[参考译文] AM2612:带有 RGMII 接口的 DP83822 演示代码
Guru**** 2999690 points
Other Parts Discussed in Thread: AM2612
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1661561/am2612-dp83822-demo-code-with-rgmii-interface
器件型号: AM2612
您好的团队、
我们的 AM2612 SDK 仅包括用于 RMII 接口的 DP83822 示例代码。 您是否有可用的 RGMII 示例代码?
Eileen
