[参考译文] LP-MSPM0G3507:从比较器触发时、ADC 结果不正确
Guru**** 2767785 points
Other Parts Discussed in Thread: MSPM0G1507
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1493291/lp-mspm0g3507-incorrect-adc-result-when-triggered-from-comparator
器件型号:LP-MSPM0G3507
主题中讨论的其他器件:MSPM0G1507
此问题似乎  已解决:e2e.ti.com/.../lp-mspm0l1306-incorrect-adc-result-after-re-enable-conversion-adc-is-triggered-by-comparator-event。 我现在正在使用 MSPM0G1507处理另一个项目。 MSPM0G 是否存在相同的问题?
    [quote userid="559305" url="~/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1493291/lp-mspm0g3507-incorrect-adc-result-when-triggered-from-comparator MSPM0G 是否存在同样的问题?
