[参考译文] AM2732:AWR2243ABGABLRQ1 请单独推荐具有引脚对引脚完全兼容并且可以完全替换每个型号的工业级版本型号
Guru**** 3008210 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1634727/am2732-awr2243abgablrq1-please-recommend-separately-the-industrial-grade-version-models-that-are-fully-compatible-in-pin-to-pin-terms-and-can-completely-replace-each-o
部件号: AM2732
除汽车级和工业级上的差异外、AM2732CDRFHQZCERQ1 和 AM2732CDRFHQZCERQ1 是否存在完全引脚对引脚兼容性和完全功能替代的可能性?
