[参考译文] TMS570LS1224:焊接前在芯片上进行编程
Guru**** 2939240 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1034643/tms570ls1224-programming-at-the-chip-before-soldering
器件型号:TMS570LS1224
我将研究在焊接之前对芯片进行编程的可编程性。  在回流焊过程中、闪存是否会保留数据?  如果器件具有此功能、是否有任何供应商能够对此器件进行编程?
