[参考译文] TMS570LS1224:120微秒的 ADC 采样延迟
Guru**** 2803255 points
Other Parts Discussed in Thread: HALCOGEN
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1019367/tms570ls1224-adc-sampling-delay-of-120micrsecs
器件型号:TMS570LS1224
主题中讨论的其他器件:HALCOGEN
我们观察到随附的 Halcogen 配置的延迟为120us。  e2e.ti.com/.../1778.adc.c
# TMS570LS1224PGE 07/16/21 10:27:05
ARCH=TMS570LS1224PGE
DRIVER.TOOLS.VAR.GCC.VALUE=0
DRIVER.TOOLS.VAR.ARM.VALUE=0
DRIVER.TOOLS.VAR.IAR.VALUE=0
DRIVER.TOOLS.VAR.GHS.VALUE=0
DRIVER.TOOLS.VAR.TI.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.VIM_CHANNEL_122_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_114_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_106_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_70_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_62_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_54_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_46_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_38_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.PMM_MEM_PD3_STATE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CAPTURE_EVENT_SOURCE_0.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_81_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_73_NAME.VALUE=het2LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_65_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_57_NAME.VALUE=adc2Group2Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_49_NAME.VALUE=spi4HighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_2_MAPPING.VALUE=2
DRIVER.SYSTEM.VAR.VIM_CAPTURE_EVENT_SOURCE_1.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_111_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_103_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_ADC1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.EQEP2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_MEMINIT_SELECTED.VALUE=1
DRIVER.SYSTEM.VAR.FLASH_DATA_3_WAIT_STATE_FREQ.VALUE=180.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_96_MAPPING.VALUE=96
DRIVER.SYSTEM.VAR.VIM_CHANNEL_88_MAPPING.VALUE=88
DRIVER.SYSTEM.VAR.VIM_CHANNEL_1_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_END_ADDRESS.VALUE=0xfcffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_5_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_DATA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_11_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_STC_SELFCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SPI3_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL1_BYPASS_ON_SLIP.VALUE=0x20000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_124_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_116_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_108_NAME.VALUE=ecap5Interrupt
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SIZE.VALUE=256_KB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_100_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_98_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_20_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_12_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_2_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI2_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CRC_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.MIBSPI1_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_HCLK_FREQ.VALUE=160.000
DRIVER.SYSTEM.VAR.CLKT_PLL2_FREQ.VALUE=160.00
DRIVER.SYSTEM.VAR.VIM_CHANNEL_81_MAPPING.VALUE=81
DRIVER.SYSTEM.VAR.VIM_CHANNEL_73_MAPPING.VALUE=73
DRIVER.SYSTEM.VAR.VIM_CHANNEL_65_MAPPING.VALUE=65
DRIVER.SYSTEM.VAR.VIM_CHANNEL_57_MAPPING.VALUE=57
DRIVER.SYSTEM.VAR.VIM_CHANNEL_49_MAPPING.VALUE=49
DRIVER.SYSTEM.VAR.VIM_CHANNEL_40_NAME.VALUE=dmaBTCAInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_32_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_24_NAME.VALUE=het1LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_16_NAME.VALUE=can1HighLevelInterrupt
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_92_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_84_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_76_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_68_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_31_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_23_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_15_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_CCM_SELFCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.PMM_MEM_PD2_STATE_AVAIL.VALUE=1
DRIVER.SYSTEM.VAR.ECLK_CLKSRC.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.CLKT_PLL2_OUTPUT_DIV.VALUE=2
DRIVER.SYSTEM.VAR.CLKT_EXT2_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CLKT_PLL1_SOURCE_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_END_ADDRESS.VALUE=0x63ffffff
DRIVER.SYSTEM.VAR.VIM_CHANNEL_96_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_88_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_9_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_4_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_HET2_DP_PBISTCHECK_ENA.VALUE=0x00040000
DRIVER.SYSTEM.VAR.CLKT_RTI2_PRE_SOURCE.VALUE=PLL1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SIZE_VALUE.VALUE=0x1A
DRIVER.SYSTEM.VAR.VIM_CHANNEL_99_NAME.VALUE=etpwm5TripZoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_50_MAPPING.VALUE=50
DRIVER.SYSTEM.VAR.VIM_CHANNEL_42_MAPPING.VALUE=42
DRIVER.SYSTEM.VAR.VIM_CHANNEL_34_MAPPING.VALUE=34
DRIVER.SYSTEM.VAR.VIM_CHANNEL_26_MAPPING.VALUE=26
DRIVER.SYSTEM.VAR.VIM_CHANNEL_18_MAPPING.VALUE=18
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD2_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.CLKT_VCLK3_DOMAIN_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_ECC_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_BANKS.VALUE=4
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_IRQ_DISP_ENTRY.VALUE=_isrStub
DRIVER.SYSTEM.VAR.VIM_CHANNEL_111_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_103_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_92_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_84_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_76_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_68_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CAN3_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK1_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.ETPWM4_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.DCC2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_PLL1_RESET_ON_OSCILLATOR_FAIL.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_PERMISSION_VALUE.VALUE=0x0600
DRIVER.SYSTEM.VAR.VIM_CHANNEL_11_MAPPING.VALUE=11
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.LBIST_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK2_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_END_ADDRESS.VALUE=0x003fffff
DRIVER.SYSTEM.VAR.VIM_CHANNEL_41_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_33_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_25_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_17_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_3_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ECAP6_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SCI_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_DATA_1_WAIT_STATE_FREQ.VALUE=100.0
DRIVER.SYSTEM.VAR.RAM_STACK_IRQ_BASE.VALUE=0x08000500
DRIVER.SYSTEM.VAR.VIM_CHANNEL_125_MAPPING.VALUE=125
DRIVER.SYSTEM.VAR.VIM_CHANNEL_117_MAPPING.VALUE=117
DRIVER.SYSTEM.VAR.VIM_CHANNEL_109_MAPPING.VALUE=109
DRIVER.SYSTEM.VAR.VIM_CHANNEL_90_NAME.VALUE=etpwm1Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_82_NAME.VALUE=dcc1DoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_74_NAME.VALUE=sciLowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_66_NAME.VALUE=i2cInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_58_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_DOMAIN_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_PMU_GLOBAL_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_BASE_ADDRESS.VALUE=0xFF000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_TASK_REGION_STACK.VALUE=5
DRIVER.SYSTEM.VAR.VIM_CHANNEL_97_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_89_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_81_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_73_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_70_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_65_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_62_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_57_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_54_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_49_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_46_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_38_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD2_STATE.VALUE=1
DRIVER.SYSTEM.VAR.EMAC_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_PBIST_DP_SELECTED.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_8_MAPPING.VALUE=8
DRIVER.SYSTEM.VAR.VIM_CHANNEL_2_NAME.VALUE=vPortPreemptiveTick
DRIVER.SYSTEM.VAR.CORE_PMU_COUNTER0_EVENT.VALUE=0x11
DRIVER.SYSTEM.VAR.FLASH_ADDRESS_WAIT_STATES.VALUE=1
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_RESET_ENTRY.VALUE=_c_int00
DRIVER.SYSTEM.VAR.VIM_CHANNEL_127_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_122_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_119_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_114_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_106_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_9_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ADC1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.MIBSPI_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ECLK_VCLK1_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL_FREQ.VALUE=00.0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SIZE_VALUE.VALUE=0x0A
DRIVER.SYSTEM.VAR.VIM_CHANNEL_125_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_117_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_110_MAPPING.VALUE=110
DRIVER.SYSTEM.VAR.VIM_CHANNEL_109_NAME.VALUE=ecap6Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_102_MAPPING.VALUE=102
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.RAM_LENGTH.VALUE=0x00030000
DRIVER.SYSTEM.VAR.CORE_MPU_TOTAL_REGION.VALUE=12
DRIVER.SYSTEM.VAR.CLKT_VCLK1_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SIZE.VALUE=64_MB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_124_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_116_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_108_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_ESRAM_SP_PBISTCHECK_VALUE_NEW.VALUE=0x00300020
DRIVER.SYSTEM.VAR.VIM_CHANNEL_41_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_33_NAME.VALUE=dmaFTCAInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_25_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_17_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_1_MAPPING.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL_SOURCE_ENABLE.VALUE=0x00000008
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_END_ADDRESS.VALUE=0x203fffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_BASE_ADDRESS.VALUE=0xF0000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_40_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_32_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_24_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_16_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_5_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_PARITY_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.SAFETY_INIT_FRAY_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_TYPE_VALUE.VALUE=0x0000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_95_MAPPING.VALUE=95
DRIVER.SYSTEM.VAR.VIM_CHANNEL_87_MAPPING.VALUE=87
DRIVER.SYSTEM.VAR.VIM_CHANNEL_79_MAPPING.VALUE=79
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_4_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_IRQ_VIC_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_121_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_113_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_105_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_70_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_62_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_54_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_50_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_46_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_42_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_38_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_34_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_26_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_18_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI1_DP_PBISTCHECK_ENA.VALUE=0x00000040
DRIVER.SYSTEM.VAR.SPI1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_100_NAME.VALUE=etpwm6Interrupt
DRIVER.SYSTEM.VAR.CLKT_RTI2_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.RAM_ECC_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_99_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN4_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SCI_ALL_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL_FREQ_INPUT.VALUE=16.0
DRIVER.SYSTEM.VAR.STC_INTERVAL.VALUE=24
DRIVER.SYSTEM.VAR.CLKT_LPO_HIGH_TRIM_VALUE.VALUE=16
DRIVER.SYSTEM.VAR.CLKT_GCLK_FREQ.VALUE=160.000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_PERMISSION_VALUE.VALUE=0x1000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_80_MAPPING.VALUE=80
DRIVER.SYSTEM.VAR.VIM_CHANNEL_72_MAPPING.VALUE=72
DRIVER.SYSTEM.VAR.VIM_CHANNEL_64_MAPPING.VALUE=64
DRIVER.SYSTEM.VAR.VIM_CHANNEL_56_MAPPING.VALUE=56
DRIVER.SYSTEM.VAR.VIM_CHANNEL_48_MAPPING.VALUE=48
DRIVER.SYSTEM.VAR.CLKT_PLL1_REF_CLOCK_DIV.VALUE=6
DRIVER.SYSTEM.VAR.FLASHW_BASE_ADDRESS.VALUE=0xFFF87000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_FIQ_ENTRY.VALUE="ldr pc,[pc,#-0x1b0]"
DRIVER.SYSTEM.VAR.VIM_CHANNEL_10_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN5_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.SCILIN_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SPI_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ALL_DVR_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CCM_MENU_VALUE.VALUE=0x0001
DRIVER.SYSTEM.VAR.PBIST_ENA1.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK4_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.VIM_CHANNEL_97_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_89_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_OSCILLATOR_FREQ.VALUE=16.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_91_NAME.VALUE=etpwm1TripZoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_83_NAME.VALUE=dcc2DoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_75_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_67_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_59_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_41_MAPPING.VALUE=41
DRIVER.SYSTEM.VAR.VIM_CHANNEL_33_MAPPING.VALUE=33
DRIVER.SYSTEM.VAR.VIM_CHANNEL_25_MAPPING.VALUE=25
DRIVER.SYSTEM.VAR.VIM_CHANNEL_17_MAPPING.VALUE=17
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_IRQ_MODE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_11_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_11_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.PMM_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.EMIF_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CAN1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CAN_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_3_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.PMM_MEM_PD3_STATEVALUE.VALUE=0xA
DRIVER.SYSTEM.VAR.CLKT_PLL1_OUTPUT_DIV.VALUE=2
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CLKT_PLL2_FM_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_BASE_ADDRESS.VALUE=0x08400000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_92_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_91_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_84_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_83_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_76_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_75_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_68_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_67_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_59_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_8_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_STC_CPUSELFTEST_ENA.VALUE=0
DRIVER.SYSTEM.VAR.ETPWM2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.HET1_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_RTI1_PRE_SOURCE.VALUE=PLL1
DRIVER.SYSTEM.VAR.FLASH_MODE_VALUE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SIZE_VALUE.VALUE=0x19
DRIVER.SYSTEM.VAR.VIM_CHANNEL_126_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_118_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_10_MAPPING.VALUE=10
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SIZE.VALUE=128_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_125_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_117_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_109_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_91_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_83_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_75_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_67_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_59_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_3_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_HET1_DP_PBISTCHECK_ENA.VALUE=0x00001000
DRIVER.SYSTEM.VAR.ECAP4_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL2_BYPASS_ON_SLIP.VALUE=0x20000000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_124_MAPPING.VALUE=124
DRIVER.SYSTEM.VAR.VIM_CHANNEL_116_MAPPING.VALUE=116
DRIVER.SYSTEM.VAR.VIM_CHANNEL_108_MAPPING.VALUE=108
DRIVER.SYSTEM.VAR.VIM_CHANNEL_50_NAME.VALUE=adc2Group0Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_42_NAME.VALUE=can2LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_34_NAME.VALUE=dmaLFSAInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_26_NAME.VALUE=mibspi1LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_18_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.FLASH_ARBITRATION.VALUE=FIX
DRIVER.SYSTEM.VAR.CLKT_LPO_HIGH_SOURCE_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_110_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_102_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.PBIST_ALGO_9_10.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL2_FREQ_INPUT.VALUE=16.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_7_MAPPING.VALUE=7
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.CLKT_RTI2_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_BACKGROUND_REGION_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_8_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_2_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CONFIG.VALUE=TRUE
DRIVER.SYSTEM.VAR.VIM_CHANNEL_101_MAPPING.VALUE=101
DRIVER.SYSTEM.VAR.VIM_CHANNEL_101_NAME.VALUE=etpwm6TripZoneInterrupt
DRIVER.SYSTEM.VAR.RAM_STACK_ABORT_LENGTH.VALUE=0x00000100
DRIVER.SYSTEM.VAR.FLASH_DATA_MAX_WAIT_STATES.VALUE=3
DRIVER.SYSTEM.VAR.FLASH_MODE.VALUE=PIPELINE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_61_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_61_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_53_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_53_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_45_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_45_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_40_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_37_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_37_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_32_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_29_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_29_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_24_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_16_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI4_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_EMAC_SP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.MINIT_VALUE.VALUE=0x1E57F
DRIVER.SYSTEM.VAR.VIM_CHANNEL_0_MAPPING.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL1_DIV.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK4_DOMAIN_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL2_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.RAM_BASE_ADDRESS.VALUE=0x08000000
DRIVER.SYSTEM.VAR.CORE_PMU_EVENT_EXPORT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_126_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_118_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_110_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_102_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_96_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_88_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.GIO_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SIZE_VALUE.VALUE=0x17
DRIVER.SYSTEM.VAR.VIM_CHANNEL_94_MAPPING.VALUE=94
DRIVER.SYSTEM.VAR.VIM_CHANNEL_86_MAPPING.VALUE=86
DRIVER.SYSTEM.VAR.VIM_CHANNEL_78_MAPPING.VALUE=78
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_TYPE.VALUE=STRONGLYORDERED_SHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_3_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_UNDEF_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_8_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_PBIST_SP_SELECTED.VALUE=0
DRIVER.SYSTEM.VAR.RAM_STACK_ABORT_BASE.VALUE=0x08000600
DRIVER.SYSTEM.VAR.VIM_CHANNEL_92_NAME.VALUE=etpwm2Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_84_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_76_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_68_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CLKT_RTI1_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_123_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_115_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_107_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_31_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_23_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_15_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_1_INT_TYPE.VALUE=FIQ
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD3_STATE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_EFUSE_SELFCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_GHV_WAKUP_SOURCE.VALUE=OSC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_TYPE_VALUE.VALUE=0x0000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_71_MAPPING.VALUE=71
DRIVER.SYSTEM.VAR.VIM_CHANNEL_63_MAPPING.VALUE=63
DRIVER.SYSTEM.VAR.VIM_CHANNEL_55_MAPPING.VALUE=55
DRIVER.SYSTEM.VAR.VIM_CHANNEL_47_MAPPING.VALUE=47
DRIVER.SYSTEM.VAR.VIM_CHANNEL_39_MAPPING.VALUE=39
DRIVER.SYSTEM.VAR.VIM_CHANNEL_4_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CORE_PMU_COUNTER1_EVENT.VALUE=0x11
DRIVER.SYSTEM.VAR.EFUSE_SELFTEST_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_DOMAIN_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.RAM_LINK_BASE_ADDRESS.VALUE=0x08000800
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_120_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_112_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_104_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_30_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_22_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_14_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_127_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_119_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CLKT_PLL2_DIV.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK3_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_LPO_TRIM_OTP_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SIZE.VALUE=8_MB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_95_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_87_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_79_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_61_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_53_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_45_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_37_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_29_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_VIM1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.FLASH_ADDRESS_WAIT_STATES_FREQ.VALUE=150.0
DRIVER.SYSTEM.VAR.RAM_STACK_BASE.VALUE=0x08000000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_51_NAME.VALUE=adc2Group1Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_43_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_40_MAPPING.VALUE=40
DRIVER.SYSTEM.VAR.VIM_CHANNEL_35_NAME.VALUE=can2HighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_32_MAPPING.VALUE=32
DRIVER.SYSTEM.VAR.VIM_CHANNEL_27_NAME.VALUE=linLowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_24_MAPPING.VALUE=24
DRIVER.SYSTEM.VAR.VIM_CHANNEL_19_NAME.VALUE=crcInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_16_MAPPING.VALUE=16
DRIVER.SYSTEM.VAR.CLKT_VCLK3_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_END_ADDRESS.VALUE=0xf07fffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.ETPWM7_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_1.VALUE=0
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_2.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_96_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_88_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN4_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_3.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_4.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_110_NAME.VALUE=eqep1Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_102_NAME.VALUE=etpwm7Interrupt
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_5.VALUE=1
DRIVER.SYSTEM.VAR.LBIST_STT.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_6.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_HTU2_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_7.VALUE=1
DRIVER.SYSTEM.VAR.ECAP2_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_8.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_TYPE_VALUE.VALUE=0x0010
DRIVER.SYSTEM.VAR.VIM_CHANNEL_123_MAPPING.VALUE=123
DRIVER.SYSTEM.VAR.VIM_CHANNEL_115_MAPPING.VALUE=115
DRIVER.SYSTEM.VAR.VIM_CHANNEL_107_MAPPING.VALUE=107
DRIVER.SYSTEM.VAR.VIM_CHANNEL_10_NAME.VALUE=het1HighLevelInterrupt
DRIVER.SYSTEM.VAR.PMM_MEM_PD2_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_9.VALUE=1
DRIVER.SYSTEM.VAR.RAM_STACK_USER_LENGTH.VALUE=0x00000300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_END_ADDRESS.VALUE=0x0843ffff
DRIVER.SYSTEM.VAR.VIM_CHANNEL_80_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_72_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_64_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_56_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_48_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_10_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_7_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_USB_SP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.SAFETY_INIT_PBIST_SELFCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ETPWM_OLDCODE.VALUE=1
DRIVER.SYSTEM.VAR.SCI2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.LIN_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_RTI1_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SIZE_VALUE.VALUE=0x11
DRIVER.SYSTEM.VAR.VIM_CHANNEL_6_MAPPING.VALUE=6
DRIVER.SYSTEM.VAR.CLKT_PLL2_SPEADING_AMOUNT.VALUE=61
DRIVER.SYSTEM.VAR.CLKT_PLL2_SPEADING_RATE.VALUE=255
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_BASE_ADDRESS.VALUE=0x08001000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_TYPE.VALUE=STRONGLYORDERED_SHAREABLE
DRIVER.SYSTEM.VAR.VIM_CHANNEL_121_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_113_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_105_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_90_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_90_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_82_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_82_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_74_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_74_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_66_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_66_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_58_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_58_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI5_DP_PBISTCHECK_ENA.VALUE=0x00000100
DRIVER.SYSTEM.VAR.CLKT_PLL2_RESET_ON_SLIP.VALUE=0x00000000
DRIVER.SYSTEM.VAR.ECLK_FREQ.VALUE=10.000
DRIVER.SYSTEM.VAR.CLKT_AVCLK1_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_100_MAPPING.VALUE=100
DRIVER.SYSTEM.VAR.VIM_CHANNEL_93_NAME.VALUE=etpwm2TripZoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_85_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_77_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_69_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.RAM_STACK_IRQ_LENGTH.VALUE=0x00000100
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_2_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_RTI2_POST_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_5_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.RAM_STACK_LENGTH.VALUE=0x00000800
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_PERMISSION.VALUE=PRIV_RO_USER_RO_EXEC
DRIVER.SYSTEM.VAR.CLKT_LPO_BIAS.VALUE=true
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_DIVIDER1.VALUE=4
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_END_ADDRESS.VALUE=0xffffffff
DRIVER.SYSTEM.VAR.CORE_PRAGMA_ENA.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_101_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_4_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_1_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SPI4_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_POST_SOURCE.VALUE=VCLKA4_DIVR
DRIVER.SYSTEM.VAR.CLKT_VCLK1_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_FREQ1.VALUE=0.000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_93_MAPPING.VALUE=93
DRIVER.SYSTEM.VAR.VIM_CHANNEL_85_MAPPING.VALUE=85
DRIVER.SYSTEM.VAR.VIM_CHANNEL_77_MAPPING.VALUE=77
DRIVER.SYSTEM.VAR.VIM_CHANNEL_69_MAPPING.VALUE=69
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_FREQ2.VALUE=80.0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SIZE.VALUE=16_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_BASE_ADDRESS.VALUE=0xFC000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_2_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_60_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_52_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_44_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_41_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_36_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_33_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_28_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_25_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_17_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.CLKT_PLL1_MUL.VALUE=120
DRIVER.SYSTEM.VAR.VIM_CHANNEL_60_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_52_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_44_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_36_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_28_NAME.VALUE=adc1Group2Interrupt
DRIVER.SYSTEM.VAR.CLKT_OSC_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SIZE.VALUE=16_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_SVC_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_125_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_117_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_109_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_98_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_31_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_23_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_15_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.PINMUX_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.PBIST_ALGO_3_4.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_LPO_BIAS_VALUE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_70_MAPPING.VALUE=70
DRIVER.SYSTEM.VAR.VIM_CHANNEL_62_MAPPING.VALUE=62
DRIVER.SYSTEM.VAR.VIM_CHANNEL_54_MAPPING.VALUE=54
DRIVER.SYSTEM.VAR.VIM_CHANNEL_46_MAPPING.VALUE=46
DRIVER.SYSTEM.VAR.VIM_CHANNEL_38_MAPPING.VALUE=38
DRIVER.SYSTEM.VAR.CLKT_AVCLK1_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL2_SOURCE_ENABLE.VALUE=0x00000080
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_PREFETCH_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_95_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_87_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_79_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_HTU2_DP_PBISTCHECK_ENA.VALUE=0x00080000
DRIVER.SYSTEM.VAR.SAFETY_INIT_EMAC_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_TASK_REGION_FIRST.VALUE=6
DRIVER.SYSTEM.VAR.PBIST_ALGO_15.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_111_NAME.VALUE=eqep2Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_103_NAME.VALUE=etpwm7TripZoneInterrupt
DRIVER.SYSTEM.VAR.PBIST_ALGO_16.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_VCLK2_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.RAM_LINK_LENGTH.VALUE=0x0002F800
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_END_ADDRESS.VALUE=0x080017ff
DRIVER.SYSTEM.VAR.VIM_CHANNEL_30_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_22_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_14_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_7_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_LPO_OSCFRQCONFIGCNT_VALUE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK2_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_31_MAPPING.VALUE=31
DRIVER.SYSTEM.VAR.VIM_CHANNEL_23_MAPPING.VALUE=23
DRIVER.SYSTEM.VAR.VIM_CHANNEL_15_MAPPING.VALUE=15
DRIVER.SYSTEM.VAR.VIM_CHANNEL_11_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.PBIST_ALGO_5_6.VALUE=0
DRIVER.SYSTEM.VAR.PBIST_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_HCLK_DOMAIN_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_122_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_114_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_111_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_106_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_103_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_10_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.ETPWM5_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ETPWM_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_PLL2_MUL.VALUE=120
DRIVER.SYSTEM.VAR.CLKT_RTI2_FREQ.VALUE=0.0
DRIVER.SYSTEM.VAR.CLKT_LPO_LOW_FREQ.VALUE=0.080
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_PREFETCH_ENTRY.VALUE=_prefetch
DRIVER.SYSTEM.VAR.VIM_CHANNEL_91_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_83_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_75_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_67_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_59_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_DMA_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK2_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_94_NAME.VALUE=etpwm3Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_86_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_78_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_OSCILLATOR_SOURCE_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_BASE_ADDRESS.VALUE=0x60000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_124_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_116_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_108_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_60_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_52_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_44_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_36_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_28_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.PMM_AUTO_CLK_WAKE_ENA.VALUE=0
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD4_STATE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_HET2_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.PBIST_ALGO_7_8.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL2_RESET_ON_OSCILLATOR_FAIL.VALUE=0x00000000
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_BASE_ADDRESS_0.VALUE=0x00030000
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_BASE_ADDRESS_1.VALUE=0x00180000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SIZE_VALUE.VALUE=0x08
DRIVER.SYSTEM.VAR.VIM_CHANNEL_122_MAPPING.VALUE=122
DRIVER.SYSTEM.VAR.VIM_CHANNEL_114_MAPPING.VALUE=114
DRIVER.SYSTEM.VAR.VIM_CHANNEL_106_MAPPING.VALUE=106
DRIVER.SYSTEM.VAR.VIM_CHANNEL_6_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD5_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.CORE_PMU_COUNTER2_EVENT.VALUE=0x11
DRIVER.SYSTEM.VAR.FLASH_DATA_WAIT_STATES.VALUE=3
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_95_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_87_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_79_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_PARITY_AVAILABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN3_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_RAMECC_SELFCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ADC2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK2_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.FLASH_DATA_2_WAIT_STATE_FREQ.VALUE=150.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_5_MAPPING.VALUE=5
DRIVER.SYSTEM.VAR.VIM_PARITY_INTERRUPT_MAPPED_TO_VIM.VALUE=FALSE
DRIVER.SYSTEM.VAR.VIM_CHANNELS.VALUE=128
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_BASE_ADDRESS_7.VALUE=0xF0200000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SIZE.VALUE=512_BYTES
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_7_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.PMM_MEM_PD1_STATE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN3_DP_PBISTCHECK_ENA.VALUE=0x00000010
DRIVER.SYSTEM.VAR.ECAP_OLDCODE.VALUE=1
DRIVER.SYSTEM.VAR.ESM_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_99_MAPPING.VALUE=99
DRIVER.SYSTEM.VAR.VIM_CHANNEL_61_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_53_NAME.VALUE=mibspi5HighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_45_NAME.VALUE=can3HighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_37_NAME.VALUE=mibspi3HighInterruptLevel
DRIVER.SYSTEM.VAR.VIM_CHANNEL_29_NAME.VALUE=can1LowLevelInterrupt
DRIVER.SYSTEM.VAR.PMM_MEM_PD1_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_PERMISSION.VALUE=PRIV_RW_USER_RO_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_5_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SIZE.VALUE=2_KB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_127_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_119_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_60_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_52_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_44_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_36_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_28_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_6_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.EQEP1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_LPO_HIGH_FREQ.VALUE=10.000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SIZE_VALUE.VALUE=0x11
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_IRQ_ENTRY.VALUE="ldr pc,[pc,#-0x1b0]"
DRIVER.SYSTEM.VAR.VIM_CHANNEL_101_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_81_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_73_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_65_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_57_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_49_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ECAP_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SPI2_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_GHV_POWER_DOWN_SOURCE.VALUE=OSC
DRIVER.SYSTEM.VAR.RAM_STACK_USER_BASE.VALUE=0x08000000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_120_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_112_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_104_NAME.VALUE=ecap1Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_92_MAPPING.VALUE=92
DRIVER.SYSTEM.VAR.VIM_CHANNEL_84_MAPPING.VALUE=84
DRIVER.SYSTEM.VAR.VIM_CHANNEL_76_MAPPING.VALUE=76
DRIVER.SYSTEM.VAR.VIM_CHANNEL_68_MAPPING.VALUE=68
DRIVER.SYSTEM.VAR.CLKT_GCLK_DOMAIN_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_1_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_81_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_73_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_65_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_57_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_49_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_ADC2_DP_PBISTCHECK_ENA.VALUE=0x00020000
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI4_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.SAFETY_INIT_USB_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.SYSTEM_INIT.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_20_NAME.VALUE=esmLowInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_12_NAME.VALUE=mibspi1HighLevelInterrupt
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_PERMISSION.VALUE=PRIV_NA_USER_NA_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_1_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_0_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_0_INT_TYPE.VALUE=FIQ
DRIVER.SYSTEM.VAR.DMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_PERMISSION_VALUE.VALUE=0x1100
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_PERMISSION_VALUE.VALUE=0x1200
DRIVER.SYSTEM.VAR.VIM_CHANNEL_61_MAPPING.VALUE=61
DRIVER.SYSTEM.VAR.VIM_CHANNEL_53_MAPPING.VALUE=53
DRIVER.SYSTEM.VAR.VIM_CHANNEL_45_MAPPING.VALUE=45
DRIVER.SYSTEM.VAR.VIM_CHANNEL_37_MAPPING.VALUE=37
DRIVER.SYSTEM.VAR.VIM_CHANNEL_29_MAPPING.VALUE=29
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_DIR.VALUE=1
DRIVER.SYSTEM.VAR.FLASH_LENGTH.VALUE=0x00140000
DRIVER.SYSTEM.VAR.RAM_STACK_FIQ_LENGTH.VALUE=0x00000100
DRIVER.SYSTEM.VAR.CLKT_EXT1_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_100_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_51_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_43_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_35_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_27_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_21_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_19_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_13_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_ADC2_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_FREQ.VALUE=0.000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_TYPE_VALUE.VALUE=0x0010
DRIVER.SYSTEM.VAR.VIM_CHANNEL_95_NAME.VALUE=etpwm3TripZoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_87_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_79_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.CLKT_VCLK1_DIVIDER.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_PERMISSION.VALUE=PRIV_RW_USER_RW_NOEXEC
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.VIM_CHANNEL_124_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_116_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_108_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_94_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_86_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_78_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.CAN2_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_DOUT.VALUE=0
DRIVER.SYSTEM.VAR.PBIST_ALGO_1.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_DATA_0_WAIT_STATE_FREQ.VALUE=50.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_30_MAPPING.VALUE=30
DRIVER.SYSTEM.VAR.VIM_CHANNEL_22_MAPPING.VALUE=22
DRIVER.SYSTEM.VAR.VIM_CHANNEL_14_MAPPING.VALUE=14
DRIVER.SYSTEM.VAR.VIM_CHANNEL_7_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.PBIST_ALGO_2.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_RTI1_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CLKT_AVCLK1_DOMAIN_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_127_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_119_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_30_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_22_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_14_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI3_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ETPWM3_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.DCC1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.HET2_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_PBIST_ESRAM_SELECTED.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK3_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_FREQ1.VALUE=80.000
DRIVER.SYSTEM.VAR.PBIST_ALGO_11_12.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL2_SOURCE_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_END_ADDRESS.VALUE=0xfe0001ff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_94_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_86_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_78_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_21_INT_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_13_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_HTU1_DP_PBISTCHECK_ENA.VALUE=0x00002000
DRIVER.SYSTEM.VAR.ECAP5_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ADC_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_70_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_62_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_54_NAME.VALUE=spi4LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_46_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_38_NAME.VALUE=mibspi3LowLevelInterrupt
DRIVER.SYSTEM.VAR.FEE_FLASH_ECC_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SIZE.VALUE=4_MB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_RESET_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_110_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_102_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_6_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD4_STATE_AVAIL.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_121_MAPPING.VALUE=121
DRIVER.SYSTEM.VAR.VIM_CHANNEL_113_MAPPING.VALUE=113
DRIVER.SYSTEM.VAR.VIM_CHANNEL_105_MAPPING.VALUE=105
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_RESERVED_ENTRY.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_121_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_113_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_105_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_71_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_63_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_55_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_47_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_39_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.PMM_MEM_PD3_STATE_AVAIL.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_121_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_113_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_105_NAME.VALUE=ecap2Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_4_MAPPING.VALUE=4
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_DOMAIN_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_END_ADDRESS.VALUE=0x87ffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SIZE.VALUE=4_GB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_120_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_112_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_104_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_PERMISSION_VALUE.VALUE=0x1300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SIZE_VALUE.VALUE=0x17
