[参考译文] TM4C1294NCPDT:未在以太网上分配 DHCP IP
Guru**** 2771175 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1062413/tm4c1294ncpdt-dhcp-ip-not-assigning-on-ethernet
器件型号:TM4C1294NCPDT
当我连接到以太网时、我无法获得 DHCP 分配的 IP、但通过我的笔记本电脑共享的以太网、我获得了 DHCP 分配的 IP、
我正在处理一个充电器、我的代码几乎是最终的。唯一的问题是、当我将以太网连接到我的 PC 共享以太网端口时、我能够以分配的 DHCP IP 访问服务器、但当我尝试通过调制解调器的实际以太网或进行访问时 一些其它的以太网 DHCP IP 未分配。我已经使用多个以太网端口进行了测试。每个端口都可以与我的 PC 和其它服务配合使用。
请检查文件以了解一些配置更改。我使用了 enet_weather 示例库。
// eth_client.c - This file handles all of the Ethernet connections using lwIP.
// Copyright (c) 2014-2017 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.4.178 of the EK-TM4C1294XL Firmware Package.
#include <stdint.h>
#include<string.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/flash.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "utils/ustdlib.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/lwiplib.h"
#include "lwip/dns.h"
#include "eth_client.h"
#include "json.h"
#include "utils/uartstdio.h"
#include "driverlib/uart.h"
#include "PacketFormat/format.h"
#include "PacketFormat/tables.h"
#include "UART_Control/UARTHandler.h"
// Flag indexes for g_sEnet.ui32Flags
#define FLAG_TIMER_DHCP_EN      0
#define FLAG_TIMER_DNS_EN       1
#define FLAG_TIMER_TCP_EN       2
#define FLAG_DHCP_STARTED       3
#define FLAG_DNS_ADDRFOUND      4
// g_sEnet.ulRequest Values
#define WEATHER_NONE            0
#define WEATHER_CURRENT         1
#define WEATHER_FORECAST        2
extern uint8_t TestMode;
char buftemp[255];
uint8_t PacketType=e_None;
extern funct ReqFunctions[];
extern TransmitProcess ProcessTransmit; /*Ethernet Transmit Structure*/
extern char Response[1024];
extern Web_Socket_Flags WebSocketflags;
extern WebSocket_Strct WebSocket;
// The current state of the Ethernet connection.
struct
    volatile uint32_t ui32Flags;
    // Array to hold the MAC addresses.
    uint8_t pui8MACAddr[8];
    // Global define of the TCP structure used.
    struct tcp_pcb *psTCP;
    // Global IP structure to hold a copy of the IP address.
    struct ip_addr sLocalIP;
    // Global IP structure to hold a copy of the DNS resolved address.
    struct ip_addr sServerIP;
    // The saved proxy name as a text string.
    const char *pcProxyName;
    volatile enum
        iEthNoConnection,
        iEthDHCPWait,
        iEthDHCPComplete,
        iEthDNSWait,
        iEthTCPConnectWait,
        iEthTCPConnectComplete,
        iEthQueryWait,
        iEthTCPOpen,
        iEthIdle
    } eState;
    unsigned long ulRequest;
    tEventFunction pfnEvent;
g_sEnet;
// Maximum size of an weather request.
#define MAX_REQUEST             4096//2048
extern uint32_t g_ui32SysClock;
extern uint32_t g_ui32IPaddr;
// Various strings used to access weather information on the web.
 char g_cWeatherRequest[] =
        "GET ">api.openweathermap.org/.../weather
 char g_cWeatherRequestForecast[] =
        "GET ">api.openweathermap.org/.../daily
 char g_cMode[] = "&mode=json&units=metric";
 char g_cAPPIDOpenWeather[] =
        "&APPID=afc5370fef1dfec1666a5676346b163b";
 char g_cHTTP11[] = " HTTP/1.0\r\n\r\n";
 /****************Hnadshake Data and URL**************/
 //char cmd_1[] ="GET /EFILLXOCPP20J/AC001TEST HTTP/1.1\r\n";//"GET HTTP/1.1\r\n";//"GET 65.0.24.136:3002/EFILL002 HTTP/1.1\r\n";
 //char cmd_2[] ="Host: 13.127.80.198:6002\r\n";
//char cmd_1[] ="GET /OCPP2.0.1/AC001TEST HTTP/1.1\r\n";//"GET HTTP/1.1\r\n";//"GET 65.0.24.136:3002/EFILL002 HTTP/1.1\r\n";
//char cmd_2[] ="Host: 65.0.24.136:3002\r\n";
 char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00002 HTTP/1.1\r\n";
 //char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00007 HTTP/1.1\r\n";
//char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00001 HTTP/1.1\r\n";
 //char cmd_1[] ="GET /EVELTXRFIK/PRO-GUJ-SZ-AC-002 HTTP/1.1\r\n";
 //char cmd_2[] ="Host: econnect.electreefi.com:80\r\n";
char cmd_3[] ="Upgrade: websocket\r\n";
char cmd_4[] ="Connection: Upgrade\r\n";
char cmd_5[] ="Sec-WebSocket-Key: hsgS1BezikgQ9FxPJ3qWyw==\r\n";
char cmd_6[] ="Sec-WebSocket-Protocol: ocpp1.6\r\n";
char cmd_7[] ="Sec-WebSocket-Version: 13\r\n\r\n";
// This structure holds the state and control values for the weather requests.
struct
    // The current weather source.
    tWeatherSource eWeatherSource;
    // The format expected from the weather source.
    enum
        iFormatJSON
    eFormat;
    // The application provided callback function.
    // The application provided weather information structure.
    tWeatherReport *psWeatherReport;
    // The local buffer used to store the current weather request.
    char pcRequest[MAX_REQUEST];
    // The number of valid bytes in the request.
    uint32_t ui32RequestSize;
g_sWeather;
// Close an active connection.
void
EthClientReset(void)
    // No longer have a link.
    g_sEnet.eState = iEthNoConnection;
    // Reset the flags to just enable the lwIP timer.
    g_sEnet.ui32Flags = (1 << FLAG_TIMER_DHCP_EN);
    // Reset the addresses.
    g_sEnet.sLocalIP.addr = 0;
    g_sEnet.sServerIP.addr = 0;
    // Deallocate the TCP structure if it was already allocated.
    if(g_sEnet.psTCP)
        // Clear out all of the TCP callbacks.
        tcp_sent(g_sEnet.psTCP, NULL);
        tcp_recv(g_sEnet.psTCP, NULL);
        tcp_err(g_sEnet.psTCP, NULL);
        // Close the TCP connection.
        tcp_close(g_sEnet.psTCP);
        g_sEnet.psTCP = 0;
// Handles lwIP TCP/IP errors.
// \param vPArg is the state data for this connection.
// \param iErr is the error that was detected.
// This function is called when the lwIP TCP/IP stack has detected an error.
// The connection is no longer valid.
// \return None.
static void
TCPError(void *vPArg, err_t iErr)
// Finalizes the TCP connection in client mode.
// \param pvArg is the state data for this connection.
// \param psPcb is the pointer to the TCP control structure.
// \param psBuf is the buffer structure that holds the data for this receive
// event.
// \param iErr is not used in this implementation.
// This function is called when the lwIP TCP/IP stack has completed a TCP
// connection.
