[参考译文] TMS570LS3137:Makefile:255:目标的配方'xxxxxx.out'失败
Guru**** 2581345 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1136623/tms570ls3137-makefile-255-recipe-for-target-xxxxxx-out-failed
器件型号:TMS570LS3137
在  编译配置生成 bin 文件时添加了"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin ""${BuildArtiftFileName}""${BuildArtifactFileBaseName}.bin""${CG_TOOL_ROOT}/bin/armofd ""${CG_TOOL_ROOT}/bin/armhex ""${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin 后、发生错误:
**** Build of configuration Debug for project mcp_app ****
"E:\\soft data\\ti\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
Building file: "../APP/src/Application.c"
Invoking: Arm Compiler
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/Application.d_raw" --obj_directory="APP/src" "../APP/src/Application.c"
Finished building: "../APP/src/Application.c"
Building file: "../APP/src/logic_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/logic_task.d_raw" --obj_directory="APP/src" "../APP/src/logic_task.c"
Finished building: "../APP/src/logic_task.c"
Building file: "../APP/src/user_CloseDoor.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_CloseDoor.d_raw" --obj_directory="APP/src" "../APP/src/user_CloseDoor.c"
Finished building: "../APP/src/user_CloseDoor.c"
Building file: "../APP/src/user_OpenDoor.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_OpenDoor.d_raw" --obj_directory="APP/src" "../APP/src/user_OpenDoor.c"
Finished building: "../APP/src/user_OpenDoor.c"
Building file: "../APP/src/user_CommData.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_CommData.d_raw" --obj_directory="APP/src" "../APP/src/user_CommData.c"
Finished building: "../APP/src/user_CommData.c"
Building file: "../APP/src/user_SysState.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_SysState.d_raw" --obj_directory="APP/src" "../APP/src/user_SysState.c"
Finished building: "../APP/src/user_SysState.c"
Building file: "../APP/src/user_app.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_app.d_raw" --obj_directory="APP/src" "../APP/src/user_app.c"
Finished building: "../APP/src/user_app.c"
Building file: "../APP/src/user_cmd.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_cmd.d_raw" --obj_directory="APP/src" "../APP/src/user_cmd.c"
Finished building: "../APP/src/user_cmd.c"
Building file: "../APP/src/user_motor.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_motor.d_raw" --obj_directory="APP/src" "../APP/src/user_motor.c"
Finished building: "../APP/src/user_motor.c"
Building file: "../APP/src/user_log.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_log.d_raw" --obj_directory="APP/src" "../APP/src/user_log.c"
Finished building: "../APP/src/user_log.c"
Building file: "../APP/src/user_out.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_out.d_raw" --obj_directory="APP/src" "../APP/src/user_out.c"
"../APP/src/user_out.c", line 127: warning #179-D: function "emagnet_out_ctrl" was declared but never referenced
Finished building: "../APP/src/user_out.c"
Building file: "../APP/src/user_obstruct.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_obstruct.d_raw" --obj_directory="APP/src" "../APP/src/user_obstruct.c"
Finished building: "../APP/src/user_obstruct.c"
Building file: "../Comm/src/PCM_Comm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/PCM_Comm.d_raw" --obj_directory="Comm/src" "../Comm/src/PCM_Comm.c"
Finished building: "../Comm/src/PCM_Comm.c"
Building file: "../Comm/src/PCC_Comm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/PCC_Comm.d_raw" --obj_directory="Comm/src" "../Comm/src/PCC_Comm.c"
Finished building: "../Comm/src/PCC_Comm.c"
Building file: "../Comm/src/PTU_Comm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/PTU_Comm.d_raw" --obj_directory="Comm/src" "../Comm/src/PTU_Comm.c"
Finished building: "../Comm/src/PTU_Comm.c"
Building file: "../APP/src/user_record.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="APP/src/user_record.d_raw" --obj_directory="APP/src" "../APP/src/user_record.c"
"../APP/src/user_record.c", line 479: warning #179-D: function "record_flt_log" was declared but never referenced
Finished building: "../APP/src/user_record.c"
Building file: "../Comm/src/canopen_app.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/canopen_app.d_raw" --obj_directory="Comm/src" "../Comm/src/canopen_app.c"