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_98_MAPPING.VALUE=98
DRIVER.SYSTEM.VAR.VIM_CHANNEL_21_NAME.VALUE=vPortYeildWithinAPI
DRIVER.SYSTEM.VAR.VIM_CHANNEL_13_NAME.VALUE=linHighLevelInterrupt
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD4_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_FUN.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_BASE_ADDRESS.VALUE=0x20000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_94_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_86_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_78_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_51_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_43_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_35_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_27_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_19_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_FRAY_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_DMA_DP_PBISTCHECK_ENA.VALUE=0x00000800
DRIVER.SYSTEM.VAR.HET_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.PBIST_ALGO_13_14.VALUE=0
DRIVER.SYSTEM.VAR.RAM_STACK_UNDEF_BASE.VALUE=0x08000700
DRIVER.SYSTEM.VAR.RAM_STACK_SVC_BASE.VALUE=0x08000300
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_TYPE.VALUE=DEVICE_NONSHAREABLE
DRIVER.SYSTEM.VAR.VIM_CHANNEL_99_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_3_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.DMM_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.MIBSPI5_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_0.VALUE=ACTIVE
DRIVER.SYSTEM.VAR.PMM_PMCTRL_PWRDN.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_AVCLK4_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_1.VALUE=ACTIVE
DRIVER.SYSTEM.VAR.VIM_CHANNEL_96_NAME.VALUE=etpwm4Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_91_MAPPING.VALUE=91
DRIVER.SYSTEM.VAR.VIM_CHANNEL_88_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_83_MAPPING.VALUE=83
DRIVER.SYSTEM.VAR.VIM_CHANNEL_75_MAPPING.VALUE=75
DRIVER.SYSTEM.VAR.VIM_CHANNEL_67_MAPPING.VALUE=67
DRIVER.SYSTEM.VAR.VIM_CHANNEL_59_MAPPING.VALUE=59
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_2.VALUE=SLEEP
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.CLKT_VCLK2_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_3.VALUE=SLEEP
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_END_ADDRESS.VALUE=0x0803ffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_0_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_40_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_32_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_24_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_16_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_5_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD5_STATE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN2_DP_PBISTCHECK_ENA.VALUE=0x00000008
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_PDR.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_4.VALUE=SLEEP
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_5.VALUE=SLEEP
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SIZE_VALUE.VALUE=0x15
DRIVER.SYSTEM.VAR.VIM_CHANNEL_8_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.ECLK_PRESCALER.VALUE=8
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_6.VALUE=SLEEP
DRIVER.SYSTEM.VAR.FLASH_BANK_CONFIG_7.VALUE=ACTIVE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_BASE_ADDRESS.VALUE=0xFE000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_126_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_118_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_97_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_89_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_80_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_72_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_64_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_56_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_48_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_HTU1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_VCLK4_FREQ.VALUE=80.000
DRIVER.SYSTEM.VAR.VIM_CHANNEL_60_MAPPING.VALUE=60
DRIVER.SYSTEM.VAR.VIM_CHANNEL_52_MAPPING.VALUE=52
DRIVER.SYSTEM.VAR.VIM_CHANNEL_44_MAPPING.VALUE=44
DRIVER.SYSTEM.VAR.VIM_CHANNEL_36_MAPPING.VALUE=36
DRIVER.SYSTEM.VAR.VIM_CHANNEL_28_MAPPING.VALUE=28
DRIVER.SYSTEM.VAR.CLKT_PLL1_BAND_WIDTH_ADJUSTMENT.VALUE=7
DRIVER.SYSTEM.VAR.CLKT_LPO_LOW_SOURCE_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.PMM_MEM_PD2_STATE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_VIM2_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CLKT_PLL2_MUL_VAL.VALUE=7700
DRIVER.SYSTEM.VAR.CLKT_RTI1_POST_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.VIM_CHANNEL_71_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_63_NAME.VALUE=het2HighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_55_NAME.VALUE=can3LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_47_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_39_NAME.VALUE=dmaHBCAInterrupt
DRIVER.SYSTEM.VAR.CLKT_PLL2_BAND_WIDTH_ADJUSTMENT.VALUE=7
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_DATA_ENTRY.VALUE=_dabort
DRIVER.SYSTEM.VAR.VIM_CHANNEL_80_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_72_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_64_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_56_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_48_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_ADC1_DP_PBISTCHECK_ENA.VALUE=0x00000400
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI3_DP_PBISTCHECK_ENA.VALUE=0x00000080
DRIVER.SYSTEM.VAR.VIM_CHANNEL_21_MAPPING.VALUE=21
DRIVER.SYSTEM.VAR.VIM_CHANNEL_13_MAPPING.VALUE=13
DRIVER.SYSTEM.VAR.CLKT_PLL2_REF_CLOCK_DIV.VALUE=6
DRIVER.SYSTEM.VAR.CLKT_PLL1_SPEADING_RATE.VALUE=255
DRIVER.SYSTEM.VAR.VIM_CHANNEL_50_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_42_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_34_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_26_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_18_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_0_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN5_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.ETPWM1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_PLL1_RESET_ON_SLIP.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_TYPE_VALUE.VALUE=0x0010
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_127_MAPPING.VALUE=127
DRIVER.SYSTEM.VAR.VIM_CHANNEL_122_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_119_MAPPING.VALUE=119
DRIVER.SYSTEM.VAR.VIM_CHANNEL_114_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_106_NAME.VALUE=ecap3nterrupt
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_PERMISSION.VALUE=PRIV_RW_USER_NA_NOEXEC
DRIVER.SYSTEM.VAR.CLKT_PLL1_FM_ENABLE.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SIZE.VALUE=4_MB
DRIVER.SYSTEM.VAR.VIM_CHANNEL_123_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_115_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_107_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_90_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_82_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_74_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_66_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_58_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_PBIST_ROM_PBIST_SELFCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ECAP3_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_30_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_22_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_14_NAME.VALUE=adc1Group0Interrupt
DRIVER.SYSTEM.VAR.CLKT_LPOLO_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_123_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_115_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_107_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_PSL.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_120_MAPPING.VALUE=120
DRIVER.SYSTEM.VAR.VIM_CHANNEL_112_MAPPING.VALUE=112
DRIVER.SYSTEM.VAR.VIM_CHANNEL_104_MAPPING.VALUE=104
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_END_ADDRESS.VALUE=0xffffffff
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SUB_4_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_BASE_ADDRESS.VALUE=0x80000000
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_SVC_ENTRY.VALUE=vPortSWI
DRIVER.SYSTEM.VAR.VIM_CHANNEL_21_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_20_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_13_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_12_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CONFIG_NEW.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_FTU_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_FLASHECC_SELFCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_EXTERNAL2_FREQ.VALUE=00.0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_97_NAME.VALUE=etpwm4TripZoneInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_89_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_3_MAPPING.VALUE=3
DRIVER.SYSTEM.VAR.CLKT_LPOHI_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_101_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_99_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_93_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_85_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_77_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_69_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_6_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_RTP_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CLKT_GHV_NORMAL_SOURCE.VALUE=PLL1
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_DIV_FREQ.VALUE=80.0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_97_MAPPING.VALUE=97
DRIVER.SYSTEM.VAR.VIM_CHANNEL_89_MAPPING.VALUE=89
DRIVER.SYSTEM.VAR.VIM_CHANNEL_9_NAME.VALUE=gioHighLevelInterrupt
DRIVER.SYSTEM.VAR.CLKT_PLL1_ENABLE.VALUE=TRUE
DRIVER.SYSTEM.VAR.FLASH_BASE_ADDRESS.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_11_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SUB_6_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_51_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_43_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_35_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_27_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_19_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_5_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_ESRAM_SP_PBISTCHECK_ENA.VALUE=0x08300020
DRIVER.SYSTEM.VAR.SAFETY_INIT_STC_ROM_PBIST_SELFCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.CORE_M3.VALUE=0
DRIVER.SYSTEM.VAR.SPI5_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK2_DOMAIN_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_TYPE.VALUE=NORMAL_OINC_NONSHARED
DRIVER.SYSTEM.VAR.VIM_CHANNEL_120_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_112_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_104_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_100_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_FTU_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.RTP_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.MIBSPI3_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_LENGTH_0.VALUE=0x00110000
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_LENGTH_1.VALUE=0x00180000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_SIZE_VALUE.VALUE=0x16
DRIVER.SYSTEM.VAR.VIM_CHANNEL_90_MAPPING.VALUE=90
DRIVER.SYSTEM.VAR.VIM_CHANNEL_82_MAPPING.VALUE=82
DRIVER.SYSTEM.VAR.VIM_CHANNEL_80_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_74_MAPPING.VALUE=74
DRIVER.SYSTEM.VAR.VIM_CHANNEL_72_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_66_MAPPING.VALUE=66
DRIVER.SYSTEM.VAR.VIM_CHANNEL_64_NAME.VALUE=sciHighLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_58_MAPPING.VALUE=58
DRIVER.SYSTEM.VAR.VIM_CHANNEL_56_NAME.VALUE=mibspi5LowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_48_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.PMM_LOGIC_PD3_STATEVALUE.VALUE=0x5
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_7_DISABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_8_SUB_1_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_93_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_85_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_77_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_69_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.EQEP_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.RTI_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.STC_MAX_TIMEOUT.VALUE=0xFFFFFFFF
DRIVER.SYSTEM.VAR.CLKT_LPO_LOW_TRIM.VALUE=100.00
DRIVER.SYSTEM.VAR.RAM_STACK_FIQ_BASE.VALUE=0x08000400
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_PERMISSION_VALUE.VALUE=0x0300
DRIVER.SYSTEM.VAR.VIM_CHANNEL_0_NAME.VALUE=esmHighInterrupt
DRIVER.SYSTEM.VAR.FLASH_BANK_LINK_LENGTH_7.VALUE=0x000010000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_SUB_2_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_50_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_42_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_34_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_26_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_18_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_HET1_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI5_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.FEE_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_10.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_LPO_LOW_TRIM_VALUE.VALUE=16
DRIVER.SYSTEM.VAR.VIM_CHANNEL_123_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_115_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_107_NAME.VALUE=ecap4Interrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_51_MAPPING.VALUE=51
DRIVER.SYSTEM.VAR.VIM_CHANNEL_43_MAPPING.VALUE=43
DRIVER.SYSTEM.VAR.VIM_CHANNEL_35_MAPPING.VALUE=35
DRIVER.SYSTEM.VAR.VIM_CHANNEL_27_MAPPING.VALUE=27
DRIVER.SYSTEM.VAR.VIM_CHANNEL_19_MAPPING.VALUE=19
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_11.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_5_PERMISSION.VALUE=PRIV_RW_USER_RW_EXEC
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_12.VALUE=1
DRIVER.SYSTEM.VAR.CCM_MENU.VALUE=NONE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_9_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SIZE.VALUE=256_KB
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_BASE_ADDRESS.VALUE=0x08000000
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_2_SUB_3_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_98_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_20_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_12_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_4_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_PARITY_ENABLE_NEW.VALUE=0xA
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN2_RAMPARITYCHECK_ENA.VALUE=1
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_13.VALUE=1
DRIVER.SYSTEM.VAR.POM_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL1_MUL_VAL.VALUE=7700
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_14.VALUE=1
DRIVER.SYSTEM.VAR.CLKT_AVCLK3_SOURCE.VALUE=VCLK
DRIVER.SYSTEM.VAR.CLKT_PLL1_FREQ.VALUE=160.00
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_1_SIZE_VALUE.VALUE=0x1F
DRIVER.SYSTEM.VAR.VIM_CHANNEL_31_NAME.VALUE=phantomInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_23_NAME.VALUE=gioLowLevelInterrupt
DRIVER.SYSTEM.VAR.VIM_CHANNEL_15_NAME.VALUE=adc1Group1Interrupt
DRIVER.SYSTEM.VAR.ERRATA_WORKAROUND_15.VALUE=1
DRIVER.SYSTEM.VAR.RAM_STACK_UNDEF_LENGTH.VALUE=0x00000100
DRIVER.SYSTEM.VAR.RAM_STACK_SVC_LENGTH.VALUE=0x00000100
DRIVER.SYSTEM.VAR.CLKT_LPO_TRIM_OTP_LOC.VALUE=0xF00801B4
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_6_SUB_6_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_HANDLER_TABLE_UNDEF_ENTRY.VALUE=_undef
DRIVER.SYSTEM.VAR.VIM_CHANNEL_93_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_85_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_77_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_71_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_69_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_63_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_55_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_47_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_39_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_CAN1_DP_PBISTCHECK_ENA.VALUE=0x00000004
DRIVER.SYSTEM.VAR.ETPWM6_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.DCC_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_20_MAPPING.VALUE=20
DRIVER.SYSTEM.VAR.VIM_CHANNEL_12_MAPPING.VALUE=12
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_7_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_ENDIAN_LITTLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_126_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_125_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_118_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.VIM_CHANNEL_117_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_109_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_FRAY_SP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.OS_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_12_SIZE_VALUE.VALUE=0x15
DRIVER.SYSTEM.VAR.VIM_CHANNEL_126_MAPPING.VALUE=126
DRIVER.SYSTEM.VAR.VIM_CHANNEL_118_MAPPING.VALUE=118
DRIVER.SYSTEM.VAR.VIM_CHANNEL_98_NAME.VALUE=etpwm5Interrupt
DRIVER.SYSTEM.VAR.ECLK_PORT_BIT0_PULL.VALUE=2
DRIVER.SYSTEM.VAR.ECLK_SUSPEND.VALUE=0
DRIVER.SYSTEM.VAR.CLKT_PLL1_SPEADING_AMOUNT.VALUE=61
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_10_SUB_5_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_4_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.CORE_VFP_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.SAFETY_INIT_VIM1_DP_PBISTCHECK_ENA.VALUE=0x00000200
DRIVER.SYSTEM.VAR.SAFETY_INIT_FMCBUS2_SELFCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.ECAP1_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.I2C_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.AJSM_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.ECLK_OSCILLATOR_FREQ.VALUE=16.000
DRIVER.SYSTEM.VAR.CLKT_LPO_HIGH_TRIM.VALUE=100.00
DRIVER.SYSTEM.VAR.VIM_CHANNEL_9_MAPPING.VALUE=9
DRIVER.SYSTEM.VAR.CLKT_VCLK4_DOMAIN_ENABLE.VALUE=FALSE
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_3_SUB_0_DISABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_71_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_63_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_55_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_47_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_41_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_39_INT_PRAGMA_ENABLE.VALUE=1
DRIVER.SYSTEM.VAR.VIM_CHANNEL_33_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_25_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_17_INT_ENABLE.VALUE=0
DRIVER.SYSTEM.VAR.VIM_CHANNEL_9_INT_TYPE.VALUE=IRQ
DRIVER.SYSTEM.VAR.SAFETY_INIT_VIM2_RAMPARITYCHECK_ENA.VALUE=0
DRIVER.SYSTEM.VAR.SAFETY_INIT_MIBSPI2_DP_PBISTCHECK_ENA.VALUE=0x00000000
DRIVER.SYSTEM.VAR.CLKT_CRYSTAL_FREQ.VALUE=16.0
DRIVER.SYSTEM.VAR.CORE_MPU_REGION_7_TYPE_VALUE.VALUE=0x0008
DRIVER.SYSTEM.VAR.VIM_CHANNEL_111_MAPPING.VALUE=111
DRIVER.SYSTEM.VAR.VIM_CHANNEL_103_MAPPING.VALUE=103
DRIVER.SYSTEM.VAR.VIM_PHANTOM_NAME.VALUE=phantomInterrupt
DRIVER.OS.VAR.OS_USERECERSIVEMUTEXES.VALUE=1
DRIVER.OS.VAR.OS_USETIMERS.VALUE=1
DRIVER.OS.VAR.OS_USECNTSEMAPHORE.VALUE=1
DRIVER.OS.VAR.OS_GENERATERUNTIMESTATS.VALUE=0
DRIVER.OS.VAR.OS_USEMPU.VALUE=0
DRIVER.OS.VAR.OS_TOTALHEAPSIZE.VALUE=12544
DRIVER.OS.VAR.OS_USEVERBOSESTACK.VALUE=2
DRIVER.OS.VAR.OS_TIMERPRIORITY.VALUE=17
DRIVER.OS.VAR.OS_SVCENABLE.VALUE=0
DRIVER.OS.VAR.OS_MAXTASKNAMELEN.VALUE=16
DRIVER.OS.VAR.OS_MAXPRIORITIES.VALUE=5
DRIVER.OS.VAR.OS_TIMERTASKSTACKDEPTH.VALUE=256
DRIVER.OS.VAR.OS_COROUTINEPRIORITIES.VALUE=2
DRIVER.OS.VAR.OS_USECOROUTINES.VALUE=0
DRIVER.OS.VAR.OS_USEMUTEXES.VALUE=1
DRIVER.OS.VAR.OS_CPUCLOCKHZ.VALUE=80000000
DRIVER.OS.VAR.OS_USEMALLOCFAILEDHOOK.VALUE=0
DRIVER.OS.VAR.OS_MINSTACKSIZE.VALUE=128
DRIVER.OS.VAR.OS_SYSTEM_MODE.VALUE=0x1F
DRIVER.OS.VAR.OS_USEPREEMPTION.VALUE=1
DRIVER.OS.VAR.OS_IDLESHOULDYIELD.VALUE=1
DRIVER.OS.VAR.OS_USEIDLEHOOK.VALUE=0
DRIVER.OS.VAR.OS_TICKRATEHZ.VALUE=1000
DRIVER.OS.VAR.OS_TIMERPQUEUELENGTH.VALUE=10
DRIVER.OS.VAR.OS_USETRACE.VALUE=0
DRIVER.OS.VAR.OS_USESTACK.VALUE=0
DRIVER.OS.VAR.OS_USETICKHOOK.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL0_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL21_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL13_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL63_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL55_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL47_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL39_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL3_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL41_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL33_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL25_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL17_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL9_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL50_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL42_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL34_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL26_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL18_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL57_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL49_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL2_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL11_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL50_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL42_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL34_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL26_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL18_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL8_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL5_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL11_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL63_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL55_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL47_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL39_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL11_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL62_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL54_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL46_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL38_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL1_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL7_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL40_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL32_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL24_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL16_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL63_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL55_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL47_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL39_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL0_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL40_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL32_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL24_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL16_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL40_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL32_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL24_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL16_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL10_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL6_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL4_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL61_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL53_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL45_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL37_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL29_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL59_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL61_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL53_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL45_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL37_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL29_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL5_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL61_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL53_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL45_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL37_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL29_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL58_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_LOW_TIME.VALUE=204.800
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL30_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL22_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL14_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL31_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL23_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL15_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL9_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL30_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL22_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL14_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL4_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL3_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL51_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL43_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL35_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL27_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL19_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL58_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL58_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL3_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL9_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL51_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL43_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL35_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL27_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL19_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL60_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL52_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL44_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL36_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL28_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL20_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL12_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL56_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL48_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_VCLK_FREQ.VALUE=80
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL30_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL22_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL14_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL8_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL20_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL12_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL2_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL2_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL8_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL56_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL48_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL1_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL41_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL33_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL25_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL17_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL57_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL49_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL41_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL33_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL25_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL17_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL10_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL7_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL51_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL43_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL35_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL27_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL19_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL62_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL54_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL46_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL38_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL21_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL13_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL7_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL10_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL6_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL59_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL0_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL1_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL62_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL54_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL46_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL38_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL31_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL23_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL15_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL31_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL23_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL15_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL56_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL48_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL5_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL50_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL42_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL34_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL26_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL18_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL60_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL52_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL44_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL36_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL28_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL20_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL12_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL6_INT_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL59_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL4_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL60_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL52_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL44_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL36_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL28_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_LPC.VALUE=16384
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL21_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL13_ENABLE.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL57_INT_LEVEL.VALUE=0
DRIVER.ESM.VAR.ESM_GROUP0_CHANNEL49_INT_LEVEL.VALUE=0
DRIVER.RTI.VAR.RTI_1_COMPARE_2_SOURCE.VALUE=0x00000100
DRIVER.RTI.VAR.RTI_1_COMPARE_3_FREQ.VALUE=0.000100000
DRIVER.RTI.VAR.RTI_1_FREQ.VALUE=80.000
DRIVER.RTI.VAR.RTI_1_COMPARE_1_ACTUALTIME.VALUE=5.000
DRIVER.RTI.VAR.RTI_1_COUNTER_1_UC_COMPARE.VALUE=7
DRIVER.RTI.VAR.RTI_1_COMPARE_1_TIME.VALUE=5.000
DRIVER.RTI.VAR.RTI_1_COMPARE_3_UPDATE.VALUE=100000
DRIVER.RTI.VAR.RTI_1_CONTINUE_ON_SUSPEND_ENABLE.VALUE=0x00000000
DRIVER.RTI.VAR.RTI_1_COMPARE_1_INPUT_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COMPARE_0_SOURCE.VALUE=0x00000000
DRIVER.RTI.VAR.RTI_1_COMPARE_2_TIME.VALUE=8.000
DRIVER.RTI.VAR.RTI_1_COMPARE_0_ACTUALTIME.VALUE=1.000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_UC_COMPARE.VALUE=7
DRIVER.RTI.VAR.RTI_1_COMPARE_1_UPDATE.VALUE=50000
DRIVER.RTI.VAR.RTI_1_COMPARE_3_TIME.VALUE=10.000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_NTU_SOURCE.VALUE=0
DRIVER.RTI.VAR.RTI_1_COMPARE_0_INPUT_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_RTI_FREQ.VALUE=0.0
DRIVER.RTI.VAR.RTI_1_COUNTER_0_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COUNTER_1_FREQUENCY.VALUE=10.000
DRIVER.RTI.VAR.RTI_1_COMPARE_3_SOURCE.VALUE=0x00001000
DRIVER.RTI.VAR.RTI_1_COUNTER_1_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_NTU_SOURCE_REG.VALUE=0x0
DRIVER.RTI.VAR.RTI_1_COMPARE_1_SOURCE.VALUE=0x00000000
DRIVER.RTI.VAR.RTI_1_NTU_1_FREQ.VALUE=0.0
DRIVER.RTI.VAR.RTI_1_COMPARE_3_ACTUALTIME.VALUE=10.000
DRIVER.RTI.VAR.RTI_1_COMPARE_0_FREQ.VALUE=0.001000000
DRIVER.RTI.VAR.RTI_1_COMPARE_2_UPDATE.VALUE=80000
DRIVER.RTI.VAR.RTI_1_BASE.VALUE=0xFFFFFC00
DRIVER.RTI.VAR.RTI_1_NTU_2_FREQ.VALUE=0.0
DRIVER.RTI.VAR.RTI_1_COMPARE_3_INPUT_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COMPARE_1_FREQ.VALUE=0.000200000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_CAPTURE_SOURCE_ENABLE.VALUE=0
DRIVER.RTI.VAR.RTI_1_COUNTER_1_CAPTURE_SOURCE_ENABLE.VALUE=0
DRIVER.RTI.VAR.RTI_1_COMPARE_0_UPDATE.VALUE=10000
DRIVER.RTI.VAR.RTI_1_NTU_3_FREQ.VALUE=160.000
DRIVER.RTI.VAR.RTI_1_COMPARE_0.VALUE=10000
DRIVER.RTI.VAR.RTI_1_COMPARE_2_ACTUALTIME.VALUE=8.000
DRIVER.RTI.VAR.RTI_1_COMPARE_1.VALUE=50000
DRIVER.RTI.VAR.RTI_1_COMPARE_2.VALUE=80000
DRIVER.RTI.VAR.RTI_1_COMPARE_3.VALUE=100000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_NTU_FREQ.VALUE=0.000
DRIVER.RTI.VAR.RTI_1_COMPARE_2_FREQ.VALUE=0.000125000
DRIVER.RTI.VAR.RTI_1_COMPARE_0_TIME.VALUE=1.000
DRIVER.RTI.VAR.RTI_1_NTU_4_FREQ.VALUE=0.000
DRIVER.RTI.VAR.RTI_1_COMPARE_2_INPUT_FREQ.VALUE=10.000000000
DRIVER.RTI.VAR.RTI_1_COUNTER_0_FREQUENCY.VALUE=10.000
DRIVER.GIO.VAR.GIO_PORT1_BIT4_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT5_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT3_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT3_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT3_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT3_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT7_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_PULL.VALUE=2
DRIVER.GIO.VAR.GIO_PORT0_BIT3_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT6_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT4_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT1_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT1_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_DIR.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT2_DOUT.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT3_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT1_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT1_DIR.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT6_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_ENA.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT2_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_PULL.VALUE=2
DRIVER.GIO.VAR.GIO_PORT0_BIT3_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_DOUT.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT4_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT3_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT1_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_PSL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT4_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_BASE_PORTA.VALUE=0xFFF7BC34
DRIVER.GIO.VAR.GIO_BASE_PORTB.VALUE=0xFFF7BC54
DRIVER.GIO.VAR.GIO_PORT1_BIT1_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT1_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT1_PULL.VALUE=2
DRIVER.GIO.VAR.GIO_PORT1_BIT4_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT5_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT1_PSL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT5_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_LVL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT1_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_POL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT0_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_PSL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT6_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_BASE.VALUE=0xFFF7BC00
DRIVER.GIO.VAR.GIO_PORT1_BIT3_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_PULL.VALUE=2
DRIVER.GIO.VAR.GIO_PORT0_BIT1_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT7_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT2_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_PSL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT7_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT6_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT4_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORTB_ENABLE.VALUE=1
DRIVER.GIO.VAR.GIO_PORT1_BIT5_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT3_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT3_PULL.VALUE=2
DRIVER.GIO.VAR.GIO_PORT0_BIT3_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT7_PULL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT0_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT5_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT4_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT0_PSL.VALUE=1
DRIVER.GIO.VAR.GIO_PORT0_BIT4_DIR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT0_PULDIS.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_DOUT.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT6_PSL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT2_PDR.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_LVL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT5_ENA.VALUE=0
DRIVER.GIO.VAR.GIO_PORT1_BIT7_POL.VALUE=0
DRIVER.GIO.VAR.GIO_PORT0_BIT1_PSL.VALUE=0
DRIVER.SCI.VAR.SCILIN_TIMMINGMODE.VALUE=1
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_DIR.VALUE=0
DRIVER.SCI.VAR.SCI_TIMMINGMODE.VALUE=1
DRIVER.SCI.VAR.SCILIN_WAKEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_PEINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT2_PULL.VALUE=2
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_DIR.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT0_DIR.VALUE=0
DRIVER.SCI.VAR.SCI_ACTUALBAUDRATE.VALUE=9597
DRIVER.SCI.VAR.SCI_EVENPARITY.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_FUN.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_DIR.VALUE=0
DRIVER.SCI.VAR.SCILIN_RXINTLVL.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT1_DIR.VALUE=0
DRIVER.SCI.VAR.SCI_BASE_PORT.VALUE=0xFFF7E540
DRIVER.SCI.VAR.SCILIN_PRESCALE.VALUE=520
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_PDR.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_FUN.VALUE=1
DRIVER.SCI.VAR.SCI_PORT_BIT0_FUN.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT2_DIR.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_PDR.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT0_PDR.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_FUN.VALUE=1
DRIVER.SCI.VAR.SCILIN_PEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT1_FUN.VALUE=1
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_PSL.VALUE=1
DRIVER.SCI.VAR.SCI_OEINTENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_PDR.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT1_PDR.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT2_FUN.VALUE=1
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_PSL.VALUE=1
DRIVER.SCI.VAR.SCI_PORT_BIT0_PSL.VALUE=1
DRIVER.SCI.VAR.SCI_PORT_BIT2_PDR.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_PSL.VALUE=1
DRIVER.SCI.VAR.SCI_PORT_BIT1_PSL.VALUE=1
DRIVER.SCI.VAR.SCILIN_BREAKINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_WAKEINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_BREAKINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT2_PSL.VALUE=1
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCI_FEINTENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_DOUT.VALUE=0
DRIVER.SCI.VAR.SCI_OEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCI_TXINTENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PARITYENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_DOUT.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT0_DOUT.VALUE=0
DRIVER.SCI.VAR.SCI_BAUDRATE.VALUE=9600
DRIVER.SCI.VAR.SCILIN_BREAKINTLVL.VALUE=0
DRIVER.SCI.VAR.SCI_WAKEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCI_BREAKINTLVL.VALUE=0
DRIVER.SCI.VAR.SCI_STOPBITS.VALUE=2
DRIVER.SCI.VAR.SCI_RXINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_FEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_EVENPARITY.VALUE=0
DRIVER.SCI.VAR.SCI_TXINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_OEINTENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_DOUT.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT1_DOUT.VALUE=0
DRIVER.SCI.VAR.SCI_PEINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_CLKMODE.VALUE=1
DRIVER.SCI.VAR.SCI_PARITYENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT0_PULL.VALUE=2
DRIVER.SCI.VAR.SCI_PORT_BIT2_DOUT.VALUE=0
DRIVER.SCI.VAR.SCILIN_BASE.VALUE=0xFFF7E400
DRIVER.SCI.VAR.SCI_RXINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_FEINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_PRESCALE.VALUE=520
DRIVER.SCI.VAR.SCILIN_OEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_TXINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_PULL.VALUE=2
DRIVER.SCI.VAR.SCI_PORT_BIT0_PULL.VALUE=2
DRIVER.SCI.VAR.SCI_PEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_WAKEINTENA.VALUE=0
DRIVER.SCI.VAR.SCI_LENGTH.VALUE=8
DRIVER.SCI.VAR.SCILIN_CLKMODE.VALUE=1
DRIVER.SCI.VAR.SCILIN_BASE_PORT.VALUE=0xFFF7E440
DRIVER.SCI.VAR.SCILIN_BAUDRATE.VALUE=9600
DRIVER.SCI.VAR.SCILIN_STOPBITS.VALUE=2
DRIVER.SCI.VAR.SCILIN_PORT_BIT2_PULL.VALUE=2
DRIVER.SCI.VAR.SCI_PORT_BIT1_PULL.VALUE=2
DRIVER.SCI.VAR.SCILIN_RXINTENA.VALUE=0
DRIVER.SCI.VAR.SCILIN_LENGTH.VALUE=8
DRIVER.SCI.VAR.SCILIN_FEINTLVL.VALUE=0
DRIVER.SCI.VAR.SCILIN_ACTUALBAUDRATE.VALUE=9597
DRIVER.SCI.VAR.SCILIN_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCI_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SCI.VAR.SCI_BASE.VALUE=0xFFF7E500
DRIVER.SCI.VAR.SCILIN_TXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_BITERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_CLKMOD.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PHASE0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_PHASE1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PHASE2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_PHASE3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_CSNR.VALUE=CS_2
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_C2TDELAYACTUAL.VALUE=25.000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TIMEOUTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_LENGTH.VALUE=8
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_C2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_CSNR.VALUE=CS_1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_T2CDELAYACTUAL.VALUE=12.500
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PARERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_OVRNINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_CSNR.VALUE=CS_3
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_C2TDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_RXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_DEYSNCENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_BASE.VALUE=0xFFF7FC00
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_DEYSNCLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_CSNR.VALUE=CS_5
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_TXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PRESCALE0.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI1_CLKMOD.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_PRESCALE1.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PRESCALE2.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TIMEOUTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PRESCALE3.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARITYENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_PARITYENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_PARITYENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_DLENERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARITYENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_BITERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_T2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_BITERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_WDELAY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_T2CDELAYACTUAL.VALUE=12.500
DRIVER.MIBSPI.VAR.MIBSPI3_WDELAY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_WDELAY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_WDELAY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_ENABLEHIGHZ.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_CSNR.VALUE=CS_4
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_CSNR.VALUE=CS_6
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_BASE_PORT.VALUE=0xFFF7FC18
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_WAITENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_WAITENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_WAITENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_WAITENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PARPOL0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARPOL1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARPOL2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARPOL3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PARERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_OVRNINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_DEYSNCENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_RXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_T2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_RXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_DEYSNCLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_CSNR.VALUE=CS_1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_BAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_CSNR.VALUE=CS_7
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_BAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_BAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_BAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_DLENERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_C2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TIMEOUTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BITERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_POLARITY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_POLARITY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_POLARITY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_BITERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_POLARITY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_CSNR.VALUE=CS_0
DRIVER.MIBSPI.VAR.MIBSPI5_T2CDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_LENGTH.VALUE=8
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_BASE_RAM.VALUE=0xFF0A0000
DRIVER.MIBSPI.VAR.MIBSPI5_CHARLEN0.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_CSDEF.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_CHARLEN1.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_CHARLEN2.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_CSNR.VALUE=CS_2
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_CHARLEN3.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_BASE_PORT.VALUE=0xFFF7F818
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WAITENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_WAITENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WAITENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WAITENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_CSNR.VALUE=CS_4