// \return This function will return an lwIP defined error code.
static err_t
TCPReceive(void *pvArg, struct tcp_pcb *psPcb, struct pbuf *psBuf, err_t iErr)
    struct pbuf *psBufCur;
//   char buftemp[1024];
    int32_t i32Items;
    if(psBuf == 0)
        // Tell the application that the connection was closed.
        if(g_sWeather.pfnEvent)
            g_sWeather.pfnEvent(ETH_EVENT_CLOSE, 0, 0);
            g_sWeather.pfnEvent = 0;
        // Close out the port.
        tcp_close(psPcb);
        if(psPcb == g_sEnet.psTCP)
            g_sEnet.psTCP = 0;
        g_sEnet.eState = iEthIdle;
        PacketType = e_None;
        return(ERR_OK);
    if(g_sEnet.eState == iEthQueryWait) //Data Response for Query
    //	memset(buftemp,0,psBuf->len);
     //   memcpy(buftemp ,psBuf->payload,psBuf->len );
       // UARTprintf("\n\t%s",buftemp);//@@@
      //  UARTprintf("\n\tLen:- %d",psBuf->len);//@@@
      //  UARTprintf("\n\t%s",((uint8_t *)psBuf->payload));//@@@
      //  UARTprintf("\n");
        i32Items = ParseExample(0,psBuf);
      //  UARTprintf("NumberofItems:  %u\n\r",i32Items);
        if(i32Items>0)
            g_sWeather.pfnEvent(ETH_EVENT_RECEIVE,
                                (void *)g_sWeather.psWeatherReport, 0);
            // Clear the event function and return to the idle state.
            PacketType = e_InitbyClientRec;
    else  //Data Recieved without Query
        // Go to idle state.
        PacketType = e_InitByServerRec;
    // Initialize the linked list pointer to parse.
    psBufCur = psBuf;
    // Free the buffers used since they have been processed.
    while(psBufCur->len != 0)
        // Indicate that you have received and processed this set of TCP data.
        tcp_recved(psPcb, psBufCur->len);
        // Go to the next buffer.
        psBufCur = psBufCur->next;
        // Terminate if there are no more buffers.
        if(psBufCur == 0)
            break;
    // Free the memory space allocated for this receive.
    pbuf_free(psBuf);
    // Return.
    return(ERR_OK);
// Handles acknowledgment of data transmitted via Ethernet.
// \param ui16Len is the length of the data transmitted.
// This function is called when the lwIP TCP/IP stack has received an
// acknowledgment for data that has been transmitted.
static err_t
TCPSent(void *pvArg, struct tcp_pcb *psPcb, u16_t ui16Len)
    // Return OK.
    return (ERR_OK);
// connection.
static err_t
TCPConnected(void *pvArg, struct tcp_pcb *psPcb, err_t iErr)
    // Check if there was a TCP error.
    if(iErr != ERR_OK)
        tcp_sent(psPcb, NULL);
        tcp_recv(psPcb, NULL);
        tcp_err(psPcb, NULL);
        tcp_close(psPcb);
            g_sEnet.psTCP = 0;
        // And return.
        return (ERR_OK);
    // Setup the TCP receive function.
    tcp_recv(psPcb, TCPReceive);
    // Setup the TCP error function.
    tcp_err(psPcb, TCPError);
    // Setup the TCP sent callback function.
    tcp_sent(psPcb, TCPSent);
    // Connection is complete.
    g_sEnet.eState = iEthTCPConnectComplete;
    // Return a success code.
    return(ERR_OK);
// TCP connect
// This function attempts to connect to a TCP endpoint.
// \return None.
err_t
EthClientTCPConnect(uint32_t ui32Port)
    err_t eTCPReturnCode;
    // Enable the TCP timer function calls.
    HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN) = 1;
    if(g_sEnet.psTCP)
        // Initially clear out all of the TCP callbacks.
        // Make sure there is no lingering TCP connection.
    // Create a new TCP socket.
    g_sEnet.psTCP = tcp_new();
    // Check if you need to go through a proxy.
  //  if(g_sEnet.pcProxyName != 0)
        // Attempt to connect through the proxy server.
    //    eTCPReturnCode = tcp_connect(g_sEnet.psTCP, &g_sEnet.sServerIP,
    //                                 ui32Port, TCPConnected);
   // else
        // Attempt to connect to the server directly.
    return(eTCPReturnCode);
// TCP connect
// \return None.
void
EthClientTCPDisconnect(void)
   // HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN) = 0;
    if(g_sEnet.psTCP)
        g_sEnet.psTCP = 0;
// Handler function when the DNS server gets a response or times out.
// \param pcName is DNS server name.
// \param psIPAddr is the DNS server's IP address.
// \param vpArg is the configurable argument.
// This function is called when the DNS server resolves an IP or times out.
// If the DNS server returns an IP structure that is not NULL, add the IP to
// to the g_sEnet.sServerIP IP structure.
// \return None.
static void
DNSServerFound(const char *pcName, struct ip_addr *psIPAddr, void *vpArg)
    // Check if a valid DNS server address was found.
    if(psIPAddr != NULL)
        // Copy the returned IP address into a global IP address.
        g_sEnet.sServerIP = *psIPAddr;
        // Tell the main program that a DNS address was found.
        HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND) = 1;
    else
        // Disable the DNS timer.
        HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN) = 0;
// Required by lwIP library to support any host-related timer functions.
void
lwIPHostTimerHandler(void)
// Send a request to the server
// \param pcRequest request to be sent
// \param ui32Size length of the request to be sent. this is usually the size
// of the request minus the termination character
// This function will send the request to the connected server
// \return the lwIP error code.
err_t
EthClientSend(char *pcRequest, uint32_t ui32Size)
    err_t eError;
    eError = tcp_write(g_sEnet.psTCP, pcRequest, ui32Size,
                       TCP_WRITE_FLAG_COPY);
    //  Write data for sending (but does not send it immediately).
    if(eError == ERR_OK)
        // Find out what we can send and send it
        tcp_output(g_sEnet.psTCP);
    return(eError);
// DHCP connect
// This function obtains the MAC address from the User registers, starts the
// DHCP timer and blocks until an IP address is obtained.
// \return None.
err_t
EthClientDHCPConnect(void)
    // Check if the DHCP has already been started.
    if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) == 0)
        // Set the DCHP started flag.
        HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) = 1;
    else
        // If DHCP has already been started, we need to clear the IPs and
        // switch to static.  This forces the LWIP to get new IP address
        // and retry the DHCP connection.
    //    lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_STATIC);
        // Restart the DHCP connection.
        lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
    return ERR_OK;
// \return None.
int32_t
EthClientDNSResolve(const char *pcName)
    err_t iRet;
    if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN))
        return(ERR_INPROGRESS);
    // Set DNS config timer to true.
    HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN) = 1;
    // Initialize the host name IP address found flag to false.
    HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND) = 0;
    // Resolve host name.
    iRet = dns_gethostbyname(pcName, &g_sEnet.sServerIP, DNSServerFound, 0);
    // If ERR_OK is returned, the local DNS table resolved the host name.  If
    // ERR_INPROGRESS is returned, the DNS request has been queued and will be
    // sent to the DNS server.
    if(iRet == ERR_OK)
        // Stop calling the DNS timer function.
    // Return host name not found.
    return(iRet);
// Returns the IP address for this interface.
// This function will read and return the currently assigned IP address for
// the Tiva Ethernet interface.
// \return Returns the assigned IP address for this interface.
uint32_t
EthClientAddrGet(void)
    // Return IP.
    return(lwIPLocalIPAddrGet());
// Returns the weather server IP address for this interface.
// This function will read and return the weather server IP address that is
// currently in use.  This could be the proxy server if the Internet proxy
// is enabled.
// \return Returns the weather server IP address for this interface.
uint32_t
EthClientServerAddrGet(void)
    // Return IP.
    return((uint32_t)g_sEnet.sServerIP.addr);
// Returns the MAC address for the Tiva Ethernet controller.
// \param pui8MACAddr is the 6 byte MAC address assigned to the Ethernet
// controller.
// This function will read and return the MAC address for the Ethernet
// controller.
void
EthClientMACAddrGet(uint8_t *pui8MACAddr)
    int32_t iIdx;
    for(iIdx = 0; iIdx < 6; iIdx++)
        pui8MACAddr[iIdx] = g_sEnet.pui8MACAddr[iIdx];
// Set the proxy string for the Ethernet connection.
// \param pcProxyName is the string used as the proxy server name.
// This function sets the current proxy used by the Ethernet connection.  The
// \e pcProxyName value can be 0 to indicate that no proxy is in use or it can
// be a pointer to a string that holds the name of the proxy server to use.
