[参考译文] AM2431:如何设置 TI CCS IDE (QSPI、EEPROM、FLASH example.syscfg)
Guru**** 2931100 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1501821/am2431-how-to-set-up-ti-ccs-ide-qspi-eeprom-flash-example-syscfg
器件型号:AM2431
尊敬的专家:
客户希望将 S25FL064L_64_Mbit_8_Mbyte 用作外部闪存。
如何在 TI CCS IDE (QSPI、EEPROM、FLASH example.syscfg)中设置该函数?
Daniel
