[参考译文] TM4C129XNCZAD:向 TM4C129XNCZADI3添加额外的柱塞
Guru**** 2538950 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1078780/tm4c129xnczad-adding-additional-ram-to-tm4c129xnczadi3
部件号:TM4C129XNCZAD
 是否可以向 TM4C129XNCZADI3添加额外的 RAM (70V06L20PFGI8)。 如果是,则所有 GPIO 引脚都支持该功能。