// The content of the pointer passed to \e pcProxyName should not be changed
// after this call as this function only stores the pointer and does not copy
// the data from this pointer.
// \return None.
void
EthClientProxySet(const char *pcProxyName)
    // Save the new proxy string.
    g_sEnet.pcProxyName = pcProxyName;
    // Reset the connection on any change to the proxy.
    EthClientReset();
// Initialize the Ethernet client
// This function initializes all the Ethernet components to not configured.
// This tells the SysTick interrupt which timer modules to call.
// \return None.
void
EthClientInit(tEventFunction pfnEvent)
    uint32_t ui32User0, ui32User1;
    // Initialize all the Ethernet components to not configured.  This tells
    // the SysTick interrupt which timer modules to call.
    HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN) = 0;
    g_sEnet.pfnEvent = pfnEvent;
    // Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
    // address needed to program the hardware registers, then program the MAC
    // address into the Ethernet Controller registers.
    FlashUserGet(&ui32User0, &ui32User1);
    g_sEnet.pui8MACAddr[0] = ((ui32User0 >> 0) & 0xff);
    g_sEnet.pui8MACAddr[1] = ((ui32User0 >> 8) & 0xff);
    g_sEnet.pui8MACAddr[2] = ((ui32User0 >> 16) & 0xff);
    g_sEnet.pui8MACAddr[3] = ((ui32User1 >> 0) & 0xff);
    g_sEnet.pui8MACAddr[4] = ((ui32User1 >> 8) & 0xff);
    g_sEnet.pui8MACAddr[5] = ((ui32User1 >> 16) & 0xff);
    lwIPInit(g_ui32SysClock, g_sEnet.pui8MACAddr, 0, 0, 0, IPADDR_USE_DHCP);
    // Start lwIP tick interrupt.
    HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN) = 1;
// Periodic Tick for the Ethernet client
// This function is the needed periodic tick for the Ethernet client. It needs
// to be called periodically through the use of a timer or systick.
// \return None.
void
EthClientTick(uint32_t ui32TickMS)
    uint32_t ui32IPAddr;
    int32_t i32Ret;
    if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN))
        lwIPTimer(ui32TickMS);
        dns_tmr();
    if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN))
        tcp_tmr();
    // Check for loss of link.
    if((g_sEnet.eState != iEthNoConnection) &&
            (lwIPLocalIPAddrGet() == 0xffffffff))
        // Reset the connection due to a loss of link.
        EthClientReset();
        // Signal a disconnect event.
        g_sEnet.pfnEvent(ETH_EVENT_DISCONNECT, 0, 0);
    else if(g_sEnet.eState == iEthNoConnection)
        // Once link is detected start DHCP.
        if(lwIPLocalIPAddrGet() != 0xffffffff)
            EthClientDHCPConnect();
            g_sEnet.eState = iEthDHCPWait;
    else if(g_sEnet.eState == iEthDHCPWait)
        // Get IP address.
        ui32IPAddr = lwIPLocalIPAddrGet();
        // If IP Address has not yet been assigned, update the display
        // accordingly.
        if((ui32IPAddr != 0xffffffff) && (ui32IPAddr != 0))
            // Update the DHCP IP address.
            g_sEnet.sLocalIP.addr = ui32IPAddr;
            g_sEnet.eState = iEthDHCPComplete;
            // Stop DHCP timer since an address has been provided.
            HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) = 0;
    else if(g_sEnet.eState == iEthDHCPComplete)
        if(g_sEnet.pcProxyName == 0)
            // Resolve the host by name.
            // i32Ret = EthClientDNSResolve("api.openweathermap.org");
           // i32Ret = EthClientDNSResolve("65.0.24.136");
            i32Ret = EthClientDNSResolve("13.127.80.198");
        	//i32Ret = EthClientDNSResolve("cms.efillelectric.com");
            //i32Ret = EthClientDNSResolve("192.168.137.1");
        	//i32Ret = EthClientDNSResolve("econnect.electreefi.com");
        else
            // Resolve the proxy by name.
            i32Ret = EthClientDNSResolve(g_sEnet.pcProxyName);
        if(i32Ret == ERR_OK)
            // If the address was already returned then go to idle.
            // Notify the main routine of the new Ethernet connection.
            g_sEnet.pfnEvent(ETH_EVENT_CONNECT, &g_sEnet.sLocalIP.addr, 4);
        else if(i32Ret == ERR_INPROGRESS)
            // If the request is pending the go to the iEthDNSWait state.
            g_sEnet.eState = iEthDNSWait;
    else if(g_sEnet.eState == iEthDNSWait)
        // Check if the host name was resolved.
        if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND))
    else if(g_sEnet.eState == iEthTCPConnectWait)
    else if(g_sEnet.eState == iEthTCPConnectComplete)
        err_t eError;
        g_sEnet.eState = iEthTCPOpen;
        eError = EthClientSend(g_sWeather.pcRequest,
                               g_sWeather.ui32RequestSize);
            // Waiting on a query response.
            g_sEnet.eState = iEthQueryWait;
        else
// Set the current weather source.
void
WeatherSourceSet(tWeatherSource eWeatherSource)
    // Save the source.
    g_sWeather.eWeatherSource = eWeatherSource;
    g_sWeather.eFormat = iFormatJSON;
// Merges strings into the current request at a given pointer and offset.
uint32_t MergeRequest1(int32_t i32Offset, char *pcSrc, int32_t i32Size)
	int32_t i32Idx;
	// Copy the base request to the buffer.
	for(i32Idx = 0; i32Idx < i32Size; i32Idx++)
		g_sWeather.pcRequest[i32Offset] = pcSrc[i32Idx];
		if(WebSocketflags.HandshakeInprogress==1)
			if((i32Offset >= sizeof(g_sWeather.pcRequest)) ||
					(pcSrc[i32Idx] == 0))
					break;
		else
			if(i32Offset >= sizeof(g_sWeather.pcRequest))
					break;
		i32Offset++;
	return(i32Offset);
// Gets the daily forecast for a given city.
 int32_t
 WeatherForecast(tWeatherSource eWeatherSource, const char *pcQuery,
                 tWeatherReport *psWeatherReport, tEventFunction pfnEvent)
     int32_t i32Idx;
   //  const char pcCount[] = "&cnt=1";
     // If the requested source is not valid or there is no call back then
     // just fail.
     // if((eWeatherSource != iWSrcOpenWeatherMap) || (g_sWeather.pfnEvent))
     //     return (-1);
     if(eWeatherSource != iWSrcOpenWeatherMap)
             return (-1);
     g_sWeather.pfnEvent = pfnEvent;
     g_sWeather.psWeatherReport = psWeatherReport;
  //   if(g_sEnet.eState == iEthNoConnection) return(0);
     // Connect or reconnect to port 80.
   //  g_sEnet.eState = iEthTCPConnectWait;
     // Copy the base forecast request to the buffer.
    // i32Idx = MergeRequest1(0, g_cWeatherRequestForecast,
    //                       sizeof(g_cWeatherRequestForecast));
     // Append the request.
     //i32Idx = MergeRequest1(i32Idx, pcQuery, sizeof(g_sWeather.pcRequest));
     // Append the request mode.
    // i32Idx = MergeRequest1(i32Idx, g_cMode, sizeof(g_cMode));
     // Append the count.
     //i32Idx = MergeRequest1(i32Idx, pcCount, sizeof(pcCount));
     // Append the App ID.
   //  i32Idx = MergeRequest1(i32Idx, g_cAPPIDOpenWeather,
         //                  sizeof(g_cAPPIDOpenWeather));
     // Append the "HTTP:/1.1" string.
    // i32Idx = MergeRequest1(i32Idx, g_cHTTP11, sizeof(g_cHTTP11));
     // UARTprintf("\n\t%s",g_sWeather.pcRequest);
     // Forcast weather report request.
