[参考译文] LP-MSPM0G3507:将工程刷写到电路板失败、i'm 也无法执行恢复出厂设置。
Guru**** 2933740 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1531368/lp-mspm0g3507-flashing-the-project-to-the-board-is-failing-and-i-m-also-unable-to-perform-a-factory-reset
器件型号:LP-MSPM0G3507
    您好感谢您提出的问题、您的项目中是否有看门狗计时器?