Finished building: "../Comm/src/canopen_app.c"
Building file: "../Comm/src/canopen_drv.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/canopen_drv.d_raw" --obj_directory="Comm/src" "../Comm/src/canopen_drv.c"
Finished building: "../Comm/src/canopen_drv.c"
Building file: "../Comm/src/canopen_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/canopen_task.d_raw" --obj_directory="Comm/src" "../Comm/src/canopen_task.c"
Finished building: "../Comm/src/canopen_task.c"
Building file: "../Comm/src/PC_Debug.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/PC_Debug.d_raw" --obj_directory="Comm/src" "../Comm/src/PC_Debug.c"
Finished building: "../Comm/src/PC_Debug.c"
Building file: "../Comm/src/mcp2_slave.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/mcp2_slave.d_raw" --obj_directory="Comm/src" "../Comm/src/mcp2_slave.c"
Finished building: "../Comm/src/mcp2_slave.c"
Building file: "../Comm/src/firmware_update.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/firmware_update.d_raw" --obj_directory="Comm/src" "../Comm/src/firmware_update.c"
Finished building: "../Comm/src/firmware_update.c"
Building file: "../Comm/src/mcp_slave.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="Comm/src/mcp_slave.d_raw" --obj_directory="Comm/src" "../Comm/src/mcp_slave.c"
Finished building: "../Comm/src/mcp_slave.c"
Building file: "../SerialDbg/src/atk_cmd.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/atk_cmd.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/atk_cmd.c"
Finished building: "../SerialDbg/src/atk_cmd.c"
Building file: "../SerialDbg/src/sci_dma.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/sci_dma.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/sci_dma.c"
Finished building: "../SerialDbg/src/sci_dma.c"
Building file: "../SerialDbg/src/crt_log.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/crt_log.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/crt_log.c"
Finished building: "../SerialDbg/src/crt_log.c"
Building file: "../SerialDbg/src/sci_drive.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/sci_drive.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/sci_drive.c"
Finished building: "../SerialDbg/src/sci_drive.c"
Building file: "../SerialDbg/src/serial_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/serial_task.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/serial_task.c"
Finished building: "../SerialDbg/src/serial_task.c"
Building file: "../auxiliary/src/aux_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/aux_task.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/aux_task.c"
Finished building: "../auxiliary/src/aux_task.c"
Building file: "../SerialDbg/src/ymodem.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="SerialDbg/src/ymodem.d_raw" --obj_directory="SerialDbg/src" "../SerialDbg/src/ymodem.c"
Finished building: "../SerialDbg/src/ymodem.c"
Building file: "../auxiliary/src/aux_tool.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/aux_tool.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/aux_tool.c"
"../auxiliary/src/aux_tool.c", line 83: warning #552-D: variable "length" was set but never used
Finished building: "../auxiliary/src/aux_tool.c"
Building file: "../auxiliary/src/kservice.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/kservice.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/kservice.c"
Finished building: "../auxiliary/src/kservice.c"
Building file: "../auxiliary/src/mem_mang.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/mem_mang.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/mem_mang.c"
Finished building: "../auxiliary/src/mem_mang.c"
Building file: "../auxiliary/src/sys_led.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/sys_led.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/sys_led.c"
Finished building: "../auxiliary/src/sys_led.c"
Building file: "../auxiliary/src/sys_rtc.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="auxiliary/src/sys_rtc.d_raw" --obj_directory="auxiliary/src" "../auxiliary/src/sys_rtc.c"
Finished building: "../auxiliary/src/sys_rtc.c"
Building file: "../canopen/src/dcf.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/dcf.d_raw" --obj_directory="canopen/src" "../canopen/src/dcf.c"
