Other Parts Discussed in Thread: TM4C129ENCZAD
我有一个 TM4C129ENCZAD 微控制器、用于通过 Telnet 控制 GPIO。 我已经修改了 shell 环境、通过 telnet 通过一些简单的命令来控制 GPIO 输出。
使用以下代码关闭了中的 GPIO、
static void open(char *str)
if (str[1] == '0'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_6, 0);
shell_output("<0>","");
if (str[1] == '1'){
ROM_GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, 0);
if (str[1] == '2'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_4, 0);
if (str[1] == '3'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_4, 0);
if (str[1] == '4'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_6, 0);
if (str[1] == '5'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_1, 0);
if (str[1] == '6'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_3, 0);
if (str[1] == '7'){
ROM_GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_1, 0);
if (str[1] == '8'){
ROM_GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_7, 0);
if (str[1] == '9'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_2, 0);
if (str[1] == 'A'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_1, 0);
if (str[1] == 'B'){
ROM_GPIOPinWrite(GPIO_PORTK_BASE, GPIO_PIN_0, 0);
if (str[1] == 'C'){
ROM_GPIOPinWrite(GPIO_PORTK_BASE, GPIO_PIN_2, 0);
if (str[1] == 'D'){
ROM_GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, 0);
if (str[1] == 'E'){
ROM_GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_5, 0);
if (str[1] == 'F'){
ROM_GPIOPinWrite(GPIO_PORTJ_BASE, GPIO_PIN_6, 0);
if (str[1] == 'G'){
ROM_GPIOPinWrite(GPIO_PORTR_BASE, GPIO_PIN_5, 0);
if (str[1] == 'H'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, 0);
if (str[1] == 'I'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0);
if (str[1] == 'J'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_6, 0);
使用 以下代码打开 GPIO 引脚、
static void close(char *str)
if (str[1] == '0'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_6, GPIO_PIN_6);
shell_output("<1>","");
if (str[1] == '1'){
ROM_GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, GPIO_PIN_5);
if (str[1] == '2'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_4, GPIO_PIN_4);
if (str[1] == '3'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_4, GPIO_PIN_4);
if (str[1] == '4'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_6, GPIO_PIN_6);
if (str[1] == '5'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_1, GPIO_PIN_1);
if (str[1] == '6'){
ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_3, GPIO_PIN_3);
if (str[1] == '7'){
ROM_GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_1, GPIO_PIN_1);
if (str[1] == '8'){
ROM_GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_7, GPIO_PIN_7);
if (str[1] == '9'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_2, GPIO_PIN_2);
if (str[1] == 'A'){
ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_1, GPIO_PIN_1);
if (str[1] == 'B'){
ROM_GPIOPinWrite(GPIO_PORTK_BASE, GPIO_PIN_0, GPIO_PIN_0);
if (str[1] == 'C'){
ROM_GPIOPinWrite(GPIO_PORTK_BASE, GPIO_PIN_2, GPIO_PIN_2);
if (str[1] == 'D'){
ROM_GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, GPIO_PIN_6);
if (str[1] == 'E'){
ROM_GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_5, GPIO_PIN_5);
if (str[1] == 'F'){
ROM_GPIOPinWrite(GPIO_PORTJ_BASE, GPIO_PIN_6, GPIO_PIN_6);
if (str[1] == 'G'){
ROM_GPIOPinWrite(GPIO_PORTR_BASE, GPIO_PIN_5, GPIO_PIN_5);
if (str[1] == 'H'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, GPIO_PIN_2);
if (str[1] == 'I'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, GPIO_PIN_3);
if (str[1] == 'J'){
ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_6, GPIO_PIN_6);
使用以下代码检查 GPIO 引脚、
static void status(char *str)
if (str[1] == '0')
if (ROM_GPIOPinRead(GPIO_PORTE_BASE, GPIO_PIN_6))
else
if (str[1] == '1')
if (ROM_GPIOPinRead(GPIO_PORTB_BASE, GPIO_PIN_5))
else
if (str[1] == '2')
if (ROM_GPIOPinRead(GPIO_PORTE_BASE, GPIO_PIN_4))
else
if (str[1] == '3')
if (ROM_GPIOPinRead(GPIO_PORTD_BASE, GPIO_PIN_4))
else
if (str[1] == '4')
if (ROM_GPIOPinRead(GPIO_PORTD_BASE, GPIO_PIN_6))
else
if (str[1] == '5')
if (ROM_GPIOPinRead(GPIO_PORTD_BASE, GPIO_PIN_1))
else
if (str[1] == '6')
if (ROM_GPIOPinRead(GPIO_PORTD_BASE, GPIO_PIN_3))
else
if (str[1] == '7')
if (ROM_GPIOPinRead(GPIO_PORTQ_BASE, GPIO_PIN_1))
else
if (str[1] == '8')
if (ROM_GPIOPinRead(GPIO_PORTB_BASE, GPIO_PIN_7))
else
if (str[1] == '9')
if (ROM_GPIOPinRead(GPIO_PORTE_BASE, GPIO_PIN_2))
else
if (str[1] == 'A')
if (ROM_GPIOPinRead(GPIO_PORTE_BASE, GPIO_PIN_1))
else
if (str[1] == 'B')
if (ROM_GPIOPinRead(GPIO_PORTK_BASE, GPIO_PIN_0))
else
if (str[1] == 'C')
if (ROM_GPIOPinRead(GPIO_PORTK_BASE, GPIO_PIN_2))
else
if (str[1] == 'D')
if (ROM_GPIOPinRead(GPIO_PORTC_BASE, GPIO_PIN_6))
else
if (str[1] == 'E')
if (ROM_GPIOPinRead(GPIO_PORTC_BASE, GPIO_PIN_5))
else
if (str[1] == 'F')
if (ROM_GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_6))
else
if (str[1] == 'G')
if (ROM_GPIOPinRead(GPIO_PORTR_BASE, GPIO_PIN_5))
else
if (str[1] == 'H')
if (ROM_GPIOPinRead(GPIO_PORTH_BASE, GPIO_PIN_2))
else
if (str[1] == 'I')
if (ROM_GPIOPinRead(GPIO_PORTH_BASE, GPIO_PIN_3))
else
if (str[1] == 'J')
if (ROM_GPIOPinRead(GPIO_PORTH_BASE, GPIO_PIN_6))
else
我需要尽快打开/关闭 GPIO 引脚、但切换需要大约750毫秒。
在计算机中、我将通过 C#程序发送 telnet 命令来打开和关闭 GPIO 引脚。
在不验证微控制器是否正确切换的情况下发送打开或关闭命令将阻止某些 GPIO 引脚正确关闭/打开。
do
string close_result1 = cdf_muxes[card].close(channel);
string close_result2 = cdf_muxes[card + 1].close(channel);
if (close_result1.Contains("1")) cr1 = true; else cr1 = false;
if (close_result2.Contains("1")) cr2 = true; else cr2 = false;
} while (!(cr1 == true & cr2 == true));
bool or1 = false;
bool or2 = false;
do
string open_result1 = cdf_muxes[card].open(channel);
string open_result2 = cdf_muxes[card + 1].open(channel);
if (open_result1.Contains("0")) or1 = true; else or1 = false;
if (open_result2.Contains("0")) or2 = true; else or2 = false;
} while (!(or1 == true & or2 == true));
是否有人对如何减少打开/关闭 GPIO 引脚所需的时间有任何建议?
Allan
