Part Number: TXB0104
Dear TI members:
When I use TXB0104 in SPI(3.3V-1.5V),and put a 2k pull-dow resistor in IO,the Voh become lower and shake。
I found the reason that TXB0104 can't diver high load and it will reduce the level of the output in your datasheet.
But I still want to know why the output signal repeatedly rise and fall.
Do you have some idea about that? Thanks.