Finished building: "../canopen/src/dcf.c"
Building file: "../canopen/src/emcy.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/emcy.d_raw" --obj_directory="canopen/src" "../canopen/src/emcy.c"
Finished building: "../canopen/src/emcy.c"
Building file: "../canopen/src/lifegrd.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/lifegrd.d_raw" --obj_directory="canopen/src" "../canopen/src/lifegrd.c"
Finished building: "../canopen/src/lifegrd.c"
Building file: "../canopen/src/lss.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/lss.d_raw" --obj_directory="canopen/src" "../canopen/src/lss.c"
Finished building: "../canopen/src/lss.c"
Building file: "../canopen/src/nmtMaster.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/nmtMaster.d_raw" --obj_directory="canopen/src" "../canopen/src/nmtMaster.c"
Finished building: "../canopen/src/nmtMaster.c"
Building file: "../canopen/src/nmtSlave.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/nmtSlave.d_raw" --obj_directory="canopen/src" "../canopen/src/nmtSlave.c"
Finished building: "../canopen/src/nmtSlave.c"
Building file: "../canopen/src/objacces.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/objacces.d_raw" --obj_directory="canopen/src" "../canopen/src/objacces.c"
Finished building: "../canopen/src/objacces.c"
Building file: "../canopen/src/pdo.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/pdo.d_raw" --obj_directory="canopen/src" "../canopen/src/pdo.c"
Finished building: "../canopen/src/pdo.c"
Building file: "../canopen/src/sync.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/sync.d_raw" --obj_directory="canopen/src" "../canopen/src/sync.c"
Finished building: "../canopen/src/sync.c"
Building file: "../canopen/src/states.c"
Invoking: Arm Compiler
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/states.d_raw" --obj_directory="canopen/src" "../canopen/src/states.c"
Finished building: "../canopen/src/states.c"
Building file: "../canopen/src/timer.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/timer.d_raw" --obj_directory="canopen/src" "../canopen/src/timer.c"
Finished building: "../canopen/src/timer.c"
Building file: "../display/src/display_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="display/src/display_task.d_raw" --obj_directory="display/src" "../display/src/display_task.c"
Finished building: "../display/src/display_task.c"
Building file: "../drivers/src/board.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/board.d_raw" --obj_directory="drivers/src" "../drivers/src/board.c"
Finished building: "../drivers/src/board.c"
Building file: "../drivers/src/adc.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/adc.d_raw" --obj_directory="drivers/src" "../drivers/src/adc.c"
Finished building: "../drivers/src/adc.c"
Building file: "../drivers/src/bsp_timer.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/bsp_timer.d_raw" --obj_directory="drivers/src" "../drivers/src/bsp_timer.c"
Finished building: "../drivers/src/bsp_timer.c"
Building file: "../canopen/src/sdo.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="canopen/src/sdo.d_raw" --obj_directory="canopen/src" "../canopen/src/sdo.c"
Finished building: "../canopen/src/sdo.c"
Building file: "../drivers/src/dabort.asm"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/dabort.d_raw" --obj_directory="drivers/src" "../drivers/src/dabort.asm"
Finished building: "../drivers/src/dabort.asm"
Building file: "../drivers/src/can.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/can.d_raw" --obj_directory="drivers/src" "../drivers/src/can.c"
Finished building: "../drivers/src/can.c"
Building file: "../display/src/crt_display.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="display/src/crt_display.d_raw" --obj_directory="display/src" "../display/src/crt_display.c"
"../display/src/crt_display.c", line 72: warning #179-D: function "print_boolean_val" was declared but never referenced
Finished building: "../display/src/crt_display.c"
Building file: "../drivers/src/esm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/esm.d_raw" --obj_directory="drivers/src" "../drivers/src/esm.c"
Finished building: "../drivers/src/esm.c"
Building file: "../drivers/src/gio.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/gio.d_raw" --obj_directory="drivers/src" "../drivers/src/gio.c"
