[参考译文] TMDX570LC43HDK:写入 TMDX570LC43HDK 上的闪存存储
Guru**** 2933740 points
Other Parts Discussed in Thread: TMDX570LC43HDK
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1546237/tmdx570lc43hdk-write-to-flash-storage-on-tmdx570lc43hdk
部件号:TMDX570LC43HDK
您好:
是否有用于将数据写入内置闪存存储(TMDX570LC43HDK 板)的示例工程。 例如、我想保存一些有关 FW 映像的元数据、稍后可供应用使用。
-萨贝斯瓦
