[参考译文] TMS570LS3137:TMS570 fapi SRAM 问题
Guru**** 2553260 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1128803/tms570ls3137-tms570-fapi-sram-problem
器件型号:TMS570LS3137
您好:
我编写了一个与以太网一起工作的引导加载程序库、当我从组1扇区0启动主应用程序时、引导加载程序工作正常、但当我从组0扇区5启动应用程序时、引导加载程序结束时、它会卡在"while (FAPI_GET_FSM_STATUS!= Fapi_Status_Success)"。 但 fapi 初始化操作已成功完成。
引导加载程序大小:142KB
要在 SRAM 中运行 fapi、我按如下方式配置链接器。
/* Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *    Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Linker Settings                                                            */
--retain="*(.intvecs)"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* Memory Map        */
MEMORY
    VECTORS    (X)   : origin=0x00000000 length=0x00000020		vfill=0xFFFFFFFF
    FLASH0     (RX)  : origin=0x00000020 length=0x180000-0x20	vfill=0xFFFFFFFF
    FLASH1     (RX)  : origin=0x00180000 length=0x00180000		vfill=0xFFFFFFFF
    SRAM       (RW)  : origin=0x08002000 length=0x0002D000
    STACK      (RW)  : origin=0x08000000 length=0x00002000
/* USER CODE BEGIN (2) */
#if 1
    ECC_VEC  (R) : origin=(0xf0400000 + (start(VECTORS) >> 3))
                   length=(size(VECTORS) >> 3)
                   ECC={algorithm=algoL2R5F021, input_range=VECTORS}
    ECC_FLA0 (R) : origin=(0xf0400000 + (start(FLASH0)  >> 3))
                   length=(size(FLASH0)  >> 3)
                   ECC={algorithm=algoL2R5F021, input_range=FLASH0 }
    ECC_FLA1 (R) : origin=(0xf0400000 + (start(FLASH1)  >> 3))
                   length=(size(FLASH1)  >> 3)
                   ECC={algorithm=algoL2R5F021, input_range=FLASH1 }
#endif
/* USER CODE END */
/* USER CODE BEGIN (3) */
ECC
    algoL2R5F021 : address_mask = 0xfffffff8 /* Address Bits 31:3 */
                   hamming_mask = R4         /* Use R4/R5 build in Mask */
                   parity_mask  = 0x0c       /* Set which ECC bits are Even and Odd parity */
                   mirroring    = F021       /* RM57Lx and TMS570LCx are build in F021 */
/* USER CODE END */
/* Section Configuration                                                      */
SECTIONS
/* USER CODE BEGIN (4) */
	.intvecs 	: 	{} > VECTORS
    flashAPI:
     .\.\libraries\f021_flash_api_02.01.01\source\Fapi_UserDefinedFunctions.obj (.text)
     .\.\libraries\flash\Src\flash.obj (.text)
     --library= "D:\Projects\ANAKS\embedded-library\F023_FLASH_API\f021_flash_api_02.01.01\F021_API_CortexR4_BE.lib"  (.text)
    } palign=8 load = FLASH0 | FLASH1, run = SRAM, LOAD_START(fapi_load_start), RUN_START(fapi_run_start), SIZE(fapi_load_size)
	.text  		: 	{} > FLASH0 | FLASH1 /*Initialized executable code and constants*/
   	.const 		: 	{} load = FLASH0 | FLASH1, run = SRAM, LOAD_START(fapi_const_load_start), RUN_START(fapi_const_run_start), SIZE(fapi_const_load_size)
   	.cinit 		: 	{} > FLASH0 | FLASH1 /*Initialized global and static variables*/
   	.pinit 		: 	{} > FLASH0 | FLASH1
   	.data  		:	{} > SRAM
   	.bss   		: 	{} > SRAM   /*Uninitialized Global and static variables */
   	.sysmem		:	{} > SRAM
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/* Misc        */
/* USER CODE BEGIN (6) */
/* USER CODE END */
引导加载程序应用程序内存分配:
哪里会出错? 可以帮帮我吗?
此致、很好...
