[参考译文] MSPM0L1227-Q1:是否可以通过 RTC 中断从待机模式恢复?
Guru**** 2933630 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1535915/mspm0l1227-q1-is-it-possible-to-resureme-from-stanby-mode-by-rtc-interrupt
器件型号:MSPM0L1227-Q1
尊敬的专家:
ITO
(04490e81-c4c6-4c0D-8b26-27752cec18be)
