[参考译文] MSPM0L1305:基于 ARM 的微控制器论坛
Guru**** 2914110 points
Other Parts Discussed in Thread: SYSCONFIG, MSPM0L1306, UNIFLASH
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1572789/mspm0l1305-arm-based-microcontrollers-forum
部件号:MSPM0L1305
Thread 中讨论的其他器件:SYSCONFIG、MSPM0L1306UNIFLASH
您好:
我的 MSPM0L1306 应用大于 4K、位于 0x0000。 如果我尝试使用辅助 BSL 加载此映像、它会覆盖辅助 BSL 所在的闪存区域。 我尝试了按照 SLAAE88D MSPM0 引导加载程序实施第 5.3.1 节中的说明将辅助 BSL 重定位到 0x4000、包括将备用 BSL 地址的 SysConfig 设置更改为 0x4041、但不起作用。 我还需要做什么?
Frank
    您好 Frank、
    您能否分享链接器 (cmd) 文件的外观?
    我建议也参考 SDK 中的 secondary_bsl_uart 示例(这适用于 MSPM0L1306):
     * Copyright (c) 2024, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    -uinterruptVectors
    /* Memory Map        */
    MEMORY
    	FLASH_SBSL_INTVEC(RWX)  :	 org = 0x00001000,      len = 0x00000040,
    	FLASH_SBSL_START(RWX)   :	 org = 0x00001040,      len = 0x00000040,
    	FLASH_SBSL(RWX)   		:	 org = 0x00001080,      len = 0x00001F80,
        SRAM(RW)				:    org = 0x20000000,      len = 0x00001000,
        BCR_CFG		 		    : 	 org = 0x41C00000,      len = 0x00000080,
        BSL_CFG				    : 	 org = 0x41C00100,      len = 0x00000080,
        FACTORY_CFG		  		: 	 org = 0x41C40000,      len = 0x00000200,
    /* Section Configuration                                                      */
    SECTIONS
    	.intvecs			: PALIGN(8) {} > FLASH_SBSL_INTVEC
    	.sblStart			: PALIGN(8) {} > FLASH_SBSL_START
        GROUP(FLASH_MEMORY) {
            .text          	: PALIGN(8) {}
            .const         	: PALIGN(8) {}
            .cinit         	: PALIGN(8) {}
            .rodata			: PALIGN(8) {}
        } > FLASH_SBSL
        GROUP(SRAM) {
        	.vtable 		: {}
            .data          	: {}
            .bss           	: {}
       } > SRAM
    	.TI.ramfunc   : load = FLASH_SBSL, palign(8), run=SRAM, table(BINIT)
        .stack  :   > SRAM (HIGH) SIZE(BSL_CI_stackSize)
        .factoryConfig          : {} > FACTORY_CFG
        .BCRConfig              : {} > BCR_CFG
        .BSLConfig              : {} > BSL_CFG
    如果使用 SysConfig、请确保已禁用链接器文件的生成。 否则、每次编译工程时都会重写该文件。
    Owen
    尊敬的 Owen:
    是的。 在 Syscongi 中与该示例工程默认禁用链接文件生成。 下面是我对 mspm0l1306.cmd 的修改,我从  MSPM0 引导加载程序实现第 5.3.1 节复制了该修改 。
    Frank
    *版权所有 (c) 2024, Texas Instruments Incorporated
    保留所有权利。
    *重新分发和使用源代码和二进制格式,无论有无
    *允许修改,前提是满足以下条件
    *符合:
    **源代码的重新分发必须保留上述版权
    *声明、本条件列表和以下免责声明。
    *二进制形式的再发行必须复制上述版权
    *声明、本条件列表和中的下述免责声明
    *分发时提供的文件和/或其他材料。