    // g_sEnet.ulRequest = WEATHER_FORECAST;
     ProcessTransmit.Tx_ActionIndex = Id_Heartbeat;
     ProcessTransmit.Tx_MessageId[e_IdCallResult]  = 2;
      i32Idx = MergeRequest1(0,Webpack,sizeof(Webpack));
     if(ProcessTransmit.TransmitFlag[e_IdCall]==1)
    	 ProcessTransmit.TransmitLength = ReqFunctions[ProcessTransmit.TransmitIndex[e_IdCall]]();
     else
    	 ProcessTransmit.TransmitLength = ReqFunctions[ProcessTransmit.TransmitIndex[e_IdCallResult]]();
      WebSocketflags.DataLen = Websocket_TxHandle(Response,ProcessTransmit.TransmitLength,1,1);
      i32Idx = MergeRequest1(0, WebSocketflags.DataBuff,  WebSocketflags.DataLen);
 	  i32Idx = MergeRequest1(0, cmd_1, sizeof(cmd_1));
      i32Idx = MergeRequest1(i32Idx, cmd_2, sizeof(cmd_2));
      i32Idx = MergeRequest1(i32Idx, cmd_3, sizeof(cmd_3));
      i32Idx = MergeRequest1(i32Idx, cmd_4, sizeof(cmd_4));
      i32Idx = MergeRequest1(i32Idx, cmd_5, sizeof(cmd_5));
      i32Idx = MergeRequest1(i32Idx, cmd_6, sizeof(cmd_6));
      i32Idx = MergeRequest1(i32Idx, cmd_7, sizeof(cmd_7));
      i32Idx = MergeRequest1(i32Idx,Webpack,sizeof(Webpack));
      i32Idx = MergeRequest1(i32Idx, Response, ProcessTransmit.TransmitLength);
    //  if(EthClientTCPConnect(3002) != ERR_OK)
     if(EthClientTCPConnect(6002) != ERR_OK)
      //if(EthClientTCPConnect(80) != ERR_OK)
          return(-1);
      else
     	// tcp_connect(g_sEnet.psTCP, &g_sEnet.sServerIP,3002, TCPConnected);
     	    tcp_recv(g_sEnet.psTCP, TCPReceive);
     	    tcp_err(g_sEnet.psTCP, TCPError);
     	    tcp_sent(g_sEnet.psTCP, TCPSent);
     // Save the size of the request.
     g_sWeather.ui32RequestSize = i32Idx;
     return(0);
// Gets the current weather information for a given city.
int32_t
WeatherCurrent(tWeatherSource eWeatherSource, const char *pcQuery,
    int32_t i32Idx;
  //  if(eWeatherSource != iWSrcOpenWeatherMap)
   //     if(g_sWeather.pfnEvent)
   //         return (-1);
   return(0);
void restore(void)
//Function Returns Length of Data After Adding Websocket
uint32_t Websocket_TxHandle(char *payload , uint32_t dtln,uint8_t Fin, uint8_t Masking)
	uint32_t Dl=0;
	if(WebSocketflags.HanshakeStatus==0)return 0;
	WebSocket.BIT_FIELD.FIN  =Fin;
	WebSocket.BIT_FIELD.RSV1=0;
	WebSocket.BIT_FIELD.RSV2=0;
	WebSocket.BIT_FIELD.RSV3=0;
	WebSocket.BIT_FIELD.OPCODE=1;
	WebSocketflags.DataBuff[0]=WebSocket.BYTE_ARRAY[0];
	Dl++;
	WebSocket.BIT_FIELD.MASK=Masking;
	//if(masking =1, Do masking of payload otherwise Do not mask payload)
	//Generate a 32 bit Masking Key if Mask flag=1;
	WebSocket.BIT_FIELD.MASKING_KEY1=0x2A;//ReturnRandomHex();//  0x2A;
	WebSocket.BIT_FIELD.MASKING_KEY2=0x3C;//ReturnRandomHex();//0x3C;
	WebSocket.BIT_FIELD.MASKING_KEY3=0x4D;//ReturnRandomHex();//0x4D;
	WebSocket.BIT_FIELD.MASKING_KEY4=0x5B;//ReturnRandomHex();//0x5B;
	//For now masking is fixed @enable i.e. 1
	if(dtln>=126) //and smaller than 65535
     //insert extended payload length here
		WebSocket.BIT_FIELD.PAYLOAD_LEN = 126;
		WebSocketflags.DataBuff[1] = WebSocket.BYTE_ARRAY[1];
		Dl++;
		WebSocket.BIT_FIELD.EXTENDED_PAYLOAD_LEN = dtln;
		WebSocketflags.DataBuff[2] = WebSocket.BYTE_ARRAY[3];
		Dl++;
		WebSocketflags.DataBuff[3] = WebSocket.BYTE_ARRAY[2];
		Dl++;
		WebSocketflags.DataBuff[4] = WebSocket.BIT_FIELD.MASKING_KEY1;
		Dl++;
		WebSocketflags.DataBuff[5] = WebSocket.BIT_FIELD.MASKING_KEY2;
		Dl++;
		WebSocketflags.DataBuff[6] = WebSocket.BIT_FIELD.MASKING_KEY3;
		Dl++;
		WebSocketflags.DataBuff[7] = WebSocket.BIT_FIELD.MASKING_KEY4;
		Dl++;
		MaskData(dtln,payload);
		Dl = (Dl+dtln);
	else
		WebSocket.BIT_FIELD.PAYLOAD_LEN = dtln;
		Dl++;
		WebSocketflags.DataBuff[2] = WebSocket.BIT_FIELD.MASKING_KEY1;
		Dl++;
		WebSocketflags.DataBuff[3] = WebSocket.BIT_FIELD.MASKING_KEY2;
		Dl++;
		WebSocketflags.DataBuff[4] = WebSocket.BIT_FIELD.MASKING_KEY3;
		Dl++;
		WebSocketflags.DataBuff[5] = WebSocket.BIT_FIELD.MASKING_KEY4;
		Dl++;
		Dl = (Dl+dtln);
	return Dl;
void MaskData(uint32_t DataSize,char *payload) //if Data Size is smaller than equal to 125 bytes
	uint32_t Lp=0;
	uint8_t KeyId=0;
	if(TestMode==false)UARTprintf("\r\nTX:- ");
	if(DataSize>=126)
		for(Lp=0;Lp<DataSize;Lp++)
			if(TestMode==false)UARTCharPut(UART0_BASE,payload[Lp]);
			WebSocketflags.DataBuff[Lp+8] = payload[Lp]^WebSocketflags.DataBuff[KeyId+4];
			KeyId++;
			if(KeyId>3)KeyId=0;
	else
			WebSocketflags.DataBuff[Lp+6] = payload[Lp]^WebSocketflags.DataBuff[KeyId+2];
			KeyId++;
			if(KeyId>3)KeyId=0;
uint8_t ReturnRandomHex(void)
	uint8_t RdmNum=0;
	RdmNum =  urand()%256-13;
	return RdmNum;
// enet_weather.c - Sample Weather application using lwIP.
