hello!
I have purchased the model TXS0108ENMER of your company.
When I measured the volume, I found that the thickness was not consistent with the PDF. I also found that the thickness was not consistent with the PDF when I bought other batches. The quantity was 0.9mm, and the maximum value of PDF was 0.8mm.
Is the PDF not updated?
