[参考译文] TMS570LC4357:TMS570LC4357
Guru**** 2403435 points
Other Parts Discussed in Thread: HALCOGEN
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1106862/tms570lc4357-tms570lc4357
器件型号:TMS570LC4357
主题中讨论的其他器件:HALCOGEN
我认为 https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/916063/tms570lc4357-data-abort-exception-after-software-reset 中提到的问题 在 HALCOGEN 中还没有得到解决。 软件复位后、我仍然会在 SCI 中看到 dabort。
