0x42,0x20) #Horizontal Sync
board.WriteI2C(serAddr,0x42,0x0) #Horizontal Sync
board.WriteI2C(serAddr,0x42,0x60) #Horizontal Total
board.WriteI2C(serAddr,0x42,0x5) #Horizontal Total
board.WriteI2C(serAddr,0x42,0xd0) #Vertical Active
board.WriteI2C(serAddr,0x42,0x2) #Vertical Active
board.WriteI2C(serAddr,0x42,0x8) #Vertical Back Porch
board.WriteI2C(serAddr,0x42,0x0) #Vertical Back Porch
board.WriteI2C(serAddr,0x42,0x4) #Vertical Sync
board.WriteI2C(serAddr,0x42,0x0) #Vertical Sync
board.WriteI2C(serAddr,0x42,0x24) #Vertical Front Porch
board.WriteI2C(serAddr,0x42,0x0) #Vertical Front Porch
board.WriteI2C(serAddr,0x41,0x27)
board.WriteI2C(serAddr,0x42,0x0) #HSYNC Polarity = +, VSYNC Polarity = +
board.WriteI2C(serAddr,0x41,0x23) #M/N Register
board.WriteI2C(serAddr,0x42,0xc2) #M value
board.WriteI2C(serAddr,0x42,0xb) #M value
board.WriteI2C(serAddr,0x42,0xf) #N value
## Enable VPs
board.WriteI2C(serAddr,0x43,0x0) #Set number of VPs used = 1
board.WriteI2C(serAddr,0x44,0x1) #Enable video processors
## Configure Serializer TX Link Layer
board.WriteI2C(serAddr,0x40,0x2e) #Link layer Reg page
board.WriteI2C(serAddr,0x41,0x1) #Link layer 0 stream enable
board.WriteI2C(serAddr,0x42,0x1) #Link layer 0 stream enable
board.WriteI2C(serAddr,0x41,0x6) #Link layer 0 time slot 0
board.WriteI2C(serAddr,0x42,0x41) #Link layer 0 time slot
board.WriteI2C(serAddr,0x41,0x20) #Set Link layer vp bpp
board.WriteI2C(serAddr,0x42,0x55) #Set Link layer vp bpp according to VP Bit per pixel
board.WriteI2C(serAddr,0x41,0x0) #Link layer 0 enable
board.WriteI2C(serAddr,0x42,0x3) #Link layer 0 enable
Reg_value = Reg_value & 0xf7
board.WriteI2C(serAddr,0x2,Reg_value) #Enable DSI
## Configure DES 0 FPD Back Channel SSCG
board.WriteI2C(desAlias0,0x40,0xa)
board.WriteI2C(desAlias0,0x41,0x5)
board.WriteI2C(desAlias0,0x42,0x7c) #Set NDIV = 124
board.WriteI2C(desAlias0,0x42,0x0) #Set NDIV = 124
board.WriteI2C(desAlias0,0x41,0x18)
board.WriteI2C(desAlias0,0x42,0xf6) #Set DEN = 16777206
board.WriteI2C(desAlias0,0x42,0xff)
board.WriteI2C(desAlias0,0x41,0x1e)
board.WriteI2C(desAlias0,0x42,0xf6) #Set NUM = 16777206
board.WriteI2C(desAlias0,0x41,0x14)
board.WriteI2C(desAlias0,0x42,0xb2) #Set Spread Type = Center and Set RAMPX_INC = 12850
board.WriteI2C(desAlias0,0x41,0x15)
board.WriteI2C(desAlias0,0x42,0x64)
board.WriteI2C(desAlias0,0x41,0x16)
board.WriteI2C(desAlias0,0x42,0xcc) #Set RAMPX_STOP = 204
board.WriteI2C(desAlias0,0x41,0x17)
board.WriteI2C(desAlias0,0x42,0x40)
board.WriteI2C(desAlias0,0x41,0x4)
board.WriteI2C(desAlias0,0x42,0x9) #Set PLL Order to Fractional
board.WriteI2C(desAlias0,0x1,0x1) #Soft Reset Des
time.sleep(0.04)
## Read Deserializer 0 Temp
board.WriteI2C(desAlias0,0x40,0x6c)
board.WriteI2C(desAlias0,0x41,0xd)
board.WriteI2C(desAlias0,0x41,0x13)
TEMP_FINAL = board.ReadI2C(desAlias0,0x42,1)
TEMP_FINAL_C = 2*TEMP_FINAL - 273
## Set up Deserializer 0 Temp Ramp Optimizations
Efuse_TS_CODE = 2
