[参考译文] TMS570LS0714:Gio 驱动强度
Guru**** 2905440 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1567302/tms570ls0714-gio-drive-strength
器件型号:TMS570LS0714
所有数据表中的电气特性我看起来高低、但在此器件上找不到 GIO 的驱动强度。 有人知道这个价值吗?
