[参考译文] TM4C1294NCPDT:是否可以在 TM4C1294NCPDT MCU 上移植 Linux?
Guru**** 2949630 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1050570/tm4c1294ncpdt-is-it-possible-to-port-linux-on-tm4c1294ncpdt-mcu
器件型号:TM4C1294NCPDT
我想知道  是否可以在 TM4C1294NCPDT MCU 上移植 Linux? 或者您不建议这样做?
