器件型号: AM2634-Q1
主题: SysConfig 中讨论的其他器件
您好:
SysConfig 图形用户界面。
按照此处 https://software-dl.ti.com/mcu-plus-sdk/esd/AM263X/latest/exports/docs/api_guide_am263x/OPTIMIZING_APPLICATIONS_WITH_MCU_SDK.html#CHAPTER_OPTIMIZATION_SECTION_5 中的建议 并设置 DebugP_assert_enabled=0 或 DebugP_LOG_enabled=0 会生成默认 SDK 操作访问多个文件的编译错误。
例如、
Arm Compiler - building file: "syscfg/ti_drivers_open_close.c""C:/ti/ti_cgt_arm_llvm_4.0.4.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Os -I"C:/ti/ti_cgt_arm_llvm_4.0.4.LTS/include/c" -I"C:/ti/mcu_plus_sdk_am263x_26_00_00_06/source" -DSOC_AM263X -DOS_NORTOS -DDebugP_ASSERT_ENABLED=0 -g -Wall -Werror -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"syscfg/ti_drivers_open_close.d_raw" -MT"syscfg/ti_drivers_open_close.o" -I"C:/Users/workspace_ccstheia/mcspi_loopback_interrupt_lld/Release/syscfg" -o"syscfg/ti_drivers_open_close.o" "syscfg/ti_drivers_open_close.c"[2]syscfg/ti_drivers_open_close.c:70:13: error: variable 'status' set but not used [-Werror,-Wunused-but-set-variable] 70 | int32_t status = MCSPI_STATUS_SUCCESS; | ^[3]syscfg/ti_drivers_open_close.c:86:13: error: variable 'status' set but not used [-Werror,-Wunused-but-set-variable] 86 | int32_t status = MCSPI_STATUS_SUCCESS; | ^2 errors generated.
Eugene
