[参考译文] TM4C1294NCPDT:ETH PHY — 电流或电压模式?
Guru**** 2914580 points
Other Parts Discussed in Thread: TM4C1294NCPDT
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1573400/tm4c1294ncpdt-eth-phy---current-or-voltage-mode
器件型号:TM4C1294NCPDT
 TM4C1294NCPDT 中的 ETH PHY 是电流模式还是电压模式 PHY?
Brian
