[参考译文] TMS570LC4357:引导加载程序示例代码
Guru**** 2470050 points
Other Parts Discussed in Thread: TMS570LC4357
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1033147/tms570lc4357-bootloader-example-code
器件型号:TMS570LC4357
我找到了几个有关引导加载程序示例代码的线程、但在尝试下载时收到"权限不足"错误;这些线程表示它们已锁定(可能是因为它们的年龄?)。 我找到的两个线程都具有此 URL、但内容不同。
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/699892/compiler-tms570lc4357-boot-loader-lc43x
您能给我指出这个引导加载程序的示例代码、还是我可以从中下载的另一个 E2E 主题?
Jim