Ramp_UP_Range_CODES_Needed = int((150-TEMP_FINAL_C)/(190/11)) + 1
Ramp_DN_Range_CODES_Needed = int((TEMP_FINAL_C-30)/(190/11)) + 1
Ramp_UP_CAP_DELTA = Ramp_UP_Range_CODES_Needed - 4
Ramp_DN_CAP_DELTA = Ramp_DN_Range_CODES_Needed - 7
board.WriteI2C(desAlias0,0x40,0x3c)
board.WriteI2C(desAlias0,0x41,0xf5)
board.WriteI2C(desAlias0,0x42,(Efuse_TS_CODE<<4)+1) # Override TS_CODE Efuse Code
if Ramp_UP_CAP_DELTA > 0:
  TS_CODE_UP = Efuse_TS_CODE - Ramp_UP_CAP_DELTA
  if TS_CODE_UP < 0:
      TS_CODE_UP = 0
  rb = board.ReadI2C(desAlias0,0x42,1)
  rb &= 0x8F
  rb |= (TS_CODE_UP << 4)
  board.WriteI2C(desAlias0,0x42,rb)
  rb &= 0xFE
  rb |= 0x01
  time.sleep(0.04)
if Ramp_DN_CAP_DELTA > 0:
  TS_CODE_DN = Efuse_TS_CODE + Ramp_DN_CAP_DELTA
  if TS_CODE_DN >= 7:
      TS_CODE_DN = 7
  rb &= 0x8F
  rb |= (TS_CODE_DN << 4)
  rb &= 0xFE
  rb |= 0x01
  time.sleep(0.04)
## Clear CRC errors from initial link process
Reg_value = Reg_value | 0x20
board.WriteI2C(serAddr,0x2,Reg_value) #CRC Error Reset
Reg_value = Reg_value & 0xdf
board.WriteI2C(serAddr,0x2,Reg_value) #CRC Error Reset Clear
## Configure Deserializer TX Layer
board.WriteI2C(desAlias0,0x40,0x44) #Select TX Link Layer Page
board.WriteI2C(desAlias0,0x41,0x1) #Select LINK0_STREAM_EN
board.WriteI2C(desAlias0,0x42,0x2) #Enable forwarded daisy chain streams
board.WriteI2C(desAlias0,0x41,0x7) #Select LINK0_SLOT_REQ1
board.WriteI2C(desAlias0,0x42,0x41) #Set number of time slots
board.WriteI2C(desAlias0,0x41,0x32)
board.WriteI2C(desAlias0,0x42,0x1) #Set FPD_TX_POL_SEL_EN
board.WriteI2C(desAlias0,0x41,0x30)
board.WriteI2C(desAlias0,0x42,0x0) #Configure FPD_TX_HPOL_CTL
board.WriteI2C(desAlias0,0x41,0x31)
board.WriteI2C(desAlias0,0x42,0x0) #Configure FPD_TX_VPOL_CTL
board.WriteI2C(desAlias0,0x41,0x0) #Link layer enable
board.WriteI2C(desAlias0,0x42,0x3) #Link layer enable
## Program Des Daisy TX
board.WriteI2C(desAlias0,0xa8,0x2c) #Enable daisy chain TX_FPD_PORTS
board.WriteI2C(desAlias0,0x5,0xc0) #Set half rate mode for 6.75Gbps daisy chain
board.WriteI2C(desAlias0,0x40,0xc) #Select PLL Reg page
board.WriteI2C(desAlias0,0x41,0x5b) #Select Channel 1 PLL Register
board.WriteI2C(desAlias0,0x42,0x8) #Disable Unused Channel 1 PLL
board.WriteI2C(desAlias0,0x1,0x30) #soft reset Des
time.sleep(0.04)
## Read Deserializer 1 Temp
board.WriteI2C(des_daisy1_Alias,0x40,0x6c)
board.WriteI2C(des_daisy1_Alias,0x41,0xd)
board.WriteI2C(des_daisy1_Alias,0x42,0x0)
board.WriteI2C(des_daisy1_Alias,0x41,0x13)
TEMP_FINAL = board.ReadI2C(des_daisy1_Alias,0x42,1)
## Set up Deserializer 1 Temp Ramp Optimizations
Efuse_TS_CODE = 2
board.WriteI2C(des_daisy1_Alias,0x40,0x3c)
board.WriteI2C(des_daisy1_Alias,0x41,0xf5)
board.WriteI2C(des_daisy1_Alias,0x42,(Efuse_TS_CODE<<4)+1) # Override TS_CODE Efuse Code
  if TS_CODE_UP < 0:
      TS_CODE_UP = 0
  rb = board.ReadI2C(des_daisy1_Alias,0x42,1)
  rb &= 0x8F