Finished building: "../drivers/src/gio.c"
Building file: "../drivers/src/het.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/het.d_raw" --obj_directory="drivers/src" "../drivers/src/het.c"
Finished building: "../drivers/src/het.c"
Building file: "../drivers/src/lin.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/lin.d_raw" --obj_directory="drivers/src" "../drivers/src/lin.c"
Finished building: "../drivers/src/lin.c"
Building file: "../drivers/src/mibspi.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/mibspi.d_raw" --obj_directory="drivers/src" "../drivers/src/mibspi.c"
Finished building: "../drivers/src/mibspi.c"
Building file: "../drivers/src/notification.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/notification.d_raw" --obj_directory="drivers/src" "../drivers/src/notification.c"
Finished building: "../drivers/src/notification.c"
Building file: "../drivers/src/pinmux.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/pinmux.d_raw" --obj_directory="drivers/src" "../drivers/src/pinmux.c"
Finished building: "../drivers/src/pinmux.c"
Building file: "../drivers/src/rti.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/rti.d_raw" --obj_directory="drivers/src" "../drivers/src/rti.c"
Finished building: "../drivers/src/rti.c"
Building file: "../drivers/src/sci.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sci.d_raw" --obj_directory="drivers/src" "../drivers/src/sci.c"
Finished building: "../drivers/src/sci.c"
Building file: "../drivers/src/spi.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/spi.d_raw" --obj_directory="drivers/src" "../drivers/src/spi.c"
Finished building: "../drivers/src/spi.c"
Building file: "../drivers/src/sys_core.asm"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_core.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_core.asm"
Finished building: "../drivers/src/sys_core.asm"
Building file: "../drivers/src/sys_dma.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_dma.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_dma.c"
Finished building: "../drivers/src/sys_dma.c"
Building file: "../drivers/src/sys_intvecs.asm"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_intvecs.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_intvecs.asm"
Finished building: "../drivers/src/sys_intvecs.asm"
Building file: "../drivers/src/sys_main.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_main.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_main.c"
Finished building: "../drivers/src/sys_main.c"
Building file: "../drivers/src/sys_mpu.asm"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_mpu.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_mpu.asm"
Finished building: "../drivers/src/sys_mpu.asm"
Building file: "../drivers/src/sys_pcr.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_pcr.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_pcr.c"
Finished building: "../drivers/src/sys_pcr.c"
Building file: "../drivers/src/sys_phantom.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_phantom.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_phantom.c"
Finished building: "../drivers/src/sys_phantom.c"
Building file: "../drivers/src/sys_pmm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_pmm.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_pmm.c"
Finished building: "../drivers/src/sys_pmm.c"
Building file: "../drivers/src/sys_pmu.asm"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_pmu.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_pmu.asm"
Finished building: "../drivers/src/sys_pmu.asm"
Building file: "../drivers/src/sys_selftest.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_selftest.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_selftest.c"
Finished building: "../drivers/src/sys_selftest.c"
Building file: "../drivers/src/sys_startup.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_startup.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_startup.c"
Finished building: "../drivers/src/sys_startup.c"
Building file: "../drivers/src/sys_vim.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/sys_vim.d_raw" --obj_directory="drivers/src" "../drivers/src/sys_vim.c"
Finished building: "../drivers/src/sys_vim.c"