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_PARERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_OVRNINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PARERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_DEYSNCLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_RXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_C2TDELAYACTUAL.VALUE=25.000
DRIVER.MIBSPI.VAR.MIBSPI1_WDELAY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WDELAY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WDELAY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_WDELAY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_BAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_CSNR.VALUE=CS_3
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_BAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_BAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_BAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_TIMEOUTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_ENABLEHIGHZ.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PARITYENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_C2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PARITYENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PARITYENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_DLENERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_PARITYENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_CSNR.VALUE=CS_5
DRIVER.MIBSPI.VAR.MIBSPI3_POLARITY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_C2TDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_POLARITY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_POLARITY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BITERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_POLARITY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_C2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_CSNR.VALUE=CS_7
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_T2CDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_BASE_RAM.VALUE=0xFF0E0000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_PARPOL0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_CHARLEN0.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI1_PARPOL1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_CHARLEN1.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PARPOL2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_CHARLEN2.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_PARPOL3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_CHARLEN3.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_BASE_PORT.VALUE=0xFFF7F418
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_T2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_SHIFTDIR0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_SHIFTDIR1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_CSNR.VALUE=CS_0
DRIVER.MIBSPI.VAR.MIBSPI5_SHIFTDIR2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_SHIFTDIR3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_CSNR.VALUE=CS_6
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_MASTER.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_C2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PARERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_OVRNINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_DLENERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_T2CDELAYACTUAL.VALUE=12.500
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT9_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI1_BAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TIMEOUTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT11_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_CSNR.VALUE=CS_1
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_POLARITY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI1_POLARITY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_BASE.VALUE=0xFFF7F400
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_POLARITY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_RXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_POLARITY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PHASE0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PHASE1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PHASE2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT9_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PHASE3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_CSNR.VALUE=CS_3
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_LENGTH.VALUE=8
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT8_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT5_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_TXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_ENABLE.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_T2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT10_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT0_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_OVRNINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_T2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT1_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT11_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_SHIFTDIR0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_MASTER.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_SHIFTDIR1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_SHIFTDIR2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_SHIFTDIR3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_CSNR.VALUE=CS_2
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG4_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PRESCALE0.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI5_PRESCALE1.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PRESCALE2.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PRESCALE3.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI3_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.MIBSPI.VAR.MIBSPI5_PARITYENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_CSNR.VALUE=CS_4
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PARITYENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PARITYENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_DLENERRLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_CSDEF.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_PARITYENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_WAITENA0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_WAITENA1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_WAITENA2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG7_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_WAITENA3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_CSNR.VALUE=CS_6
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_T2EDELAYACTUAL.VALUE=0.000
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI1_TIMEOUTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG1_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_CLKMOD.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT9_DOUT.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PHASE0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_PHASE1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PHASE2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT11_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT1_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI3_PHASE3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT2_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG4_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG6_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_RXINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_WDELAY0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_ENABLEHIGHZ.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_WDELAY1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG5_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_WDELAY2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT17_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT25_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_WDELAY3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG5_BUF_CSNR.VALUE=CS_5
DRIVER.MIBSPI.VAR.MIBSPI3_BASE.VALUE=0xFFF7F800
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT27_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT19_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT3_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_MASTER.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT8_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG0_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG4_TRGSRC.VALUE=TRG_DISABLED
DRIVER.MIBSPI.VAR.MIBSPI3_C2EDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_TG2_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_LOCK.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT25_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT17_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_ONESHOT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_C2TDELAYACTUAL.VALUE=25.000
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT1_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG7_BUF_CSNR.VALUE=CS_7
DRIVER.MIBSPI.VAR.MIBSPI1_TG3_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_C2TDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_LENGTH.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_OVRNINTLVL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_SHIFTDIR0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT10_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG6_BUF_MODE.VALUE=4
DRIVER.MIBSPI.VAR.MIBSPI5_DEYSNCENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_SHIFTDIR1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG1_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT4_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI1_SHIFTDIR2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_SHIFTDIR3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_FUN.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_TG0_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_FUN.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT8_DIR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT0_PSL.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_T2CDELAY.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT4_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG2_TRGEVT.VALUE=TRG_ALWAYS
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_CSHOLD_LASTBUF.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT2_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI1_CSDEF.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_CS_ENCODE.VALUE=0xFF
DRIVER.MIBSPI.VAR.MIBSPI5_TG7_USE_CS_ENCODE.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TXINTENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT3_PULDIS.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG3_BUF_WDEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_TG2_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_TG6_PRST.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PRESCALE0.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI1_PORT_BIT5_DOUT.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI3_PRESCALE1.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI3_BASE_RAM.VALUE=0xFF0C0000
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT3_PULL.VALUE=2
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT0_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI5_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PARPOL0.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT10_DIR.VALUE=1
DRIVER.MIBSPI.VAR.MIBSPI3_TG3_BUF_CSHOLD.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PRESCALE2.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI3_CHARLEN0.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI5_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.MIBSPI.VAR.MIBSPI5_PARPOL1.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PRESCALE3.VALUE=79
DRIVER.MIBSPI.VAR.MIBSPI3_CHARLEN1.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI3_DLENERRENA.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT26_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PORT_BIT18_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI5_PARPOL2.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_PORT_BIT2_PDR.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG5_BUF_DFSEL.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_TG0_BUF_CSNR.VALUE=CS_0
DRIVER.MIBSPI.VAR.MIBSPI3_CHARLEN2.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI5_PARPOL3.VALUE=0
DRIVER.MIBSPI.VAR.MIBSPI3_CHARLEN3.VALUE=16
DRIVER.MIBSPI.VAR.MIBSPI1_TG1_TRGSRC.VALUE=TRG_DISABLED
DRIVER.SPI.VAR.SPI5_PORT_BIT26_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT18_DIR.VALUE=0
DRIVER.SPI.VAR.SPI3_PHASE2.VALUE=0
DRIVER.SPI.VAR.SPI2_TIMEOUTLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT1_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT25_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT17_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PHASE3.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT11_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_T2CDELAYACTUAL.VALUE=12.500
DRIVER.SPI.VAR.SPI4_POLARITY0.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT1_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT4_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI4_POLARITY1.VALUE=0
DRIVER.SPI.VAR.SPI2_T2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT2_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PORT_BIT9_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_POLARITY2.VALUE=0
DRIVER.SPI.VAR.SPI2_BITERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_SHIFTDIR0.VALUE=0
DRIVER.SPI.VAR.SPI1_RXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_DEYSNCENA.VALUE=0
DRIVER.SPI.VAR.SPI4_POLARITY3.VALUE=0
DRIVER.SPI.VAR.SPI1_SHIFTDIR1.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT10_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT2_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT4_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_SHIFTDIR2.VALUE=0
DRIVER.SPI.VAR.SPI1_SHIFTDIR3.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT2_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT10_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT8_DIR.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT0_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT0_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT25_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT17_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT11_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT4_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT11_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT25_DIR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT17_DIR.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT9_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_PRESCALE0.VALUE=79
DRIVER.SPI.VAR.SPI3_PRESCALE1.VALUE=79
DRIVER.SPI.VAR.SPI1_C2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT19_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT0_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PRESCALE2.VALUE=79
DRIVER.SPI.VAR.SPI1_MASTER.VALUE=1
DRIVER.SPI.VAR.SPI3_PRESCALE3.VALUE=79
DRIVER.SPI.VAR.SPI3_PORT_BIT2_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_C2TDELAY.VALUE=0
DRIVER.SPI.VAR.SPI2_BASE_PORT.VALUE=0xFFF7F618
DRIVER.SPI.VAR.SPI5_BITERRENA.VALUE=0
DRIVER.SPI.VAR.SPI4_OVRNINTENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT9_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT25_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT17_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_C2TDELAYACTUAL.VALUE=25.000
DRIVER.SPI.VAR.SPI4_PORT_BIT10_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT8_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_WAITENA0.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT11_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_WAITENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_OVRNINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_WAITENA2.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT9_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT9_DIR.VALUE=1
DRIVER.SPI.VAR.SPI4_WAITENA3.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT1_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_T2CDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT26_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT18_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT5_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_TXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT10_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_BASE_RAM.VALUE=0xFF0E0000
DRIVER.SPI.VAR.SPI5_PORT_BIT1_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT2_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_CHARLEN0.VALUE=16
DRIVER.SPI.VAR.SPI1_CHARLEN1.VALUE=16
DRIVER.SPI.VAR.SPI4_PORT_BIT8_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI1_CHARLEN2.VALUE=4
DRIVER.SPI.VAR.SPI1_CHARLEN3.VALUE=16
DRIVER.SPI.VAR.SPI5_PORT_BIT3_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT10_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT0_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_PARERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT8_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_DLENERRENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT26_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT18_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT9_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_PARITYENA0.VALUE=0
DRIVER.SPI.VAR.SPI4_ENABLEHIGHZ.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT3_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI5_T2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI4_PARITYENA1.VALUE=0
DRIVER.SPI.VAR.SPI4_PARITYENA2.VALUE=0
DRIVER.SPI.VAR.SPI4_DLENERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_RXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT4_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT25_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT17_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT11_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT3_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PARITYENA3.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT2_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT1_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI3_CLKMOD.VALUE=1
DRIVER.SPI.VAR.SPI1_PHASE0.VALUE=0
DRIVER.SPI.VAR.SPI1_PHASE1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT19_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT0_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PHASE2.VALUE=0
DRIVER.SPI.VAR.SPI1_PHASE3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT25_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT17_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT11_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_BAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT8_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_BAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI5_PORT_BIT2_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_BAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_BAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI5_WDELAY0.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT4_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT10_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT25_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT17_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_C2TDELAYACTUAL.VALUE=25.000
DRIVER.SPI.VAR.SPI1_ENABLEHIGHZ.VALUE=0
DRIVER.SPI.VAR.SPI5_WDELAY1.VALUE=0
DRIVER.SPI.VAR.SPI4_C2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_WDELAY2.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT11_DIR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT9_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_TIMEOUTLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_WDELAY3.VALUE=0
DRIVER.SPI.VAR.SPI5_PARERRENA.VALUE=0
DRIVER.SPI.VAR.SPI4_RAM_PARITY_ENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT5_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT19_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT0_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT11_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_POLARITY0.VALUE=0
DRIVER.SPI.VAR.SPI2_POLARITY1.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT5_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_POLARITY2.VALUE=0
DRIVER.SPI.VAR.SPI3_DEYSNCENA.VALUE=0
DRIVER.SPI.VAR.SPI2_POLARITY3.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT11_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT1_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_DEYSNCLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT8_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PORT_BIT10_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT26_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT18_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_T2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI1_PORT_BIT9_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_T2CDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT3_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT10_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT0_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT3_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PORT_BIT9_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT5_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_C2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI1_PRESCALE0.VALUE=39
DRIVER.SPI.VAR.SPI4_BASE_RAM.VALUE=0xFF0E0000
DRIVER.SPI.VAR.SPI1_PRESCALE1.VALUE=79
DRIVER.SPI.VAR.SPI4_CHARLEN0.VALUE=16
DRIVER.SPI.VAR.SPI2_PORT_BIT1_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PRESCALE2.VALUE=39
DRIVER.SPI.VAR.SPI4_CHARLEN1.VALUE=16
DRIVER.SPI.VAR.SPI1_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_PRESCALE3.VALUE=39
DRIVER.SPI.VAR.SPI5_PORT_BIT1_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_T2CDELAYACTUAL.VALUE=12.500
DRIVER.SPI.VAR.SPI4_CHARLEN2.VALUE=16
DRIVER.SPI.VAR.SPI1_PORT_BIT8_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_CHARLEN3.VALUE=16
DRIVER.SPI.VAR.SPI1_BASE.VALUE=0xFFF7F400
DRIVER.SPI.VAR.SPI3_BITERRENA.VALUE=0
DRIVER.SPI.VAR.SPI3_OVRNINTENA.VALUE=0
DRIVER.SPI.VAR.SPI3_RXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_ACTUALBAUDRATE0.VALUE=2000.000
DRIVER.SPI.VAR.SPI3_PORT_BIT10_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT4_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT2_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT25_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT17_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI5_PORT_BIT2_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_ACTUALBAUDRATE2.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_PARPOL0.VALUE=0
DRIVER.SPI.VAR.SPI5_BITERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_SHIFTDIR0.VALUE=0
DRIVER.SPI.VAR.SPI4_OVRNINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT8_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_ACTUALBAUDRATE3.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_PARPOL1.VALUE=0
DRIVER.SPI.VAR.SPI4_SHIFTDIR1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT19_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT0_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_PARPOL2.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT0_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI4_SHIFTDIR2.VALUE=0
DRIVER.SPI.VAR.SPI5_PARPOL3.VALUE=0
DRIVER.SPI.VAR.SPI4_SHIFTDIR3.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT11_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT1_DIR.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT8_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT25_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT17_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT11_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_TXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT2_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT9_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_CLKMOD.VALUE=1
DRIVER.SPI.VAR.SPI5_TIMEOUTENA.VALUE=0
DRIVER.SPI.VAR.SPI2_DLENERRENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT11_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT5_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PARITYENA0.VALUE=0
DRIVER.SPI.VAR.SPI3_PARITYENA1.VALUE=0
DRIVER.SPI.VAR.SPI1_T2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT3_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_BASE_PORT.VALUE=0xFFF7FC18
DRIVER.SPI.VAR.SPI3_PORT_BIT9_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT9_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PARITYENA2.VALUE=0
DRIVER.SPI.VAR.SPI3_DLENERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT0_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_PARITYENA3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT1_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_WDELAY0.VALUE=0
DRIVER.SPI.VAR.SPI4_WDELAY1.VALUE=0
DRIVER.SPI.VAR.SPI4_WDELAY2.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT2_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT4_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_WDELAY3.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT10_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_T2CDELAYACTUAL.VALUE=12.500
DRIVER.SPI.VAR.SPI4_MASTER.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT2_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT8_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT3_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PORT_BIT0_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_BASE.VALUE=0xFFF7F600
DRIVER.SPI.VAR.SPI4_PORT_BIT10_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT8_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT0_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI3_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI3_PARERRENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI2_C2TDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PARERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT1_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT8_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_DEYSNCENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT2_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_WAITENA0.VALUE=0
DRIVER.SPI.VAR.SPI3_WAITENA1.VALUE=0
DRIVER.SPI.VAR.SPI3_WAITENA2.VALUE=0
DRIVER.SPI.VAR.SPI3_DEYSNCLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT3_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_WAITENA3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT26_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT18_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT11_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT8_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT10_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT10_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_TXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_BAUDRATE0.VALUE=2000.000
DRIVER.SPI.VAR.SPI2_PORT_BIT1_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_C2TDELAYACTUAL.VALUE=25.000
DRIVER.SPI.VAR.SPI5_BAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI5_BAUDRATE2.VALUE=2000.000
DRIVER.SPI.VAR.SPI4_PORT_BIT11_DIR.VALUE=0
DRIVER.SPI.VAR.SPI4_PARPOL0.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT9_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_BAUDRATE3.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_RAM_PARITY_ENA.VALUE=0
DRIVER.SPI.VAR.SPI4_PARPOL1.VALUE=0
DRIVER.SPI.VAR.SPI4_PARPOL2.VALUE=0
DRIVER.SPI.VAR.SPI4_PARPOL3.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT2_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT3_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_OVRNINTENA.VALUE=0
DRIVER.SPI.VAR.SPI1_BITERRENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT3_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_POLARITY0.VALUE=0
DRIVER.SPI.VAR.SPI4_PHASE0.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT0_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_POLARITY1.VALUE=0
DRIVER.SPI.VAR.SPI4_T2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI4_PHASE1.VALUE=0
DRIVER.SPI.VAR.SPI5_POLARITY2.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT8_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PHASE2.VALUE=0
DRIVER.SPI.VAR.SPI3_BITERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_OVRNINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_RXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_SHIFTDIR0.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT26_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT18_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_POLARITY3.VALUE=1
DRIVER.SPI.VAR.SPI4_PHASE3.VALUE=0
DRIVER.SPI.VAR.SPI2_SHIFTDIR1.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT9_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_T2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI2_SHIFTDIR2.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT8_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI1_ACTUALBAUDRATE0.VALUE=2000.000
DRIVER.SPI.VAR.SPI2_SHIFTDIR3.VALUE=0
DRIVER.SPI.VAR.SPI1_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI4_PORT_BIT10_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT0_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT3_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_ACTUALBAUDRATE2.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_PORT_BIT11_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_ACTUALBAUDRATE3.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_PORT_BIT9_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI4_C2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI2_PORT_BIT2_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_BASE.VALUE=0xFFF7F800
DRIVER.SPI.VAR.SPI3_PORT_BIT1_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT8_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PRESCALE0.VALUE=79
DRIVER.SPI.VAR.SPI3_PORT_BIT8_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT4_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI3_WDELAY0.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT25_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT17_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI4_PRESCALE1.VALUE=79
DRIVER.SPI.VAR.SPI3_C2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI3_WDELAY1.VALUE=0
DRIVER.SPI.VAR.SPI4_PRESCALE2.VALUE=79
DRIVER.SPI.VAR.SPI3_WDELAY2.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT3_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PRESCALE3.VALUE=79
DRIVER.SPI.VAR.SPI4_TIMEOUTENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_WDELAY3.VALUE=0
DRIVER.SPI.VAR.SPI1_DLENERRENA.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT10_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_ENABLEHIGHZ.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT1_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_PARITYENA0.VALUE=0
DRIVER.SPI.VAR.SPI5_C2TDELAY.VALUE=0
DRIVER.SPI.VAR.SPI2_PARITYENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT8_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_TIMEOUTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_BASE_PORT.VALUE=0xFFF7F818
DRIVER.SPI.VAR.SPI2_PORT_BIT10_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_PARITYENA2.VALUE=0
DRIVER.SPI.VAR.SPI2_DLENERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_MASTER.VALUE=1
DRIVER.SPI.VAR.SPI2_PARITYENA3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT19_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT0_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT11_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT11_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_RAM_PARITY_ENA.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT3_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_T2CDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_TXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT3_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT9_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_BASE_RAM.VALUE=0xFF0C0000
DRIVER.SPI.VAR.SPI3_CHARLEN0.VALUE=16
DRIVER.SPI.VAR.SPI3_CHARLEN1.VALUE=16
DRIVER.SPI.VAR.SPI1_PARERRENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT11_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_CHARLEN2.VALUE=16
DRIVER.SPI.VAR.SPI2_PORT_BIT2_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_CHARLEN3.VALUE=16
DRIVER.SPI.VAR.SPI5_PORT_BIT9_DIR.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT9_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PORT_BIT0_FUN.VALUE=1
DRIVER.SPI.VAR.SPI3_PARERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_RXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT9_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_PARPOL0.VALUE=0
DRIVER.SPI.VAR.SPI1_DEYSNCLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_PARPOL1.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT8_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT10_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PARPOL2.VALUE=0
DRIVER.SPI.VAR.SPI2_T2CDELAYACTUAL.VALUE=12.500
DRIVER.SPI.VAR.SPI4_BASE.VALUE=0xFFF7FA00
DRIVER.SPI.VAR.SPI3_PARPOL3.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT2_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT0_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_CLKMOD.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT5_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI3_BAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PHASE0.VALUE=0
DRIVER.SPI.VAR.SPI3_BAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PHASE1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_DIR.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT8_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT0_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_BAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PHASE2.VALUE=0
DRIVER.SPI.VAR.SPI2_TXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_BAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PORT_BIT10_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_PHASE3.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT3_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT0_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT25_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT17_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_PORT_BIT11_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_OVRNINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT1_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI3_POLARITY0.VALUE=0
DRIVER.SPI.VAR.SPI3_POLARITY1.VALUE=0
DRIVER.SPI.VAR.SPI3_POLARITY2.VALUE=0
DRIVER.SPI.VAR.SPI2_OVRNINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT0_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_BITERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_DEYSNCENA.VALUE=0
DRIVER.SPI.VAR.SPI3_POLARITY3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT8_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT11_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_WDELAY0.VALUE=0
DRIVER.SPI.VAR.SPI2_WDELAY1.VALUE=0
DRIVER.SPI.VAR.SPI2_WDELAY2.VALUE=0
DRIVER.SPI.VAR.SPI2_WDELAY3.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT10_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_C2TDELAYACTUAL.VALUE=25.000
DRIVER.SPI.VAR.SPI5_PORT_BIT11_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT9_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT11_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT11_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_PRESCALE0.VALUE=79
DRIVER.SPI.VAR.SPI2_PRESCALE1.VALUE=79
DRIVER.SPI.VAR.SPI2_PORT_BIT8_DIR.VALUE=0
DRIVER.SPI.VAR.SPI2_PRESCALE2.VALUE=79
DRIVER.SPI.VAR.SPI3_TIMEOUTENA.VALUE=0
DRIVER.SPI.VAR.SPI2_PRESCALE3.VALUE=79
DRIVER.SPI.VAR.SPI1_PORT_BIT8_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT0_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PARITYENA0.VALUE=0
DRIVER.SPI.VAR.SPI1_C2TDELAY.VALUE=0
DRIVER.SPI.VAR.SPI1_PARITYENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT8_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_TIMEOUTLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT1_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_PARITYENA2.VALUE=0
DRIVER.SPI.VAR.SPI1_DLENERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_BASE_PORT.VALUE=0xFFF7F418
DRIVER.SPI.VAR.SPI5_RXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI4_BITERRENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT1_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_PARITYENA3.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT9_PDR.VALUE=0
DRIVER.SPI.VAR.SPI4_T2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI2_PORT_BIT8_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_WAITENA0.VALUE=0
DRIVER.SPI.VAR.SPI5_BASE.VALUE=0xFFF7FC00
DRIVER.SPI.VAR.SPI2_WAITENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_SHIFTDIR0.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_WAITENA2.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT10_DIR.VALUE=1
DRIVER.SPI.VAR.SPI5_SHIFTDIR1.VALUE=0
DRIVER.SPI.VAR.SPI2_WAITENA3.VALUE=0
DRIVER.SPI.VAR.SPI5_C2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI5_SHIFTDIR2.VALUE=0
DRIVER.SPI.VAR.SPI5_SHIFTDIR3.VALUE=0
DRIVER.SPI.VAR.SPI1_TXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT8_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT1_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT26_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT18_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_TXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT9_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_PARPOL0.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT0_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT9_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_PARPOL1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT2_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI2_PARPOL2.VALUE=0
DRIVER.SPI.VAR.SPI2_PARPOL3.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT2_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_PARERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_CLKMOD.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT10_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_T2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT11_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_RXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT11_DIR.VALUE=0
DRIVER.SPI.VAR.SPI2_RAM_PARITY_ENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT11_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT0_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT8_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT9_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_BAUDRATE0.VALUE=2000.000
DRIVER.SPI.VAR.SPI1_BAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT8_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT1_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_BAUDRATE2.VALUE=2000.000
DRIVER.SPI.VAR.SPI3_PORT_BIT4_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT25_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT17_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_BAUDRATE3.VALUE=2000.000
DRIVER.SPI.VAR.SPI5_PORT_BIT11_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_WDELAY0.VALUE=0
DRIVER.SPI.VAR.SPI2_C2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI1_WDELAY1.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT9_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_MASTER.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT10_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT3_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_WDELAY2.VALUE=0
DRIVER.SPI.VAR.SPI4_PARERRENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT10_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_WDELAY3.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT9_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT8_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_C2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI1_POLARITY0.VALUE=0
DRIVER.SPI.VAR.SPI4_C2TDELAY.VALUE=0
DRIVER.SPI.VAR.SPI1_POLARITY1.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT4_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT25_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT17_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_POLARITY2.VALUE=1
DRIVER.SPI.VAR.SPI1_OVRNINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_DLENERRENA.VALUE=0
DRIVER.SPI.VAR.SPI2_DEYSNCENA.VALUE=0
DRIVER.SPI.VAR.SPI1_POLARITY3.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT10_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_WAITENA0.VALUE=0
DRIVER.SPI.VAR.SPI5_ENABLEHIGHZ.VALUE=0
DRIVER.SPI.VAR.SPI3_T2CDELAYACTUAL.VALUE=12.500
DRIVER.SPI.VAR.SPI1_PORT_BIT1_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_WAITENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_WAITENA2.VALUE=0
DRIVER.SPI.VAR.SPI4_DEYSNCLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT9_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_WAITENA3.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT9_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT10_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT2_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI4_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_T2CDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT27_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT19_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_PORT_BIT0_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT2_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI4_TXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT3_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT0_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT0_PSL.VALUE=1
DRIVER.SPI.VAR.SPI2_BASE_RAM.VALUE=0xFF0E0000
DRIVER.SPI.VAR.SPI2_CHARLEN0.VALUE=16
DRIVER.SPI.VAR.SPI1_PORT_BIT11_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT4_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT11_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_CHARLEN1.VALUE=16
DRIVER.SPI.VAR.SPI2_TIMEOUTENA.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT9_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_CHARLEN2.VALUE=16
DRIVER.SPI.VAR.SPI2_ENABLEHIGHZ.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT11_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_CHARLEN3.VALUE=16
DRIVER.SPI.VAR.SPI3_PORT_BIT0_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_TIMEOUTLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_BITERRENA.VALUE=0
DRIVER.SPI.VAR.SPI1_RXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT11_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT2_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT10_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_RXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_BITERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_SHIFTDIR0.VALUE=0
DRIVER.SPI.VAR.SPI1_PARPOL0.VALUE=0
DRIVER.SPI.VAR.SPI3_SHIFTDIR1.VALUE=0
DRIVER.SPI.VAR.SPI1_PARPOL1.VALUE=0
DRIVER.SPI.VAR.SPI5_PHASE0.VALUE=0
DRIVER.SPI.VAR.SPI4_C2TDELAYACTUAL.VALUE=25.000
DRIVER.SPI.VAR.SPI3_SHIFTDIR2.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT8_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT11_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_PARPOL2.VALUE=0
DRIVER.SPI.VAR.SPI5_PHASE1.VALUE=0
DRIVER.SPI.VAR.SPI3_SHIFTDIR3.VALUE=0
DRIVER.SPI.VAR.SPI1_PARPOL3.VALUE=0
DRIVER.SPI.VAR.SPI5_PHASE2.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT9_PULL.VALUE=2
DRIVER.SPI.VAR.SPI1_PORT_BIT3_FUN.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT27_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT19_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_PHASE3.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT1_PSL.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT8_DIR.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_DIR.VALUE=1
DRIVER.SPI.VAR.SPI1_TXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI5_PRESCALE0.VALUE=39
DRIVER.SPI.VAR.SPI1_PORT_BIT10_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_C2EDELAY.VALUE=0
DRIVER.SPI.VAR.SPI5_PRESCALE1.VALUE=79
DRIVER.SPI.VAR.SPI5_PRESCALE2.VALUE=39
DRIVER.SPI.VAR.SPI3_PORT_BIT5_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT1_DIR.VALUE=1
DRIVER.SPI.VAR.SPI5_PRESCALE3.VALUE=39
DRIVER.SPI.VAR.SPI3_PORT_BIT9_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_T2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI3_PORT_BIT8_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI2_ACTUALBAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT3_PDR.VALUE=0
DRIVER.SPI.VAR.SPI2_ACTUALBAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI4_BASE_PORT.VALUE=0xFFF7FA18
DRIVER.SPI.VAR.SPI2_PORT_BIT10_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_ACTUALBAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_PORT_BIT0_PULL.VALUE=2
DRIVER.SPI.VAR.SPI5_OVRNINTENA.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI2_ACTUALBAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PORT_BIT9_PSL.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT3_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI5_PORT_BIT1_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_MASTER.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT4_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT1_DOUT.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT2_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_T2CDELAY.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT9_DIR.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT0_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_PORT_BIT11_PSL.VALUE=1
DRIVER.SPI.VAR.SPI5_BASE_RAM.VALUE=0xFF0A0000
DRIVER.SPI.VAR.SPI5_CHARLEN0.VALUE=16
DRIVER.SPI.VAR.SPI3_PORT_BIT10_PULL.VALUE=2
DRIVER.SPI.VAR.SPI3_PORT_BIT2_DIR.VALUE=1
DRIVER.SPI.VAR.SPI5_CHARLEN1.VALUE=16
DRIVER.SPI.VAR.SPI2_PARERRENA.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT4_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI5_CHARLEN2.VALUE=4
DRIVER.SPI.VAR.SPI1_PORT_BIT4_PDR.VALUE=0
DRIVER.SPI.VAR.SPI5_CHARLEN3.VALUE=16
DRIVER.SPI.VAR.SPI5_PORT_BIT25_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT17_DIR.VALUE=0
DRIVER.SPI.VAR.SPI5_PORT_BIT11_PULL.VALUE=2
DRIVER.SPI.VAR.SPI4_PARERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI2_PORT_BIT11_DIR.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT0_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_DLENERRENA.VALUE=0
DRIVER.SPI.VAR.SPI4_RXINTENA.VALUE=0
DRIVER.SPI.VAR.SPI3_RAM_PARITY_ENA.VALUE=0
DRIVER.SPI.VAR.SPI5_PARITYENA0.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT0_PDR.VALUE=0
DRIVER.SPI.VAR.SPI1_WAITENA0.VALUE=0
DRIVER.SPI.VAR.SPI5_PARITYENA1.VALUE=0
DRIVER.SPI.VAR.SPI1_WAITENA1.VALUE=0
DRIVER.SPI.VAR.SPI5_PARITYENA2.VALUE=0
DRIVER.SPI.VAR.SPI5_DLENERRLVL.VALUE=0
DRIVER.SPI.VAR.SPI4_PORT_BIT8_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_DEYSNCLVL.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT5_FUN.VALUE=1
DRIVER.SPI.VAR.SPI1_WAITENA2.VALUE=0
DRIVER.SPI.VAR.SPI5_PARITYENA3.VALUE=0
DRIVER.SPI.VAR.SPI1_WAITENA3.VALUE=0
DRIVER.SPI.VAR.SPI1_PORT_BIT3_PSL.VALUE=1
DRIVER.SPI.VAR.SPI3_PORT_BIT1_FUN.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT8_PULL.VALUE=2
DRIVER.SPI.VAR.SPI2_PORT_BIT9_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI4_BAUDRATE0.VALUE=1000.000
DRIVER.SPI.VAR.SPI1_T2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI4_BAUDRATE1.VALUE=1000.000
DRIVER.SPI.VAR.SPI4_BAUDRATE2.VALUE=1000.000
DRIVER.SPI.VAR.SPI4_TXINTLVL.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT3_DIR.VALUE=1
DRIVER.SPI.VAR.SPI2_PORT_BIT10_FUN.VALUE=1
