[参考译文] TM4C1294NCPDT:通过 LAN 接口实现 HTTPS 客户端
Guru**** 3003130 points
Other Parts Discussed in Thread: TM4C1294NCPDT
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1590533/tm4c1294ncpdt-https-client-implementation-through-lan-interface
器件型号: TM4C1294NCPDT
您好、
TM4C1294NCPDT
tirtos_tivac_2_01_00_03
任何人都实施/尝试了基于 LAN 的 HTTPS 客户端、即向 HTTPS 服务器发送数据
是否可以这样做?
请发布您的体验、这会很有帮助