Building file: "../drivers/src/system.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="drivers/src/system.d_raw" --obj_directory="drivers/src" "../drivers/src/system.c"
Finished building: "../drivers/src/system.c"
Building file: "../fault/src/fault.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="fault/src/fault.d_raw" --obj_directory="fault/src" "../fault/src/fault.c"
"../fault/src/fault.c", line 211: warning #179-D: function "locked_sw_off_fault" was declared but never referenced
"../fault/src/fault.c", line 258: warning #179-D: function "locked_sw_on_fault" was declared but never referenced
"../fault/src/fault.c", line 392: warning #179-D: function "door_dis_unlock_fault" was declared but never referenced
"../fault/src/fault.c", line 450: warning #179-D: function "door_sud_unlock_fault" was declared but never referenced
"../fault/src/fault.c", line 658: warning #179-D: function "emagnet_out_fault" was declared but never referenced
"../fault/src/fault.c", line 1229: warning #179-D: function "hard_input_diff_fault" was declared but never referenced
Finished building: "../fault/src/fault.c"
Building file: "../fault/src/fault_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="fault/src/fault_task.d_raw" --obj_directory="fault/src" "../fault/src/fault_task.c"
Finished building: "../fault/src/fault_task.c"
Building file: "../io/src/bsp_input.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="io/src/bsp_input.d_raw" --obj_directory="io/src" "../io/src/bsp_input.c"
Finished building: "../io/src/bsp_input.c"
Building file: "../io/src/bsp_output.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="io/src/bsp_output.d_raw" --obj_directory="io/src" "../io/src/bsp_output.c"
Finished building: "../io/src/bsp_output.c"
Building file: "../io/src/pwm_io.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="io/src/pwm_io.d_raw" --obj_directory="io/src" "../io/src/pwm_io.c"
Finished building: "../io/src/pwm_io.c"
Building file: "../io/src/io_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="io/src/io_task.d_raw" --obj_directory="io/src" "../io/src/io_task.c"
Finished building: "../io/src/io_task.c"
Building file: "../motor/src/motor_comm.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="motor/src/motor_comm.d_raw" --obj_directory="motor/src" "../motor/src/motor_comm.c"
Finished building: "../motor/src/motor_comm.c"
Building file: "../motor/src/motor_ctrl.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="motor/src/motor_ctrl.d_raw" --obj_directory="motor/src" "../motor/src/motor_ctrl.c"
Finished building: "../motor/src/motor_ctrl.c"
Building file: "../motor/src/motor_task.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="motor/src/motor_task.d_raw" --obj_directory="motor/src" "../motor/src/motor_task.c"
Finished building: "../motor/src/motor_task.c"
Building file: "../motor/src/motor_samp.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="motor/src/motor_samp.d_raw" --obj_directory="motor/src" "../motor/src/motor_samp.c"
Finished building: "../motor/src/motor_samp.c"
Building file: "../pcmaster/src/pcmaster.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="pcmaster/src/pcmaster.d_raw" --obj_directory="pcmaster/src" "../pcmaster/src/pcmaster.c"
Finished building: "../pcmaster/src/pcmaster.c"
Building file: "../record/src/store_task.c"
Invoking: Arm Compiler
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="record/src/store_task.d_raw" --obj_directory="record/src" "../record/src/store_task.c"
Finished building: "../record/src/store_task.c"
Building file: "../record/src/bsp_w25drv.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="record/src/bsp_w25drv.d_raw" --obj_directory="record/src" "../record/src/bsp_w25drv.c"
Finished building: "../record/src/bsp_w25drv.c"
Building file: "../record/src/bsp_flashdrv.c"
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/display/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/pcmaster/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/SerialDbg/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/APP/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/auxiliary/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/canopen/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/Comm/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/drivers/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/fault/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/io/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/motor/inc" --include_path="D:/zhaokai/work/CHSHYQ/DCU/src/mcp_app/record/inc" --include_path="E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="record/src/bsp_flashdrv.d_raw" --obj_directory="record/src" "../record/src/bsp_flashdrv.c"