#include <stdint.h>
#include <string.h>
#include "inc/hw_ints.h"
#include "inc/hw_nvic.h"
#include "inc/hw_gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/emac.h"
#include "driverlib/timer.h"
#include "drivers/pinout.h"
#include "utils/cmdline.h"
#include "utils/locator.h"
#include "utils/flash_pb.h"
#include "enet_weather.h"
#include "fatfs/src/ff.h"
#include "fatfs/src/diskio.h"
#include "json.h"
#include "Timer_Control/TimerHandler.h"
#include "Conversions/unit_conversion.h"
#include "GPIO_Control/GPIO_Controls.h"
#include "Sensing_ADC/ADC_Sensing.h"
#include "sd_card/sd_card.h"
#include "EEPROM_Control/Int_EEPR.h"
#include "EEPROM_Control/i2c_config.h"
#include "EEPROM_Control/24AAN256.h"
#include "DisplayData/DisplayCommands.h"
#include "inc/hw_hibernate.h"
#include "driverlib/hibernate.h"
#include "UART_Control/Modem.h"
void Transmit_DataForCallResult(void);
void Transmit_DataForCall(void);
void HandleConnectionsServerStates(void);
void SendHandshake(void);
//extern VP_Table Variabledatatable[];
extern Relay_States RelayStates;
uint32_t OCPPVersion=0;
extern Level_Passwords LevelPasswords;
uint32_t OV_OC_DelayTime=0;
extern EV_Param EVParam;
char buffr[50];
uint8_t PowerUpflag=1;
uint8_t EthResetRequired=0;
uint32_t WaitEthReconnect=WAIT_ETH_RECONNECT;
extern Fuction_Handle FuctionHandle[TOTAL_ACTION_ARRAY_COUNT];
//extern uint16_t *tableArray1[];
extern Param_Update_Flags ParamUpdateFlags;
extern UpdateSDCard_TL UpdateSDCardTL;
extern uint8_t Fault_Table1K_Flag;
extern uint8_t TL_Table1K_Flag;
extern uint8_t CacheMem1K_Flag;
extern Disp_ControlFunc DispControlFuncLatest;
//extern Relay_States RelayStates;
//extern struct g_sEnet;
//! \addtogroup example_list
//! <h1>Ethernet Weather Application (enet_weather)</h1>
//! This example application demonstrates the operation of the Tiva C series
//! evaluation kit as a weather reporting application.
//! The application supports updating weather information from Open Weather Map
//! weather provider(http://openweathermap.org/).  The application uses the
//! lwIP stack to obtain an address through DNS, resolve the address of the
//! Open Weather Map site and then build and handle all of the requests
//! necessary to access the weather information.  The application can also use
//! a web proxy, allows for a custom city to be added to the list of cities and
//! toggles temperature units from Celsius to Fahrenheit.  The application
//! scrolls through the city list at a fixed interval when there is a valid
//! IP address and displays this information over the UART.
//! The application will print the city name, status, humidity, current temp
//! and the high/low. In addition the application will display what city it
//! is currently updating. Once the app has scrolled through the cities a
//! a defined amount of times, it will attempt to update the information.
//! UART0, connected to the Virtual Serial Port and running at 115,200, 8-N-1,
//! is used to display messages from this application.
//!/ For additional details about Open Weather Map refer to their web page at:
//! http://openweathermap.org/
//! For additional details on lwIP, refer to the lwIP web page at:
//! savannah.nongnu.org/.../
// Connection states for weather application.
volatile enum
    STATE_NOT_CONNECTED, //ETHERNET NOT CONNECTED
    STATE_NEW_CONNECTION, //SERVER CONNECTION STARTED
    STATE_CONNECTED_IDLE, //CONNECTED AND CLIENT IN IDLE STATE
    STATE_WAIT_DATA, //WAITING DATA TO RECEIVE
    STATE_PROCESS_RX_DATA, //PROCESSING RECIEVED DATA
    STATE_SERVER_BUSY,//This Happens if Server do not Respond Any Data for A Query
    STATE_DATA_PROCESSED,
g_iState = STATE_NOT_CONNECTED;
uint8_t TCP_ConnectionStatus= e_TCP_Disconnected;
// Global for IP address.
// The delay count to reduce traffic to the weather server.
volatile uint32_t g_ui32Delay;
err_t Err;
// System Clock rate in Hertz.
// Flag indicate Ehernet Transmission//1-->Transmit,0-->Idle
//uint8_t EthFlagTransmit=0;
extern Timer_Flags TimerFlags;
extern uint32_t Time_Sec;
// The defaults for the flash and application settings.
static const sParameters g_sDefaultParams =
 0,
 {"Custom City Name"},
 {"your.proxy.com"},
 false,
 false,
 false,
 false
// The current live configuration settings for the application.
sParameters g_sConfig;
// The state of each city panel.
struct
    // The last update time for this city.
    uint32_t ui32LastUpdate;
    // The current weather report data for this city.
    tWeatherReport sReport;
    // Indicates if the city needs updating.
    bool bNeedsUpdate;
    // The name of the current city.
    const char *pcName;
g_psCityInfo[1];
// Interrupt priority definitions.  The top 3 bits of these values are
// significant with lower values indicating higher priority interrupts.
#define SYSTICK_INT_PRIORITY    0x80
#define ETHERNET_INT_PRIORITY   0xC0
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
// MAC address.
char g_pcMACAddr[40];
// IP address.
char g_pcIPAddr[20];
// Update the IP address string.
void
UpdateIPAddress(char *pcAddr, uint32_t ipAddr)
    uint8_t *pui8Temp = (uint8_t *)&ipAddr;
    if(ipAddr == 0)
        ustrncpy(pcAddr, "IP: ---.---.---.---", sizeof(g_pcIPAddr));
    else
        usprintf(pcAddr,"IP: %d.%d.%d.%d", pui8Temp[0], pui8Temp[1],
                 pui8Temp[2], pui8Temp[3]);
void ProcessMcuLed(void);
// Update the MAC address string.
void
UpdateMACAddr(void)
    uint8_t pui8MACAddr[6];
    EthClientMACAddrGet(pui8MACAddr);
    usprintf(g_pcMACAddr, "MAC: %02x:%02x:%02x:%02x:%02x:%02x",
             pui8MACAddr[0], pui8MACAddr[1], pui8MACAddr[2], pui8MACAddr[3],
             pui8MACAddr[4], pui8MACAddr[5]);
// Print the IP address string.
void
PrintIPAddress(char *pcAddr, uint32_t ipaddr)
    uint8_t *pui8Temp = (uint8_t *)&ipaddr;
    // Convert the IP Address into a string.
    UARTprintf("%d.%d.%d.%d\n", pui8Temp[0], pui8Temp[1], pui8Temp[2],
               pui8Temp[3]);
// Updates the UART information.
void
UpdateUART(void)
    volatile uint32_t ui32IPaddr;
    // Get the IP address.
    ui32IPaddr = EthClientAddrGet();
    // If the IP changed, reassign.
    if (g_ui32IPaddr != ui32IPaddr)
        // Reassign the global IP to the current.
        g_ui32IPaddr = ui32IPaddr;
        // Update the UART.
        //  g_UpdateUART = 1;
    // Check if we should scroll the cities.
    // Clear the terminal.  Print the banner and IP place holder.
      UARTprintf("SYSTEM IP: ");
    // Print the IP address.
      PrintIPAddress(g_pcIPAddr, ui32IPaddr);
      UARTprintf("\n");
void
WeatherEvent(uint32_t ui32Event, void* pvData, uint32_t ui32Param)
    if(ui32Event == ETH_EVENT_RECEIVE)
        // Let the main loop update the city.
        g_iState = STATE_DATA_PROCESSED;
        g_iState= STATE_CONNECTED_IDLE;
        //  g_psCityInfo[g_ui32CityUpdating].ui32LastUpdate =
        //   g_psCityInfo[g_ui32CityUpdating].sReport.ui32Time;
    else if(ui32Event == ETH_EVENT_INVALID_REQ)
        //if Data packet Recieved not Valid
        // g_psCityInfo[g_ui32CityUpdating].sReport.pcDescription = g_pcNotFound;
        //g_iState = STATE_UPDATE_CITY;
    else if(ui32Event == ETH_EVENT_CLOSE)
        if(g_iState == STATE_WAIT_DATA)
            //  g_pcServerBusy;
            //SERVER NOT ABLE TO RESPOND//
            g_iState = STATE_SERVER_BUSY;
    // If the update indicated no time, then just set the time to a value
    // to indicate that at least the update occurred.
    if(g_psCityInfo[0].ui32LastUpdate == 0)
        // Failed to update for some reason.
        g_psCityInfo[0].ui32LastUpdate = 1;
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
    // Call the lwIP timer handler.
    EthClientTick(SYSTEM_TICK_MS);
    disk_timerproc();
    // Handle the delay between accesses to the weather server.
    if(g_ui32Delay != 0)
        g_ui32Delay--;
// Network events handler.
void
EnetEvents(uint32_t ui32Event, void *pvData, uint32_t ui32Param)
    if(ui32Event == ETH_EVENT_CONNECT)
       // if(!(TCP_ConnectionStatus==e_TCP_NotResponding))
            g_iState = STATE_NEW_CONNECTION;
        // Update the string version of the address.