  board.WriteI2C(des_daisy1_Alias,0x42,rb)
  rb &= 0xFE
  rb |= 0x01
  board.WriteI2C(des_daisy1_Alias,0x1,0x1)
  time.sleep(0.04)
  if TS_CODE_DN >= 7:
      TS_CODE_DN = 7
  rb &= 0x8F
  rb &= 0xFE
  rb |= 0x01
  time.sleep(0.04)
## Hold Des DTG in reset
board.WriteI2C(desAlias0,0x40,0x50) #Select DTG Page
board.WriteI2C(desAlias0,0x42,0x6) #Hold Local Display Output Port 0 DTG in Reset
board.WriteI2C(desAlias0,0x41,0x62)
board.WriteI2C(desAlias0,0x42,0x6) #Hold Local Display Output Port 1 DTG in Reset
## Disable Stream Mapping
board.WriteI2C(desAlias0,0xe,0x3) #Select both Output Ports
board.WriteI2C(desAlias0,0xd0,0x0) #Disable FPD4 video forward to Output Port
board.WriteI2C(desAlias0,0xd7,0x0) #Disable FPD3 video forward to Output Port
## Setup DTG for port 0
board.WriteI2C(desAlias0,0x41,0x20)
board.WriteI2C(desAlias0,0x42,0x13) #Set up Local Display DTG BPP, Sync Polarities, and Measurement Type
board.WriteI2C(desAlias0,0x41,0x29) #Set Hstart
board.WriteI2C(desAlias0,0x42,0x80) #Hstart upper byte
board.WriteI2C(desAlias0,0x41,0x2a)
board.WriteI2C(desAlias0,0x42,0x50) #Hstart lower byte
board.WriteI2C(desAlias0,0x41,0x2f) #Set HSW
board.WriteI2C(desAlias0,0x42,0x40) #HSW upper byte
board.WriteI2C(desAlias0,0x42,0x20) #HSW lower byte
## Map video to display output
board.WriteI2C(desAlias0,0xd0,0xd) #Enable FPD_RX video forward to Output Port and Enable FPD_RX to Daisy Output 0
board.WriteI2C(desAlias0,0xd1,0xf) #Every stream forwarded on DC
board.WriteI2C(desAlias0,0xd6,0x0) #Send Stream 0 to Output Port 0 and Send Stream 0 to Output Port 1
board.WriteI2C(desAlias0,0xd7,0x0) #FPD3 to local display output mapping disabled
board.WriteI2C(desAlias0,0xe,0x1) #Select Port 0
## Configure 988 Display
board.WriteI2C(desAlias0,0x40,0x2c) #Configure OLDI/RGB Port Settings
board.WriteI2C(desAlias0,0x42,0x2f)
board.WriteI2C(desAlias0,0x42,0xc)
board.WriteI2C(desAlias0,0x40,0x2e) #Configure OLDI/RGB PLL
board.WriteI2C(desAlias0,0x41,0x8)
board.WriteI2C(desAlias0,0x42,0x25) #PLL_NUM23_16
board.WriteI2C(desAlias0,0x42,0xed) #PLL_NUM15_8
board.WriteI2C(desAlias0,0x42,0x8) #PLL_NUM7_0
board.WriteI2C(desAlias0,0x42,0xff) #PLL_DEN23_16
board.WriteI2C(desAlias0,0x42,0xff) #PLL_DEN15_8
board.WriteI2C(desAlias0,0x42,0xf6) #PLL_DEN7_0
board.WriteI2C(desAlias0,0x42,0x20) #PLL_NDIV
board.WriteI2C(desAlias0,0x41,0x2d)
board.WriteI2C(desAlias0,0x42,0x11) #TX_SEL_CLKDIV
## Release Des DTG reset
board.WriteI2C(desAlias0,0x42,0x4) #Release Local Display Output Port 0 DTG
board.WriteI2C(desAlias0,0x42,0x4) #Release Local Display Output Port 1 DTG
## Enable OLDI Output
board.WriteI2C(desAlias0,0x1,0x40) #OLDI Reset
board.WriteI2C(desAlias0,0x40,0x2c) #Enable OLDI/RGB
board.WriteI2C(desAlias0,0x41,0x2)
board.WriteI2C(desAlias0,0x42,0x10)
board.WriteI2C(desAlias0,0x41,0x20) #P0 TX_EN
board.WriteI2C(des_daisy1_Alias,0x40,0x50) #Select DTG Page