DRIVER.SPI.VAR.SPI4_BAUDRATE3.VALUE=1000.000
DRIVER.SPI.VAR.SPI2_PORT_BIT2_PULDIS.VALUE=0
DRIVER.SPI.VAR.SPI1_TIMEOUTENA.VALUE=0
DRIVER.SPI.VAR.SPI5_CLKMOD.VALUE=1
DRIVER.SPI.VAR.SPI4_PORT_BIT8_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_PORT_BIT9_DOUT.VALUE=0
DRIVER.SPI.VAR.SPI3_PHASE0.VALUE=0
DRIVER.SPI.VAR.SPI2_C2EDELAYACTUAL.VALUE=0.000
DRIVER.SPI.VAR.SPI1_PORT_BIT5_PDR.VALUE=0
DRIVER.SPI.VAR.SPI3_PHASE1.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_SYNC.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_BAUDRATE.VALUE=500
DRIVER.CAN.VAR.CAN_2_PORT_RX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_ID.VALUE=30
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_ID.VALUE=22
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_ID.VALUE=14
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_ID.VALUE=9
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_RAMBASE.VALUE=0xFF1C0000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_NOMINAL_BIT_RATE.VALUE=500.000
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_PIN_MODE.VALUE=1
DRIVER.CAN.VAR.CAN_2_PHASE_SEG.VALUE=2
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_ID.VALUE=31
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_ID.VALUE=23
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_ID.VALUE=15
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_AUTO_BUS_ON.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_BASE.VALUE=0xFFF7DC00
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_ID.VALUE=40
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_ID.VALUE=32
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_ID.VALUE=24
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_ID.VALUE=16
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_RX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_ID.VALUE=41
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_ID.VALUE=33
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_ID.VALUE=25
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_ID.VALUE=17
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_BRP_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_DIR.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PROP_SEG.VALUE=3
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_ID.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_NOMINAL_BIT_RATE.VALUE=500.000
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_ID.VALUE=50
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_ID.VALUE=42
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_ID.VALUE=34
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_ID.VALUE=26
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_ID.VALUE=18
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PROPAGATION_DELAY.VALUE=700
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_ID.VALUE=2
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_NOMINAL_BIT_TIME.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_SAMPLE_POINT.VALUE=75.000
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_ID.VALUE=51
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_ID.VALUE=43
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_ID.VALUE=35
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_ID.VALUE=27
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_ID.VALUE=19
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_ID.VALUE=3
DRIVER.CAN.VAR.CAN_2_PORT_RX_DOUT.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_BASE.VALUE=0xFFF7DE00
DRIVER.CAN.VAR.CAN_1_RAMBASE.VALUE=0xFF1E0000
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_RX_PULL.VALUE=2
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_IDENTIFIER_MODE.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_ID.VALUE=60
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_ID.VALUE=52
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_ID.VALUE=44
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_ID.VALUE=36
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_ID.VALUE=28
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_ID.VALUE=4
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_AUTO_RETRANSMISSION.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_ID.VALUE=61
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_ID.VALUE=53
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_ID.VALUE=45
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_ID.VALUE=37
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_ID.VALUE=29
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_TX_PULL.VALUE=2
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_NOMINAL_BIT_RATE.VALUE=500.000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_ID.VALUE=5
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_BRPE_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_RX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_ID.VALUE=62
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_ID.VALUE=54
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_ID.VALUE=46
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_ID.VALUE=38
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_NOMINAL_BIT_TIME.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_PORT_RX_DIR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_TQ.VALUE=250.000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_ID.VALUE=6
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_ID.VALUE=63
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_ID.VALUE=55
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_ID.VALUE=47
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_ID.VALUE=39
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_DLC.VALUE=7
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_TQ.VALUE=250.000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_BRPE.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_ID.VALUE=7
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_BASE.VALUE=0xFFF7E000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_PORT_TX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_ID.VALUE=64
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_ID.VALUE=56
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_ID.VALUE=48
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_DOUT.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_TQ.VALUE=250.000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_ID.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_ID.VALUE=10
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_ID.VALUE=57
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_ID.VALUE=49
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_DLC.VALUE=6
DRIVER.CAN.VAR.CAN_1_SAMPLE_POINT_REFERENCE.VALUE=75
DRIVER.CAN.VAR.CAN_1_PROPAGATION_DELAY.VALUE=700
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_ID.VALUE=9
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_ID.VALUE=11
DRIVER.CAN.VAR.CAN_1_NOMINAL_BIT_TIME.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_RX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_ENABLE.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_PIN_MODE.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_ID.VALUE=58
DRIVER.CAN.VAR.CAN_2_SAMPLE_POINT_REFERENCE.VALUE=75
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PORT_RX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_ID.VALUE=20
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_ID.VALUE=12
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_AUTO_BUS_ON.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_ID.VALUE=59
DRIVER.CAN.VAR.CAN_1_PORT_RX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_SAMPLE_POINT_REFERENCE.VALUE=75
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_DLC.VALUE=5
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_SHIFT.VALUE=18
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_BRPE.VALUE=0
DRIVER.CAN.VAR.CAN_1_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_ID.VALUE=21
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_ID.VALUE=13
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_BRPE_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_1_BRP_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_ID.VALUE=30
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_ID.VALUE=22
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_ID.VALUE=14
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_DLC.VALUE=5
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_BAUDRATE.VALUE=500
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_ID.VALUE=31
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_ID.VALUE=23
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_ID.VALUE=15
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PORT_RX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_SAMPLE_POINT.VALUE=75.000
DRIVER.CAN.VAR.CAN_1_PORT_TX_DIR.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.CAN.VAR.CAN_3_PHASE_SEG.VALUE=2
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_ID.VALUE=40
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_ID.VALUE=32
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_ID.VALUE=24
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_ID.VALUE=16
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_PORT_RX_DOUT.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_DLC.VALUE=6
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_RX_PULL.VALUE=2
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_BRPE.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_ID.VALUE=41
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_ID.VALUE=0x200
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_ID.VALUE=25
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_ID.VALUE=17
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_ID.VALUE=0x100
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_PORT_TX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_ID.VALUE=50
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_ID.VALUE=42
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_ID.VALUE=0x340
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_ID.VALUE=26
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_ID.VALUE=18
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_BRP.VALUE=19
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_PROP_SEG.VALUE=3
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_ID.VALUE=10
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_ID.VALUE=0x200
DRIVER.CAN.VAR.CAN_1_AUTO_BUS_ON_TR.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_DLC.VALUE=7
DRIVER.CAN.VAR.CAN_3_PORT_RX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_ID.VALUE=51
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_ID.VALUE=43
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_ID.VALUE=0x350
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_ID.VALUE=27
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_ID.VALUE=19
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_AUTO_BUS_ON_TIME.VALUE=0
DRIVER.CAN.VAR.CAN_3_PORT_RX_DIR.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_ID.VALUE=11
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_ID.VALUE=0x300
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_ID.VALUE=60
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_ID.VALUE=52
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_ID.VALUE=44
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_ID.VALUE=0x360
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_ID.VALUE=28
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_BRP.VALUE=19
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_PORT_RX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_ID.VALUE=20
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_ID.VALUE=12
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_ID.VALUE=0x400
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_NOMINAL_AUTO_BUS_ON_TIME.VALUE=0.000
DRIVER.CAN.VAR.CAN_2_SHIFT.VALUE=18
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MASK.VALUE=0x1FFFFFFF
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_TX_DOUT.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_31_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_23_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_15_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_ID.VALUE=0x7E7
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_ID.VALUE=53
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_ID.VALUE=45
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_ID.VALUE=0x370
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_ID.VALUE=29
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_PULL.VALUE=2
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_ID.VALUE=21
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_ID.VALUE=13
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_ID.VALUE=0x500
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_ID.VALUE=0x7EF
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_ID.VALUE=54
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_ID.VALUE=46
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_ID.VALUE=0x380
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_BRP.VALUE=19
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_IDENTIFIER_MODE.VALUE=0x40000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PHASE_SEG.VALUE=2
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_ID.VALUE=30
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_ID.VALUE=22
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_ID.VALUE=14
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_ID.VALUE=0x600
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_AUTO_BUS_ON_TIME.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_RX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_ID.VALUE=0x701
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_ID.VALUE=55
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_ID.VALUE=47
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_ID.VALUE=0x390
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_ID.VALUE=31
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_ID.VALUE=23
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_20_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_ID.VALUE=15
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_12_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_PORT_TX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_ID.VALUE=0x700
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_PORT_RX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_ID.VALUE=0x700
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_ID.VALUE=56
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_ID.VALUE=48
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_ID.VALUE=40
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_ID.VALUE=32
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_ID.VALUE=24
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_ID.VALUE=16
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_ID.VALUE=0x800
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_NOMINAL_AUTO_BUS_ON_TIME.VALUE=0.000
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_AUTO_RETRANSMISSION.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_ID.VALUE=57
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_ID.VALUE=49
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_AUTO_BUS_ON.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_40_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_32_MASK.VALUE=0x00000600
DRIVER.CAN.VAR.CAN_1_MESSAGE_24_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_16_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_ID.VALUE=41
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_ID.VALUE=33
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_ID.VALUE=25
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_ID.VALUE=17
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_ID.VALUE=9
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_SJW.VALUE=2
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_BAUDRATE.VALUE=500
DRIVER.CAN.VAR.CAN_1_MESSAGE_61_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_53_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_45_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_37_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_29_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_IDENTIFIER_MODE.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_ID.VALUE=58
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_AUTO_BUS_ON_TIME.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_ID.VALUE=50
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_ID.VALUE=42
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_ID.VALUE=34
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_ID.VALUE=26
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_ID.VALUE=18
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_TX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_PIN_MODE.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_30_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_22_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_14_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_PORT_RX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_AUTO_BUS_ON_TR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_ID.VALUE=59
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_TX_DIR.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_DIR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_4_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_ID.VALUE=51
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_ID.VALUE=43
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_ID.VALUE=35
DRIVER.CAN.VAR.CAN_3_MESSAGE_30_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_ID.VALUE=27
DRIVER.CAN.VAR.CAN_3_MESSAGE_22_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_ID.VALUE=19
DRIVER.CAN.VAR.CAN_3_MESSAGE_14_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_6_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_SJW.VALUE=2
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_RX_PULL.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_50_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_42_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_34_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_26_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_18_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_ID.VALUE=60
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_ID.VALUE=52
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_ID.VALUE=44
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_ID.VALUE=36
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_ID.VALUE=28
DRIVER.CAN.VAR.CAN_1_MESSAGE_63_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_55_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_47_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_39_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_NOMINAL_AUTO_BUS_ON_TIME.VALUE=0.000
DRIVER.CAN.VAR.CAN_1_SYNC.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_11_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_SHIFT.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_PORT_RX_PULDIS.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_40_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_32_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_24_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_16_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_ID.VALUE=200
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_BRP_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_2_BRPE_FREQ.VALUE=4.000
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PROP_SEG.VALUE=3
DRIVER.CAN.VAR.CAN_1_MESSAGE_41_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_33_MASK.VALUE=0x00000200
DRIVER.CAN.VAR.CAN_1_MESSAGE_25_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_17_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_ID.VALUE=61
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_ID.VALUE=53
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_ID.VALUE=45
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_ID.VALUE=37
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_ID.VALUE=29
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_SJW.VALUE=2
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_1_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_3_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_ID.VALUE=2
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_8_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_10_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_SAMPLE_POINT.VALUE=75.000
DRIVER.CAN.VAR.CAN_2_MESSAGE_51_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_43_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_35_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_27_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_19_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_ID.VALUE=62
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_ID.VALUE=54
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_ID.VALUE=46
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_ID.VALUE=38
DRIVER.CAN.VAR.CAN_1_MESSAGE_64_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_56_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_48_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_PORT_TX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_1_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_21_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_13_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_7_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_5_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_60_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_52_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_44_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_36_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_28_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_ID.VALUE=3
DRIVER.CAN.VAR.CAN_1_PORT_RX_DOUT.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_1_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_ID.VALUE=63
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_ID.VALUE=55
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_ID.VALUE=47
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_ID.VALUE=39
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_RAMBASE.VALUE=0xFF1A0000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_PORT_RX_DIN.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_59_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_PORT_TX_PDR.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_ID.VALUE=4
DRIVER.CAN.VAR.CAN_1_MESSAGE_31_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_23_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_15_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_PORT_RX_DIR.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_PORT_TX_DOUT.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_64_ID.VALUE=64
DRIVER.CAN.VAR.CAN_3_MESSAGE_56_ID.VALUE=56
DRIVER.CAN.VAR.CAN_3_MESSAGE_48_ID.VALUE=48
DRIVER.CAN.VAR.CAN_3_MESSAGE_31_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_23_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_15_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_57_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_49_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_3_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_SYNC.VALUE=1
DRIVER.CAN.VAR.CAN_2_PORT_TX_PULL.VALUE=2
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_2_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_64_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_63_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_56_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_55_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_48_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_47_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_39_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_61_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_53_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_45_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_37_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_29_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_ID.VALUE=10
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_ID.VALUE=5
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_57_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_49_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_4_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_50_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_42_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_34_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_26_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_18_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_ID.VALUE=57
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_ID.VALUE=49
DRIVER.CAN.VAR.CAN_3_MESSAGE_41_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_33_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_25_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_17_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_9_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_62_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_54_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_46_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_38_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_51_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_43_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_35_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_27_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_19_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_9_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_41_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_33_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_25_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_17_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_11_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_5_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_58_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_11_ID.VALUE=11
DRIVER.CAN.VAR.CAN_2_MESSAGE_6_ID.VALUE=6
DRIVER.CAN.VAR.CAN_3_PROPAGATION_DELAY.VALUE=700
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_57_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_49_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_AUTO_RETRANSMISSION.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_20_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_12_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_9_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_ENA.VALUE=0x80000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_58_ID.VALUE=58
DRIVER.CAN.VAR.CAN_1_MESSAGE_60_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_52_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_44_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_36_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_28_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_3_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_7_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_2_MESSAGE_10_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_PORT_TX_PSL.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_60_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_52_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_44_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_36_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_28_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_62_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_54_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_46_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_38_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_20_ID.VALUE=20
DRIVER.CAN.VAR.CAN_2_MESSAGE_12_ID.VALUE=12
DRIVER.CAN.VAR.CAN_2_MESSAGE_7_ID.VALUE=7
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_59_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_51_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_43_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_35_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_27_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_19_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_61_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_53_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_45_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_40_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_37_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_32_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_29_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_24_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_16_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_3_MESSAGE_10_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_1_MESSAGE_8_BOOL_ENA.VALUE=1
DRIVER.CAN.VAR.CAN_1_MESSAGE_2_MASK.VALUE=0x000007FF
DRIVER.CAN.VAR.CAN_3_MESSAGE_59_ID.VALUE=59
DRIVER.CAN.VAR.CAN_3_MESSAGE_50_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_42_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_34_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_26_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_18_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_AUTO_BUS_ON_TR.VALUE=0
DRIVER.CAN.VAR.CAN_2_MESSAGE_30_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_22_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_14_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_5_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_4_DLC.VALUE=8
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_63_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_62_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_55_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_54_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_47_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_46_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_EOB.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_39_DIR.VALUE=0x20000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_38_INT_ENA_REF.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_PORT_RX_FUN.VALUE=1
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_BOOL_ENA.VALUE=0
DRIVER.CAN.VAR.CAN_1_MESSAGE_58_INT_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_21_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_1_MESSAGE_13_ENA.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_6_RTR.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_3_MESSAGE_2_INT_LEVEL.VALUE=0x00000000
DRIVER.CAN.VAR.CAN_2_MESSAGE_21_ID.VALUE=21
DRIVER.CAN.VAR.CAN_2_MESSAGE_13_ID.VALUE=13
DRIVER.CAN.VAR.CAN_2_MESSAGE_8_ID.VALUE=8
DRIVER.ADC.VAR.ADC2_GROUP1_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_PIN21_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN13_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_GROUP1_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC2_GROUP0_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_PARITY_ENABLE.VALUE=0x00000005
DRIVER.ADC.VAR.ADC1_GROUP2_PIN17_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC1_GROUP2_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC2_GROUP2_PIN7_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN10_ENABLE.VALUE=0x00000400
DRIVER.ADC.VAR.ADC1_GROUP2_TRIGGER_EDGE_ENABLE.VALUE=0x00000008
DRIVER.ADC.VAR.ADC1_GROUP2_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_EXTENDED_SAMPLE_TIME.VALUE=900.00
DRIVER.ADC.VAR.ADC2_GROUP2_PIN0_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_CHANNEL_TOTAL_TIME.VALUE=0.000000
DRIVER.ADC.VAR.ADC1_GROUP1_FIFO_SIZE.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP2_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_SAMPLE_PRESCALER.VALUE=1
DRIVER.ADC.VAR.ADC1_GROUP1_LENGTH.VALUE=16
DRIVER.ADC.VAR.ADC2_GROUP1_ID_ENABLE.VALUE=0x00000020
DRIVER.ADC.VAR.ADC1_GROUP2_CONVERSION_TIME.VALUE=1.300
DRIVER.ADC.VAR.ADC2_PORT_BIT0_DIR.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_PIN4_ENABLE.VALUE=0x00000010
DRIVER.ADC.VAR.ADC2_GROUP0_PIN11_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN7_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_ALT_TRIG.VALUE=1
DRIVER.ADC.VAR.ADC2_GROUP1_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN0_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_CONVERSION_TIME.VALUE=1.300
DRIVER.ADC.VAR.ADC2_GROUP2_LENGTH.VALUE=32
DRIVER.ADC.VAR.ADC2_GROUP2_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN4_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN22_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN14_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_ACTUAL_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP2_SAMPLE_PRESCALER.VALUE=1
DRIVER.ADC.VAR.ADC2_GROUP2_PIN12_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN18_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_PIN8_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN11_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_BND.VALUE=2
DRIVER.ADC.VAR.ADC2_GROUP0_PIN1_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN23_ENABLE.VALUE=0x00800000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_SAMPLE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_PORT_BIT0_PULDIS.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP2_PIN5_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN8_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_ID_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_EXTENDED_SAMPLE_TIME.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP0_CONVERSION_TIME.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP0_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC1_GROUP1_PIN1_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC2_GROUP1_TRIGGER_EDGE_ENABLE.VALUE=0x00000008
DRIVER.ADC.VAR.ADC2_GROUP0_CONVERSION_TIME.VALUE=1.300
DRIVER.ADC.VAR.ADC2_BND.VALUE=2
DRIVER.ADC.VAR.ADC2_GROUP1_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_PORT_BIT0_PDR.VALUE=0
DRIVER.ADC.VAR.ADC2_ACTUAL_CYCLE_TIME.VALUE=100.00
DRIVER.ADC.VAR.ADC2_GROUP1_SAMPLE_PRESCALER.VALUE=7
DRIVER.ADC.VAR.ADC2_GROUP1_PIN9_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_SAMPLE_TIME.VALUE=900.00
DRIVER.ADC.VAR.ADC2_GROUP1_PIN2_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_TRIGGER_MODE.VALUE=0x00000008
DRIVER.ADC.VAR.ADC1_GROUP0_PIN5_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_PIN13_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN9_ENABLE.VALUE=0x00000200
DRIVER.ADC.VAR.ADC1_GROUP0_PIN19_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.ADC.VAR.ADC2_GROUP1_SCAN_TIME.VALUE=125.000
DRIVER.ADC.VAR.ADC2_GROUP0_CHANNEL_TOTAL_TIME.VALUE=0.000000
DRIVER.ADC.VAR.ADC1_GROUP2_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP0_LENGTH.VALUE=16
DRIVER.ADC.VAR.ADC1_GROUP0_SAMPLE_PRESCALER.VALUE=1
DRIVER.ADC.VAR.ADC1_PORT_BIT0_PULDIS.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP2_PIN2_ENABLE.VALUE=0x00000004
DRIVER.ADC.VAR.ADC1_GROUP0_PIN20_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN12_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_PIN10_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN24_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN16_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_ACTUAL_SAMPLE_TIME.VALUE=200.00
DRIVER.ADC.VAR.ADC2_GROUP0_PIN6_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_TRIGGER_MODE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_PORT_BIT0_PSL.VALUE=1
DRIVER.ADC.VAR.ADC1_GROUP2_CHANNEL_TOTAL_TIME.VALUE=24.875000
DRIVER.ADC.VAR.ADC1_GROUP0_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_LENGTH.VALUE=64
DRIVER.ADC.VAR.ADC2_GROUP0_DISCHARGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN21_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN13_ENABLE.VALUE=0x00002000
DRIVER.ADC.VAR.ADC2_GROUP0_PINS.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP0_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_GROUP0_SAMPLE_PRESCALER.VALUE=1
DRIVER.ADC.VAR.ADC1_GROUP0_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP2_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN6_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_RAMBASE.VALUE=0xFF3A0000
DRIVER.ADC.VAR.ADC2_GROUP0_BND.VALUE=8
DRIVER.ADC.VAR.ADC1_PORT_BIT0_DOUT.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_SCAN_TIME.VALUE=0.000
DRIVER.ADC.VAR.ADC1_GROUP0_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC2_GROUP2_FIFO_SIZE.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_PIN7_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_PIN14_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP1_BND.VALUE=8
DRIVER.ADC.VAR.ADC2_GROUP0_HW_TRIGGER_SOURCE_ALT.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP1_PIN0_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_ALT_TRIG_COMP.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_HW_TRIGGER_SOURCE_ALT.VALUE=EPWM_A1
DRIVER.ADC.VAR.ADC2_GROUP1_PIN11_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN7_ENABLE.VALUE=0x00000080
DRIVER.ADC.VAR.ADC1_GROUP0_PIN17_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_PARITY_ENABLE.VALUE=0x00000005
DRIVER.ADC.VAR.ADC1_ACTUAL_CYCLE_TIME.VALUE=100.00
DRIVER.ADC.VAR.ADC2_GROUP2_HW_TRIGGER_SOURCE_ALT.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP2_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN0_ENABLE.VALUE=0x00000001
DRIVER.ADC.VAR.ADC1_GROUP2_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN10_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_PINS.VALUE=3
DRIVER.ADC.VAR.ADC1_GROUP1_PIN22_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN14_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_PIN4_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN18_ENABLE.VALUE=0x00040000
DRIVER.ADC.VAR.ADC2_GROUP2_PIN8_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_TRIGGER_EDGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN11_ENABLE.VALUE=0x00000800
DRIVER.ADC.VAR.ADC2_GROUP2_PIN1_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_FIFO_SIZE.VALUE=15
DRIVER.ADC.VAR.ADC1_GROUP1_PIN4_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_RAMBASE.VALUE=0xFF3E0000
DRIVER.ADC.VAR.ADC1_BASE.VALUE=0xFFF7C000
DRIVER.ADC.VAR.ADC1_PORT_BIT0_DIR.VALUE=0
DRIVER.ADC.VAR.ADC2_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.ADC.VAR.ADC2_GROUP2_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP2_ID_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_ACTUAL_SAMPLE_TIME.VALUE=900.00
DRIVER.ADC.VAR.ADC1_GROUP2_LENGTH.VALUE=32
DRIVER.ADC.VAR.ADC1_GROUP0_BND.VALUE=8
DRIVER.ADC.VAR.ADC2_GROUP2_CHANNEL_TOTAL_TIME.VALUE=0.000000
DRIVER.ADC.VAR.ADC2_GROUP2_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_PIN5_ENABLE.VALUE=0x00000020
DRIVER.ADC.VAR.ADC2_GROUP0_PIN12_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN8_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_TRIGGER_EDGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_PINS.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP0_EXTENDED_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC1_GROUP1_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC1_GROUP0_PIN1_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_EXTENDED_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP1_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_GROUP2_TRIGGER_MODE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_FIFO_SIZE.VALUE=16
DRIVER.ADC.VAR.ADC1_GROUP2_PIN5_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN23_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_BND.VALUE=8
DRIVER.ADC.VAR.ADC2_GROUP2_PIN13_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN19_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_PORT_BIT0_DOUT.VALUE=0
DRIVER.ADC.VAR.ADC2_CYCLE_TIME.VALUE=100.00
DRIVER.ADC.VAR.ADC1_GROUP1_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC1_GROUP1_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP0_PIN9_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_PRESCALE.VALUE=7
DRIVER.ADC.VAR.ADC1_GROUP1_PIN20_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN12_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP0_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_BASE.VALUE=0xFFF7C200
DRIVER.ADC.VAR.ADC2_GROUP0_PIN2_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP2_PIN24_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN16_ENABLE.VALUE=0x00010000
DRIVER.ADC.VAR.ADC1_GROUP2_ID_ENABLE.VALUE=0x00000020
DRIVER.ADC.VAR.ADC2_GROUP2_PIN6_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN9_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_PORT_BIT0_PDR.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_SAMPLE_TIME.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_PIN2_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_CONVERSION_TIME.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP0_FIFO_SIZE.VALUE=16
DRIVER.ADC.VAR.ADC1_PORT_BIT0_PULL.VALUE=2
DRIVER.ADC.VAR.ADC1_GROUP0_LENGTH.VALUE=16
DRIVER.ADC.VAR.ADC2_GROUP1_CONVERSION_TIME.VALUE=1.300
DRIVER.ADC.VAR.ADC1_GROUP0_PINS.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP0_ACTUAL_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP1_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_PIN10_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_ID_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN6_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_SCAN_TIME.VALUE=0.000
DRIVER.ADC.VAR.ADC2_GROUP1_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC1_GROUP1_CHANNEL_TOTAL_TIME.VALUE=0.000000
DRIVER.ADC.VAR.ADC1_GROUP0_EXTENDED_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC1_GROUP0_HW_TRIGGER_SOURCE_ALT.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP1_PIN14_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_PORT_BIT0_PSL.VALUE=1
DRIVER.ADC.VAR.ADC1_GROUP2_EXTENDED_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP1_LENGTH.VALUE=16
DRIVER.ADC.VAR.ADC1_GROUP1_HW_TRIGGER_SOURCE_ALT.VALUE=EVENT
DRIVER.ADC.VAR.ADC1_GROUP2_PIN3_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN21_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN13_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC1_GROUP2_HW_TRIGGER_SOURCE_ALT.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP2_PIN11_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN17_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_GROUP0_PIN7_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN10_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC2_GROUP0_PIN0_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN22_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN14_ENABLE.VALUE=0x00004000
DRIVER.ADC.VAR.ADC1_CYCLE_TIME.VALUE=100.00
DRIVER.ADC.VAR.ADC2_GROUP0_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP2_PIN4_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN7_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC1_GROUP0_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC1_GROUP1_PIN0_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_ID_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_DISCHARGE_TIME.VALUE=0.00
DRIVER.ADC.VAR.ADC1_GROUP2_SCAN_TIME.VALUE=875.000
DRIVER.ADC.VAR.ADC1_GROUP1_PINS.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP1_TRIGGER_EDGE_ENABLE.VALUE=0x00000008
DRIVER.ADC.VAR.ADC1_ALT_TRIG_COMP.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP0_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_PIN8_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_ALT_TRIG.VALUE=1
DRIVER.ADC.VAR.ADC1_GROUP1_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_PIN1_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_RAM_PARITY_ENA.VALUE=0
DRIVER.ADC.VAR.ADC1_GROUP0_PIN4_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_DISCHARGE_PRESCALER.VALUE=0
DRIVER.ADC.VAR.ADC2_GROUP1_PIN12_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN8_ENABLE.VALUE=0x00000100
DRIVER.ADC.VAR.ADC1_GROUP0_PIN18_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_RESOLUTION.VALUE=12_BIT
DRIVER.ADC.VAR.ADC1_GROUP2_PIN1_ENABLE.VALUE=0x00000002
DRIVER.ADC.VAR.ADC1_GROUP0_PIN11_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_SCAN_TIME.VALUE=0.000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN23_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN15_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_HW_TRIGGER_SOURCE.VALUE=EVENT
DRIVER.ADC.VAR.ADC2_GROUP0_PIN5_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN19_ENABLE.VALUE=0x00080000
DRIVER.ADC.VAR.ADC1_PRESCALE.VALUE=7
DRIVER.ADC.VAR.ADC2_GROUP0_ACTUAL_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC1_GROUP2_PINS.VALUE=15
DRIVER.ADC.VAR.ADC2_PORT_BIT0_PULL.VALUE=2
DRIVER.ADC.VAR.ADC1_LENGTH.VALUE=64
DRIVER.ADC.VAR.ADC2_GROUP2_PIN9_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN20_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN12_ENABLE.VALUE=0x00001000
DRIVER.ADC.VAR.ADC2_GROUP2_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP1_CHANNEL_TOTAL_TIME.VALUE=6.725000
DRIVER.ADC.VAR.ADC2_GROUP2_PIN2_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_CONTINUOUS_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_PIN5_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_ACTUAL_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC1_GROUP0_SCAN_TIME.VALUE=0.000
DRIVER.ADC.VAR.ADC2_GROUP1_PIN6_ENABLE.VALUE=0x00000040
DRIVER.ADC.VAR.ADC2_GROUP0_PIN13_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP0_TRIGGER_EDGE_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN9_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_SAMPLE_TIME.VALUE=300.00
DRIVER.ADC.VAR.ADC2_GROUP1_FIFO_SIZE.VALUE=3
DRIVER.ADC.VAR.ADC1_GROUP0_PIN2_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP1_PIN10_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP2_PIN6_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN24_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP0_PIN16_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC2_GROUP2_PIN14_ENABLE.VALUE=0x00000000
DRIVER.ADC.VAR.ADC1_GROUP1_TRIGGER_MODE.VALUE=0x00000008
DRIVER.ADC.VAR.ADC1_GROUP0_ACTUAL_DISCHARGE_TIME.VALUE=0.00
DRIVER.LIN.VAR.LIN_PORT_BIT0_DOUT.VALUE=0
DRIVER.LIN.VAR.LIN_PEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TOAWUSINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_BEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TOA3WUSINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT1_DOUT.VALUE=0
DRIVER.LIN.VAR.LIN_MAXPRESCALE.VALUE=3600
DRIVER.LIN.VAR.LIN_LENGTH.VALUE=8
DRIVER.LIN.VAR.LIN_PARITYENA.VALUE=0
DRIVER.LIN.VAR.LIN_BREAKINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TX_MASK.VALUE=0xFF
DRIVER.LIN.VAR.LIN_MSTMOD.VALUE=1
DRIVER.LIN.VAR.LIN_SDEL.VALUE=1
DRIVER.LIN.VAR.LIN_PORT_BIT2_DOUT.VALUE=0
DRIVER.LIN.VAR.LIN_TOAWUSINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_WAKEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_HGENCTRL.VALUE=1
DRIVER.LIN.VAR.LIN_TOA3WUSINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT0_DIR.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT0_PULL.VALUE=2
DRIVER.LIN.VAR.LIN_CEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_BREAKINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PBEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT1_DIR.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT0_FUN.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT1_PULDIS.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT2_DIR.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT1_PULL.VALUE=2
DRIVER.LIN.VAR.LIN_WAKEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT0_PDR.VALUE=0
DRIVER.LIN.VAR.LIN_OEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT1_FUN.VALUE=2
DRIVER.LIN.VAR.LIN_NREINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT1_PDR.VALUE=0
DRIVER.LIN.VAR.LIN_PORT_BIT2_FUN.VALUE=4
DRIVER.LIN.VAR.LIN_CEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT0_PSL.VALUE=1
DRIVER.LIN.VAR.LIN_PORT_BIT2_PULL.VALUE=2
DRIVER.LIN.VAR.LIN_PBEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT2_PDR.VALUE=0