        UpdateIPAddress(g_pcIPAddr, EthClientAddrGet());
    else if(ui32Event == ETH_EVENT_DISCONNECT)
        // Update the address to 0.0.0.0.
        UpdateIPAddress(g_pcIPAddr, 0);
int
main(void)
    ROM_FPULazyStackingEnable();
    ROM_FPUEnable();
    sParameters *pParams;
    // Make sure the main oscillator is enabled because this is required by
    // the PHY.  The system must have a 25MHz crystal attached to the OSC
    // pins.  The SYSCTL_MOSC_HIGHFREQ parameter is used when the crystal
    // frequency is 10MHz or higher.
    SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
#if INTERNAL_CLOCK
    //Run On internal Clock
    g_ui32SysClock = MAP_SysCtlClockFreqSet(SYSCTL_OSC_INT | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480, 120000000);
#elif EXTERNAL_CLOCK
    // Run from the PLL at 120 MHz.
    g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
            SYSCTL_OSC_MAIN |
            SYSCTL_USE_PLL |
            SYSCTL_CFG_VCO_480), 120000000);
#endif
    // Configure the device pins.
    PinoutSet(true, false);
    GPIO_Configure();
    /********************************EEPROM INITIALIZATION********************************/
    initialize_Internal_EEPR();
    LoadEEPROMAllParameters();
    // Initialize the UART 0.
    UARTStdioConfig(0, 115200, g_ui32SysClock);
    /********************************UART CONFIGURATIONS**********************************/
   //    Initialize_Uart(0);
    Initialize_Uart(1);
    Initialize_Uart(2);
    Initialize_Uart(3);
    // Configure SysTick for a periodic interrupt at 10ms.
    SysTickPeriodSet((g_ui32SysClock / 1000) * SYSTEM_TICK_MS);
    SysTickEnable();
    SysTickIntEnable();
    // Initialized the flash program block and read the current settings.
    FlashPBInit(FLASH_PB_START, FLASH_PB_END, 256);
    pParams = (sParameters *)FlashPBGet();
    // Use the defaults if no settings were found.
    if(pParams == 0)
        g_sConfig = g_sDefaultParams;
    else
        g_sConfig = *pParams;
    // Set the IP address to 0.0.0.0.
    // Enable processor interrupts.
    IntMasterEnable();
    // Set the interrupt priorities.  We set the SysTick interrupt to a higher
    // priority than the Ethernet interrupt to ensure that the file system
    // tick is processed if SysTick occurs while the Ethernet handler is being
    // processed.  This is very likely since all the TCP/IP and HTTP work is
    // done in the context of the Ethernet interrupt.
    IntPriorityGroupingSet(4);
    IntPrioritySet(INT_EMAC0, ETHERNET_INT_PRIORITY);
    IntPrioritySet(FAULT_SYSTICK, SYSTICK_INT_PRIORITY);
    g_sConfig.bProxyEnabled=0;
    if(g_sConfig.bProxyEnabled)
        EthClientProxySet(g_sConfig.pcProxy);
        EthClientInit(EnetEvents);
    else
        EthClientProxySet(0);
    UpdateMACAddr();
    g_ui32IPaddr = EthClientAddrGet();
    // Update the current city information.
    UpdateUART();
    // Loop forever.  All the work is done in interrupt handlers.
    /*************************************ENABLING RTC MODULE******************************************************/
	ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_HIBERNATE);
	// Wait for the Hibernate module to be ready.
	while(!ROM_SysCtlPeripheralReady(SYSCTL_PERIPH_HIBERNATE)){}
	ROM_HibernateEnableExpClk(g_ui32SysClock);
	ROM_SysCtlDelay(3000);
	ROM_HibernateClockConfig(HIBERNATE_OSC_LOWDRIVE);
	ROM_SysCtlDelay(1000);
	ROM_HibernateRTCTrimSet(0x7FFF);
	ROM_HibernateRTCEnable(); // start RTC count
    /********************************TIMER CONFIGURATIONS**********************************/
    Initialize_TIMER(TIMER1);
    Initialize_TIMER(TIMER0);
    /*******************************Initialize EEPROM I2C********************************/
    InitI2C1();
    /********************************ADC CONFIGURATIONS**********************************/
    ADC_Configure();
    /********************************SD Card CONFIGURATIONS**********************************/
    ConfigureSD_Card();
    UpadateParam();
    /*******************************UPDATE DISPLAY PARAMETERS****************************/
    InitDisplayVariables();
    //WriteEEPbysize(&Def_QR_CodeA[0] , 0X28 ,20);
    //WriteEEPbysize(&Def_QR_CodeB[0] , 0x3C ,20);
   // WriteEEPbysize(&Def_QR_CodeC[0] , 0X50 ,20);
   // UpdateFaultLogCount(1);
   // SetChargingCostParams(0,0,0,0,1);
   // SetChargingCostParams(0,0,0,0,2);
   // SetChargingCostParams(0,0,0,0,3);
    InitCostVariablesfromEEPOnLoad();
    LoadEEPParameters();
    LoadVPParamValueFromEEProm();
    LoadMeterValueOnInitialization();
    FormatHandshakeStr();
    //UpdateFaultTabletoSDCard();
    //UpdateTLTabletoSDCard();
   // Update1KfullCountFlag(0,enFaultLog);
   // Update1KfullCountFlag(0,enTradeLog);
   //Update1KfullCountFlag(0,enCacheData);
   //Fault_Table1K_Flag = Read1Kflag(enFaultLog);
   //TL_Table1K_Flag = Read1Kflag(enTradeLog);
   //CacheMem1K_Flag = Read1Kflag(enCacheData);
   //UpdateFaultLogCount(1);
   //UpdateTLLogCount(0);
   // FaultTableTotalPages = TotalPageCount(TotalSavedLogCount_Fault);
   // TL_TotalPages = TotalPageCount(TotalSavedLogCount_TL);
    //FaultTableCurrentPageNo = GetCurrentPage(6);
    //TL_CurrentPageNo = GetCurrentPage(12);
    //ParseSDCardDataFaultTable(1);
    //ParseSDCardDataTLTable(1);
  //  InitializeDisplayParameters();
     //memset(&ChargingRateA,0,4);
    //ReadEEpbysize(Variabledatatable[TBID_PRODUCTID].Default_value ,Variabledatatable[TBID_PRODUCTID].EepAdress,Variabledatatable[TBID_PRODUCTID].DataLength );
  //  uint32_t defval[1];
  //  defval[0] = 0;
  //  Set_Int_EEP_32bit(defval , OCPP_VERSION );
    //Set_Int_EEP_32bit(defval , 820 );
   // Set_Int_EEP_32bit(defval , 824 );
    //OverVoltage =  Get_Int_EEP_32bit(Variabledatatable[TBID_OVERVOLTAGE].EepAdress);
    //LocalIpAddr =   Get_Int_EEP_32bit(Variabledatatable[TBID_LOCALIPADDR].EepAdress);
   // xx =  ReqFunctions[Id_Authorize]();
   // UARTprintf("%s \n", Response);
   // xx =  ReqFunctions[Id_BootNotification]();
   xx =   Req_Authorize();
    //Pointer to string Array Get Field Value example
        int i=0;
        char **ptr = NULL;
        ptr =ActionString;
        strcpy(buffr, ptr[0]);
        strcpy(buffr, ptr[1]);
        for(i=0;i<2;i++)
            UARTprintf("   %s \n", ptr[i]);
    //Pointer to string Array Get Field Name example
        int i=0;
        char **ptr = NULL;
        ptr =TypeField_Name_strings[0];
        for(i=0;i<2;i++)
    strcpy(model_str , "EVAC001.01");
    strcpy(VendorName_str , "E-fill Pvt. Ltd.");
        int i=0;
