[参考译文] TM4C1236H6PM:TM4C1236H6PMI 和 TM4C1236H6PMI7之间有何区别?
Guru**** 2526700 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1078051/tm4c1236h6pm-what-is-the-difference-between-tm4c1236h6pmi-and-tm4c1236h6pmi7
部件号:TM4C1236H6PM
尊敬的
  作为标题,请告诉我  TM4C1236H6PMI TM4C1236H6PMI7之间的区别
非常感谢。
