[参考译文] CC3220SF-LAUNCHXL:没有适用于 cc3220sf-launchxl 的 GNU Arm 编译器
Guru**** 2885230 points
Other Parts Discussed in Thread: CC3220SF
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1481278/cc3220sf-launchxl-no-gnu-arm-compilers-for-cc3220sf-launchxl
器件型号:CC3220SF-LAUNCHXL
Thread 中讨论的其他器件:CC3220SF
请查看以下详细信息...
network_terminal_CC3220SF_LAUNCHXL_FreeRTOS_gcc
当前未安装支持器件"CC3220SF"的 GNU Arm 编译器!
Im 正在转发有关此问题的任何回复