    ** Texas Instruments Incorporated 的名称和名称均不相同
    *其贡献者可用于认可或推广衍生产品
    *未经事先书面许可,从本软件下载。
    *本软件由版权持有人和贡献者“按原样“提供
    “服务“以“按现状“和“按可得到“的基础提供。
    *对特定的适销性和适用性的暗示保证
    *目的不受限制。 在任何情况下,著作权人或
    *贡献者对任何直接、间接、附带、特别、
    但对服务不作任何明示或暗示的保证,包括但不限于秒杀网服务的适用性、没有错误或疏漏、持续性
    *替代商品或服务的采购;使用、数据或利润的损失;
    *或业务中断)然而引起的,并根据任何责任理论,
    *无论在合同中,严格责任,还是侵权(包括疏忽或
    以任何方式产生于本软件的使用,
    *即使被告知可能发生此类损害。
    -uinterruptVectors
    /*存储器映射*/
    移动数据
    FLASH_SBSL_INTvec (rwx):org = 0x00004000、len = 0x00000040、
    FLASH_SBSL_START (RWX):org = 0x00004040、len = 0x00000040、
    FLASH_SBSL (rwx):org = 0x00004080、len = 0x00001F80、
    SRAM (RW):org = 0x20000000、len = 0x00001000、
    BCR_CFG:org = 0x41C00000、len = 0x00000080、
    BSL_CFG:org = 0x41C00100、len = 0x00000080、
    FACTORY_CFG:org = 0x41C40000、len = 0x00000200、
    /*段配置*/
    很重要
    .intvecs:PALIGN(8){}> FLASH_SBSL_INTvec
    .sblStart:PALIGN(8){}> FLASH_SBSL_START
    GROUP (FLASH_MEMORY){
    .text : PALIGN(8){}
    .const : PALIGN(8){}
    .cinit:PALIGN(8){}
    .rodata : PALIGN(8){}
    }> FLASH_SBSL
    GROUP (SRAM){
    .vtable :{}
    .data :{}
    .bss :{}
    }> SRAM
    .TI.ramfunc:load = FLASH_SBSL、palign (8)、run=SRAM、table (BINIT)
    .stack :> SRAM (high) size (BSL_CI_STACKSIZE )
    .factoryConfig :{}> factory_CFG
    .BCRConfig :{}> BCR_CFG
    .BSLSConfig:{}> BSL_CFG
    您好 Frank、
    您的链接器文件看起来不错。 当您说它不起作用时、您是指辅助 BSL 仍从 0x1080 开始?
    您是否尝试过重新编译整个项目? “Project">"Rebuild Project"“ Project"</s>“ “
    您是否可以共享整个项目?
    Owen
    您好 Frank、
    我还想补充一点、更改 NONMAIN 时必须执行 POR。 在完成此操作之前、对 NONMAIN 的任何更改都不会生效。
    我刚好能够调整 SDK 示例、将 BSL 移至从 0x4000 开始。
    Owen
    尊敬的 Owen:
    是的、我总是执行 Rebuild Project。 当我尝试加载辅助 BSL 大于 1K 的映像时、Uniflash 会收到以下错误消息(在小于 1K 时有效)。 我附上了一个辅助 BSL 工程和 GPIO 工程的 zip 文件。 对于 GPIO 工程、我在 gpio_toggle_output.c 中添加了一些代码以使映像大小大于 1K(const uint8_t dummy_data[4024]={0};) 我相信我做了一些错误的事情,但不能弄清楚。
    Frank
    2025年10月3日、8:16:00 AM] [info] Cortex-M0P:MSPM0L1306(引导加载程序)
    [引导 2025年10月3日 加载程序、8:16:00 AM] [info] Cortex-M0P:正在调用引导加载程序…
    2025年10月3日、8:16:04 AM] [info] CORTEX_M0P:
    [BSL、8:16:04 AM] [info] Cortex-M0P:2025年10月3日 已连接
    [BSL、8:16:04 AM] [info] Cortex-M0P:命令解释器版本:[0x0001]构建 ID:[0x0001]应用版本:[0x00000000]活动插件接口版本:[0x1331] BSL 最大缓冲器大小:[0x0704] BSL 缓冲器起始地址:[0x20000180] BCR 配置 ID:[0x00000x0001] 2025年10月3日 配置 ID [0x00000x0001]
    [BSL、8:16:04 AM] [info] Cortex-M0P:2025年10月3日 密码正确!
    [DataBlock 2025年10月3日、8:16:04 AM] [info] Cortex-M0P:从 0x0 开始擦除包含 DataBlock 的扇区成功!
