[参考译文] AM263P4:将 HS-SE FS 器件转换为 HS SE 器件
Guru**** 3003130 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1592271/am263p4-converting-hs-fs-device-in-to-hs-se-device
器件型号: AM263P4
是否有任何关于如何将 HS-SE FS 器件转换为 HS-SE 器件的录制资源?
Shashank B
