TMDS1204: TMDS1204 and Spread Spectrum Clocking (SSC)
Part Number: TMDS1204
Other Parts Discussed in Thread: TMDS181
Hi:
When using the TMDS1204 chip, we encountered issues with FPGA reception while receiving HDMI 2.0 signals, which may be caused by input clock random jitter. This could potentially be due to spread spectrum modulation on the driver side.
Does the TMDS1204 support clock recovery functionality to correct both deterministic jitter and random jitter, thereby providing a clean clock output for FPGA use?
Is the TMDS181 capable of performing the same jitter correction as described above?
Thanks!