    [DataBlock 2025年10月3日、8:16:04 AM] [info] Cortex-M0P:从 0x6E4 开始擦除包含 DataBlock 的扇区成功!
    2025年10月3日、8:16:04 AM] 【错误】Cortex-M0P:
    [CORTEX](2025年10月3日、8:16:05 AM )【错误】CORTEX_M0P:[ERROR_MESS]Process is Failed!
    e2e.ti.com/.../secondary_5F00_bsl_5F00_uart_5F00_LP_5F00_MSPM0L1306_5F00_nortos_5F00_ticlang.zipe2e.ti.com/.../5756.gpio_5F00_toggle_5F00_output_5F00_LP_5F00_MSPM0L1306_5F00_nortos_5F00_ticlang.zip
    您好 Frank、
    感谢您与我分享这些项目。
    该过程当前失败的原因是在 SysConfig 中配置了 SWP。 下部扇区设置为 0xFFFFF00F。  这保护了位于 0x1000 处时包含辅助 BSL 的闪存区域。 由于我们移动了它、我们需要相应地移动 SWP。 我认为它现在应该是 0xFF00FFFF。 这保护扇区 16-23。
    现在我遇到了有关 8 位对齐的问题、但我认为它与应用程序 Hex 文件无关。 我认为它可能与 BSL 有关、但我必须研究它并返回给您星期一。
    Owen
    谢谢!!! 我期待您的发现。
    Frank
    您好 Frank、
    您是否能够复制我在您的最终观察到的行为?
    Owen
    尊敬的 Owen:
    是的、在将 SWP 更改为 0xFF00FFFF 后、我能够进行复制。
    2025年10月6日、10:14:26 AM] [info] Cortex-M0P:MSPM0L1306(引导加载程序)
    [引导 2025年10月6日 加载程序、10:14:26 AM] [info] Cortex-M0P:正在调用引导加载程序…
    2025年10月6日、10:14:29 AM] [info] Cortex-M0P:
    [BSL、10:14:29 AM] [info] Cortex-M0P:2025年10月6日 已连接
    [BSL、10:14:29 AM] [info] Cortex-M0P:命令解释器版本:[0x0001]构建 ID:[0x0001]应用版本:[0x00000000]活动插件接口版本:[0x1331] BSL 最大缓冲器大小:[0x0704] BSL 缓冲器起始地址:[0x20000180] BCR 配置 ID:[0x00000x0001] 2025年10月6日 配置 ID [0x00000x0001]
    [BSL、10:14:29 AM] [info] Cortex-M0P:2025年10月6日 密码正确!
    [DataBlock 2025年10月6日、10:14:29 AM] [info] Cortex-M0P:从 0x0 开始擦除包含 DataBlock 的扇区成功!
    [DataBlock 2025年10月6日、10:14:29 AM] [info] Cortex-M0P:从 0x6E4 开始擦除包含 DataBlock 的扇区成功!
    [DataBlock 2025年10月6日、10:14:29 AM] [info] Cortex-M0P:从 0xDC8 开始擦除包含 DataBlock 的扇区成功!
    [MCU 2025年10月6日、10:14:29 AM] [info] Cortex-M0P:擦除存储器时长:0.09514s
    [NVM 2025年10月6日、10:14:31 AM] 【错误】Cortex-M0P:[ERROR]闪存编程的起始地址或数据长度未进行 8 字节对齐!
    [CORTEX](2025年10月6日、10:14:31 AM )【错误】CORTEX_M0P:[ERROR_MESS]Process is Failed!
    尊敬的 Owen:
    我将 bsl_host_mcu_to_mscpm0l11_xx_l13xxI_target_uart_LPxxx 示例移植到 Windows、并在 SWP 设置为 0xFF00FFFF 时可以正常加载我的映像!! 不确定这是否指向 Uniflash 出现问题
    Frank
    您好 Frank、
    实现 SWP 的原因是为了防止写入 BSL。 除非您刷写的程序足够大、足以写入 BSL 或尝试写入 SWP 存储器、否则它不会导致问题。 我当前正在查看辅助 BSL 代码以了解是否还有任何其他需要更改的内容。
    Owen
