[参考译文] AM263P4:EtherCAT(从器件和/或主器件)和 TSN 配置文件:
Guru**** 2930900 points
Other Parts Discussed in Thread: LP-AM263P
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1587765/am263p4-ethercat-slave-and-or-master-and-tsn-profiles
器件型号: AM263P4
主题中讨论的其他器件: LP-AM263P
  • 您是否有关于 EtherCAT(从站和/或主站)的任何 SDK 或应用手册?
  • 您是否有任何支持以下 TSN 配置文件的 SDK 或应用手册:
    –802.1AS (PTP)
    –802.1Qbv(计划流量)
