[参考译文] MSPM0G3519:LIN 驱动器是否支持针对 LIN 从节点的 LIN 唤醒信号检测
Guru**** 3003880 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1510004/mspm0g3519-is-lin-driver-support-lin-wakeup-signal-detection-for-lin-slave-node
器件型号:MSPM0G3519
LIN 唤醒信号检测功能在 LIN 从驱动器中是否可用? 它如何检测从节点的 LIN 唤醒信号?
