Part Number: ISOW7841A-Q1
Other Parts Discussed in Thread: ISOW7841
目前我们正在使用ISOW7841A-Q1这个芯片,从规格书第9页,Iiso(out)应该是Viso测的驱动能力是127mA?
我准备用ISOW7841的Viso给其他元件供电(5V_input,5V_ouput),但规格书种没找到ISOW7841次级侧本身的电流功耗(1Mbps速率),所以不确定ISOW7841能否驱动其他元件,请告知ISOW7841次级侧本身的电流功耗,谢谢。
For ISOW7841A-Q1 datasheet P9, does Iiso(out)=127mA mean the components viso output supply capability?
I will use ISOW7841 Viso for other component at the same time(5V_input,5V_ouput), but I do not find ISOW7841 itself Iiso current supply (with wave clock input of 1Mbps & without other loader)? so I am not sure ISOW7841 can drive other components. can you tell me Iiso supply requirement of ISOW7841? thanks