board.WriteI2C(des_daisy1_Alias,0x41,0x32)
board.WriteI2C(des_daisy1_Alias,0x42,0x6) #Hold Local Display Output Port 0 DTG in Reset
board.WriteI2C(des_daisy1_Alias,0x41,0x62)
board.WriteI2C(des_daisy1_Alias,0x42,0x6) #Hold Local Display Output Port 1 DTG in Reset
board.WriteI2C(des_daisy1_Alias,0xe,0x3) #Select both Output Ports
board.WriteI2C(des_daisy1_Alias,0xd0,0x0) #Disable FPD4 video forward to Output Port
board.WriteI2C(des_daisy1_Alias,0xd7,0x0) #Disable FPD3 video forward to Output Port
board.WriteI2C(des_daisy1_Alias,0x41,0x20)
board.WriteI2C(des_daisy1_Alias,0x42,0x53) #Set up Local Display DTG BPP, Sync Polarities, and Measurement Type
board.WriteI2C(des_daisy1_Alias,0x41,0x29) #Set Hstart
board.WriteI2C(des_daisy1_Alias,0x42,0x80) #Hstart upper byte
board.WriteI2C(des_daisy1_Alias,0x41,0x2a)
board.WriteI2C(des_daisy1_Alias,0x42,0x50) #Hstart lower byte
board.WriteI2C(des_daisy1_Alias,0x41,0x2f) #Set HSW
board.WriteI2C(des_daisy1_Alias,0x42,0x40) #HSW upper byte
board.WriteI2C(des_daisy1_Alias,0x41,0x30)
board.WriteI2C(des_daisy1_Alias,0x42,0x20) #HSW lower byte
board.WriteI2C(des_daisy1_Alias,0xd0,0xc) #Enable FPD_RX video forward to Output Port
board.WriteI2C(des_daisy1_Alias,0xd1,0xf) #Every stream forwarded on DC
board.WriteI2C(des_daisy1_Alias,0xd6,0x0) #Send Stream 0 to Output Port 0 and Send Stream 0 to Output Port 1
board.WriteI2C(des_daisy1_Alias,0xd7,0x0) #FPD3 to local display output mapping disabled
board.WriteI2C(des_daisy1_Alias,0xe,0x1) #Select Port 0
board.WriteI2C(des_daisy1_Alias,0x40,0x2c) #Configure OLDI/RGB Port Settings
board.WriteI2C(des_daisy1_Alias,0x41,0x0)
board.WriteI2C(des_daisy1_Alias,0x42,0x2f)
board.WriteI2C(des_daisy1_Alias,0x41,0x1)
board.WriteI2C(des_daisy1_Alias,0x40,0x2e) #Configure OLDI/RGB PLL
board.WriteI2C(des_daisy1_Alias,0x41,0x8)
board.WriteI2C(des_daisy1_Alias,0x42,0x25) #PLL_NUM23_16
board.WriteI2C(des_daisy1_Alias,0x42,0xed) #PLL_NUM15_8
board.WriteI2C(des_daisy1_Alias,0x42,0x8) #PLL_NUM7_0
board.WriteI2C(des_daisy1_Alias,0x42,0xff) #PLL_DEN23_16
board.WriteI2C(des_daisy1_Alias,0x42,0xff) #PLL_DEN15_8
board.WriteI2C(des_daisy1_Alias,0x42,0xf6) #PLL_DEN7_0
board.WriteI2C(des_daisy1_Alias,0x41,0x18)
board.WriteI2C(des_daisy1_Alias,0x42,0x20) #PLL_NDIV
board.WriteI2C(des_daisy1_Alias,0x41,0x2d)
board.WriteI2C(des_daisy1_Alias,0x42,0x12) #TX_SEL_CLKDIV
board.WriteI2C(des_daisy1_Alias,0x42,0x4) #Release Local Display Output Port 0 DTG
board.WriteI2C(des_daisy1_Alias,0x42,0x4) #Release Local Display Output Port 1 DTG
board.WriteI2C(des_daisy1_Alias,0x1,0x40) #OLDI Reset
board.WriteI2C(des_daisy1_Alias,0x40,0x2c) #Enable OLDI/RGB
board.WriteI2C(des_daisy1_Alias,0x41,0x2)
board.WriteI2C(des_daisy1_Alias,0x42,0x14)
board.WriteI2C(des_daisy1_Alias,0x41,0x2) #Toggle OLDI_SER_EN for Dual OLDI Mode
board.WriteI2C(des_daisy1_Alias,0x41,0x20) #P0 TX_EN
board.WriteI2C(des_daisy1_Alias,0x41,0x22) #P1 TX_EN
