Part Number: TXS0108E
Other Parts Discussed in Thread: TXB0104, TXB0108
Is the level conversion chip of TXS0108E suitable for I2S signal conversion? After knowing that the driving ability of the TXS01xx series is very weak, it can be said that it is not. Does that mean that it can only be used in other open-drop circuits such as I2C. If it needs to be used in the level conversion of I2S, can the TXB series be used? Or is there a more suitable model to recommend? thanks.