DRIVER.LIN.VAR.LIN_BASE_PORT.VALUE=0xFFF7E440
DRIVER.LIN.VAR.LIN_ACTUALBAUDRATE.VALUE=20.000
DRIVER.LIN.VAR.LIN_PORT_BIT1_PSL.VALUE=2
DRIVER.LIN.VAR.LIN_ISFEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_FEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT2_PSL.VALUE=4
DRIVER.LIN.VAR.LIN_OEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TXINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_NREINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_IDINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_SBREAK.VALUE=13
DRIVER.LIN.VAR.LIN_TOINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_BAUDRATE.VALUE=20.000
DRIVER.LIN.VAR.LIN_RX_MASK.VALUE=0xFF
DRIVER.LIN.VAR.LIN_ISFEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_RXINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_BASE.VALUE=0xFFF7E400
DRIVER.LIN.VAR.LIN_FEINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TXINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PORT_BIT2_PULDIS.VALUE=0
DRIVER.LIN.VAR.LIN_IDINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_TOINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_MAXBAUDRATE.VALUE=22.222
DRIVER.LIN.VAR.LIN_BEINTENA.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_RXINTLVL.VALUE=0x00000000
DRIVER.LIN.VAR.LIN_PRESCALE.VALUE=249
DRIVER.LIN.VAR.LIN_PORT_BIT0_PULDIS.VALUE=0
DRIVER.HET.VAR.HET2_EDGE5_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_PWM0_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT0_PULL.VALUE=1
DRIVER.HET.VAR.HET2_INT_X0.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE4_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_BIT1_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_HRSHARE.VALUE=0x00000008
DRIVER.HET.VAR.HET2_INT_X1.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_BIT29_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT0_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_IGNORE_SUSPEND_ENABLE.VALUE=0x00020000
DRIVER.HET.VAR.HET2_PWM3_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_PWM1_PIN_SELECT.VALUE=2
DRIVER.HET.VAR.HET2_BIT12_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT3_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_INT_X2.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X3.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_INT_X4.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_PWM0_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT4_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM3_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT4_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X5.VALUE=0x00000000
DRIVER.HET.VAR.HET2_IGNORE_SUSPEND_ENABLE.VALUE=0x00020000
DRIVER.HET.VAR.HET1_BIT30_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT26_HRSHARE.VALUE=0x00002000
DRIVER.HET.VAR.HET1_BIT22_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM4_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT3_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X6.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE0_PIN_SELECT.VALUE=9
DRIVER.HET.VAR.HET1_BIT28_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT7_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_INT_X7.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT7_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X8.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT18_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT10_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X9.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT11_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT11_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_PWM4_PIN_SELECT.VALUE=16
DRIVER.HET.VAR.HET2_PWM4_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET1_RAM_BASE.VALUE=0xFF460000
DRIVER.HET.VAR.HET2_EDGE6_BOTH.VALUE=0
DRIVER.HET.VAR.HET2_PWM2_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT15_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE2_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_BIT11_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PIN_ENABLE.VALUE=0
DRIVER.HET.VAR.HET1_CAP3_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT24_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT5_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT27_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT19_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE6_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT24_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT16_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT2_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE3_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_EDGE5_PIN_SELECT.VALUE=10
DRIVER.HET.VAR.HET2_BIT13_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT27_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT19_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_CAP5_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_PWM4_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT8_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_CAP2_PIN_SELECT.VALUE=4
DRIVER.HET.VAR.HET2_BIT4_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT29_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT0_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT8_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_BIT1_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT12_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_PWM4_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_BIT18_PULL.VALUE=1
DRIVER.HET.VAR.HET2_BIT16_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_BIT0_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT6_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP5_PIN_SELECT.VALUE=26
DRIVER.HET.VAR.HET1_BIT28_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT10_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_EDGE7_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM0_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT1_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE7_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_EDGE5_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_PWM5_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_BIT3_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE7_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_EDGE1_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_PWM1_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT14_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT4_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_EDGE4_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_BIT5_PULL.VALUE=1
DRIVER.HET.VAR.HET1_MASTER.VALUE=1
DRIVER.HET.VAR.HET2_EDGE5_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_ENA.VALUE=0
DRIVER.HET.VAR.HET2_PWM0_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT2_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT5_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT8_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT1_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_LR_ACTUALTIME.VALUE=800.000
DRIVER.HET.VAR.HET1_PWM5_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_PWM5_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM4_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_BIT9_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM0_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT5_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_PIN_SELECT.VALUE=18
DRIVER.HET.VAR.HET2_BIT13_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT12_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_EDGE7_BOTH.VALUE=0
DRIVER.HET.VAR.HET2_BIT17_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_ENA.VALUE=0
DRIVER.HET.VAR.HET1_BIT30_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT27_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT19_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT7_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE5_PIN_SELECT.VALUE=21
DRIVER.HET.VAR.HET1_BIT29_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT0_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET_DIS_BLACKBOX.VALUE=0
DRIVER.HET.VAR.HET2_PWM7_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_HR_ACTUALFREQUENCY.VALUE=80.000
DRIVER.HET.VAR.HET2_PWM5_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_BIT25_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT17_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT4_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE0_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_CAP6_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT20_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT15_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X10.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT28_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_INT_X11.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X20.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X12.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_PWM6_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT16_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X21.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X13.VALUE=0x00000000
DRIVER.HET.VAR.HET2_HR_PRESCALE.VALUE=0
DRIVER.HET.VAR.HET1_EDGE6_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM6_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_LR_PRESCALE.VALUE=6
DRIVER.HET.VAR.HET2_PWM0_PIN_SELECT.VALUE=8
DRIVER.HET.VAR.HET2_BIT6_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X30.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X22.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X14.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X31.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X23.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X15.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_INT_X24.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X16.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BASE_PORT.VALUE=0xFFF7B84C
DRIVER.HET.VAR.HET2_PWM5_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT0_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X25.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X17.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_PWM3_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT10_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT14_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X26.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X18.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X27.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X19.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT18_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X28.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_PWM0_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_BIT18_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_INT_X29.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_ENA.VALUE=0
DRIVER.HET.VAR.HET2_CAP7_PIN_SELECT.VALUE=6
DRIVER.HET.VAR.HET2_BIT8_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_PWM4_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_PWM3_PIN_SELECT.VALUE=14
DRIVER.HET.VAR.HET1_BIT11_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT1_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM0_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_BIT2_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE6_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_BIT5_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT14_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_BIT20_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PIN_ENABLE.VALUE=0
DRIVER.HET.VAR.HET2_BIT16_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT5_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM0_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_BIT6_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM7_ENA.VALUE=0
DRIVER.HET.VAR.HET1_PWM0_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT8_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE4_PIN_SELECT.VALUE=8
DRIVER.HET.VAR.HET2_BIT7_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT9_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT3_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT10_PULL.VALUE=1
DRIVER.HET.VAR.HET2_CAP1_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_EDGE6_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP1_PIN_SELECT.VALUE=2
DRIVER.HET.VAR.HET2_BIT15_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT13_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_EDGE3_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_PWM6_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT9_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE0_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_PWM2_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_BIT26_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT18_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT6_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE3_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT16_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT17_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP4_PIN_SELECT.VALUE=24
DRIVER.HET.VAR.HET1_BIT29_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT0_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM2_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_EDGE3_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT3_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_HRSHARE.VALUE=0x00000002
DRIVER.HET.VAR.HET2_PWM6_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT8_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT4_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT4_HRSHARE.VALUE=0x00000004
DRIVER.HET.VAR.HET1_BIT25_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT17_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT16_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_PWM4_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_PWM1_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_PWM7_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_PWM3_ENA.VALUE=0
DRIVER.HET.VAR.HET1_BIT24_HRSHARE.VALUE=0x00001000
DRIVER.HET.VAR.HET1_BIT16_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT10_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_PIN_SELECT.VALUE=17
DRIVER.HET.VAR.HET1_BIT20_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT12_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT3_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X10.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X11.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT3_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE7_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_EDGE0_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT7_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X20.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X12.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT14_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_BIT10_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X21.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X13.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT18_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_EDGE4_PIN_SELECT.VALUE=20
DRIVER.HET.VAR.HET1_INT_X30.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X22.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X14.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET1_INT_X31.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X23.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X15.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE5_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_PWM1_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_BIT7_PULL.VALUE=1
DRIVER.HET.VAR.HET1_INT_X24.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X16.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP2_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM3_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X25.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X17.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT9_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT5_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X26.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X18.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X27.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X19.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT11_PULL.VALUE=1
DRIVER.HET.VAR.HET1_INT_X28.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_RAM_SIZE.VALUE=160
DRIVER.HET.VAR.HET1_EDGE2_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_INT_X29.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT17_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT14_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_PWM3_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_PWM5_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_PWM1_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_BIT10_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP4_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_BIT8_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT4_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_ENA.VALUE=0
DRIVER.HET.VAR.HET1_PWM0_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_BIT4_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_EDGE1_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM1_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT27_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT19_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT8_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT14_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP6_PIN_SELECT.VALUE=4
DRIVER.HET.VAR.HET1_PWM2_PIN_SELECT.VALUE=12
DRIVER.HET.VAR.HET1_BIT1_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM3_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_PWM2_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_EDGE4_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT28_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE0_BOTH.VALUE=0
DRIVER.HET.VAR.HET2_EDGE6_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_PWM5_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT8_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT4_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE3_PIN_SELECT.VALUE=6
DRIVER.HET.VAR.HET2_PWM2_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT18_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT11_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT10_PULL.VALUE=1
DRIVER.HET.VAR.HET2_EDGE1_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_PWM5_ENA.VALUE=0
DRIVER.HET.VAR.HET1_BIT8_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP0_PIN_SELECT.VALUE=0
DRIVER.HET.VAR.HET1_BIT21_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT13_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT5_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_BIT4_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE2_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_BIT9_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_BIT1_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM4_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT7_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_PWM7_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_BIT8_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM2_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT12_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT31_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT23_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT15_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP3_PIN_SELECT.VALUE=6
DRIVER.HET.VAR.HET1_BIT7_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_PWM4_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_BIT12_PULL.VALUE=1
DRIVER.HET.VAR.HET1_PWM0_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_PWM0_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_CAP5_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT26_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT15_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM0_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_EDGE4_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_BIT20_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT12_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE5_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM6_ENA.VALUE=0
DRIVER.HET.VAR.HET1_BIT6_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE1_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_PWM3_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE3_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT28_PULL.VALUE=1
DRIVER.HET.VAR.HET2_CAP7_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM3_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_PWM4_PIN_SELECT.VALUE=16
DRIVER.HET.VAR.HET1_BIT10_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_BIT9_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE3_PIN_SELECT.VALUE=15
DRIVER.HET.VAR.HET1_PWM1_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT8_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BASE.VALUE=0xFFF7B800
DRIVER.HET.VAR.HET2_EDGE1_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_PWM6_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT12_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT2_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_PIN_SELECT.VALUE=19
DRIVER.HET.VAR.HET1_PWM5_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_LR_ACTUALTIME.VALUE=800.000
DRIVER.HET.VAR.HET1_BIT21_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT13_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT11_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM3_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_PWM7_ENA.VALUE=0
DRIVER.HET.VAR.HET1_HR_PRESCALE.VALUE=0
DRIVER.HET.VAR.HET1_BIT30_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT22_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT14_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT7_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_HR_ACTUALFREQUENCY.VALUE=80.000
DRIVER.HET.VAR.HET2_PWM1_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT5_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE4_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP0_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_BIT4_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE2_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_PWM2_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT8_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT11_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_EDGE6_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_MASTER.VALUE=1
DRIVER.HET.VAR.HET1_PWM5_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT9_PULL.VALUE=1
DRIVER.HET.VAR.HET2_EDGE6_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT10_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP5_PIN_SELECT.VALUE=2
DRIVER.HET.VAR.HET1_PWM1_PIN_SELECT.VALUE=10
DRIVER.HET.VAR.HET1_BIT9_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT13_PULL.VALUE=1
DRIVER.HET.VAR.HET1_PWM7_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_PWM5_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT24_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.HET.VAR.HET2_BIT16_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT10_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE0_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_BIT30_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X0.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE2_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_PWM4_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT28_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT0_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT0_HRSHARE.VALUE=0x00000001
DRIVER.HET.VAR.HET1_INT_X1.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE2_PIN_SELECT.VALUE=4
DRIVER.HET.VAR.HET2_PWM2_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT8_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X2.VALUE=0x00000000
DRIVER.HET.VAR.HET1_DIS_BLACKBOX.VALUE=0
DRIVER.HET.VAR.HET2_LR_TIME.VALUE=800.000
DRIVER.HET.VAR.HET1_INT_X3.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_EDGE5_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_BIT29_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT0_PULL.VALUE=1
DRIVER.HET.VAR.HET1_INT_X4.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT2_HRSHARE.VALUE=0x00000002
DRIVER.HET.VAR.HET1_BIT21_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT13_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X5.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT20_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT3_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_INT_X6.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET1_INT_X7.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BASE_PORT.VALUE=0xFFF7B94C
DRIVER.HET.VAR.HET1_INT_X8.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT17_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT2_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_BIT30_HRSHARE.VALUE=0x00008000
DRIVER.HET.VAR.HET1_BIT22_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_INT_X9.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BASE.VALUE=0xFFF7B900
DRIVER.HET.VAR.HET2_EDGE2_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_EDGE0_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_BIT10_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP2_PIN_SELECT.VALUE=4
DRIVER.HET.VAR.HET1_BIT11_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_PWM0_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT31_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT23_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT20_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT15_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM4_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_BIT18_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP1_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT30_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_PWM6_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT31_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT23_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT15_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT9_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE6_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT7_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE1_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_RAM_SIZE.VALUE=160
DRIVER.HET.VAR.HET2_BIT9_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT21_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT13_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT0_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_CAP3_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_BIT0_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_PIN_SELECT.VALUE=6
DRIVER.HET.VAR.HET2_PWM6_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT14_PULL.VALUE=1
DRIVER.HET.VAR.HET1_EDGE7_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT17_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_EDGE2_PIN_SELECT.VALUE=13
DRIVER.HET.VAR.HET1_BIT20_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_HR_FREQUENCY.VALUE=80.000
DRIVER.HET.VAR.HET2_PWM2_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_EDGE5_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_EDGE1_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_PWM5_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT24_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT18_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE0_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT0_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_PWM6_PIN_SELECT.VALUE=18
DRIVER.HET.VAR.HET2_EDGE2_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_EDGE7_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT1_PULL.VALUE=1
DRIVER.HET.VAR.HET2_EDGE5_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_EDGE4_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_HRSHARE.VALUE=0x00000008
DRIVER.HET.VAR.HET1_BIT30_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT4_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_BIT1_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT8_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT0_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT4_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE7_PIN_SELECT.VALUE=14
DRIVER.HET.VAR.HET2_PWM7_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_PWM3_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_PWM3_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_EDGE3_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_PWM1_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM2_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT28_HRSHARE.VALUE=0x00004000
DRIVER.HET.VAR.HET1_BIT26_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP4_PIN_SELECT.VALUE=0
DRIVER.HET.VAR.HET2_PWM0_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_PWM0_PIN_SELECT.VALUE=8
DRIVER.HET.VAR.HET1_BIT21_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT13_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_LR_TIME.VALUE=800.000
DRIVER.HET.VAR.HET2_EDGE0_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM3_ACTION.VALUE=3
DRIVER.HET.VAR.HET1_BIT25_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT21_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT17_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT13_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM5_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_PWM1_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT20_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT11_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT24_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT16_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM5_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_RAM_BASE.VALUE=0xFF440000
DRIVER.HET.VAR.HET2_PWM3_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT7_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM4_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT15_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP4_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT8_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE1_PIN_SELECT.VALUE=2
DRIVER.HET.VAR.HET1_CAP7_PIN_SELECT.VALUE=30
DRIVER.HET.VAR.HET1_BIT31_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT23_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT15_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE7_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_BIT2_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE4_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_BIT15_PULL.VALUE=1
DRIVER.HET.VAR.HET2_BIT10_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP6_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM2_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT18_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_BIT0_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET1_BIT30_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE1_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE2_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_BIT26_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM1_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT16_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT5_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_RAM_PARITY_ENA.VALUE=0x00000005
DRIVER.HET.VAR.HET1_PWM7_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_PWM0_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT1_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_CAP1_PIN_SELECT.VALUE=2
DRIVER.HET.VAR.HET1_PWM7_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_BIT2_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM6_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM4_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT10_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM7_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT10_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE7_PIN_SELECT.VALUE=23
DRIVER.HET.VAR.HET1_BIT24_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT5_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM7_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_PWM7_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_PWM4_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT3_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE5_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_EDGE4_BOTH.VALUE=0
DRIVER.HET.VAR.HET2_PWM1_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT11_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE1_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_LR_PRESCALE.VALUE=6
DRIVER.HET.VAR.HET2_PWM2_PIN_SELECT.VALUE=12
DRIVER.HET.VAR.HET2_BIT1_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT31_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT23_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT15_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM6_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_EDGE2_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT30_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT27_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT22_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT19_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT14_PULL.VALUE=1
DRIVER.HET.VAR.HET2_EDGE2_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_BIT8_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT9_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE1_PIN_SELECT.VALUE=11
DRIVER.HET.VAR.HET1_BIT25_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT17_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_BIT8_PULL.VALUE=1
DRIVER.HET.VAR.HET1_PWM4_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM0_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT14_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT2_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM5_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT0_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_PIN_SELECT.VALUE=17
DRIVER.HET.VAR.HET1_BIT25_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT17_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM6_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT4_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE1_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_CAP7_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT28_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT24_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT16_PULL.VALUE=1
DRIVER.HET.VAR.HET2_BIT12_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_PWM1_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT0_HRSHARE.VALUE=0x00000001
DRIVER.HET.VAR.HET1_EDGE7_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_PWM1_DUTY_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE6_PIN_SELECT.VALUE=12
DRIVER.HET.VAR.HET2_BIT2_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_DIS_BLACKBOX.VALUE=0
DRIVER.HET.VAR.HET1_BIT24_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT16_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE3_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE6_EVENT.VALUE=1
DRIVER.HET.VAR.HET1_EDGE3_BOTH.VALUE=0
DRIVER.HET.VAR.HET1_PWM6_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET1_BIT28_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT13_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_PWM1_DUTY.VALUE=50
DRIVER.HET.VAR.HET1_BIT20_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT12_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP3_PIN_SELECT.VALUE=6
DRIVER.HET.VAR.HET2_BIT10_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT2_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_PWM3_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_EDGE3_EVENT.VALUE=1
DRIVER.HET.VAR.HET2_PWM6_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_PWM3_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET1_BIT3_PULL.VALUE=1
DRIVER.HET.VAR.HET2_PWM1_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT1_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT26_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT6_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM1_DUTYTIME.VALUE=500.000
DRIVER.HET.VAR.HET2_BIT5_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_POLARITY.VALUE=3
DRIVER.HET.VAR.HET2_BIT16_HRSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP0_POLARITY.VALUE=0
DRIVER.HET.VAR.HET1_BIT4_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE0_PIN_SELECT.VALUE=0
DRIVER.HET.VAR.HET2_BIT10_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_CAP6_PIN_SELECT.VALUE=28
DRIVER.HET.VAR.HET1_PWM2_PERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_EDGE5_BOTH.VALUE=0
DRIVER.HET.VAR.HET2_BIT13_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT3_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE0_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_PWM7_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_BIT3_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT25_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT17_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_EDGE4_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT31_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT29_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT23_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT15_PULL.VALUE=1
DRIVER.HET.VAR.HET1_BIT0_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_CAP2_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_PWM7_DUTY.VALUE=50
DRIVER.HET.VAR.HET2_BIT6_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM4_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT11_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT26_DOUT.VALUE=0
DRIVER.HET.VAR.HET1_BIT18_DOUT.VALUE=0
DRIVER.HET.VAR.HET2_PWM6_PERIOD_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_ACTION.VALUE=3
DRIVER.HET.VAR.HET2_BIT9_PULL.VALUE=1
DRIVER.HET.VAR.HET1_PWM7_DUTY_LVL.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM3_PERIOD_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM2_ENA.VALUE=0
DRIVER.HET.VAR.HET2_BIT12_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE3_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM7_PIN_SELECT.VALUE=19
DRIVER.HET.VAR.HET2_BIT2_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_CAP0_PIN_SELECT.VALUE=0
DRIVER.HET.VAR.HET1_BIT27_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT19_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT6_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM0_DUTY_PRESCALER.VALUE=80128
DRIVER.HET.VAR.HET2_EDGE7_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET2_PWM0_POLARITY.VALUE=3
DRIVER.HET.VAR.HET1_BIT26_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_XORSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT10_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_EDGE6_PIN_SELECT.VALUE=22
DRIVER.HET.VAR.HET1_PWM0_ACTUALPERIOD.VALUE=1000.000
DRIVER.HET.VAR.HET2_HR_FREQUENCY.VALUE=80.000
DRIVER.HET.VAR.HET2_BIT17_PULL.VALUE=1
DRIVER.HET.VAR.HET2_BIT14_DIR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_PWM5_PERIOD_PRESCALER.VALUE=159872
DRIVER.HET.VAR.HET2_EDGE4_POLARITY.VALUE=0
DRIVER.HET.VAR.HET2_EDGE0_INTENA.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT7_PULDIS.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT4_HRSHARE.VALUE=0x00000004
DRIVER.HET.VAR.HET1_BIT2_ANDSHARE.VALUE=0x00000000
DRIVER.HET.VAR.HET2_BIT4_PDR.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT26_PSL.VALUE=0x00000000
DRIVER.HET.VAR.HET1_BIT18_PSL.VALUE=0x00000000
DRIVER.RTP.VAR.RTP_PORT_BIT1_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT3_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT1_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT5_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT14_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT11_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT3_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT8_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT4_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT6_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT2_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT10_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT6_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT14_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT12_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT17_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT4_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT10_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT2_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT5_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT3_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT11_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT7_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT13_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT5_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT11_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT9_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT6_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT12_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT4_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT12_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT8_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT10_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT15_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT14_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT18_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT6_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT0_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT4_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT12_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT3_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT7_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT5_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT13_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT9_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT11_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT15_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT7_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT13_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT8_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT6_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT14_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT12_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT16_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT16_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT17_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT8_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT1_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT10_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT14_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT4_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT9_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT7_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT15_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT9_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT13_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT10_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT17_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT2_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT9_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT15_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT8_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT16_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT14_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT18_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT17_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_BASE_PORT.VALUE=0xFFFFFA38
DRIVER.RTP.VAR.RTP_PORT_BIT2_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT16_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT5_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT9_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT17_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT15_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT15_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT11_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT17_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT7_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT18_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT0_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT16_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT18_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT3_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT18_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT6_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT17_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT12_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT13_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT18_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT4_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT5_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT7_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT10_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT13_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT18_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT5_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT11_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT8_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT0_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT11_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT14_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT3_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT1_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT6_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT0_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT9_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT2_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT12_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT16_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT15_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT0_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT0_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT1_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_BASE.VALUE=0xFFFFFA00
DRIVER.RTP.VAR.RTP_PORT_BIT3_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT8_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT1_PULDIS.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT1_PDR.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT7_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT2_FUN.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT0_PSL.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT4_DIR.VALUE=0
DRIVER.RTP.VAR.RTP_BASE_RAM.VALUE=0xFFF83000
DRIVER.RTP.VAR.RTP_PORT_BIT13_PULL.VALUE=2
DRIVER.RTP.VAR.RTP_PORT_BIT10_DIR.VALUE=1
DRIVER.RTP.VAR.RTP_PORT_BIT16_DOUT.VALUE=0
DRIVER.RTP.VAR.RTP_PORT_BIT2_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT14_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT17_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT17_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT4_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT1_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT18_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT0_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT15_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT4_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT2_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT7_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT15_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT18_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT0_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_BASE.VALUE=0xFFFFF700
