[参考译文] TM4C1290NCPDT:UDMA 从闪存存储器传输...
Guru**** 2845830 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/893894/tm4c1290ncpdt-udma-transfers-from-flash-memory
器件型号:TM4C1290NCPDT
主题中讨论的其他器件:DK-TM4C129X
香榭丽舍
是否可以设置一个 UDMA 传输来将数据从闪存移动到 CCM (CRC 模块)?