Finished building: "../record/src/bsp_flashdrv.c"
Building target: "mcp_app.out"
Invoking: Arm Linker
"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi -z -m"mcp_app.map" --heap_size=0x800 --stack_size=0x800 -i"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/lib" -i"E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="mcp_app_linkInfo.xml" --rom_model --be32 -o "mcp_app.out" "./APP/src/Application.obj" "./APP/src/logic_task.obj" "./APP/src/user_CloseDoor.obj" "./APP/src/user_CommData.obj" "./APP/src/user_OpenDoor.obj" "./APP/src/user_SysState.obj" "./APP/src/user_app.obj" "./APP/src/user_cmd.obj" "./APP/src/user_log.obj" "./APP/src/user_motor.obj" "./APP/src/user_obstruct.obj" "./APP/src/user_out.obj" "./APP/src/user_record.obj" "./Comm/src/PCC_Comm.obj" "./Comm/src/PCM_Comm.obj" "./Comm/src/PC_Debug.obj" "./Comm/src/PTU_Comm.obj" "./Comm/src/canopen_app.obj" "./Comm/src/canopen_drv.obj" "./Comm/src/canopen_task.obj" "./Comm/src/firmware_update.obj" "./Comm/src/mcp2_slave.obj" "./Comm/src/mcp_slave.obj" "./SerialDbg/src/atk_cmd.obj" "./SerialDbg/src/crt_log.obj" "./SerialDbg/src/sci_dma.obj" "./SerialDbg/src/sci_drive.obj" "./SerialDbg/src/serial_task.obj" "./SerialDbg/src/ymodem.obj" "./auxiliary/src/aux_task.obj" "./auxiliary/src/aux_tool.obj" "./auxiliary/src/kservice.obj" "./auxiliary/src/mem_mang.obj" "./auxiliary/src/sys_led.obj" "./auxiliary/src/sys_rtc.obj" "./canopen/src/dcf.obj" "./canopen/src/emcy.obj" "./canopen/src/lifegrd.obj" "./canopen/src/lss.obj" "./canopen/src/nmtMaster.obj" "./canopen/src/nmtSlave.obj" "./canopen/src/objacces.obj" "./canopen/src/pdo.obj" "./canopen/src/sdo.obj" "./canopen/src/states.obj" "./canopen/src/sync.obj" "./canopen/src/timer.obj" "./display/src/crt_display.obj" "./display/src/display_task.obj" "./drivers/src/adc.obj" "./drivers/src/board.obj" "./drivers/src/bsp_timer.obj" "./drivers/src/can.obj" "./drivers/src/dabort.obj" "./drivers/src/esm.obj" "./drivers/src/gio.obj" "./drivers/src/het.obj" "./drivers/src/lin.obj" "./drivers/src/mibspi.obj" "./drivers/src/notification.obj" "./drivers/src/pinmux.obj" "./drivers/src/rti.obj" "./drivers/src/sci.obj" "./drivers/src/spi.obj" "./drivers/src/sys_core.obj" "./drivers/src/sys_dma.obj" "./drivers/src/sys_intvecs.obj" "./drivers/src/sys_main.obj" "./drivers/src/sys_mpu.obj" "./drivers/src/sys_pcr.obj" "./drivers/src/sys_phantom.obj" "./drivers/src/sys_pmm.obj" "./drivers/src/sys_pmu.obj" "./drivers/src/sys_selftest.obj" "./drivers/src/sys_startup.obj" "./drivers/src/sys_vim.obj" "./drivers/src/system.obj" "./fault/src/fault.obj" "./fault/src/fault_task.obj" "./io/src/bsp_input.obj" "./io/src/bsp_output.obj" "./io/src/io_task.obj" "./io/src/pwm_io.obj" "./motor/src/motor_comm.obj" "./motor/src/motor_ctrl.obj" "./motor/src/motor_samp.obj" "./motor/src/motor_task.obj" "./pcmaster/src/pcmaster.obj" "./record/src/bsp_flashdrv.obj" "./record/src/bsp_w25drv.obj" "./record/src/store_task.obj" "../drivers/src/sys_link.cmd" -lrtsv7R4_T_be_v3D16_eabi.lib
<Linking>
Finished building target: "mcp_app.out"
"E:/soft data/ti/ccs/utils/tiobj2bin/tiobj2bin" "mcp_app.out" "mcp_app.bin" "E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armofd" "E:/soft data/ti/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armhex" "E:/soft data/ti/ccs/utils/tiobj2bin/mkhex4bin"
makefile:255: recipe for target 'mcp_app.out' failed
gmake[1]: *** [mcp_app.out] Error -1073741819
makefile:251: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
谢谢、此致
耶鲁李
    是否将此脚本添加到 post-built 步骤?
    路径 "E:/soft data/ti/CCS/utils/tiobj2bin/tiobj2bin"包含一个空格。
    gmaking[1]:***[DSP28388D_THD_CM.hex]错误-1073741819 中, 使用 tiobj2bin 的编译后规则,gmake 的相同错误-1073741819被认为是由安装 CCS 的路径中的空间引起的。
    您能否尝试在不包含空格的路径中安装 CCS?
    您好、Yale、
    切斯特是正确的。 此问题是 由路径中的空间引起的: E:/soft data/ti/CCS/utils/tiobj2bin/tiobj2bin
    高 QJ、高切斯特、
    感谢你的所有帮助。 它的工作原理。
