[参考译文] AM263P4-Q1:构建 SDK 示例工程时出错
Guru**** 3003130 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1514141/am263p4-q1-error-while-building-sdk-example-project
器件型号:AM263P4-Q1
您好、专家、
我已经安装了 python 和 openssl、但在工程编译过程中仍然遇到错误。 错误日志如下所示。
[101]C:/ti/ccs2011/ccs/utils/bin/gmake -C C:\Felix\Working_Record\CCS_20_Workspace\swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang -f makefile_ccs_bootimage_gen OUTNAME=swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang PROFILE=Debug MCU_PLUS_SDK_PATH=C:/ti/mcu_plus_sdk_am263px_10_01_00_34 CG_TOOL_ROOT=C:/ti/ccs2011/ccs/tools/compiler/ti-cgt-armllvm_4.0.2.LTS CCS_INSTALL_DIR=C:\ti\ccs2011\ccs\ CCS_IDE_MODE=desktop DEVICE=am263px
[102] Boot image: am263px:r5fss0-0:nortos:ti-arm-clang C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.appimage  ...
[103]C:\ti\ccs2011\ccs\/tools/node/node C:/ti/mcu_plus_sdk_am263px_10_01_00_34/tools/boot/out2rprc/elf2rprc.js Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.out >> Debug/temp_stdout_Debug.txt
[104]C:\ti\ccs2011\ccs\/utils/cygwin/cp swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc
[105]C:\ti\ccs2011\ccs\/utils/cygwin/cp C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc_tmp
[106]C:\ti\ccs2011\ccs\/utils/cygwin/rm -f C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc
[107]C:/ti/mcu_plus_sdk_am263px_10_01_00_34/tools/boot/xipGen/xipGen.exe -i C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc_tmp -o C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc -x C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc_xip --flash-start-addr 0x60000000 -v > Debug/temp_stdout_Debug.txt
[108]C:\ti\ccs2011\ccs\/tools/node/node C:/ti/mcu_plus_sdk_am263px_10_01_00_34/tools/boot/multicoreImageGen/multicoreImageGen.js --devID 55 --out C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.appimage C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc@0  >> Debug/temp_stdout_Debug.txt
[109]C:\ti\ccs2011\ccs\/tools/node/node C:/ti/mcu_plus_sdk_am263px_10_01_00_34/tools/boot/multicoreImageGen/multicoreImageGen.js --devID 55 --out C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.appimage_xip C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc_xip@0  >> Debug/temp_stdout_Debug.txt
[110]C:\ti\ccs2011\ccs\/utils/cygwin/rm -f C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc_tmp
[111] Boot multi-core ELF image: am263px:r5fss0-0:nortos:ti-arm-clang C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.mcelf ...
[112]python C:/ti/mcu_plus_sdk_am263px_10_01_00_34/tools/boot/multicore-elf/genimage.py --core-img=0:Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.out --output=C:/Felix/Working_Record/CCS_20_Workspace/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang/Debug/swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.mcelf --merge-segments=true --tolerance-limit=0 --ignore-context=false --xip=0x60000000:0x68000000 --xlat="" --max_segment_size=8192
[113]makefile_ccs_bootimage_gen:87: recipe for target 'all' failed
[114]Traceback (most recent call last):
[115]  File "C:\ti\mcu_plus_sdk_am263px_10_01_00_34\tools\boot\multicore-elf\genimage.py", line 39, in <module>
[116]    from modules.multicoreelf import MultiCoreELF, OTFAECCMProcessor
[117]  File "C:\ti\mcu_plus_sdk_am263px_10_01_00_34\tools\boot\multicore-elf\modules\multicoreelf.py", line 45, in <module>
[118]    from .gmac import enc_process_data
[119]  File "C:\ti\mcu_plus_sdk_am263px_10_01_00_34\tools\boot\multicore-elf\modules\gmac.py", line 37, in <module>
[120]    from cryptography.hazmat.primitives.ciphers import Cipher, algorithms, modes
[121]ModuleNotFoundError: No module named 'cryptography'
[122]gmake[3]: *** [all] Error 1
[123]makefile:168: recipe for target 'post-build' failed
[124]gmake[2]: [post-build] Error 2 (ignored)
[125]**** Build Finished
由于此错误、会生成.xer5f、但如果使用该.xer5f 文件进行调试、则在加载程序时报告以下错误。
Cortex_R5_0: AM263Px_ZCZ_S
Cortex_R5_0: Board Selected : CC
Cortex_R5_0: Part Selected : Standard
Cortex_R5_0: GEL: Encountered a problem loading file: C:\Users\a0220432\AppData\Local\Temp\ti_cloud_storage\swap_to_b_am263px-cc_r5fss0-0_nortos_ti-arm-clang.rprc Could not determine target type of file
请帮助调查此问题。