DRIVER.DMM.VAR.DMM_PORT_BIT1_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT3_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT9_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT1_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT2_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT2_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT0_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT5_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT4_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT8_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT16_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT2_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT3_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_BASE_PORT.VALUE=0xFFFFF770
DRIVER.DMM.VAR.DMM_PORT_BIT1_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT5_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT10_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT3_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT4_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT2_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT6_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT6_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT7_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT9_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT17_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT0_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT4_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT5_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT3_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT0_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT7_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT18_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT5_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT6_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT4_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT8_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT7_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT18_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT6_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT10_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT7_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT5_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT5_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT1_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT9_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT12_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT7_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT8_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT16_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT6_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT8_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT10_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT8_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT12_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT9_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT10_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT7_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT2_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT10_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT13_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT9_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT3_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT8_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT9_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT12_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT10_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT14_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT14_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT0_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT12_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT9_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT3_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT11_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT14_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT11_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT15_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT8_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT14_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT1_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT12_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT16_DIR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT1_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT14_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT4_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT12_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT15_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT15_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT12_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT17_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT15_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT16_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT14_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT18_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT2_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT6_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT16_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT5_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT13_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT16_DOUT.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT17_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT15_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT17_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT17_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT10_PULDIS.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT18_FUN.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT16_PSL.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT3_PULL.VALUE=2
DRIVER.DMM.VAR.DMM_PORT_BIT0_DIR.VALUE=1
DRIVER.DMM.VAR.DMM_PORT_BIT18_PDR.VALUE=0
DRIVER.DMM.VAR.DMM_PORT_BIT6_DOUT.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT0_DIR.VALUE=0
DRIVER.I2C.VAR.I2C_STOPBITS.VALUE=2
DRIVER.I2C.VAR.I2C_PORT_BIT1_DIR.VALUE=0
DRIVER.I2C.VAR.I2C_ICXRDYINTLVL.VALUE=0
DRIVER.I2C.VAR.I2C_BASE_PORT.VALUE=0xFFF7D44C
DRIVER.I2C.VAR.I2C_DATACOUNT.VALUE=8
DRIVER.I2C.VAR.I2C_ADDRMODE.VALUE=7BIT_AMODE
DRIVER.I2C.VAR.I2C_PORT_BIT0_FUN.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT0_PDR.VALUE=0
DRIVER.I2C.VAR.I2C_BC_VALUE.VALUE=0x0003
DRIVER.I2C.VAR.I2C_PORT_BIT1_FUN.VALUE=0
DRIVER.I2C.VAR.I2C_RM_ENA.VALUE=0
DRIVER.I2C.VAR.I2C_BC.VALUE=8_BIT
DRIVER.I2C.VAR.I2C_PORT_BIT1_PDR.VALUE=0
DRIVER.I2C.VAR.I2C_TXRX_VALUE.VALUE=0
DRIVER.I2C.VAR.I2C_SCDLVL.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT0_PSL.VALUE=1
DRIVER.I2C.VAR.I2C_STPCND.VALUE=1
DRIVER.I2C.VAR.I2C_ALINTENA.VALUE=0
DRIVER.I2C.VAR.I2C_PRESCALE.VALUE=9
DRIVER.I2C.VAR.I2C_PORT_BIT1_PSL.VALUE=1
DRIVER.I2C.VAR.I2C_TXRX.VALUE=TRANSMITTER
DRIVER.I2C.VAR.I2C_PORT_BIT0_DOUT.VALUE=0
DRIVER.I2C.VAR.I2C_ALINTLVL.VALUE=0
DRIVER.I2C.VAR.I2C_RXDMA.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT0_PULDIS.VALUE=0
DRIVER.I2C.VAR.I2C_BASE.VALUE=0xFFF7D400
DRIVER.I2C.VAR.I2C_ARDYINTENA.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT1_DOUT.VALUE=0
DRIVER.I2C.VAR.I2C_TXDMA.VALUE=0
DRIVER.I2C.VAR.I2C_MSMODE.VALUE=1
DRIVER.I2C.VAR.I2C_ICCH.VALUE=35
DRIVER.I2C.VAR.I2C_AASLVL.VALUE=0
DRIVER.I2C.VAR.I2C_ICCL.VALUE=35
DRIVER.I2C.VAR.I2C_AAS.VALUE=0
DRIVER.I2C.VAR.I2C_BCM.VALUE=0
DRIVER.I2C.VAR.I2C_ADDRMODE_VALUE.VALUE=0x0001
DRIVER.I2C.VAR.I2C_ICRRDYINTENA.VALUE=0
DRIVER.I2C.VAR.I2C_FDF.VALUE=0
DRIVER.I2C.VAR.I2C_ARDYINTLVL.VALUE=0
DRIVER.I2C.VAR.I2C_PARITYENA.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT0_PULL.VALUE=2
DRIVER.I2C.VAR.I2C_LENGTH.VALUE=8
DRIVER.I2C.VAR.I2C_NACKINTENA.VALUE=0
DRIVER.I2C.VAR.I2C_SCD.VALUE=0
DRIVER.I2C.VAR.I2C_PORT_BIT1_PULL.VALUE=2
DRIVER.I2C.VAR.I2C_ICRRDYINTLVL.VALUE=0
DRIVER.I2C.VAR.I2C_STACND.VALUE=1
DRIVER.I2C.VAR.I2C_PORT_BIT1_PULDIS.VALUE=0
DRIVER.I2C.VAR.I2C_ICXRDYINTENA.VALUE=0
DRIVER.I2C.VAR.I2C_NACKINTLVL.VALUE=0
DRIVER.I2C.VAR.I2C_EVENPARITY.VALUE=0
DRIVER.I2C.VAR.I2C_BAUDRATE.VALUE=100
DRIVER.I2C.VAR.I2C_MODCLK.VALUE=8
DRIVER.DCC.VAR.DCC1_ENABLE_KEY.VALUE=10
DRIVER.DCC.VAR.PINMUX_BASE.VALUE=0xFFFFEA00
DRIVER.DCC.VAR.DCC1_DETECTION_TIME.VALUE=5000.00
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE1_VALUE.VALUE=0x0002
DRIVER.DCC.VAR.DCC1_ENABLE_ERROR_INTERRUPT.VALUE=0xA
DRIVER.DCC.VAR.DCC2_ENABLE.VALUE=0xA
DRIVER.DCC.VAR.PINMUX_BASE_PORT.VALUE=0xFFFFEA40
DRIVER.DCC.VAR.DCC2_ENABLE_ERROR_INTERRUPT.VALUE=0xA
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE0_VALUE.VALUE=0x0001
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE0_FREQ.VALUE=0
DRIVER.DCC.VAR.DCC2_VALID0_SEED.VALUE=0
DRIVER.DCC.VAR.DCC2_CLKT_N2HET2_0_FREQ.VALUE=1
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE1_FREQ.VALUE=0
DRIVER.DCC.VAR.DCC2_DETECTION_TIME.VALUE=5000.00
DRIVER.DCC.VAR.DCC2_CLOCK_DRIFT.VALUE=1.0
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE1_VALUE.VALUE=0x0002
DRIVER.DCC.VAR.DCC1_CLKT_N2HET1_31_FREQ.VALUE=1
DRIVER.DCC.VAR.DCC2_COUNT0_SEED.VALUE=0
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE0.VALUE=OSCIN
DRIVER.DCC.VAR.DCC2_CLOCK_SOURCE1.VALUE=VCLK
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE0_FREQ.VALUE=16.0
DRIVER.DCC.VAR.DCC1_VALID0_SEED.VALUE=1584
DRIVER.DCC.VAR.DCC1_BASE.VALUE=0xFFFFEC00
DRIVER.DCC.VAR.DCC2_COUNT1_SEED.VALUE=0
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE1_FREQ.VALUE=160.00
DRIVER.DCC.VAR.DCC1_CLOCK_DRIFT.VALUE=1.0
DRIVER.DCC.VAR.DCC1_ENABLE.VALUE=0xA
DRIVER.DCC.VAR.DCC1_ENABLE_SINGLESHOT_MODE.VALUE=0x5
DRIVER.DCC.VAR.DCC2_ENABLE_SINGLESHOT_MODE.VALUE=0x5
DRIVER.DCC.VAR.DCC2_BASE.VALUE=0xFFFFF400
DRIVER.DCC.VAR.DCC1_DONE_INTERRUPT_ENABLE.VALUE=0xA
DRIVER.DCC.VAR.DCC2_DONE_INTERRUPT_ENABLE.VALUE=0xA
DRIVER.DCC.VAR.DCC2_ENABLE_KEY.VALUE=0xA
DRIVER.DCC.VAR.DCC1_COUNT0_SEED.VALUE=78408
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE0_VALUE.VALUE=0x0001
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE0.VALUE=OSCIN
DRIVER.DCC.VAR.DCC1_CLOCK_SOURCE1.VALUE=PLL1
DRIVER.DCC.VAR.CLKT_TCK_FREQ.VALUE=12.0
DRIVER.DCC.VAR.DCC1_COUNT1_SEED.VALUE=792000
DRIVER.PINMUX.VAR.DMA_EIDXS_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_2.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_2.VALUE=0
DRIVER.PINMUX.VAR.MUX61_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX7_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_3.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_3.VALUE=0
DRIVER.PINMUX.VAR.MUX61_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX7_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_4.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_4.VALUE=0
DRIVER.PINMUX.VAR.ETPWM_TIME_BASE_SELECT.VALUE=OFF
DRIVER.PINMUX.VAR.MUX61_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX50_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX42_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX34_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX26_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX18_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_5.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_5.VALUE=0
DRIVER.PINMUX.VAR.MUX61_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_6.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_6.VALUE=0
DRIVER.PINMUX.VAR.MUX61_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_7.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_7.VALUE=0
DRIVER.PINMUX.VAR.MUX53_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX45_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX37_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX29_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_8.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_10.VALUE=1
DRIVER.PINMUX.VAR.MUX99_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_96_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_88_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_5_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_9.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_FIDXD_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_12.VALUE=1
DRIVER.PINMUX.VAR.MUX30_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_13.VALUE=1
DRIVER.PINMUX.VAR.MUX30_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_14.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_10.VALUE=1
DRIVER.PINMUX.VAR.MUX30_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_81_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_73_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_65_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_57_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_49_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTLFSEN_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTBTCEN_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_CHPR_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX30_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_16.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_12.VALUE=1
DRIVER.PINMUX.VAR.MUX30_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTBTCEN_13.VALUE=1
DRIVER.PINMUX.VAR.MUX30_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX22_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX14_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTBTCEN_14.VALUE=1
DRIVER.PINMUX.VAR.MUX101_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_50_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_42_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_34_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_26_SELECT.VALUE=3
DRIVER.PINMUX.VAR.PIN_MUX_18_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_ADDMW_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTBTCEN_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_ENABLEINT_1.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_16.VALUE=1
DRIVER.PINMUX.VAR.DMA_ENABLEINT_2.VALUE=1
DRIVER.PINMUX.VAR.DMA_ENABLEINT_3.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_10.VALUE=FIXED
DRIVER.PINMUX.VAR.DMA_ENABLEINT_4.VALUE=1
DRIVER.PINMUX.VAR.PINMUX10.VALUE=PINMUX_PIN_86_AD1EVT
DRIVER.PINMUX.VAR.MUX11_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_11_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_PRITY_11.VALUE=FIXED
DRIVER.PINMUX.VAR.DMA_CHPR_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.PINMUX11.VALUE=PINMUX_PIN_91_HET1_24
DRIVER.PINMUX.VAR.DMA_PRITY_12.VALUE=FIXED
DRIVER.PINMUX.VAR.PINMUX20.VALUE=PINMUX_PIN_130_MIBSPI1NCS_1
DRIVER.PINMUX.VAR.PINMUX12.VALUE="PINMUX_PIN_92_HET1_26 | PINMUX_PIN_96_MIBSPI1NENA | PINMUX_PIN_97_MIBSPI5NENA"
DRIVER.PINMUX.VAR.DMA_PRITY_13.VALUE=FIXED
DRIVER.PINMUX.VAR.PINMUX21.VALUE=PINMUX_PIN_133_GIOB_1
DRIVER.PINMUX.VAR.PINMUX13.VALUE="PINMUX_PIN_98_MIBSPI5SOMI_0 | PINMUX_PIN_99_MIBSPI5SIMO_0 | PINMUX_PIN_100_MIBSPI5CLK | PINMUX_PIN_105_MIBSPI1NCS_0"
DRIVER.PINMUX.VAR.DMA_PRITY_14.VALUE=FIXED
DRIVER.PINMUX.VAR.PINMUX14.VALUE="PINMUX_PIN_106_HET1_08 | PINMUX_PIN_107_HET1_28"
DRIVER.PINMUX.VAR.MUX92_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX84_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX76_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX68_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_15.VALUE=FIXED
DRIVER.PINMUX.VAR.DMA_PRITY_16.VALUE=FIXED
DRIVER.PINMUX.VAR.PINMUX33.VALUE="PINMUX_PIN_36_HET1_04 | PINMUX_PIN_51_MIBSPI3SOMI | PINMUX_PIN_52_ECAP3 | PINMUX_PIN_53_EQEP1A"
DRIVER.PINMUX.VAR.PINMUX17.VALUE="PINMUX_PIN_118_nTZ3 | PINMUX_PIN_124_HET1_12"
DRIVER.PINMUX.VAR.PINMUX34.VALUE="PINMUX_PIN_139_HET1_16 | PINMUX_PIN_140_HET1_18 | PINMUX_PIN_141_HET1_20"
DRIVER.PINMUX.VAR.PINMUX18.VALUE="PINMUX_PIN_125_HET1_14 | PINMUX_PIN_126_GIOB_0"
DRIVER.PINMUX.VAR.DMA_ADDMR_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.PINMUX35.VALUE=0
DRIVER.PINMUX.VAR.PINMUX27.VALUE=PINMUX_PIN_32_MIBSPI5NCS_0
DRIVER.PINMUX.VAR.PINMUX19.VALUE=PINMUX_PIN_127_HET1_30
DRIVER.PINMUX.VAR.MUX98_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX98_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_10.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX98_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX7_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_11.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_PRITY_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX98_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_20.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_12.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX100_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX98_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_21.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_13.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX100_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_30.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_22.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_14.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_0.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_0.VALUE=ENABLED
DRIVER.PINMUX.VAR.MUX100_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_109_SELECT.VALUE=1
DRIVER.PINMUX.VAR.DMA_CHANNEL_31.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_23.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_15.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_TTYPE_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_1.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ENABLEREG_1.VALUE=1
DRIVER.PINMUX.VAR.MUX100_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_24.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_16.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_2.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ENABLEREG_2.VALUE=1
DRIVER.PINMUX.VAR.MUX100_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX91_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX83_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX75_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX67_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX59_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_25.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_17.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_3.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ENABLEREG_3.VALUE=1
DRIVER.PINMUX.VAR.MUX91_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX83_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX75_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX67_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX59_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_26.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_18.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_4.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ENABLEREG_4.VALUE=1
DRIVER.PINMUX.VAR.MUX91_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX83_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX75_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX67_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX61_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX59_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX53_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX45_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX37_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX29_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_102_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_27.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_19.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_5.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ADDMR_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX91_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX83_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX75_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX67_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX59_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_28.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_6.VALUE=ENABLED
DRIVER.PINMUX.VAR.ETPWM2_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.MUX91_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX83_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX75_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX67_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX59_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX6_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_29.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_FIDXS_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_7.VALUE=ENABLED
DRIVER.PINMUX.VAR.MUX6_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_8.VALUE=ENABLED
DRIVER.PINMUX.VAR.MUX6_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.DMA_TTYPE_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_9.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX6_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX60_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX6_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX60_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX6_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_10.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_10.VALUE=0
DRIVER.PINMUX.VAR.MUX60_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_11.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTASS_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX60_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_20.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_12.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_12.VALUE=0
DRIVER.PINMUX.VAR.MUX60_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_21.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_13.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_13.VALUE=0
DRIVER.PINMUX.VAR.MUX52_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX44_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX36_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX28_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_30.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_22.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_14.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_14.VALUE=0
DRIVER.PINMUX.VAR.MUX104_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_94_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_86_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_78_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_3_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_31.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_23.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_15.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_PRITY_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ACC_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_STADD_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_24.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_16.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_STADD_2.VALUE=0
DRIVER.PINMUX.VAR.MUX21_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.DMA_TTYPE_25.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_17.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_STADD_3.VALUE=0
DRIVER.PINMUX.VAR.MUX21_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_26.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_18.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_STADD_4.VALUE=0
DRIVER.PINMUX.VAR.MUX30_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX22_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX21_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.MUX14_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_71_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_63_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_55_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_47_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_39_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_27.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_19.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX21_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_28.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_28.VALUE=0
DRIVER.PINMUX.VAR.MUX21_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_29.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_29.VALUE=0
DRIVER.PINMUX.VAR.MUX21_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX13_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_0.VALUE=0
DRIVER.PINMUX.VAR.MUX95_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX87_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX79_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_40_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_32_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_24_SELECT.VALUE=2
DRIVER.PINMUX.VAR.PIN_MUX_16_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_2.VALUE=0
DRIVER.PINMUX.VAR.ETPWM7_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_0.VALUE=CONSTANT
DRIVER.PINMUX.VAR.ETPWM_TBCLK_SELECT.VALUE=OFF
DRIVER.PINMUX.VAR.DMA_TTYPE_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_1.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_2.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_3.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_4.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_0.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_5.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_1.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMR_6.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_2.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMR_7.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_3.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMR_8.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_4.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMR_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_9.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_5.VALUE=8BIT
DRIVER.PINMUX.VAR.GATE_EMIF_CLK.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_6.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX97_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX89_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_7.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX97_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX89_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_8.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX97_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX89_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX80_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX72_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX64_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX56_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX48_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_9.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMW_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX97_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX89_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX97_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX89_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_107_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX90_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX82_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX74_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX66_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX58_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_DEBUGMODE.VALUE=IGNORE_SUSPEND
DRIVER.PINMUX.VAR.MUX90_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX82_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX74_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX66_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX58_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_0.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ERRACT.VALUE=IGNORE
DRIVER.PINMUX.VAR.MUX90_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX82_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX74_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX66_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX58_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX3_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_100_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_1.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CHPR_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX90_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX82_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX74_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX66_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX58_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_2.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_BASE_PORT.VALUE=0xFFFFF040
DRIVER.PINMUX.VAR.MUX90_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX82_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX74_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX66_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX58_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX5_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_3.VALUE=CONSTANT
DRIVER.PINMUX.VAR.MUX5_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_4.VALUE=CONSTANT
DRIVER.PINMUX.VAR.MUX5_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.DMA_AIM_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_5.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTFTCEN_1.VALUE=1
DRIVER.PINMUX.VAR.MUX5_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_6.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTFTCEN_2.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX27_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX5_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_7.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTFTCEN_3.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX27_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX5_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_8.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTEN_10.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTFTCEN_4.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX41_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX33_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX27_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX25_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX17_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_99_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_8_SELECT.VALUE=5
DRIVER.PINMUX.VAR.DMA_ADDMR_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_9.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTEN_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTFTCEN_5.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX27_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_12.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTFTCEN_6.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX27_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_13.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTFTCEN_7.VALUE=1
DRIVER.PINMUX.VAR.MUX51_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX43_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX35_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX27_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX19_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_14.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTFTCEN_8.VALUE=1
DRIVER.PINMUX.VAR.ALT_ADC_SELECT.VALUE=2
DRIVER.PINMUX.VAR.MUX98_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_92_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_84_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_76_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_68_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_1_SELECT.VALUE=3
DRIVER.PINMUX.VAR.DMA_INTEN_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTFTCEN_9.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTEN_16.VALUE=1
DRIVER.PINMUX.VAR.MUX20_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX20_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX20_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_61_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_53_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_45_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_37_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_29_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX20_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION3.VALUE=1
DRIVER.PINMUX.VAR.MUX20_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX20_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX12_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX100_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_30_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_22_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_14_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX10_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ENDADD_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ENDADD_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_ENDADD_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_ENDADD_4.VALUE=0
DRIVER.PINMUX.VAR.MUX91_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX83_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX75_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX67_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX59_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTASS_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTASS_1.VALUE=TO_VIM
DRIVER.PINMUX.VAR.DMA_INTASS_2.VALUE=TO_VIM
DRIVER.PINMUX.VAR.ETPWM5_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.CONCOUNT.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTASS_3.VALUE=TO_VIM
DRIVER.PINMUX.VAR.DMA_INTASS_4.VALUE=TO_VIM
DRIVER.PINMUX.VAR.DMA_ADDMR_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHAS_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ACC_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHAS_2.VALUE=0
DRIVER.PINMUX.VAR.MUX96_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX88_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_3.VALUE=0
DRIVER.PINMUX.VAR.MUX96_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX88_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_10.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_0.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_CHAS_4.VALUE=0
DRIVER.PINMUX.VAR.MUX96_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX88_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX6_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_11.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ADDMW_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_1.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_INTMP_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHAS_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX96_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX88_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_20.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_12.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_2.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_CHAS_6.VALUE=0
DRIVER.PINMUX.VAR.MUX96_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX88_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_21.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_13.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_3.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_CHAS_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_30.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_22.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_14.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_4.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_CHAS_8.VALUE=0
DRIVER.PINMUX.VAR.GIOB_DISABLE_SELECT.VALUE=OFF
DRIVER.PINMUX.VAR.PIN_MUX_105_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_31.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_23.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ADDMW_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_15.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_ADDMR_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_5.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_TRIG_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHAS_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_24.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_16.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_6.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX81_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX73_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX65_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_25.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_17.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_7.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX81_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX73_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX65_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_26.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_18.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_8.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_0.VALUE=0
DRIVER.PINMUX.VAR.MUX81_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX73_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX65_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX60_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX52_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX44_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX36_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX28_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXS_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_27.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_FIDXS_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_19.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_9.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ENABLE1.VALUE=1
DRIVER.PINMUX.VAR.MUX81_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX73_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX65_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_28.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_2.VALUE=0
DRIVER.PINMUX.VAR.MUX81_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX73_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX65_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX4_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXS_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_29.VALUE=ENABLED
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_3.VALUE=0
DRIVER.PINMUX.VAR.MUX57_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX49_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX4_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_10.VALUE=1
DRIVER.PINMUX.VAR.ECAP.VALUE=0
DRIVER.PINMUX.VAR.MUX4_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_BYP_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_1.VALUE=1
DRIVER.PINMUX.VAR.MUX4_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_12.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_2.VALUE=1
DRIVER.PINMUX.VAR.MUX50_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX34_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX26_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX18_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX4_OPTION4.VALUE=1
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_13.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_3.VALUE=1
DRIVER.PINMUX.VAR.MUX50_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX34_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX26_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX18_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX4_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_14.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_4.VALUE=1
DRIVER.PINMUX.VAR.MUX50_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX34_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX26_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX18_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.PIN_MUX_97_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_89_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_6_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_ADDMR_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_IFT_COUNT_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_5.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_1.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX50_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX34_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX26_OPTION3.VALUE=1
DRIVER.PINMUX.VAR.MUX18_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_BYP_16.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTBTCEN_6.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_2.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX50_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX34_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX26_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX18_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTBTCEN_7.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_3.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX50_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX42_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX34_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX26_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX18_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTBTCEN_8.VALUE=1
DRIVER.PINMUX.VAR.DMA_PRITY_4.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX103_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_90_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_82_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_74_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_66_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_58_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTBTCEN_9.VALUE=1
DRIVER.PINMUX.VAR.DMA_TRIG_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_5.VALUE=FIXED
DRIVER.PINMUX.VAR.DMA_PRITY_6.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX11_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_PRITY_7.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX11_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_PRITY_8.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX21_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX13_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX11_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.PIN_MUX_51_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_43_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_35_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_27_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_19_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_9.VALUE=FIXED
DRIVER.PINMUX.VAR.MUX11_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX11_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.ETPWM_TBCLK_SYNC_ENABLE.VALUE=0
DRIVER.PINMUX.VAR.AD1.VALUE=0
DRIVER.PINMUX.VAR.MUX11_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.AD2.VALUE=0
DRIVER.PINMUX.VAR.MUX94_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX86_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX78_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_20_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_12_SELECT.VALUE=3
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX9_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX104_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX104_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX104_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_PRITY_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.ALT_ADC.VALUE=1
DRIVER.PINMUX.VAR.I2C.VALUE=0
DRIVER.PINMUX.VAR.MUX104_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX104_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX95_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX87_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX79_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX95_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX87_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX79_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX95_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX87_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX79_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX71_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX63_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX55_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX47_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX39_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_DEBUGMODE_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX95_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX87_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX79_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.ETPWM3_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.MUX95_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX87_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX79_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_10.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_103_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_12.VALUE=0
DRIVER.PINMUX.VAR.MUX80_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX72_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX64_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX56_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_13.VALUE=0
DRIVER.PINMUX.VAR.HET1.VALUE=0
DRIVER.PINMUX.VAR.MUX80_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX72_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX64_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX56_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_10.VALUE=0
DRIVER.PINMUX.VAR.HET2.VALUE=0
DRIVER.PINMUX.VAR.MUX80_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX72_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX64_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX56_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX2_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_1.VALUE=1
DRIVER.PINMUX.VAR.MUX80_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX72_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX64_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX56_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_2.VALUE=1
DRIVER.PINMUX.VAR.MUX80_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX72_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX64_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX56_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX3_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_3.VALUE=1
DRIVER.PINMUX.VAR.MUX56_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX48_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX3_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_10.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTEN_4.VALUE=1
DRIVER.PINMUX.VAR.MUX3_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXD_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXD_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_11.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_AIM_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTEN_5.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTASS_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX3_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_20.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_12.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTEN_6.VALUE=1