        char **ptr = NULL;
        ptr =TypeFieldstrings[0];
        for(i=0;i<2;i++)
    //Pointer to string Array Get Enum strings Example
    int i=0;
    char **ptr = NULL;
    char **ptr1 = NULL;
    ptr =EnumStrings[0];  //Here Enter index of Enum
    ptr1 =EnumStrings[1];  //Here Enter index of Enum
    strcpy(buffr, ptr[0]); //Get this by enum Value for perticular parameter
    strcpy(buffr, ptr[1]); //Get this by enum Value for perticular parameter
    strcpy(buffr, ptr[2]);
    strcpy(buffr, ptr[3]);
    strcpy(buffr, ptr[4]);
    strcpy(buffr, ptr1[0]);
    strcpy(buffr, ptr1[1]);
    strcpy(buffr, ptr1[2]);
    strcpy(buffr, ptr1[3]);
    strcpy(buffr, ptr1[4]);
    strcpy(buffr, ptr1[5]);
    strcpy(buffr, ptr1[6]);
    strcpy(buffr, ptr1[7]);
    strcpy(buffr, ptr1[8]);
    strcpy(buffr, ptr1[9]);
   //sprintf("%s",ptr[0]);
    for(i=0;i<4;i++)
    for(i=0;i<4;i++)
        UARTprintf("   %s \n", ptr1[i]);
  //  UARTprintf("This is new! \n", Response);
 //   RelayStates.Bit.Relay_1=STATEON;
  //  RelayStates.Bit.Relay_2=STATEON;
  //  RelayStates.Bit.Relay_3=STATEON;
    UpdateSDCardTL.TL_SavePending[1]=0;
    UpdateSDCardTL.TL_SavePending[2]=0;
    UpdateSDCardTL.TL_SavePending[3]=0;
    ParamUpdateFlags.Bit.ParamStartStopFlag=0;
    ParamUpdateFlags.Bit.TimerFlagInitDelay=0;
    DispControlFuncLatest.Bit.Flag_fault_Upbtn=1;
    DispControlFuncLatest.Bit.Flag_TL_Downbtn=1;
    TimerFlags.Bit.Flag_InitFault=0;
    EVParam.InitBootNotificationDoneflag=0;
    FuctionHandle[Id_BootNotification].BIT_FIELD.ProcessingEn=1;
    //FuctionHandle[Id_StartTransactionOCP16].BIT_FIELD.ProcessingEn=1;
    InitModemParams();
    OV_OC_DelayTime = OVOC_DETECT_DELAY;
    RelayStates.Bit.BatteryPowerRelay = STATEON;
    while(1)
        if(g_iState == STATE_NEW_CONNECTION) g_iState = STATE_CONNECTED_IDLE;
        if((PowerUpflag==1)&&(g_iState==STATE_CONNECTED_IDLE))
        	PowerUpflag = 0;
        if((PowerUpflag==0)&&(g_iState == STATE_NOT_CONNECTED)&&(EthResetRequired==0))
        	EthResetRequired = 1;
        if((g_iState == STATE_CONNECTED_IDLE)&&(EthResetRequired==1))
        	WaitEthReconnect = WAIT_ETH_RECONNECT;
        	//reset here
        Sec_1Loop();
      //  HandleConnectionsServerStates();
        CalculateEnergy_MeterValues();
        ProcessMcuLed();
        InputPfcStatus();
        RelayControl();
        //Response once Data Received from Server(Take a flag which tell to responce)
        if(g_ui32Delay<=0)
            UpdateUART();
            g_ui32Delay = SYSTEM_TICK_MS * 50;
        SendHandshake();
        Transmit_DataForCallResult();
        TransmitModemDataToServer();
      //  Transmit_DataForCall();
       // SD_Card_CommandHandler_Processor(); //UART Commands for SD Card
        //OCPP1.6 related Commands//
        GetStartTransactionResponseparam(); //OCPP1.6
        GetAuthResponseParam();
        GetBootNotificationResponseparam();
        GetUndefinedResponseparam();
        GetHeartbeatResponseParam();
        GetTransactionEventResponseparam();
        GetStopTransactionResponseparam();
        GetCancelReservationReqparam();
        GetCertificateSignedReqparam();
        GetChangeAvailabilityReqparam();
        GetClearCacheReqparam();
        GetClearChargingProfileReqparam();
        GetClearDisplayMessageReqparam();
        GetClearVariableMonitoringReqparam();
        GetCostUpdatedReqparam();
        GetCustomerInformationReqparam();
        GetDataTransferReqparam();
        GetDeleteCertificateReqparam();
        GetBaseReportReqparam();
        GetChargingProfilesReqparam();
        GetCompositeScheduleReqparam();
        GetDisplayMessagesReqparam();
        GetInstalledCertificateIdsReqparam();
        GetLocalListVersionReqparam();
        GetLogReqparam();
        GetMonitoringReportReqparam();
        GetReportReqparam();
        GetTransactionStatusReqparam();
        InstallCertificateReqparam();
        PublishFirmwareReqparam();
        RequestStartTransactionReqparam();
        RemoteStartTransactionReqparam();
        RequestStopTransactionReqparam();
        RemoteStopTransactionReqparam();
        ReserveNowReqparam();
        ResetReqparam();
        SendLocalListReqparam();
        SetChargingProfileReqparam();
        SetDisplayMessageReqparam();
        SetMonitoringBaseReqparam();
        SetMonitoringLevelReqparam();
        SetNetworkProfileReqparam();
        SetVariablesReqparam();
        TriggerMessageReqparam();
        UnlockConnectorReqparam();
        UnpublishFirmwareReqparam();
        UpdateFirmwareReqparam();
        GetConfigurationReqparam();
        FnTx_Authorize();
        FnTx_BootNotification();
        FnTx_FirmwareStatusNotification();
        FnTx_Heartbeat();
        FnTx_LogStatusNotification();
        FnTx_MeterValues();
        FnTx_NotifyChargingLimit();
        FnTx_ReservationStatusUpdate();
        FnTx_SecurityEventNotification();
        FnTx_StatusNotification();
        FnTx_TransactionEvent();
        FnTx_StartTransaction();
        FnTx_StopTransaction();
        FnTxC_CancelReservation();
        FnTxC_CertificateSigned();
        FnTxC_ChangeAvailability();
        FnTxC_ClearCache();
        FnTxC_ClearChargingProfile();
        FnTxC_ClearDisplayMessage();
        FnTxC_ClearVariableMonitoring();
        FnTxC_CostUpdated();
        FnTxC_CustomerInformation();
        FnTxC_DataTransfer();
        FnTxC_DeleteCertificate();
        FnTxC_GetBaseReport();
        FnTxC_GetChargingProfiles();
        FnTxC_GetCompositeSchedule();
        FnTxC_GetDisplayMessages();
        FnTxC_GetInstalledCertificateIds();
        FnTxC_GetLocalListVersion();
        FnTxC_GetLog();
        FnTxC_GetMonitoringReport();
        FnTxC_GetReport();
        FnTxC_GetTransactionStatus();
        FnTxC_InstallCertificate();
        FnTxC_PublishFirmware();
        FnTxC_RequestStartTransaction();
        FnTxC_RequestStopTransaction();
        FnTxC_RemoteStopTransaction();
        FnTxC_ReserveNow();
        FnTxC_Reset();
        FnTxC_SendLocalList();
        FnTxC_SetChargingProfile();
        FnTxC_SetDisplayMessage();
        FnTxC_SetMonitoringBase();
        FnTxC_SetMonitoringLevel();
        FnTxC_SetNetworkProfile();
        FnTxC_SetVariables();
        FnTxC_TriggerMessage();
        FnTxC_UnlockConnector();
        FnTxC_UnpublishFirmware();
        FnTxC_UpdateFirmware();
        FnTxC_RemoteStartTransaction();
        FnTxC_GetConfiguration();
        TransmitPeriodicHeartbeat();
        TransmitPeriodicBootNotification();
