[参考译文] TMS570LC4357:LIN1/SCI1空闲线路中断
Guru**** 2609955 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1471664/tms570lc4357-lin1-sci1-idle-line-interrupt
器件型号:TMS570LC4357
我想询问是否可以在 LIN1/SC1模块上接收到数据包后生成空闲线路中断?  我看到可以使用  SCI 设置 中断寄存器(SCISETINT)中的设置超时 INT 位、但触发中断所需的4秒时间过长。