DRIVER.PINMUX.VAR.EMIF.VALUE=0
DRIVER.PINMUX.VAR.MUX41_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX25_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX17_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX3_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_CP0_ISADDR_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_21.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_13.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTEN_7.VALUE=1
DRIVER.PINMUX.VAR.ETPWM_TZ1.VALUE=ASYNC
DRIVER.PINMUX.VAR.MUX41_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX25_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX17_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX3_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_30.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_22.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_14.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_8.VALUE=1
DRIVER.PINMUX.VAR.ETPWM_TZ2.VALUE=ASYNC
DRIVER.PINMUX.VAR.MUX41_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX40_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX32_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX25_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX24_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX17_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX16_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_95_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_87_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_79_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_4_SELECT.VALUE=4
DRIVER.PINMUX.VAR.DMA_ADDMR_31.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_23.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_15.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMR_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_IET_COUNT_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTEN_9.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ACC_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.ETPWM_TZ3.VALUE=ASYNC
DRIVER.PINMUX.VAR.MUX41_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX25_OPTION3.VALUE=1
DRIVER.PINMUX.VAR.MUX17_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_24.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_16.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_12.VALUE=0
DRIVER.PINMUX.VAR.MUX41_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX25_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX17_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_25.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_17.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_13.VALUE=0
DRIVER.PINMUX.VAR.MUX41_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX33_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX25_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX17_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_26.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_18.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_10.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX97_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX89_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_80_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_72_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_64_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_56_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_48_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_27.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_19.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_11.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_ADDMW_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.GIOA.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_28.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_20.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_12.VALUE=8BIT
DRIVER.PINMUX.VAR.GIOB.VALUE=0
DRIVER.PINMUX.VAR.MUX10_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_29.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_21.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_13.VALUE=8BIT
DRIVER.PINMUX.VAR.GIOB_DISABLE.VALUE=0
DRIVER.PINMUX.VAR.MUX10_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_30.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_22.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_14.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX10_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.PIN_MUX_41_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_33_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_25_SELECT.VALUE=3
DRIVER.PINMUX.VAR.PIN_MUX_17_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_31.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_IET_COUNT_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_23.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_15.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_CHANNEL_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX10_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_28.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_24.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_16.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX10_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_29.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_25.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_17.VALUE=8BIT
DRIVER.PINMUX.VAR.MUX10_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_26.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_18.VALUE=8BIT
DRIVER.PINMUX.VAR.PIN_MUX_10_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_27.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_19.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_BYP_1.VALUE=1
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_28.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_BYP_2.VALUE=1
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_29.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_BYP_3.VALUE=1
DRIVER.PINMUX.VAR.DMA_BYP_4.VALUE=1
DRIVER.PINMUX.VAR.EQEP.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_BYP_5.VALUE=1
DRIVER.PINMUX.VAR.DMA_BYP_6.VALUE=1
DRIVER.PINMUX.VAR.DMA_BYP_7.VALUE=1
DRIVER.PINMUX.VAR.DMA_BYP_8.VALUE=1
DRIVER.PINMUX.VAR.MUX90_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX82_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX74_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX66_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX58_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_BYP_9.VALUE=1
DRIVER.PINMUX.VAR.MIBSPI1.VALUE=0
DRIVER.PINMUX.VAR.MUX103_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MIBSPI3.VALUE=0
DRIVER.PINMUX.VAR.MUX103_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.OHCI0.VALUE=0
DRIVER.PINMUX.VAR.MUX103_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MIBSPI5.VALUE=0
DRIVER.PINMUX.VAR.W2FC.VALUE=0
DRIVER.PINMUX.VAR.OHCI1.VALUE=0
DRIVER.PINMUX.VAR.MUX103_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX103_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX94_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX86_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX78_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX94_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX86_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX78_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX94_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX86_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX78_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX5_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_108_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX94_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX86_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX78_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX94_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX86_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX78_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX9_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX9_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_10.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX9_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_101_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXD_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_11.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_PRITY_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX9_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_12.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX71_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX63_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX9_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXD_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_13.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX71_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX63_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX9_OPTION5.VALUE=1
DRIVER.PINMUX.VAR.DMA_ADDMW_10.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_0.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_14.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX71_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX63_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX51_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX43_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX35_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX27_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX19_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_11.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXD_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_15.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX71_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX63_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_20.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_12.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_16.VALUE=HIGH
DRIVER.PINMUX.VAR.ETPWM1_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.MUX71_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX63_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX2_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_21.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_13.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_3.VALUE=0
DRIVER.PINMUX.VAR.MUX55_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX47_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX39_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX2_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_30.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_22.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_14.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_EIDXD_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_10.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.MUX2_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_9_SELECT.VALUE=5
DRIVER.PINMUX.VAR.DMA_ADDMW_31.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CHANNEL_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_23.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CHANNEL_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_15.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_CHANNEL_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXD_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_IET_COUNT_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_11.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.MUX2_OPTION3.VALUE=1
DRIVER.PINMUX.VAR.DMA_ADDMW_24.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_16.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_12.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.MUX40_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX24_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX16_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX2_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_25.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_17.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_13.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.MUX40_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX24_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX16_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX2_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_26.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_18.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_14.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTFTCEN_10.VALUE=1
DRIVER.PINMUX.VAR.MUX40_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX24_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.MUX16_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_93_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_85_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_77_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_69_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_2_SELECT.VALUE=3
DRIVER.PINMUX.VAR.DMA_ADDMW_27.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_ADDMW_19.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_IET_COUNT_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_15.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_PRITY_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTFTCEN_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX40_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX24_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX16_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_28.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_TRIG_16.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTFTCEN_12.VALUE=1
DRIVER.PINMUX.VAR.MUX40_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX24_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX16_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_29.VALUE=CONSTANT
DRIVER.PINMUX.VAR.DMA_INTFTCEN_13.VALUE=1
DRIVER.PINMUX.VAR.MUX40_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX32_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX24_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX16_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTFTCEN_14.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTHBCEN_10.VALUE=1
DRIVER.PINMUX.VAR.MUX102_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_70_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_62_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_54_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_46_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_38_SELECT.VALUE=4
DRIVER.PINMUX.VAR.DMA_TTYPE_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTFTCEN_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTHBCEN_11.VALUE=1
DRIVER.PINMUX.VAR.DMA_CHPR_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ERRACT_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MII.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTFTCEN_16.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTHBCEN_12.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTHBCEN_13.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTHBCEN_14.VALUE=1
DRIVER.PINMUX.VAR.GATE_EMIF_CLK_SELECT.VALUE=OFF
DRIVER.PINMUX.VAR.MUX20_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX12_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_31_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_23_SELECT.VALUE=2
DRIVER.PINMUX.VAR.PIN_MUX_15_SELECT.VALUE=4
DRIVER.PINMUX.VAR.DMA_ADDMW_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTHBCEN_15.VALUE=1
DRIVER.PINMUX.VAR.DMA_TRIG_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHPR_1.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_INTHBCEN_16.VALUE=1
DRIVER.PINMUX.VAR.DMA_CHPR_2.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_CHPR_3.VALUE=HIGH
DRIVER.PINMUX.VAR.ETPWM_TIME_BASE_SYNC_ENABLE.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTMP_10.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_4.VALUE=HIGH
DRIVER.PINMUX.VAR.MUX93_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX85_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX77_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX69_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_29_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_11.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_5.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_TRIG_1.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.ETPWM_EPWM1SYNCI.VALUE=ASYNC
DRIVER.PINMUX.VAR.DMA_INTMP_12.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_6.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_TRIG_2.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.ETPWM6_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.DMA_INTMP_13.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_7.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_TRIG_3.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTMP_14.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_8.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_TRIG_4.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_CHANNEL_28_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_6_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_15.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_CHPR_9.VALUE=HIGH
DRIVER.PINMUX.VAR.DMA_TRIG_5.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTHBCEN_1.VALUE=1
DRIVER.PINMUX.VAR.SCI.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTMP_16.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_TRIG_6.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTHBCEN_2.VALUE=1
DRIVER.PINMUX.VAR.DMA_TRIG_7.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTHBCEN_3.VALUE=1
DRIVER.PINMUX.VAR.DMA_TRIG_8.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTHBCEN_4.VALUE=1
DRIVER.PINMUX.VAR.MUX8_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_9_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_9.VALUE=HARDWARE_TRIGGER
DRIVER.PINMUX.VAR.DMA_INTHBCEN_5.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_1.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_INTHBCEN_6.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_2.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_ENABLEPAR.VALUE=1
DRIVER.PINMUX.VAR.MUX102_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTHBCEN_7.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_3.VALUE=GROUP_A
DRIVER.PINMUX.VAR.MUX102_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTHBCEN_8.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_4.VALUE=GROUP_A
DRIVER.PINMUX.VAR.MUX102_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTHBCEN_9.VALUE=1
DRIVER.PINMUX.VAR.DMA_CHPR_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_5.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_TRIG_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ACC_1.VALUE=ALL
DRIVER.PINMUX.VAR.ETPWM.VALUE=0
DRIVER.PINMUX.VAR.MUX102_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTMP_6.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_ACC_2.VALUE=ALL
DRIVER.PINMUX.VAR.MUX102_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX93_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX85_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX77_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX69_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTMP_7.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_ACC_3.VALUE=ALL
DRIVER.PINMUX.VAR.MUX93_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX85_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX77_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX69_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTMP_8.VALUE=GROUP_A
DRIVER.PINMUX.VAR.DMA_ACC_4.VALUE=ALL
DRIVER.PINMUX.VAR.MUX93_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX85_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX77_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX70_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX69_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX62_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX54_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX46_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX38_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_106_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_0_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTMP_9.VALUE=GROUP_A
DRIVER.PINMUX.VAR.MUX93_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX85_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX77_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX69_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX93_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX85_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX77_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX69_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX8_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX8_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX8_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_BASE.VALUE=0xFFFFF000
DRIVER.PINMUX.VAR.MUX8_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX70_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX62_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX8_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX70_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX62_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX8_OPTION5.VALUE=1
DRIVER.PINMUX.VAR.MUX70_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX62_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX1_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_20_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_12_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX70_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX62_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX70_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX62_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION4.VALUE=1
DRIVER.PINMUX.VAR.MUX1_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX54_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX46_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX38_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX1_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX1_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_98_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_7_SELECT.VALUE=2
DRIVER.PINMUX.VAR.DMA_ADDMR_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX1_OPTION3.VALUE=1
DRIVER.PINMUX.VAR.MUX31_OPTION0.VALUE=1
DRIVER.PINMUX.VAR.MUX23_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX1_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX31_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX23_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX1_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX31_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX31_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX23_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.MUX23_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX15_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_91_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_83_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_75_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_67_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_59_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TRIG_8_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX31_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX23_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX31_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX23_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION4.VALUE=1
DRIVER.PINMUX.VAR.MUX31_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX23_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.MUX15_OPTION5.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_0.VALUE=0
DRIVER.PINMUX.VAR.MUX96_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX88_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_60_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_52_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_44_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_36_SELECT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_28_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_0.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_21_SELECT.VALUE=2
DRIVER.PINMUX.VAR.PIN_MUX_13_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_21_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_13_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMW_10_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMR_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_1.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHPR_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_PRITY_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_BASE_RAM.VALUE=0xFFF80000
DRIVER.PINMUX.VAR.DMA_EIDXS_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_2.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_3.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_4.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_25_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_AIM_17_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TTYPE_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_5.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_1.VALUE=1
DRIVER.PINMUX.VAR.DMA_FIDXD_6.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_2.VALUE=1
DRIVER.PINMUX.VAR.SPI2.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_7.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_3.VALUE=1
DRIVER.PINMUX.VAR.DMA_FIDXD_8.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_4.VALUE=1
DRIVER.PINMUX.VAR.SPI4.VALUE=0
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_30_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_24_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_22_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_16_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_9.VALUE=0
DRIVER.PINMUX.VAR.DMA_AIM_2_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHAS_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_5.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTASS_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.RMII.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHAS_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_6.VALUE=1
DRIVER.PINMUX.VAR.PINMUX0.VALUE="PINMUX_PIN_1_GIOB_3 | PINMUX_PIN_2_GIOA_0 | PINMUX_PIN_3_nTZ1 | PINMUX_PIN_4_nTZ2"
DRIVER.PINMUX.VAR.MUX99_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_INTLFSEN_7.VALUE=1
DRIVER.PINMUX.VAR.PINMUX1.VALUE="PINMUX_PIN_5_GIOA_1 | PINMUX_PIN_6_HET1_11"
DRIVER.PINMUX.VAR.MUX99_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_10.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_INTLFSEN_8.VALUE=1
DRIVER.PINMUX.VAR.PINMUX2.VALUE="PINMUX_PIN_9_EQEP2I | PINMUX_PIN_14_ETPWM1A"
DRIVER.PINMUX.VAR.MUX99_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX81_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX73_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX65_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX57_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.MUX49_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_11.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_PRITY_14_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_INTLFSEN_9.VALUE=1
DRIVER.PINMUX.VAR.DMA_INTMP_5_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ACC_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.PINMUX3.VALUE="PINMUX_PIN_15_HET1_22 | PINMUX_PIN_16_ETPWM1B"
DRIVER.PINMUX.VAR.MUX99_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_20.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_12.VALUE=8BIT
DRIVER.PINMUX.VAR.ETPWM4_EQEPERR12.VALUE=EQEPERR12
DRIVER.PINMUX.VAR.PINMUX4.VALUE="PINMUX_PIN_22_ETPWM2A | PINMUX_PIN_23_EQEP2A | PINMUX_PIN_24_EQEP2B"
DRIVER.PINMUX.VAR.MUX101_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX99_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_21.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_13.VALUE=8BIT
DRIVER.PINMUX.VAR.PINMUX5.VALUE="PINMUX_PIN_25_ETPWM2B | PINMUX_PIN_30_ETPWM3A | PINMUX_PIN_31_ETPWM3B"
DRIVER.PINMUX.VAR.MUX101_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_30.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_22.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_14.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_0.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.PINMUX6.VALUE="PINMUX_PIN_33_HET1_07 | PINMUX_PIN_35_ETPWM7A"
DRIVER.PINMUX.VAR.MUX101_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_31.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_23.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_15.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_1_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_1.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHPR_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.ALT_ADC_A.VALUE=0
DRIVER.PINMUX.VAR.PINMUX7.VALUE="PINMUX_PIN_37_MIBSPI3NCS_1 | PINMUX_PIN_38_ETPWM5A"
DRIVER.PINMUX.VAR.MUX101_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_24.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_20.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_16.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_12.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_2.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.ALT_ADC_B.VALUE=1
DRIVER.PINMUX.VAR.PINMUX8.VALUE="PINMUX_PIN_39_HET1_13 | PINMUX_PIN_40_MIBSPI1NCS_2 | PINMUX_PIN_41_ECAP1"
DRIVER.PINMUX.VAR.MUX101_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX92_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX84_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX76_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.MUX68_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_25.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_21.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_17.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_13.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_3.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.PINMUX9.VALUE="PINMUX_PIN_54_EQEP1B | PINMUX_PIN_55_EQEP1I"
DRIVER.PINMUX.VAR.MUX92_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX84_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX76_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.MUX68_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_30.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_26.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_22.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_18.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_14.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_4.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX92_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX84_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX76_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX68_OPTION2.VALUE=0
DRIVER.PINMUX.VAR.MUX4_CONFLICT.VALUE=0
DRIVER.PINMUX.VAR.PIN_MUX_104_SELECT.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_31.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_31_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_27.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_26_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_23.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_23_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_19.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_18_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_15.VALUE=0
DRIVER.PINMUX.VAR.DMA_ADDMW_15_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_ADDMR_7_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_CHANNEL_5.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_CHANNEL_4_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_WRITE_ELSIZE_3_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_TRIG_11_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.MUX92_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX84_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX76_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.MUX68_OPTION3.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_28.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_24.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_16.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_6.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX92_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX84_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX76_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX68_OPTION4.VALUE=0
DRIVER.PINMUX.VAR.MUX7_OPTION0.VALUE=0
DRIVER.PINMUX.VAR.DMA_READ_ELSIZE_29.VALUE=8BIT
DRIVER.PINMUX.VAR.DMA_EIDXS_25.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_17.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_7.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.MUX7_OPTION1.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_26.VALUE=0
DRIVER.PINMUX.VAR.DMA_EIDXS_18.VALUE=0
DRIVER.PINMUX.VAR.DMA_FIDXD_10.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_8.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_TTYPE_0.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_0.VALUE=0
DRIVER.PINMUX.VAR.MUX7_OPTION2.VALUE=1
DRIVER.PINMUX.VAR.DMA_EIDXS_27.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_27_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_EIDXS_19.VALUE=0
DRIVER.PINMUX.VAR.DMA_TTYPE_19_VALUE.VALUE=0x0001
DRIVER.PINMUX.VAR.DMA_FIDXD_11.VALUE=0
DRIVER.PINMUX.VAR.DMA_CHANNEL_9.VALUE=CHANNEL0
DRIVER.PINMUX.VAR.DMA_TTYPE_1.VALUE=FRAME_TRANSFER
DRIVER.PINMUX.VAR.DMA_CP0_IDADDR_1.VALUE=0
DRIVER.PINMUX.VAR.MUX7_OPTION3.VALUE=0
DRIVER.CRC.VAR.CRC_CH2_PSIH.VALUE=0
DRIVER.CRC.VAR.HTU_CPB_7_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH2_PSIL.VALUE=0
DRIVER.CRC.VAR.HTU_DCP0_TRDIR_1.VALUE=HET_TO_MAIN_MEM
DRIVER.CRC.VAR.CRC_CH1_CCI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPBL_7_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_5_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPB_1_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_DEBMOD_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH1_CFI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPAL_1_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ENABUS_1.VALUE=0
DRIVER.CRC.VAR.HTU_CPA_2_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH2_WDTO.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH2_CCI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_MP1_ACC_1.VALUE=READ_ONLY
DRIVER.CRC.VAR.HTU_CONTPAR_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH2_CFI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPB_6_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_DCP0_EC_1.VALUE=0
DRIVER.CRC.VAR.HTU_DCP0_CPBFULADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPAL_6_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_CPA_7_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_CPB_3_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH1_DTE.VALUE=0
DRIVER.CRC.VAR.HTU_DCP0_FC_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH1_CVH.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH1_PSSIH.VALUE=0
DRIVER.CRC.VAR.HTU_BASE.VALUE=0xFFF7A400
DRIVER.CRC.VAR.CRC_CH1_CVL.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH1_PSSIL.VALUE=0
DRIVER.CRC.VAR.HTU_ICPBL_3_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_1_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH2_DTE.VALUE=1
DRIVER.CRC.VAR.CRC_CH2_CVH.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH2_CVL.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH1_PCP.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPA_6_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPB_2_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH1_SCP.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_DCP0_CPAFULADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPAL_2_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.CRC_CH2_PCP.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_CPA_3_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH1_PSA.VALUE=1
DRIVER.CRC.VAR.CRC_CH1_ORI.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH2_SCP.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_MP1_STADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPB_7_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH1_TOE.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPAL_7_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.CRC_CH2_PSA.VALUE=1
DRIVER.CRC.VAR.CRC_CH2_ORI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_CPB_4_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_MP0_ENA_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH2_MODE_VALUE.VALUE=0x0001
DRIVER.CRC.VAR.CRC_CH1_URI.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH2_PSSIH.VALUE=0
DRIVER.CRC.VAR.CRC_CH2_TOE.VALUE=0x00000000
DRIVER.CRC.VAR.CRC_CH2_PSSIL.VALUE=0
DRIVER.CRC.VAR.CRC_CH1_BCTO.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_ICPBL_4_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_2_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_PAR_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH2_URI.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_CONT_1.VALUE=0
DRIVER.CRC.VAR.HTU_ENAREQ_1.VALUE=0
DRIVER.CRC.VAR.HTU_MP1_ERRENA_1.VALUE=0
DRIVER.CRC.VAR.HTU_MP0_STADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPA_7_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPB_3_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPAL_3_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_CPA_4_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_CPB_0_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH2_BCTO.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_DCP0_MMADD_1.VALUE=POST_INCREMENT
DRIVER.CRC.VAR.HTU_ENAINTMAP_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH1_MODE_VALUE.VALUE=0x0001
DRIVER.CRC.VAR.HTU_ICPBL_0_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_CPB_5_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_MP1_ENA_1.VALUE=0
DRIVER.CRC.VAR.HTU_DCP0_HETADD.VALUE=0
DRIVER.CRC.VAR.HTU_ICPBL_5_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_3_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_CPA_0_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_RES_1.VALUE=0
DRIVER.CRC.VAR.HTU_DCP0_CPATMOD_1.VALUE=POST_INCREMENT
DRIVER.CRC.VAR.HTU_MP1_ENDADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPB_4_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_BASE.VALUE=0xFE000000
DRIVER.CRC.VAR.HTU_ICPAL_4_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.CRC_CH1_MODE.VALUE=FULL_CPU
DRIVER.CRC.VAR.HTU_CPA_5_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_CPB_1_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_VBHOLD_1.VALUE=0
DRIVER.CRC.VAR.HTU_MP0_ERRENA_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPBL_1_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_CPB_6_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.CRC_CH2_MODE.VALUE=FULL_CPU
DRIVER.CRC.VAR.HTU_DCP0_TRDAT_1.VALUE=32BIT
DRIVER.CRC.VAR.HTU_ICPBL_6_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_4_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPB_0_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPAL_0_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_CPA_1_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_DCP0_CPBTMOD_1.VALUE=POST_INCREMENT
DRIVER.CRC.VAR.CRC_CH1_PSIH.VALUE=0
DRIVER.CRC.VAR.HTU_MP0_ACC_1.VALUE=READ_ONLY
DRIVER.CRC.VAR.CRC_CH1_PSIL.VALUE=0
DRIVER.CRC.VAR.HTU_ICPB_5_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ICPAL_5_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_DCP0_ADMOD_1.VALUE=INCREMENT_16BIT
DRIVER.CRC.VAR.HTU_CPA_6_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_CPB_2_SEL_1.VALUE=ENABLE
DRIVER.CRC.VAR.HTU_ENA_1.VALUE=0
DRIVER.CRC.VAR.CRC_CH1_WDTO.VALUE=0x00000000
DRIVER.CRC.VAR.HTU_MP0_ENDADD_1.VALUE=0
DRIVER.CRC.VAR.HTU_ICPBL_2_SEL_1.VALUE=HIGH
DRIVER.CRC.VAR.HTU_ICPA_0_SEL_1.VALUE=ENABLE
DRIVER.EMAC.VAR.EMAC_ADD1.VALUE=FF
DRIVER.EMAC.VAR.EMAC_ADD2.VALUE=FF
DRIVER.EMAC.VAR.EMAC_ADD3.VALUE=FF
DRIVER.EMAC.VAR.EMAC_ADD4.VALUE=FF
DRIVER.EMAC.VAR.EMAC_ADD5.VALUE=FF
DRIVER.EMAC.VAR.EMAC_ADD6.VALUE=FF
DRIVER.EMAC.VAR.EMAC_CTRL_BASE.VALUE=0xFCF78800
DRIVER.EMAC.VAR.EMAC_LOOPBACK_ENA.VALUE=0
DRIVER.EMAC.VAR.MDIO_BASE.VALUE=0xFCF78900
DRIVER.EMAC.VAR.EMAC_BASE.VALUE=0xFCF78000
DRIVER.EMAC.VAR.EMAC_BASE_PORT.VALUE=0xFFFFFFFF
DRIVER.EMAC.VAR.EMAC_TRANSMIT_ENA.VALUE=1
DRIVER.EMAC.VAR.EMAC_CHANNELNUMBER.VALUE=0
DRIVER.EMAC.VAR.EMAC_RX_PBUF_ALLOC.VALUE=10
DRIVER.EMAC.VAR.EMAC_UNICAST_ENA.VALUE=1
DRIVER.EMAC.VAR.EMAC_FULL_DUPLEX_ENA.VALUE=1
DRIVER.EMAC.VAR.EMAC_PHYADDRESS.VALUE=0
DRIVER.EMAC.VAR.EMAC_MII_ENA.VALUE=1
DRIVER.EMAC.VAR.EMAC_CTRL_RAM_BASE.VALUE=0xFC520000
DRIVER.EMAC.VAR.EMAC_BROADCAST_ENA.VALUE=1
DRIVER.EMAC.VAR.EMAC_RECEIVE_ENA.VALUE=1
DRIVER.EMIF.VAR.EMIF_ASYNC2_TAVAV.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_TD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_EXTENDED_WAIT.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_TH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TA.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_WAIT.VALUE=pin0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_NOR_FLASH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TEHQZ.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_TA.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_TD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ENA_SDRAM.VALUE=1
DRIVER.EMIF.VAR.EMIF_ASYNC3_TH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TELQV.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_PAGE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_ENA.VALUE=1
DRIVER.EMIF.VAR.EMIF_SDRAM_REFRESH_CYCLES.VALUE=0
DRIVER.EMIF.VAR.EMIF_AVAILABLE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_TEHEL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_ENA.VALUE=1
DRIVER.EMIF.VAR.EMIF_ASYNC1_R_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_ASYNC3_TELEH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_STROBE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_ENA.VALUE=1
DRIVER.EMIF.VAR.EMIF_ASYNC1_ASIZE.VALUE=8_bit
DRIVER.EMIF.VAR.EMIF_SDRAM_TRC_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_TAVAV.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_BANKS.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_PAGE_DELAY_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRAS_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRRD_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_BASE.VALUE=0xFCFFE800
DRIVER.EMIF.VAR.EMIF_ASYNC3_TEHQZ.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_W_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_ASYNC3_TELQV.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_PAGE_SIZE.VALUE=4_words
DRIVER.EMIF.VAR.EMIF_CLKFRQ.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_W_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_ASYNC2_R_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_SDRAM_TREFRESH_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_R_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_SDRAM_TXSR_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_TSU.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_EXTENDED_WAIT.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_ASIZE.VALUE=8_bit
DRIVER.EMIF.VAR.EMIF_ASYNC2_TSU.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_W_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_ASYNC3_NOR_FLASH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_PAGE_DELAY_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_W_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_SDRAM_INIT_TIME.VALUE=200
DRIVER.EMIF.VAR.EMIF_SDRAM_TREFRESH_DEFAULT.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_TSU.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_PAGE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_STROBE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_R_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_SDRAM_TWR_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_R_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_CLK.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRCD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_W_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_SDRAM_TRFC.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_ASIZE.VALUE=8_bit
DRIVER.EMIF.VAR.EMIF_SDRAM_TRAS.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_NOR_FLASH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_PAGE_DELAY.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_CAS_LATENCY.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC_WAIT_POLARITY0.VALUE=pin_low
DRIVER.EMIF.VAR.EMIF_SDRAM_TRCD_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC_WAIT_POLARITY1.VALUE=pin_high
DRIVER.EMIF.VAR.EMIF_ASYNC1_PAGE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_R_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_SDRAM_TRC.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRRD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_PAGE_DELAY_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_W_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_ASYNC1_TEHEL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC_MAX_EXT_WAIT.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRP.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_PAGE_SIZE.VALUE=4_words
DRIVER.EMIF.VAR.EMIF_ASYNC1_W_SETUP.VALUE=15
DRIVER.EMIF.VAR.EMIF_ASYNC1_TELEH.VALUE=0
DRIVER.EMIF.VAR.EMIF_MS.VALUE=0.001
DRIVER.EMIF.VAR.EMIF_NS.VALUE=0.000000001
DRIVER.EMIF.VAR.EMIF_SDRAM_TWR.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_EXTENDED_WAIT.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_REFRESH_PERIOD.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC3_R_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_ASYNC1_TAVAV.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_PAGE_DELAY.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_WAIT.VALUE=pin0
DRIVER.EMIF.VAR.EMIF_SDRAM_TXSR.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_TEHQZ.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_R_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_ASYNC1_TELQV.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_STROBE_MODE.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRP_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_W_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_ASYNC1_PAGE_SIZE.VALUE=4_words
DRIVER.EMIF.VAR.EMIF_ASYNC2_WAIT.VALUE=pin0
DRIVER.EMIF.VAR.EMIF_ASYNC2_TEHEL.VALUE=0
DRIVER.EMIF.VAR.EMIF_SDRAM_TRFC_VAL.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_R_HOLD.VALUE=7
DRIVER.EMIF.VAR.EMIF_SDRAM_PAGE_SIZE.VALUE=elements_256
DRIVER.EMIF.VAR.EMIF_ASYNC2_TELEH.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC1_PAGE_DELAY.VALUE=0
DRIVER.EMIF.VAR.EMIF_IBANK.VALUE=0
DRIVER.EMIF.VAR.EMIF_ASYNC2_W_STROBE.VALUE=63
DRIVER.EMIF.VAR.EMIF_ASYNC1_TA.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD28.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD29.VALUE=0
DRIVER.POM.VAR.POM_REGION_10_ENA.VALUE=1
DRIVER.POM.VAR.POM_TIMEOUT_ENABLE.VALUE=0
DRIVER.POM.VAR.POM_REGION_11_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_20_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_12_ENA.VALUE=1
DRIVER.POM.VAR.POM_NO_OF_REGION.VALUE=1
