[参考译文] TM4C129ENCZAD:引脚兼容替换件
Guru**** 2539500 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1092145/tm4c129enczad-pin-compatible-replacement
部件号:TM4C129ENCZAD
 TM4C129ENCZADT3有哪些引脚兼容替换件?
Allan
    您好,Allan,
    它靠近超集设备和高温机型,因此只有三个选项:
    • TM4C129LNZADT3
    • TM4C129XNCZADT3
    • TM4C129XNCZADT3R
    此致,
    Ralph Jacobi