        //Display Hnadling Functions//
        UpdateVPDataBufftoEEPandAssignvaluetoVP();
        UpdateStartStopChargingIcon();
        UpdateCurrent_Voltage_Power();
        UpdateTime();
        UpdateNetworkStatus();
        //UpdateandCheckOTP();
        //UpdateandCheckSettingUserIDPassword();
        UpdateCheckIpMode();
        updateFaultTable();
        UploadFaultTableData();
        updateTradeLogsTable();
        UploadTLTableData();
        StartChargingDisplayUpdate();
        StopChargingDisplayUpdate();
        StopChargingA();
        StopChargingB();
        StopChargingC();
        StartChargingGunA();
        StartChargingGunB();
        StartChargingGunC();
        UpdateRTCTimetoDisplay();
        UpdateRTCTimefromDisplay();
        CalculateSessionDurationAllGun();
        UpdatePicNumber();
        UpdateCostParamtodisplayA();
        UpdateCostParamtodisplayB();
        UpdateCostParamtodisplayC();
        UpdateRealtimeCostGunA();
        UpdateRealtimeCostGunB();
        UpdateRealtimeCostGunC();
        ChargingAnimationPicshow();
        GetPFCFaults(); //Uncomment Later
        FaultDisplay();
        WriteFaultDataToDisplay();
        OV_OC_faults(); //Uncomment Later
        UpdateFaultToServer();
        TxMeterValueA();
        TxMeterValueB();
        TxMeterValueC();
        RealTimeUpdateSDCardFaults();
        RealTimeUpdateSDCardTL();
        //GSM Modem
        ProcessModemATRxbuff();
        ProcessModemUartRxPack();
        ProcessModemUartRxPack2();
        StateMachineModemATCommunication();
        ModemResesetOnRetries();
        StartModemCommAfterReset();
        HanshakeProcess();
        TurnModuleOnOff();
        ModuleReset();
        GetSignalStrengthTx();
        ProcessStatusNotificationPeriodic();
        if(TimerFlags.Bit.FunctionCodeProcessTimeflag==1)
          TimerFlags.Bit.FunctionCodeProcessTimeflag=0;
          Fc_B_C02_Authorization_StartButton_Con1();
          Fc_B_C02_Authorization_StartButton_Con2();
          Fc_B_C02_Authorization_StartButton_Con3();
          Fc_B_C05_Authorization_CSMS_ConAll();
          Fc_B_F03_RemoteStopTransaction_CSMS_ConAll();
          StopFaultTxInit();
          Fc_B_E06_FaultStop_CSMS_ConAll();
        HandleMultiStart();
        HandleMultiStop();
        CheckModemServerComm();
        if(g_iState == STATE_NOT_CONNECTED)
        	 TCP_ConnectionStatus = e_TCP_Disconnected;
        else
        	TCP_ConnectionStatus = e_TCP_Connected;
//Author: Pradeep Kumar
//Date: 06/01/2021  Time: 19:37
//Function void Transmit_Data(void)
//Input Parameters: None
//Description:This Function will be called in while Loop
//This is the main Function to transmit Data to Ethernet
	if(g_iState==STATE_CONNECTED_IDLE)
		if(EthResetRequired==1)
			//EthClientTCPDisconnect();
			EthResetRequired=0;
			Soft_Reset();
	//if((ProcessTransmit.TransmitFlag[e_IdCallResult]==0)||(ProcessTransmit.TransmitFlag[e_IdCall]==0))return;
	//if(ProcessTransmit.Tx_Inprogress[e_IdCallResult]==1)return; //Uncomment Later , This will Block packet if Server Did not Respond//
	if(WaitEthReconnect>0)return;
	if((WebSocketflags.HanshakeStatus ==1)&&(WebSocketflags.HandshakeInprogress==0))
			if(ProcessTransmit.TransmitFlag[e_IdCallResult]==1)
			//EthClientReset();
			//Return 1 if packet send successfully otherwise return 0
			if(WeatherForecast(iWSrcOpenWeatherMap,g_psCityInfo[0].pcName,&g_psCityInfo[0].sReport,WeatherEvent)==0)
				g_iState=STATE_WAIT_DATA;
			ProcessTransmit.TransmitFlag[e_IdCallResult]=0;
			ProcessTransmit.Tx_Inprogress[e_IdCallResult]=1;
			Time_Sec = 10; //10 Sec
			else if(ProcessTransmit.TransmitFlag[e_IdCall]==1)
					g_iState=STATE_CONNECTED_IDLE;
				ProcessTransmit.TransmitFlag[e_IdCall]=0;
				ProcessTransmit.Tx_Inprogress[e_IdCall]=1;
	else if((WebSocketflags.HanshakeStatus ==0)&&(WebSocketflags.HandshakeInprogress==0))
		WebSocketflags.FlagProcessHandshake=1;
	if( ProcessTransmit.TransmitFlag[e_IdCall]==0)return;
	  if(ProcessTransmit.Tx_Inprogress[e_IdCall]==1)return; //Uncomment Later , This will Block packet if Server Did not Respond//
			//EthClientReset();
			if(WeatherCurrent(iWSrcOpenWeatherMap,g_psCityInfo[0].pcName,&g_psCityInfo[0].sReport,WeatherEvent)==0)
				restore();
				//		g_sEnet.eState = 8;
//Function void HandleConnectionsServerStates(void)
//This Function Handles and gives Connection Status
        if(Time_Sec == 0)
            // Close out the current connection.
            //   EthClientTCPDisconnect();
            //lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_STATIC);
            // lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
        	//EthClientReset();
        	//EthClientInit(EnetEvents);
            TCP_ConnectionStatus = e_TCP_NotResponding;
            Time_Sec = 10; //Retry Delay
        return;
        if(TCP_ConnectionStatus==e_TCP_NotResponding)
            if(Time_Sec == 0)
                //   WeatherForecast1(iWSrcOpenWeatherMap,
                //                                  g_psCityInfo[0].pcName,
                //                                  &g_psCityInfo[0].sReport,
                //                                  WeatherEvent);
                // This Condition Should not Occurr//
                //lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
            	//EthClientReset();
                // EthClientInit(EnetEvents);
                g_iState=STATE_NOT_CONNECTED;
                //   g_iState= STATE_CONNECTED_IDLE;
        else
    else
    if(TimerFlags.Bit.MCU_Led_Flag_1sec==0)return;
    TimerFlags.Bit.MCU_Led_Flag_1sec=0;
    if(ROM_GPIOPinRead(GPIO_PORTK_BASE ,MCU_LED )==0)  ROM_GPIOPinWrite(GPIO_PORTK_BASE, MCU_LED, MCU_LED);
    else  ROM_GPIOPinWrite(GPIO_PORTK_BASE, MCU_LED, 0);
    ProcessChargingTimeout();
  //  IndicationPower();
    ChargingLEDAIndication();
    ChargingLEDBIndication();
	ChargingLEDCIndication();
	FaultIndication();
	//if(ProcessTransmit.Tx_Inprogress[e_IdCallResult]==0)return;
	if(WebSocketflags.FlagProcessHandshake==0)return;
    	WebSocketflags.FlagProcessHandshake=0;
    	WebSocketflags.HandshakeInprogress=1;
    		//EthClientReset();
当我尝试使用 enet_weather 示例时、也会发生同样的情况。
    您好 Pradeep、
    您 的笔记本电脑可能是自行分配的196.x.x.x 地址,或者您的无线路由器没有配置 DHCP 地址池? 您可以选中 Windows,依次选择“开始”、“运行”,键入 cmd HIT ENTER,在命令提示符处键入“route print”,并尝试 netstat。 其他一些网络命令可能是 ipconfig 等... 没有 IP 帮助程序的防火墙或路由器也可能会停止来自未知网络或客户端的 BootP 广播。
    感谢 G1的评论。 另请检查 DHCP 服务器是否与主机位于同一子网中。 TivaWare 库中有多个以太网示例。 如果它们都不能为您工作,则很可能是您的网络设置问题。
    谢谢、我将进行检查。