DRIVER.POM.VAR.POM_REGION_21_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_13_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_30_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_22_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_14_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_31_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_23_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_15_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_1_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_32_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_24_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_16_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_2_ENA.VALUE=0
DRIVER.POM.VAR.POM_REGION_25_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_17_ENA.VALUE=1
DRIVER.POM.VAR.POM_OVRLY_START_ADD1.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD2.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD3.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD4.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD5.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD6.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD7.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD8.VALUE=0
DRIVER.POM.VAR.POM_OVLY_TRG_REGION.VALUE=INTERNAL_RAM
DRIVER.POM.VAR.POM_OVRLY_START_ADD9.VALUE=0
DRIVER.POM.VAR.POM_REGION_3_ENA.VALUE=0
DRIVER.POM.VAR.POM_REGION_26_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_18_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_4_ENA.VALUE=0
DRIVER.POM.VAR.POM_REGION_27_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_19_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_5_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_28_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_6_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_SIZE10.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE11.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE20.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE12.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_29_ENA.VALUE=1
DRIVER.POM.VAR.POM_REGION_SIZE21.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE13.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE30.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE22.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE14.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE31.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE23.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE15.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE32.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE24.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE16.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE25.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE17.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE26.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE18.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE27.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE19.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE28.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE29.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_7_ENA.VALUE=1
DRIVER.POM.VAR.POM_BASE.VALUE=0xFFA04000
DRIVER.POM.VAR.POM_PROG_START_ADD10.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD11.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD20.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD12.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD21.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD13.VALUE=0
DRIVER.POM.VAR.POM_REGION_8_ENA.VALUE=1
DRIVER.POM.VAR.POM_PROG_START_ADD30.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD22.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD14.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD31.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD23.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD15.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD32.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD24.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD16.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD25.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD17.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD26.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD18.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD27.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD19.VALUE=0
DRIVER.POM.VAR.POM_REGION_SIZE1.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_PROG_START_ADD28.VALUE=0
DRIVER.POM.VAR.POM_REGION_SIZE2.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_PROG_START_ADD29.VALUE=0
DRIVER.POM.VAR.POM_REGION_SIZE3.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE4.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE5.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE6.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE7.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE8.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_SIZE9.VALUE=SIZE_64BYTES
DRIVER.POM.VAR.POM_REGION_9_ENA.VALUE=1
DRIVER.POM.VAR.POM_PROG_START_ADD1.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD2.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD3.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD4.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD5.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD6.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD7.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD8.VALUE=0
DRIVER.POM.VAR.POM_PROG_START_ADD9.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD10.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD11.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD20.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD12.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD21.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD13.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD30.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD22.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD14.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD31.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD23.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD15.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD32.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD24.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD16.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD25.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD17.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD26.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD18.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD27.VALUE=0
DRIVER.POM.VAR.POM_OVRLY_START_ADD19.VALUE=0
DRIVER.PMM.VAR.PMM_RAM_PWR_DOMAIN2_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_PWR_DOMAIN5_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_PWR_DOMAIN3_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_RAM_PWR_DOMAIN3_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_RAM_PWR_DOMAIN1_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_PWR_DOMAIN4_ENABLE.VALUE=0
DRIVER.PMM.VAR.PMM_PWR_DOMAIN2_ENABLE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM3_PWMA_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM2_PWMA_COMPARE.VALUE=1000
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM3_PWMA_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM3_PWMA_DUTY.VALUE=30
DRIVER.ETPWM.VAR.ETPWM7_PWMB_PERIOD.VALUE=10000000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_HSPCLKDIV.VALUE=10
DRIVER.ETPWM.VAR.ETPWM4_CLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM7_BASE.VALUE=0xFCF79200
DRIVER.ETPWM.VAR.ETPWM5_TB_ACTUALFREQUENCY.VALUE=0.125
DRIVER.ETPWM.VAR.ETPWM6_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_PWMB_PERIOD.VALUE=1000
DRIVER.ETPWM.VAR.ETPWM6_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_PWMA_DUTYTIME.VALUE=500.000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM7_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM7_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMB_COMPARE.VALUE=50
DRIVER.ETPWM.VAR.ETPWM2_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMA_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM1_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM2_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CLKDIV.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMB_DUTY.VALUE=30
DRIVER.ETPWM.VAR.ETPWM7_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM4_PWMB_ACTUALPERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM1_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_HSPCLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM6_OSHT_ACTUAL_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM4_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_DUTYTIME.VALUE=5000000.000
DRIVER.ETPWM.VAR.ETPWM3_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_TB_ACTUALFREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM1_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_COMPARE.VALUE=750
DRIVER.ETPWM.VAR.ETPWM2_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM6_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM6_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM6_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM5_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM1_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_PWMB_PERIOD_REG.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM5_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMA_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMA_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM5_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_HSPCLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_CLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_TB_FREQUENCY.VALUE=90.000
DRIVER.ETPWM.VAR.ETPWM4_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM7_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM6_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM5_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM6_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMA_DUTYTIME.VALUE=9375.000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_COMPARE.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM3_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM2_CLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM7_PWMA_ACTUALPERIOD.VALUE=10000000.000
DRIVER.ETPWM.VAR.ETPWM2_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM5_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM7_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMB_PERIOD_REG.VALUE=79
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_PWMA_PERIOD.VALUE=10000000
DRIVER.ETPWM.VAR.ETPWM4_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_TB_ACTUALFREQUENCY.VALUE=0.125
DRIVER.ETPWM.VAR.ETPWM3_TB_FREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM2_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM1_PWMB_DUTY.VALUE=20
DRIVER.ETPWM.VAR.ETPWM1_HSPCLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM4_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMA_COMPARE.VALUE=750
DRIVER.ETPWM.VAR.ETPWM2_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM3_PWMB_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM2_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_DUTYTIME.VALUE=12500.000
DRIVER.ETPWM.VAR.ETPWM6_OSHT_WIDTH_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM2_PWMA_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM5_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM4_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM5_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM4_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM5_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM6_PWMA_PERIOD_REG.VALUE=1000
DRIVER.ETPWM.VAR.ETPWM6_HSPCLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_PERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM7_CBC.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_HSPCLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM2_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_CLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM1_PWMA_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM7_PWMB_DUTYTIME.VALUE=5000000.000
DRIVER.ETPWM.VAR.ETPWM3_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_CLKDIV.VALUE=40
DRIVER.ETPWM.VAR.ETPWM2_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMB_COMPARE.VALUE=625
DRIVER.ETPWM.VAR.ETPWM7_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM6_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMB_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM1_BASE.VALUE=0xFCF78C00
DRIVER.ETPWM.VAR.ETPWM6_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM1_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM4_TB_ACTUALFREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM2_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM6_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMA_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM3_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_HSPCLKDIV.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_ACTUALPERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM5_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_PWMB_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_PWMA_DUTYTIME.VALUE=5000000.000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_PERIOD_REG.VALUE=79
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_PWMB_COMPARE.VALUE=40
DRIVER.ETPWM.VAR.ETPWM4_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM3_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM3_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_PWMB_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM2_BASE.VALUE=0xFCF78D00
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM7_CLKDIV_REG.VALUE=6
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_TB_FREQUENCY.VALUE=90.000
DRIVER.ETPWM.VAR.ETPWM5_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM3_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM5_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM4_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM3_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM4_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_HSPCLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_TB_ACTUALFREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM5_CLKDIV.VALUE=40
DRIVER.ETPWM.VAR.ETPWM7_PWMA_COMPARE.VALUE=625
DRIVER.ETPWM.VAR.ETPWM6_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMB_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM4_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMB_DUTYTIME.VALUE=500.000
DRIVER.ETPWM.VAR.ETPWM7_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMA_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM1_PWMB_COMPARE.VALUE=500
DRIVER.ETPWM.VAR.ETPWM1_CLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM7_PWMB_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM2_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM4_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM2_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM7_PWMB_ACTUALPERIOD.VALUE=10000000.000
DRIVER.ETPWM.VAR.ETPWM2_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM4_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_PWMA_PERIOD.VALUE=10000000
DRIVER.ETPWM.VAR.ETPWM5_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_TB_FREQUENCY.VALUE=90.000
DRIVER.ETPWM.VAR.ETPWM4_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM4_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM2_PWMA_DUTY.VALUE=40
DRIVER.ETPWM.VAR.ETPWM5_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_BASE.VALUE=0xFCF78E00
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM2_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_PWMB_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM2_PWMA_DUTYTIME.VALUE=12500.000
DRIVER.ETPWM.VAR.ETPWM1_PWMA_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM4_HSPCLKDIV.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMA_COMPARE.VALUE=40
DRIVER.ETPWM.VAR.ETPWM1_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMA_ACTUALPERIOD.VALUE=10000000.000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_PERIOD.VALUE=1000
DRIVER.ETPWM.VAR.ETPWM2_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM3_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM7_PWMB_PERIOD_REG.VALUE=1249
DRIVER.ETPWM.VAR.ETPWM7_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMA_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM7_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_TB_ACTUALFREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM4_PWMB_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM2_PWMA_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM7_PWMB_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_PWMA_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM3_PWMB_FALLING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM3_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMA_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM7_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_PWMA_DUTYTIME.VALUE=5000000.000
DRIVER.ETPWM.VAR.ETPWM1_TB_FREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM3_CLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_CLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMB_ACTUALPERIOD.VALUE=31250.000
DRIVER.ETPWM.VAR.ETPWM5_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM2_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM5_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM3_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMA_COMPARE.VALUE=1250
DRIVER.ETPWM.VAR.ETPWM7_OST.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_DUTYTIME.VALUE=50.000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_DUTYTIME.VALUE=6250.000
DRIVER.ETPWM.VAR.ETPWM6_PWMA_DEADBAND_INVERT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_DUTY.VALUE=40
DRIVER.ETPWM.VAR.ETPWM5_PWMB_PERIOD.VALUE=10000000
DRIVER.ETPWM.VAR.ETPWM4_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM3_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_PWMB_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM4_BASE.VALUE=0xFCF78F00
DRIVER.ETPWM.VAR.ETPWM3_PWMA_FALLING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM4_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_PERIOD_REG.VALUE=1249
DRIVER.ETPWM.VAR.ETPWM4_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMB_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_HSPCLKDIV_REG.VALUE=5
DRIVER.ETPWM.VAR.ETPWM6_PWMB_ACTUALPERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM2_PWMB_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM3_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM2_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMB_DUTYTIME.VALUE=500.000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM2_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMA_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM7_PWMB_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_PWMB_COMPARE.VALUE=625
DRIVER.ETPWM.VAR.ETPWM5_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM1_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_PERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM1_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_TB_ACTUALFREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM2_ENABLE_SOCA.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_ENABLE_SOCB.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_HSPCLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM5_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM6_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_PWMA_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM6_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_DUTYTIME_REG.VALUE=3
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_SOCB_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_PWMA_PERIOD_REG.VALUE=1249
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_PWMA_ACTUALPERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM7_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM5_PWMA_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_BASE.VALUE=0xFCF79000
DRIVER.ETPWM.VAR.ETPWM3_PWMA_RISING_EDGE_DELAY.VALUE=12.500
DRIVER.ETPWM.VAR.ETPWM7_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM7_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM1_CLKDIV.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM6_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM3_PWMB_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM4_PWMB_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM4_PWMA_DUTYTIME.VALUE=500.000
DRIVER.ETPWM.VAR.ETPWM7_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMA_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM7_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_PWMA_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM7_HSPCLKDIV.VALUE=10
DRIVER.ETPWM.VAR.ETPWM5_CLKDIV_REG.VALUE=6
DRIVER.ETPWM.VAR.ETPWM2_PWMB_COMPARE.VALUE=1000
DRIVER.ETPWM.VAR.ETPWM2_DEADBAND_OUTPUT.VALUE=PWMA_PWMB_NIL
DRIVER.ETPWM.VAR.ETPWM1_INTERRUPT_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM4_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM5_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM4_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM1_OSHT_WIDTH.VALUE=100
DRIVER.ETPWM.VAR.ETPWM4_OSHT_WIDTH_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_PWMA_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_PWMA_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM6_PWMA_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM2_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM7_DCBEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_MODE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_DCBEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM2_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_CBC1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_PWMA_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM5_TB_FREQUENCY.VALUE=90.000
DRIVER.ETPWM.VAR.ETPWM1_SELECT_SOCA.VALUE=DCAEVT1
DRIVER.ETPWM.VAR.ETPWM7_CBC2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM1_SELECT_SOCB.VALUE=DCBEVT1
DRIVER.ETPWM.VAR.ETPWM7_CBC3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMA_PERIOD_REG.VALUE=1249
DRIVER.ETPWM.VAR.ETPWM3_CHOPPER_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM2_HSPCLKDIV_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_CBC4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM6_CHOPPER_ACTUALPERIOD.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM7_CBC5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_CBC6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM5_PWMA_COMPARE.VALUE=625
DRIVER.ETPWM.VAR.ETPWM3_PWMA_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM1_CHOPPER_PERIOD_REG.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMB_PERIOD_REG.VALUE=2499
DRIVER.ETPWM.VAR.ETPWM7_PWMA_FALLING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM7_PWMA_RISING_EDGE_DELAY.VALUE=11.111
DRIVER.ETPWM.VAR.ETPWM6_BASE.VALUE=0xFCF79100
DRIVER.ETPWM.VAR.ETPWM3_PWMB_DUTYTIME.VALUE=9375.000
DRIVER.ETPWM.VAR.ETPWM6_PWMB_ENA.VALUE=1
DRIVER.ETPWM.VAR.ETPWM5_OSHT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_PWMB_RISING_EDGE_DELAY_REG.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_PWMA_PERIOD.VALUE=1000.000
DRIVER.ETPWM.VAR.ETPWM5_OSHT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_DEADBAND_INPUT.VALUE=PWMA_RED_FED
DRIVER.ETPWM.VAR.ETPWM5_PWMB_ACTUALPERIOD.VALUE=10000000.000
DRIVER.ETPWM.VAR.ETPWM5_OSHT3.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_OSHT4.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM2_SELECT_EVENT.VALUE=NO_EVENT
DRIVER.ETPWM.VAR.ETPWM5_OSHT5.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM5_PWMB_DUTY.VALUE=50
DRIVER.ETPWM.VAR.ETPWM5_OSHT6.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM7_OSHT_ACTUAL_WIDTH.VALUE=100.000
DRIVER.ETPWM.VAR.ETPWM6_CLKDIV.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_PWMA_DEADBAND_OUT.VALUE=0
DRIVER.ETPWM.VAR.ETPWM7_HSPCLKDIV_REG.VALUE=5
DRIVER.ETPWM.VAR.ETPWM2_CHOPPER_DUTY_NEW.VALUE=50.0
DRIVER.ETPWM.VAR.ETPWM3_PWMA_PERIOD.VALUE=31250
DRIVER.ETPWM.VAR.ETPWM2_TB_FREQUENCY.VALUE=80.000
DRIVER.ETPWM.VAR.ETPWM6_DCAEVT1.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM3_PWMA_POLARITY.VALUE=0
DRIVER.ETPWM.VAR.ETPWM6_SOCA_PERIOD.VALUE=1
DRIVER.ETPWM.VAR.ETPWM6_DCAEVT2.VALUE=0x0000
DRIVER.ETPWM.VAR.ETPWM4_FDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_RDELAY_SOURCE.VALUE=0
DRIVER.ETPWM.VAR.ETPWM1_PWMA_DUTYTIME.VALUE=15625.000
DRIVER.ECAP.VAR.ECAP1_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP2_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP4_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_RESET_COUNTER_CAP1.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP6_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP6_RESET_COUNTER_CAP3.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP6_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP5_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP5_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP4_CAP2_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP5_PRESCALE.VALUE=0
DRIVER.ECAP.VAR.ECAP5_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_PWM_COMPARE.VALUE=50
DRIVER.ECAP.VAR.ECAP5_CAP4_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP5_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP6_PWM_PERIOD_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP6_WRAP_COUNTER.VALUE=CAPTURE_EVENT1
DRIVER.ECAP.VAR.ECAP3_PWM_COMPARE.VALUE=40
DRIVER.ECAP.VAR.ECAP2_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP6_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_PWM_DUTYTIME.VALUE=500.000
DRIVER.ECAP.VAR.ECAP3_RESET_COUNTER_CAP1.VALUE=RESET_ENABLE
DRIVER.ECAP.VAR.ECAP3_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP3_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP3_RESET_COUNTER_CAP3.VALUE=RESET_ENABLE
DRIVER.ECAP.VAR.ECAP3_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP1_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP3_WRAP_COUNTER.VALUE=CAPTURE_EVENT4
DRIVER.ECAP.VAR.ECAP2_PWM_PERIOD_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP5_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP5_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_CAPTURE_MODE.VALUE=ONE_SHOT
DRIVER.ECAP.VAR.ECAP5_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_CEVT4.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP1_CAP2_POLARITY.VALUE=FALLING_EDGE
DRIVER.ECAP.VAR.ECAP4_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP1_PWM_DUTYTIME.VALUE=500
DRIVER.ECAP.VAR.ECAP5_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP2_CAP4_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_PRESCALE.VALUE=1
DRIVER.ECAP.VAR.ECAP1_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP6_CAP2_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_CAPTURE_MODE.VALUE=CONTINUOUS
DRIVER.ECAP.VAR.ECAP2_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP4_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP6_PWM_ACTUALPERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP4_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP1_CEVT4.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_PRESCALE.VALUE=0
DRIVER.ECAP.VAR.ECAP5_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP4_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP3_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP3_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP5_RESET_COUNTER_CAP1.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP5_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP5_RESET_COUNTER_CAP3.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP5_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP6_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP3_PWM_PERIOD_REG.VALUE=79
DRIVER.ECAP.VAR.ECAP6_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_CEVT4.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_PWM_COMPARE.VALUE=50
DRIVER.ECAP.VAR.ECAP5_PWM_ACTUALPERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP6_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP3_CAP2_POLARITY.VALUE=FALLING_EDGE
DRIVER.ECAP.VAR.ECAP5_PWM_DUTYTIME.VALUE=500.000
DRIVER.ECAP.VAR.ECAP1_BASE.VALUE=0xFCF79300
DRIVER.ECAP.VAR.ECAP4_CAP4_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP2_PWM_COMPARE.VALUE=50
DRIVER.ECAP.VAR.ECAP4_WRAP_COUNTER.VALUE=CAPTURE_EVENT1
DRIVER.ECAP.VAR.ECAP5_CAPTURE_MODE.VALUE=ONE_SHOT
DRIVER.ECAP.VAR.ECAP1_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP2_RESET_COUNTER_CAP1.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP4_PWM_ACTUALPERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP2_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP1_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_PWM_DUTYTIME.VALUE=500.000
DRIVER.ECAP.VAR.ECAP2_RESET_COUNTER_CAP3.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP2_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP2_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP6_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP2_BASE.VALUE=0xFCF79400
DRIVER.ECAP.VAR.ECAP2_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP2_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_CEVT4.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_WRAP_COUNTER.VALUE=CAPTURE_EVENT4
DRIVER.ECAP.VAR.ECAP6_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP5_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP4_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP2_CAPTURE_MODE.VALUE=ONE_SHOT
DRIVER.ECAP.VAR.ECAP3_PWM_ACTUALPERIOD.VALUE=1000
DRIVER.ECAP.VAR.ECAP3_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP3_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP1_CAP4_POLARITY.VALUE=FALLING_EDGE
DRIVER.ECAP.VAR.ECAP4_PWM_PERIOD_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP3_PRESCALE.VALUE=1
DRIVER.ECAP.VAR.ECAP6_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP3_BASE.VALUE=0xFCF79500
DRIVER.ECAP.VAR.ECAP5_CAP2_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP3_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP6_CAP4_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_PWM_ACTUALPERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP4_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP3_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP1_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP6_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP2_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_PWM_DUTYTIME.VALUE=500.000
DRIVER.ECAP.VAR.ECAP4_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP4_BASE.VALUE=0xFCF79600
DRIVER.ECAP.VAR.ECAP6_PRESCALE.VALUE=0
DRIVER.ECAP.VAR.ECAP4_PWM_COMPARE.VALUE=50
DRIVER.ECAP.VAR.ECAP4_RESET_COUNTER_CAP1.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP3_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP3_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_RESET_COUNTER_CAP3.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP3_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP3_CEVT4.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP6_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP5_WRAP_COUNTER.VALUE=CAPTURE_EVENT1
DRIVER.ECAP.VAR.ECAP4_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP3_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_PWM_ACTUALPERIOD.VALUE=1000
DRIVER.ECAP.VAR.ECAP6_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP6_CAPTURE_MODE.VALUE=ONE_SHOT
DRIVER.ECAP.VAR.ECAP1_PWM_COMPARE.VALUE=40
DRIVER.ECAP.VAR.ECAP2_CAP2_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP3_PWM_DUTYTIME.VALUE=500
DRIVER.ECAP.VAR.ECAP3_CAP4_POLARITY.VALUE=FALLING_EDGE
DRIVER.ECAP.VAR.ECAP4_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP1_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_PWM_PERIOD_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP6_PWM_PERIOD.VALUE=1000.000
DRIVER.ECAP.VAR.ECAP5_BASE.VALUE=0xFCF79700
DRIVER.ECAP.VAR.ECAP3_ENA_PWM.VALUE=0
DRIVER.ECAP.VAR.ECAP2_WRAP_COUNTER.VALUE=CAPTURE_EVENT1
DRIVER.ECAP.VAR.ECAP3_CAPTURE_MODE.VALUE=CONTINUOUS
DRIVER.ECAP.VAR.ECAP1_RESET_COUNTER_CAP1.VALUE=RESET_ENABLE
DRIVER.ECAP.VAR.ECAP1_RESET_COUNTER_CAP2.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP1_RESET_COUNTER_CAP3.VALUE=RESET_ENABLE
DRIVER.ECAP.VAR.ECAP1_RESET_COUNTER_CAP4.VALUE=RESET_DISABLE
DRIVER.ECAP.VAR.ECAP5_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_PWM_DUTY.VALUE=50
DRIVER.ECAP.VAR.ECAP1_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP4_PRESCALE_REG.VALUE=0
DRIVER.ECAP.VAR.ECAP2_PRESCALE.VALUE=0
DRIVER.ECAP.VAR.ECAP2_CNTOVF.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP5_CAP1_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP1_PWM_PERIOD_REG.VALUE=79
DRIVER.ECAP.VAR.ECAP6_CMP.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP2_ENA_LOAD.VALUE=0
DRIVER.ECAP.VAR.ECAP3_PRD.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP3_RESET_COUNTER.VALUE=0
DRIVER.ECAP.VAR.ECAP6_BASE.VALUE=0xFCF79800
DRIVER.ECAP.VAR.ECAP6_CAP3_POLARITY.VALUE=RISING_EDGE
DRIVER.ECAP.VAR.ECAP4_CEVT1.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_CEVT2.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_CEVT3.VALUE=0x0000
DRIVER.ECAP.VAR.ECAP4_CEVT4.VALUE=0x0000
DRIVER.EQEP.VAR.EQEP2_QUPRD.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP2_INDEX_EVT_INIT_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_IGATE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_QPE_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_PC_RST_MODE.VALUE=MAX_POSITION
DRIVER.EQEP.VAR.EQEP1_UTO_INT_ENA.VALUE=1
DRIVER.EQEP.VAR.EQEP1_SEL_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_INDEX_EVT_SELECT.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP2_PCE_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_PCU_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_BASE.VALUE=0xFCF79900
DRIVER.EQEP.VAR.EQEP1_INV_QEPS_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP1_INV_QEPA_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PCSHDW.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PC_INIT_VALUE.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP2_PCR_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_BASE.VALUE=0xFCF79A00
DRIVER.EQEP.VAR.EQEP1_ENABLE_CAPTURE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_INV_QEPB_POL.VALUE=1
DRIVER.EQEP.VAR.EQEP2_MAXPC_VALUE.VALUE=0x000007FF
DRIVER.EQEP.VAR.EQEP1_PCM_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_PCPOL.VALUE=ACTIVE_HIGH
DRIVER.EQEP.VAR.EQEP2_UNIT_POS_PRESCALER.VALUE=PS_1
DRIVER.EQEP.VAR.EQEP2_CAP_CLK_PRESCALER.VALUE=PS_1
DRIVER.EQEP.VAR.EQEP1_PCSPW.VALUE=0x000
DRIVER.EQEP.VAR.EQEP1_POSCMP.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP2_PC_MODE.VALUE=QUADRATURE_COUNT
DRIVER.EQEP.VAR.EQEP1_PCE_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_INV_QEPS_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP1_SET_INIT_AT_STARTUP.VALUE=0
DRIVER.EQEP.VAR.EQEP2_ENABLE_CAPTURE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_STROBE_EVT_SELECT.VALUE=DIRECTON_DEPENDENT
DRIVER.EQEP.VAR.EQEP2_PCPOL.VALUE=ACTIVE_HIGH
DRIVER.EQEP.VAR.EQEP2_INV_QEPA_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP1_CAP_CLK_PRESCALER.VALUE=PS_1
DRIVER.EQEP.VAR.EQEP2_QDC_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_QCLM.VALUE=ON_UNIT_TIMOUT_EVENT
DRIVER.EQEP.VAR.EQEP1_PC_MODE.VALUE=QUADRATURE_COUNT
DRIVER.EQEP.VAR.EQEP2_WTO_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_SWI_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_PCR_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_INV_QEPB_POL.VALUE=1
DRIVER.EQEP.VAR.EQEP1_IEL.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP2_PCSPW.VALUE=0x000
DRIVER.EQEP.VAR.EQEP1_PC_INIT_VALUE.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP1_PCLOAD.VALUE=QPOSCNT_EQ_QPSCMP
DRIVER.EQEP.VAR.EQEP2_IEL_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_IEL.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP1_MAXPC_VALUE.VALUE=0x000007FF
DRIVER.EQEP.VAR.EQEP1_INV_QEPI_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP2_QCLM.VALUE=ON_UNIT_TIMOUT_EVENT
DRIVER.EQEP.VAR.EQEP1_STROBE_EVT_INIT_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PCO_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_STROBE_EVT_INIT_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_EXT_CLK_RATE.VALUE=RESOLUTION_1x
DRIVER.EQEP.VAR.EQEP1_STROBE_EVT_SELECT.VALUE=DIRECTON_DEPENDENT
DRIVER.EQEP.VAR.EQEP1_UNIT_POS_PRESCALER.VALUE=PS_1
DRIVER.EQEP.VAR.EQEP1_WDPRD.VALUE=0x0000
DRIVER.EQEP.VAR.EQEP1_SEL.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP1_SOEN.VALUE=0
DRIVER.EQEP.VAR.EQEP2_QPE_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PC_RST_MODE.VALUE=MAX_POSITION
DRIVER.EQEP.VAR.EQEP1_WDE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_SET_INIT_AT_STARTUP.VALUE=0
DRIVER.EQEP.VAR.EQEP2_UTO_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_SWI_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_POSITIVE_ROTATION.VALUE=CLOCKWISE
DRIVER.EQEP.VAR.EQEP2_SEL_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_SEL.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP2_PCU_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_WDE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_SPSEL.VALUE=INDEX_PIN
DRIVER.EQEP.VAR.EQEP1_PCSHDW.VALUE=0
DRIVER.EQEP.VAR.EQEP1_SWAP.VALUE=0
DRIVER.EQEP.VAR.EQEP2_SOEN.VALUE=0
DRIVER.EQEP.VAR.EQEP2_POSCMP.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP1_QUPRD.VALUE=0x00000000
DRIVER.EQEP.VAR.EQEP1_IGATE.VALUE=0
DRIVER.EQEP.VAR.EQEP1_QDC_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_SWAP.VALUE=0
DRIVER.EQEP.VAR.EQEP2_WDPRD.VALUE=0x0000
DRIVER.EQEP.VAR.EQEP1_WTO_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_POSITIVE_ROTATION.VALUE=CLOCKWISE
DRIVER.EQEP.VAR.EQEP2_INV_QEPI_POL.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PCM_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP1_IEL_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_EXT_CLK_RATE.VALUE=RESOLUTION_1x
DRIVER.EQEP.VAR.EQEP2_SPSEL.VALUE=INDEX_PIN
DRIVER.EQEP.VAR.EQEP1_PCO_INT_ENA.VALUE=0
DRIVER.EQEP.VAR.EQEP2_INDEX_EVT_SELECT.VALUE=RISING_EDGE
DRIVER.EQEP.VAR.EQEP1_INDEX_EVT_INIT_ENABLE.VALUE=0
DRIVER.EQEP.VAR.EQEP2_PCLOAD.VALUE=QPOSCNT_EQ_QPSCMP
DRIVER.FEE.VAR.FEE_START_SECTOR.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_4_BANK.VALUE=7
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_OFFSET.VALUE=176
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_OFFSET.VALUE=144
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_OFFSET.VALUE=40
DRIVER.FEE.VAR.FEE_READ_CYCLE_COUNT.VALUE=10
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_NUMBER_OF_VIRTUAL_SECTORS.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_INDEX15_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX4_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_FLASH_CRC_ENABLE.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_NUMBER.VALUE=12
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_5_BANK.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_NUMBER.VALUE=3
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_5_NUMBER.VALUE=5
DRIVER.FEE.VAR.FEE_SECTORS_EEP1.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_OFFSET.VALUE=256
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_5_START.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_NUMBER.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_OFFSET.VALUE=112
DRIVER.FEE.VAR.FEE_DRIVER_INDEX.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_VS5_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX9_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX13_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX2_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_NUMBER.VALUE=10
DRIVER.FEE.VAR.FEE_NUMBER_OF_EEPS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_NUMBER.VALUE=8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_NUMBER.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_DEVICE_INDEX.VALUE=0
DRIVER.FEE.VAR.FEE_PAGE_OVERHEAD.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_3_NUMBER.VALUE=3
DRIVER.FEE.VAR.FEE_TI_FEE_SW_MAJOR_VERSION.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_OFFSET.VALUE=224
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_1_END.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_1_START.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_SECTOR_NUMBER.VALUE=1
DRIVER.FEE.VAR.FEE_VIRTUALPAGE_SIZE.VALUE=8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_OFFSET.VALUE=3136
DRIVER.FEE.VAR.FEE_VS3_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX7_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_2_END.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX11_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_FLASH_WRITECOUNTER_SAVE.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_VS_INDEX.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_NUMBER.VALUE=15
DRIVER.FEE.VAR.FEE_TI_FEE_SW_PATCH_VERSION.VALUE=0
DRIVER.FEE.VAR.FEE_JOBERROR_NOTIFICATION.VALUE=JobErrorNotification
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_NUMBER.VALUE=6
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_3_END.VALUE=2
DRIVER.FEE.VAR.FEE_BLOCK_SIZE.VALUE=0x10
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_TOTAL_BLOCKS_DATASETS.VALUE=6
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_1_NUMBER.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_SIZE.VALUE=16
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_OFFSET.VALUE=192
DRIVER.FEE.VAR.FEE_BLOCK_INDEX.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_4_END.VALUE=3
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_OFFSET.VALUE=1072
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_MAXIMUM_BLOCKING_TIME.VALUE=600
DRIVER.FEE.VAR.FEE_VS1_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_NO_OF_UNCONFIGURED_BLOCKS_TO_COPY.VALUE=0
DRIVER.FEE.VAR.FEE_FLASH_BANK_NUM.VALUE=7
DRIVER.FEE.VAR.FEE_BLOCK_INDEX16_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX5_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_NUMBER.VALUE=13
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_5_END.VALUE=4
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_2_START.VALUE=1
DRIVER.FEE.VAR.FEE_SECTOR_OVERHEAD.VALUE=16
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_NUMBER.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_SIZE.VALUE=1024
DRIVER.FEE.VAR.FEE_TI_FEE_SW_MINOR_VERSION.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_VERSIONINFO_API.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_OFFSET.VALUE=160
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_DATASETS.VALUE=1
DRIVER.FEE.VAR.MAX_BLOCK_TIME.VALUE=600
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_OFFSET.VALUE=128
DRIVER.FEE.VAR.FEE_WRITE_CYCLES.VALUE=10
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_OFFSET.VALUE=16
DRIVER.FEE.VAR.FEE_NUMBER_OF_BLOCKS.VALUE=6
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_BANK.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX14_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX3_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_NUMBER_OF_EIGHTBYTEWRITES.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_3_SIZE.VALUE=1024
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_11_NUMBER.VALUE=11
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_NUMBER.VALUE=9
DRIVER.FEE.VAR.FEE_END_SECTOR.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_1_BANK.VALUE=7
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_NUMBER.VALUE=2
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_FLASH_ERROR_CORRECTION_HANDLING.VALUE=TI_Fee_None
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_4_NUMBER.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_DEVERROR_DETECT.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_OFFSET.VALUE=240
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_3_START.VALUE=2
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_1_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_OFFSET.VALUE=4168
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_SIZE.VALUE=1024
DRIVER.FEE.VAR.FEE_VS4_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX8_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_MAX_NUMBER_OF_LINKS.VALUE=256
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_EEP.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX12_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX1_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_FLASH_ERROR_CORRECTION_ENABLE.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_2_BANK.VALUE=7
DRIVER.FEE.VAR.FEE_DATASELECT_BITS.VALUE=0
DRIVER.FEE.VAR.FEE_OPERATING_FREQ.VALUE=160.000
DRIVER.FEE.VAR.FEE_TOTAL_SECTORS.VALUE=4
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_16_NUMBER.VALUE=16
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_2_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_NUMBER.VALUE=7
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_9_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_2_NUMBER.VALUE=2
DRIVER.FEE.VAR.FEE_JOBEND_NOTIFICATION.VALUE=JobEndNotification
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_SIZE.VALUE=1024
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_13_OFFSET.VALUE=208
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_12_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_8_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_ENABLE_ECC.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_OVERHEAD.VALUE=24
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_7_DATASETS.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_4_OFFSET.VALUE=2104
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_3_BANK.VALUE=7
DRIVER.FEE.VAR.FEE_VS2_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX6_ENABLE.VALUE=1
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_DEVICE_INDEX.VALUE=0x00000000
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_10_SIZE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX10_ENABLE.VALUE=0
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_14_NUMBER.VALUE=14
DRIVER.FEE.VAR.FEE_VIRTUAL_SECTOR_4_START.VALUE=3
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_15_IMED_DATA.VALUE=TRUE
DRIVER.FEE.VAR.FEE_CHECK_BANK7_ACCESS.VALUE=STD_OFF
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_WRITE_CYCLES.VALUE=0x8
DRIVER.FEE.VAR.FEE_POLLING_MODE.VALUE=STD_ON
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_5_NUMBER.VALUE=5
DRIVER.FEE.VAR.FEE_BLOCK_INDEX_6_SIZE.VALUE=1024
DRIVER.AJSM.VAR.AJSM_NEW_KEY_WORD_2.VALUE=0xFFFDFFFE
DRIVER.AJSM.VAR.AJSM_NEW_KEY_WORD_3.VALUE=0xFFEFFFFF
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_WORD_0.VALUE=0xEFFDFFFF
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_WORD_1.VALUE=0xFFFFFFFF
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_WORD_2.VALUE=0xFFFDFFFE
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_WORD_3.VALUE=0xFFEFFFFF
DRIVER.AJSM.VAR.AJSM_SCAN_PATTERN_WORD_0.VALUE=PATTERN_NOT_REQUIRED
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_ECC_BYTE_0.VALUE=0xFF
DRIVER.AJSM.VAR.AJSM_SCAN_PATTERN_WORD_1.VALUE=PATTERN_NOT_REQUIRED
DRIVER.AJSM.VAR.AJSM_VISIBLE_KEY_ECC_BYTE_1.VALUE=0xFF
DRIVER.AJSM.VAR.AJSM_SCAN_PATTERN_WORD_2.VALUE=PATTERN_NOT_REQUIRED
DRIVER.AJSM.VAR.AJSM_SCAN_PATTERN_WORD_3.VALUE=PATTERN_NOT_REQUIRED
DRIVER.AJSM.VAR.AJSM_NEW_KEY_ECC_BYTE_0.VALUE=0xFF
DRIVER.AJSM.VAR.AJSM_NEW_KEY_ECC_BYTE_1.VALUE=0xFF
DRIVER.AJSM.VAR.AJSM_SCAN_PATTERN.VALUE=PATTERN_NOT_REQUIRED
DRIVER.AJSM.VAR.AJSM_NEW_KEY_WORD_0.VALUE=0xEFFDFFFF
DRIVER.AJSM.VAR.AJSM_NEW_KEY_WORD_1.VALUE=0xFFFFFFFF
    延迟取决于要采样的每个通道的采样时间、转换时间和扫描时间。 我刚才看一下您的代码、我认为120us 对于采样15个 ADC1通道(组2)或3个 ADC2 (EVT 组)来说太长了。
    您如何测量延迟时间?
    您好 QJ、
    感谢您的回答。
    120us 的延迟时间需要一些解释。  SW 的开关频率为61us。 在执行由 PWM 触发的 FOC 之前对 ADC 进行采样。 我们交叉检查了 ADC 在预期的时间被采样(我们检查了寄存器中的值)。这些值在两个开关 cyccles (122us)之后进入缓冲器 GxBUF。
    您可以使用 PMU 或切换 GIO 引脚来测量 ADC 采样的延迟时间:
    _pmuInit_()
    _pmuResetCyclCounter_()
    _pmuStartCounter_(pmuCYCLE _计数器);
    adcStartConversion (adcREG1、adcGROUP1);
    while ((adcIsConversionComplete (adcREG1、adcGROUP1))==0);
    _pmuStopCounter_(pmuCYCLE _计数器);
    周期=_pmuGetCycleCount_();
    您好 QJ、
    我可以通过更改 BNDB 和 BNDA 值来更改缓冲区大小来解决该问题。
