DS90UB983-Q1: 983remap lane功能使用
Part Number: DS90UB983-Q1
dptx的phy的线序与标准的dp接口不同,是否可以使用remap功能将其对应映射。映射关系如下所示。DPTX phy线序与dp标准接口连接有问题,是否可以通过remap功能将lane序调整正确。
  • 感谢您对TI产品的关注!
    已经收到了您的案例,调查需要些时间,感谢您的耐心等待
  • 您好
    对于通道重映射、您能否确保写入 APB 寄存器0x30 (APB_LANE_REMAP)= 0x14E?
  • 可以确保 APB 寄存器0x30 (APB_LANE_REMAP)= 0x14E。
  • remap后使用1个lane进行link training不成功,4条lane可以成功,也可以显示图像。
  • 您好
    不知道您的意思。 您说1个信道不成功、但4个信道可能成功、您能否说明哪个信道的链路训练不成功、以及发生这种情况的频率? 您是否可以运行此脚本来读取983的 DP 训练状态和 MSA 值?
      Copyright 2018 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user who
      downloaded the software, his/her employer (which must be your employer) and
      Texas Instruments Incorporated (the "License"). You may not use this Software
      unless you agree to abide by the terms of the License. The License limits your
      use, and you acknowledge, that the Software may not be modified, copied or
      distributed unless embedded on a Texas Instruments microcontroller which is
      integrated into your product. Other than for the foregoing purpose, you may
      not use, reproduce, copy, prepare derivative works of, modify, distribute,
      perform, display or sell this Software and/or its documentation for any
      purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL TEXAS
      INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER LEGAL
      EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES INCLUDING BUT NOT
      LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE OR CONSEQUENTIAL
      DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT OF SUBSTITUTE GOODS,
      TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT
      LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
    devAddr=0x18
    print ("DP Lock Status")
    print board.APB_Read(0x0,0x400)*27, ("Rate")
    print board.APB_Read(0x0,0x404), ("Lanes")
    print hex(board.APB_Read(0x0,0x43c))
    print hex(board.APB_Read(0x0,0x440))
    print ("   ")
    print("H Res")
    print board.APB_Read(0x0,0x500)
    print("H POL")
    print board.APB_Read(0x0,0x504)
    print("H SYNC WIDTH")
    h_sync=board.APB_Read(0x0,0x508)
    print h_sync
    print("H BACK PORCH")
    H_Back = board.APB_Read(0x0,0x50C) - h_sync
    print H_Back
    print("H TOTAL")
    print board.APB_Read(0x0,0x510)
    print("V Res")
    print board.APB_Read(0x0,0x514)
    print("V POL")
    print board.APB_Read(0x0,0x518)
    print("V SYNC WIDTH")
    v_sync=board.APB_Read(0x0,0x51C)
    print v_sync
    print("V BACK PORCH ")
    v_back = board.APB_Read(0x0,0x520) - v_sync
    print v_back
    print("HV TOTAL")
    print board.APB_Read(0x0,0x524)
    print("MSA_MISC0")
    print board.APB_Read(0x0,0x528)
    print("MSA_MISC1")
    print board.APB_Read(0x0,0x52C)
    print("MSA_MVID")
    print board.APB_Read(0x0,0x530)
    print("MSA_NVID")
    print board.APB_Read(0x0,0x534)
    print("MSA_VBID")
    print board.APB_Read(0x0,0x538)
