i convert the LSF0108's IBIS model to pspice model,found that LSF0108's each pin is one single component,makes me can't use it to draw schematic,and run function simulate.how can i solve it?
Hi Jack,
The IBIS model TI provides is not intended to be converted to PSPICE. Typically an IBIS file is only going to provide the IO Buffer characteristics, usually used with signal integrity analysis to judge signal quality. A PSpice model is a functional mode which unfortunately we do not have.
I'm sorry I can't create it's Pspice model, you can check with the E2E English forum to see if an engineer can help you create it.
E2E English forum link:https://e2e.ti.com/support/logic-group/logic/f/logic-forum
