[参考译文] TMDSCNCD263:这是否与台风兼容?
Guru**** 2933630 points
Other Parts Discussed in Thread: TMDSCNCD263
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1529973/tmdscncd263-is-this-compatible-with-typhoon
器件型号:TMDSCNCD263
此 AM263x 控制卡是否可与任何 Typhoon HIL 产品配合使用: https://www.typhoon-hil.com/products/hil-interfaces/hil-ti-interface-cards/hil-ti-dsp-180-interface/
