[参考译文] AM2612:"No Module named struct"on clean install / build of SDK example
Guru**** 2916330 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1580097/am2612-no-module-named-construct-on-clean-install-build-of-sdk-example
器件型号:AM2612
您好、ASM 团队:
尝试在全新安装的 10_02_00_15 SDK 上构建一个简单的 GPIO 切换程序后、我收到以下错误。 我们以前见过这种情况吗?  image.png
祝您一切顺利、
Ethan cope
